P006-004-GN
P006-004-GN
    TRIPPLITE
    POWERCORDGREENCONNECTORS4'
P006-004-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Desktop Computer AC Power Cable, NEMA 5-15P to C13 - 10A, 125V, 18 AWG, 4 ft. (1.22 m), Green Plugs Highlights ● Recommended for powering computers, printers and other home/office peripherals ● 4-ft. (1.22 m) length allows flexibility in placing devices, while avoiding cable clutter ● NEMA 5-15P to C13 extension cord is ideal replacement for worn-out or missing cable ● Green plugs for fast, easy identification in a crowded PDU, UPS or surge protector MODEL NUMBER: P006-004-GN Applications ● Connect devices like computers, printers and monitors to a PDU up to 4-ft. (1.22 m) away in your workstation ● Extend an existing power connection up to 4-ft. (1.22 m) to more easily place a device or reach a power source ● Provide a high-quality replacement for a worn-out or missing power cord Computer power cable allows you to connect your PC, printer or monitor into a surge protector, PDU or UPS with a NEMA 5-15R outlet. Package Includes Features Desktop Computer Power Cord Connects PCs, Printers, Monitors and Other EquipmentThis computer power supply cable is designed for home/office desktop computer applications. You can use it to connect a computer, monitor, printer, scanner or other device with a C14 power inlet to an AC wall outlet, surge protector, UPS system or PDU. The 4-ft. (1.22 m) length helps reduce cable clutter and minimize the risk of tripping. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer AC power cable features fully molded green ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332168511 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 125 PHYSICAL 1/3 ● P006-004-GN NEMA 5-15P to C13 Computer Power Cable, 4ft. (1.22 m), Green Plugs 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Green Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.7mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 4 Cable Length (m) 1.22 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.37 Shipping Weight (kg) 0.17 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P006-004-GN 价格&库存
很抱歉,暂时无法提供与“P006-004-GN”相匹配的价格&库存,您可以联系我们找货
