P005-006-RD
P005-006-RD
    TRIPPLITE
    6.0' (1.83m) Power Cord Black IEC 320-C14 To IEC 320-C13 SJT
P005-006-RD 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy Duty PDU Power Cord, C13 to C14 - 15A, 250V, 14 AWG, 6 ft., Red Plugs MODEL NUMBER: P005-006-RD Highlights ● Recommended for powering computers, servers and other network devices ● 6 ft. length allows flexibility in placing devices in relationship to AC outlet ● PDU-style cord replaces or upgrades standard power cord provided by manufacturer ● Color-coded red ends for fast, easy identification in a crowded rack or workstation ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications Computer power extension cord connects devices with C13/C14 power connectors or extends your existing power connection by 6 ft. Features C14-to-C13 Power Cable for Network Devices That Require a Heavy-Gauge Connection This IEC-320-C14 to IEC-320-C13 cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This C14 male to C13 female cord can be used to connect a computer, server, monitor or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device’s manufacturer. The six-foot length allows you flexibility in placing equipment with respect to the power outlet. Color-Coded Connectors Avoid Misidentification That Can Cause Costly Downtime This computer power extension cord features fully molded red ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332168375 Country/Region North America INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL Color Black; Red 1/2 ● Connect devices like computers, servers and monitors to a PDU up to 6 ft. away in your data center ● Extend an existing power connection up to 6 ft. to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device’s original manufacturer Package Includes ● P005-006-RD Heavy-Duty C13 to C14 PDU-Style Power Extension Cable, 6 ft., Red Plugs 1000 Eaton Boulevard Cleveland, OH 44122 United States Power Cord Jacket Type SJT Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Weight (lbs.) 0.71 Shipping Weight (kg) 0.32 ENVIRONMENTAL Operating Temperature Range -4 F (-20 C) to 140 F (60 C) Storage Temperature Range -4 F (-20 C) to 140 F (60 C) Operating Humidity Range 10-85% RH Storage Humidity Range 10-85% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P005-006-RD
- 物料型号: P005-006-RD - 器件简介: 这是一个重型C13到C14的PDU电源延长线,适用于需要重型电源连接的网络设备。它具有14 AWG线缆,适合高功率连接,是大型服务器应用的可靠解决方案。C14公头到C13母头的线缆,可用于连接计算机、服务器、显示器或驱动器到UPS系统或PDU,或替换或升级设备制造商提供的标凈电源线。 - 引脚分配: IEC-320-C14到IEC-320-C13 - 参数特性: - 最大输入安培数: 15 - 电压兼容性(VAC): 100-250 - 电源线类型: SJT - 导体数量: 3 - 线规(AWG): 14 - 线规(OD-mm2): 2.08 - 电缆长度(ft.): 6 - 电缆长度(m): 1.83 - 产品保修期(全球): 有限终身保修 - 功能详解: 用于为计算机、服务器和其他网络设备供电;6英尺的长度允许在设备与交流电源插座之间灵活放置;PDU风格的电源线可以替换或升级制造商提供的标凈电源线;红色端子便于在拥挤的机架或工作站中快速、轻松识别。 - 应用信息: 连接计算机、服务器和显示器等设备到数据中心的PDU,距离可达6英尺;扩展现有电源连接,使设备更容易放置或达到机架中的电源;更新或替换设备原始制造商提供的标凈电源线。 - 封装信息: 电源线外皮类型为SJT,颜色为黑色和红色,操作温度范围为-4F(-20C)至140F(60C),存储温度范围为-4F(-20C)至140F(60C),操作湿度范围为10-85%RH,存储湿度范围为10-85%RH。
P005-006-RD 价格&库存
很抱歉,暂时无法提供与“P005-006-RD”相匹配的价格&库存,您可以联系我们找货
