P005-006-YW
P005-006-YW
    TRIPPLITE
    P005-006-YW
P005-006-YW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Heavy-Duty PDU Power Cord, C13 to C14 - 15A, 250V, 14 AWG, 6 ft. (1.83 m), Yellow Plugs MODEL NUMBER: P005-006-YW Highlights ● Recommended for powering computers, servers and other network devices ● 6-ft. (1.83 m) length allows flexibility in placing devices in relationship to AC outlet ● PDU-style cord replaces or upgrades standard power cord provided by manufacturer ● Color-coded yellow ends for fast, easy identification in a crowded rack or workstation ● Thick 14 AWG wire gauge manages high power levels required for larger equipment Applications Computer power extension cord connects devices with C13/C14 power connectors or extends your existing power connection by 6 ft. Features C14-to-C13 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis IEC320-C14 to IEC-320-C13 cable features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This C14 male to C13 female cord can be used to connect a computer, server, monitor or drive to a UPS system or PDU or replace or upgrade the standard power cord provided by the device's manufacturer. The 6-ft. (1.83 m) length allows you flexibility in placing equipment with respect to the power outlet. Color-Coded Connectors Avoid Misidentification That Can Cause Costly DowntimeThis computer power extension cord features fully molded yellow ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332168382 Device Compatibility Computer; Monitor/HDTV; Printer; Server; Router; Network Switch; UPS; PDU Country/Region Global INPUT Maximum Input Amps 15 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 ● Connect devices like computers, servers and monitors to a PDU up to 6-ft. (1.83 m) away in your data center ● Extend an existing power connection up to 6-ft. (1.83 m) to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device's original manufacturer Package Includes ● P005-006-YW Heavy-Duty C13 to C14 PDU-Style Power Extension Cable, 6-ft. (1.83 m), Yellow Plugs 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Yellow Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.2mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Weight (lbs.) 0.69 Shipping Weight (kg) 0.31 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P005-006-YW 价格&库存
很抱歉,暂时无法提供与“P005-006-YW”相匹配的价格&库存,您可以联系我们找货
