P004-004-GN
P004-004-GN
    TRIPPLITE
    4.00' (1.22m) Power Cord Black IEC 320-C14 To IEC 320-C13 SJT
P004-004-GN 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States PDU Power Cord, C13 to C14 - 10A, 250V, 18 AWG, 4 ft. (1.22 m), Green MODEL NUMBER: P004-004-GN Highlights ● Recommended for powering computers, printers and other essential peripherals ● 4-ft. (1.22 m) length allows flexibility in placing devices, while avoiding cable clutter ● C13-to-C14 PDU-style extension cord is ideal replacement for worn-out or missing cable ● Color-coded green for fast, easy identification in a crowded rack or workstation Applications ● Connect devices like computers, servers and monitors to a PDU up to 4-ft. (1.22 m) away in your data center ● Extend an existing power connection up to 4-ft. (1.22 m) to more easily place a device or reach a power source near your workstation ● Provide a high-quality replacement for a worn-out or missing power cord Green computer power extension cord connects devices with C13/C14 power connectors or extends your existing power connection by 4 ft. Features C14-to-C13 Power Cable Connects Computers, Printers, Servers and Other EquipmentThis IEC320-C14 to IEC-320-C13 cable is designed for small data center, office workstation and other lower-amp applications. This C14 male to C13 female cord can be used to power a computer, server or monitor; attach a server or drive to a UPS system or PDU; or extend an existing connection up to 4-ft. (1.22 m). The 4-ft. (1.22 m) length helps reduce cable clutter and minimize the risk of tripping. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis computer power extension cord features a green SJT jacket and fully molded green ends. The color-coding allows easy, fast identification in a crowded rack or workstation and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332168337 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region Global INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/3 Package Includes ● P004-004 C14 Male to C13 Female Power Cable, 4-ft. (1.22 m), Green 1000 Eaton Boulevard Cleveland, OH 44122 United States Plug Color Green Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.7mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 4 Cable Length (m) 1.22 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.42 Shipping Weight (kg) 0.19 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 IEC-320-C14 Side B - Connector 1 IEC-320-C13 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications CSA (Canada); cUL Listed; UL Listed Product Compliance RoHS; REACH 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P004-004-GN
物料型号:P004-004-GN
器件简介:该产品是一条绿色电脑电源延长线,适用于连接具有C13/C14电源连接器的设备,或扩展现有电源连接4英尺。
引脚分配:C14公头至C13母头电源线。
参数特性: - 最大输入电流:10安培 - 电压兼容性:100-250伏交流电 - 线缆规格:18 AWG,外径7.7mm - 线缆长度:4英尺(1.22米) - 操作温度范围:-4至140华氏度(-20至60摄氏度) - 存储温度范围:-4至140华氏度(-20至60摄氏度) - 操作湿度范围:20-80%RH - 存储湿度范围:20-80%RH
功能详解:该电源线推荐用于为电脑、打印机和其他基本外围设备供电,4英尺长度提供了设备放置的灵活性,同时避免了电缆混乱。C13至C14 PDU风格的延长线是磨损或丢失电缆的理想替代品。
应用信息: - 连接计算机、服务器和监视器至数据中心的PDU,最远可达4英尺。 - 扩展现有电源连接至4英尺,以更容易放置设备或到达工作站附近的电源。 - 为磨损或丢失的电源线提供高质量的替代品。
封装信息:产品采用绿色SJT外套和完全成型的绿色端头,易于在拥挤的机架或工作站中快速识别,以防止电缆意外断开。
产品认证:CSA(加拿大);cUL Listed;UL Listed 产品合规性:RoHS:REACH
P004-004-GN 价格&库存
很抱歉,暂时无法提供与“P004-004-GN”相匹配的价格&库存,您可以联系我们找货
