P036-002-20RA
P036-002-20RA
    TRIPPLITE
    2.00' (609.6mm) Power Cord Black IEC 320-C20, Right Angle To IEC 320-C19 SJTW
P036-002-20RA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, C19 to Right Angle C20 Heavy Duty, 20A, 250V, 12 AWG, 2 ft., Black MODEL NUMBER: P036-002-20RA Highlights ● Right-angle C20 plug allows easier connection in confined or hard-to-reach spaces ● Recommended for powering servers, routers and other highoutput network devices ● 2 ft. length allows flexibility in placing devices, while avoiding cable clutter ● C20 to C19 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 12 AWG wire gauge manages high power levels required for larger equipment Applications Heavy-duty extension cable with right-angle C20 end allows connection of C19/C20 high-output devices in tight spaces or awkward angles. Features 20A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis heavy-duty extension cord features 12 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be used to connect a server, router, network switch or blade server enclosure to a UPS system or PDU or replace or upgrade the standard power cord provided by the device’s manufacturer. The two-foot length helps reduce cable clutter and minimize the risk of tripping. Right-Angle C20 Plug Makes Connecting in Tight Spaces EasierThe C19 to C20 right-angle cable is easier to install in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the right-angled C20 plug guides the heavy-duty extension cable parallel to your peripheral, allowing you to push the device up against a wall or hide it behind a desk to maximize space. Specifications OVERVIEW UPC Code 037332156532 Country/Region North America INPUT Maximum Input Amps 20 Voltage Compatibility (VAC) 100-250 PHYSICAL 1/2 ● Connect devices like computers, servers and monitors to a PDU up to 2 ft. away in your data center ● Extend an existing power connection up to 2 ft. to more easily place a device or reach a power source in a rack ● Update or replace the standard power cord provided by a device’s original manufacturer ● Power a device located in a hard-to-access area behind a desk or flush against a wall Package Includes ● P036-002-20RA C19 to RightAngle C20 Heavy-Duty Extension Cord, 2 ft., Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Power Cord Jacket Type SJT Number of Conductors 3 Wire Gauge (AWG) 12 Wire Gauge (OD - mm²) 3.31 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 0.50 x 5.00 x 7.60 Shipping Dimensions (hwd / cm) 1.27 x 12.70 x 19.30 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 CONNECTIONS Side A - Connector 1 IEC-320-C20 - RIGHT ANGLE Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P036-002-20RA 价格&库存
很抱歉,暂时无法提供与“P036-002-20RA”相匹配的价格&库存,您可以联系我们找货
