1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Extension Cord, C19 to Left Angle C20 Heavy Duty, 20A, 250V, 12 AWG, 2 ft., Black
MODEL NUMBER: P036-002-20LA
Highlights
Left-angle C20 plug allows
easier connection in confined or
hard-to-reach spaces
Recommended for powering
servers, routers and other highoutput network devices
2 ft. length allows flexibility in
placing devices, while avoiding
cable clutter
C20 to C19 cord replaces or
upgrades standard power cord
provided by manufacturer
Thick 12 AWG wire gauge
manages high power levels
required for larger equipment
Applications
Heavy-duty extension cable with left-angle C20 end allows connection of C19/C20 high-output devices in
tight spaces or awkward angles.
Features
20A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis
heavy-duty extension cord features 12 AWG wire suitable for high power connections, making it a reliable
solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be
used to connect a server, router, network switch or blade server enclosure to a UPS system or PDU or
replace or upgrade the standard power cord provided by the device’s manufacturer. The two-foot length
helps reduce cable clutter and minimize the risk of tripping.
Left-Angle C20 Plug Makes Connecting in Tight Spaces EasierThe C19 to C20 left-angle cable is
easier to install in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the
left-angled C20 plug guides the heavy-duty extension cable parallel to your peripheral, allowing you to
push the device up against a wall or hide it behind a desk to maximize space.
Specifications
OVERVIEW
UPC Code
037332156525
Country/Region
North America
INPUT
Maximum Input Amps
Voltage Compatibility (VAC)
100-250
PHYSICAL
1/2
Connect devices like computers,
servers and monitors to a PDU
up to 2 ft. away in your data
center
Extend an existing power
connection up to 2 ft. to more
easily place a device or reach a
power source in a rack
Update or replace the standard
power cord provided by a
device’s original manufacturer
Power a device located in a
hard-to-access area behind a
desk or flush against a wall
Package Includes
P036-002-20LA C19 to LeftAngle C20 Heavy-Duty
Extension Cord, 2 ft., Black
Cleveland, OH 44122
United States
Color
Black
Power Cord Jacket Type
SJT
Number of Conductors
3
Wire Gauge (AWG)
12
Wire Gauge (OD - mm²)
3.31
Cable Length (ft.)
2
Cable Length (m)
0.61
Shipping Dimensions (hwd / in.)
0.25 x 5.20 x 8.70
Shipping Dimensions (hwd / cm)
0.64 x 13.21 x 22.10
Shipping Weight (lbs.)
0.50
Shipping Weight (kg)
0.23
CONNECTIONS
Side A - Connector 1
IEC-320-C20 - LEFT ANGLE
Side B - Connector 1
IEC-320-C19
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“P036-002-20LA”相匹配的价格&库存,您可以联系我们找货
