P022-015-GY-HG
P022-015-GY-HG
    TRIPPLITE
    HOSPITAL-GRADEPOWEREXTENSIONC
P022-015-GY-HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hospital-Grade Extension Cord, NEMA 5-15P to NEMA 5-15R - Green Dot, 13A, 125V, 16 AWG, 15 ft. (4.57 m), Gray MODEL NUMBER: P022-015-GY-HG Highlights ● Adds 15-ft. (4.57 m) to your existing power connection to provide flexibility in placing devices ● Medical power cord replaces or upgrades power cord provided by manufacturer ● 5-15P-HG plug connects to AC power; 5-15R-HG end connects to device’s input cord ● Color-coded gray for fast, easy identification in a crowded PDU, UPS or surge protector Applications Hospital-grade extension cord connects two devices with 5-15P-HG/5-15R-HG power connectors in a hospital or other medical facility. ● Connect devices like PCs, mobile carts, monitors and printers to a power outlet up to 15-ft. (4.57 m) away in a hospital environment ● Extend an existing power connection up to 15-ft. (4.57 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device’s original manufacturer Features Hospital-Grade Extension Cord is a Safe Solution for Medical FacilitiesThis hospital-grade power cord is designed for computers, mobile carts, printers, scanners, monitors and other compatible hospital equipment within a healthcare facility. It features a NEMA 5-15R-HG end for connecting to a device and a NEMA 5-15P-HG plug for connecting to a hospital-grade AC power source. The 15-ft. (4.57 m) length allows you great flexibility in placing equipment with respect to the power outlet. Designed and Tested to Strict Hospital-Grade StandardsThis cord is tested to ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49 standards, ensuring it’s a dependable power solution for hospital environments. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis extension cord features a gray SJT jacket and fully molded gray ends. The color-coding allows easy, fast identification in a crowded surge protector and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332200112 Device Compatibility Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 13 1/3 Package Includes ● P022-015-GY-HG HospitalGrade Extension Cord, 5-15PHG to 5-15R-HG, 15-ft. (4.57 m), Gray 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Gray Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating FT2 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9mm Number of Conductors 3 Wire Gauge (AWG) 16 Wire Gauge (OD - mm²) 1.31 Cable Length (ft.) 15 Cable Length (m) 4.57 Shipping Dimensions (hwd / in.) 14.17 x 11.80 x 0.50 Shipping Dimensions (hwd / cm) 35.99 x 29.97 x 1.27 Shipping Weight (lbs.) 1.24 Shipping Weight (kg) 0.56 ENVIRONMENTAL Operating Temperature Range -4 TO 140 F (- 20° TO 60°C) Storage Temperature Range -4 TO 140 F (- 20° TO 60°C) Operating Humidity Range 20-80% RH Storage Humidity Range 20-80% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P-HG Side B - Connector 1 NEMA 5-15R FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P022-015-GY-HG 价格&库存
很抱歉,暂时无法提供与“P022-015-GY-HG”相匹配的价格&库存,您可以联系我们找货
