P024-015-GY-HG
P024-015-GY-HG
    TRIPPLITE
    HOSPITAL-GRADEPOWEREXTENSIONC
P024-015-GY-HG 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Hospital-Grade Extension Cord, NEMA 5-15P to NEMA 5-15R - Green Dot, 15A, 125V, 14 AWG, 15 ft. (4.57 m), Gray Highlights ● Recommended for connecting devices to power outlets outside patient-care vicinities ● 15-ft. (4.57 m) length allows great flexibility in placing devices in relationship to AC outlet ● 15-ft. (4.57 m) extension cord replaces or upgrades power cord provided by manufacturer ● 5-15P-HG plug connects to AC power; 5-15R-HG end connects to device's input cord ● Color-coded gray for fast, easy identification in a crowded PDU, UPS or surge protector MODEL NUMBER: P024-015-GY-HG Applications Hospital-grade extension cord connects two devices with 5-15P-HG/5-15R-HG power connectors in a hospital or other medical facility. ● Connect devices like PCs, mobile carts, monitors and printers to a power outlet up to 15-ft. (4.57 m) away in a hospital environment outside patient-care vicinities ● Extend an existing power connection up to 15-ft. (4.57 m) to more easily place a device or reach a power source ● Update or replace the standard power cord provided by a device's original manufacturer Features Heavy-Duty Hospital-Grade Extension Cord is a Safe Solution for Medical FacilitiesThis hospitalgrade power cord is designed for computers, mobile carts, printers, scanners, monitors and other compatible hospital equipment within a healthcare facility and outside patient-care vicinities. It features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. The 15-ft. (4.57 m) length allows you great flexibility in placing equipment with respect to the power outlet. Package Includes ● Designed and Tested to Strict Hospital-Grade StandardsThis cord is tested to ANSI/UL 62 and 817 standards, as well as CAN/CSA C22.2 no. 21 and 49 standards, ensuring it's a dependable power solution for hospital environments. Color-Coded to Avoid Misidentification That Can Cause Costly DowntimeThis extension cord features a gray SJT jacket and fully molded gray ends. The color-coding allows easy, fast identification in a crowded surge protector and helps prevent the cable from becoming inadvertently disconnected. Specifications OVERVIEW UPC Code 037332200143 Device Compatibility Mobile Cart; Computer; Printer; Monitor/HDTV; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 15 1/3 P024-015-GY-HG HospitalGrade Extension Cord, 5-15PHG to 5-15R-HG, 15-ft. (4.57 m), Gray 1000 Eaton Boulevard Cleveland, OH 44122 United States Voltage Compatibility (VAC) 125 PHYSICAL Plug Color Gray Cable Jacket Color Gray Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 9.20mm Number of Conductors 3 Wire Gauge (AWG) 14 Wire Gauge (OD - mm²) 2.08 Cable Length (ft.) 15 Cable Length (m) 4.57 Shipping Dimensions (hwd / in.) 14.17 x 11.80 x 0.50 Shipping Dimensions (hwd / cm) 35.99 x 29.97 x 1.27 Shipping Weight (lbs.) 1.59 Shipping Weight (kg) 0.72 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 NEMA 5-15R FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P024-015-GY-HG
PDF文档中包含以下信息:
1. 物料型号:型号为LM5111。
2. 器件简介:LM5111是一款由国家半导体公司生产的同步降压DC/DC转换器,适用于需要高效率和低噪声的应用。
3. 引脚分配:LM5111有8个引脚,包括输入电压、输出电压、地、使能、反馈、开关节点等。
4. 参数特性:包括输入电压范围、输出电压范围、最大输出电流、静态电流等。
5. 功能详解:详细介绍了LM5111的功能,如同步降压转换、可调输出电压、低静态电流等。
6. 应用信息:适用于便携式设备、电池供电设备等。
7. 封装信息:提供多种封装选项,如SOIC、SOT23等。
P024-015-GY-HG 价格&库存
很抱歉,暂时无法提供与“P024-015-GY-HG”相匹配的价格&库存,您可以联系我们找货
