1000 Eaton Boulevard
Cleveland, OH 44122
United States
Power Extension Cord, C19 to C20 - Heavy-Duty,
20A, 250V, 12 AWG, 10 ft. (3.05 m), Black
MODEL NUMBER: P036-010
Highlights
Recommended for powering
servers, routers and other highoutput network devices
10-ft. (3.05 m) length allows
great flexibility in placing
devices in relationship to AC
outlet
C20 to C19 cord replaces or
upgrades standard power cord
provided by manufacturer
Thick 12 AWG wire gauge
manages high power levels
required for larger equipment
Applications
C19 to C20 20A heavy-duty extension cable connects high-output devices with C19/C20 power
connectors, including blade server chassis.
Connect devices like computers,
servers and monitors to a PDU
up to 10-ft. (3.05 m) away in
your data center
Extend an existing power
connection up to 10-ft. (3.05 m)
to more easily place a device or
reach a power source in a rack
Update or replace the standard
power cord provided by a
device's original manufacturer
Features
20A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis
heavy-duty extension cord features 12 AWG wire suitable for high power connections, making it a reliable
solution for large server applications that require a higher-rated, heavier-gauge cable. This cord can be
used to connect a server, router, network switch or blade server enclosure to a UPS system or PDU or
replace or upgrade the standard power cord provided by the device's manufacturer. The 10-ft. (3.05 m)
length allows you great flexibility in placing equipment with respect to the power outlet.
Specifications
OVERVIEW
UPC Code
037332176837
Device Compatibility
Server; Router; Network Switch; UPS; PDU
Country/Region
North America
INPUT
Maximum Input Amps
Voltage Compatibility (VAC)
250
PHYSICAL
Color
Black
Cable Jacket Color
Black
1/3
Package Includes
P036-010 C19 to C20 HeavyDuty Extension Cord, 10-ft.
(3.05 m), Black
Cleveland, OH 44122
United States
Cable Jacket Material
PVC
Cable Jacket Rating
VW-1
Power Cord Jacket Type
SJT
Cable Outer Diameter (OD)
11.0
Number of Conductors
3
Wire Gauge (AWG)
12
Wire Gauge (OD - mm²)
3.31
Cable Length (ft.)
10
Cable Length (m)
3.05
Shipping Dimensions (hwd / in.)
10.98 x 7.00 x 0.50
Shipping Dimensions (hwd / cm)
27.89 x 17.78 x 1.27
Shipping Weight (lbs.)
1.62
Shipping Weight (kg)
0.73
ENVIRONMENTAL
Operating Temperature Range
-4 F TO 140 F (-20 C TO 60 C)
Storage Temperature Range
Relative Humidity
10 to 65% RH, Non-Condensing
CONNECTIONS
Side A - Connector 1
IEC-320-C20
Side B - Connector 1
IEC-320-C19
FEATURES & SPECIFICATIONS
High Voltage
Yes
Locking Plug
No
Antibacterial
No
Angled Plug
No
Coiled Power Cord
No
STANDARDS & COMPLIANCE
Product Certifications
cUL Listed; UL Listed
Product Compliance
RoHS
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
Lifetime limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“P036-010”相匹配的价格&库存,您可以联系我们找货
