P036-002-6
P036-002-6
    TRIPPLITE
    CABLECONVERTER2'
P036-002-6 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Power Extension Cord, C19 to C20 - Heavy-Duty, 20A, 250V, 12 AWG, 2 ft. (0.61 m), Black, 6-Pack MODEL NUMBER: P036-002-6 Highlights ● Recommended for powering servers, routers and other highoutput network devices ● 2-ft. (0.61 m) length allows flexibility in placing devices, while avoiding cable clutter ● C20 to C19 cord replaces or upgrades standard power cord provided by manufacturer ● Thick 12 AWG wire gauge manages high power levels required for larger equipment Applications C19 to C20 20A heavy-duty extension cables connect high-output devices with C19/C20 power connectors, including blade server chassis. ● Connect devices like computers, servers and monitors to a PDU up to 2-ft. (0.61 m) away in your data center ● Extend existing power connections up to 2-ft. (0.61 m) to more easily place devices or reach a power source in a rack ● Update or replace the standard power cords provided by the original manufacturers Features 20A C20-to-C19 Power Cable for Network Devices That Require a Heavy-Gauge ConnectionThis package of six heavy-duty extension cords features 12 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher-rated, heavier-gauge cable. These cords can be used to connect servers, routers, network switches and blade server enclosures to a UPS system or PDU or replace or upgrade the standard power cords provided by the devices' manufacturers. The 2-ft. (0.61 m) length helps reduce cable clutter and minimize the risk of tripping. Specifications OVERVIEW UPC Code 037332180674 Device Compatibility Server; Router; Network Switch; UPS; PDU Country/Region North America INPUT Maximum Input Amps 20 Voltage Compatibility (VAC) 250 PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC 1/3 Package Includes ● (6) C19 to C20 Heavy-Duty Extension Cords, 2-ft. (0.61 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 11.2mm Number of Conductors 3 Wire Gauge (AWG) 12 Wire Gauge (OD - mm²) 3.31 Cable Length (ft.) 2 Cable Length (m) 0.61 Shipping Dimensions (hwd / in.) 2.25 x 9.00 x 13.00 Shipping Dimensions (hwd / cm) 5.72 x 22.86 x 33.02 Shipping Weight (lbs.) 2.80 Shipping Weight (kg) 1.27 ENVIRONMENTAL Operating Temperature Range 23 F TO 140 F (-5 CTO 60 C) Storage Temperature Range -4 F TO 176 F(-20 C TO 80C) Operating Humidity Range 0% to 90% RH, Non-Condensing Storage Humidity Range 0% to 90% RH, Non-Condensing CONNECTIONS Side A - Connector 1 IEC-320-C20 Side B - Connector 1 IEC-320-C19 FEATURES & SPECIFICATIONS High Voltage Yes Locking Plug No Antibacterial No Angled Plug No Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P036-002-6 价格&库存
很抱歉,暂时无法提供与“P036-002-6”相匹配的价格&库存,您可以联系我们找货
