TCSD-10-D-12.00-01-N
    SAMTEC(申泰)
TCSD-10-D-12.00-01-N 数据手册
REVISION BD TCSD-XX-X-XX.XX-01-X-XXX-XXX DO NOT SCALE FROM THIS PRINT NOTES: No OF POSITIONS 1. HIDDEN LINES ARE USED TO SHOW POLARIZATION 03, 04, 05, 07, 08, 10, 12, WHEN USING -N OPTION. 13, 15, 17, 20, 22, 25 2. C REPRESENTS A CRITICAL DIMENSION. NOTE: OTHER POSITIONS 3. AS OF REV 'C' ON TCB-50 CABLE ASSEMBLIES WILL BE LEAD FREE. AVAILABLE AS ASO. TOOL 4. ALL ASSEMBLIES TO BE 100% ELECTRICALLY TESTED FOR SHORTS AND OPENS. IS CAPABLE OF POSITIONS 2-25 5. ALL ASSEMBLIES TO BE 100% HI-POT TESTED AT 800V. 6. STRAIN RELIEF TO WITHSTAND 5LB STRAIGHT PULL. 7. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS MAY NOT EXTEND PAST THE CABLE INSULATION. END ASSEMBLY 8. REFERENCE TCSD-XX-XX-X-X-XXX PRINT FOR CONNECTOR ASSEMBLY AND ITS REQUIREMENTS. 9. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND PAST THE -S: SINGLE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE THICKNESS ON CONSECUTIVE -D: DOUBLE AND LESS THAN 50% OF THE CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. ASSEMBLY LENGTH 10. FOR LENGTHS LESS THAN 12.5" TOLERANCE SHALL BE +/-.125, (INCLUDES ADDED OPTION LENGTHS) ALL OTHER LENGTHS SHALL BE +/-1%. 11. FOR ASSEMBLY LENGTH SHORTER THAN 2.000[50.80] BREAK OUT ALL OPTIONS THAT USE -D"XX": 4.00 [101.6] MINIMUM SHALL EXTEND TO THE OPPOSITE CONNECTOR. ALL OTHER OPTION: 1.00 [25.4] MINIMUM 12. SEE PACKAGING MANUAL FOR PACKAGING INSTRUCTIONS OPTIONS #2 SEE OPTIONS BELOW OPTIONS #1 SEE OPTIONS BELOW PLATING OPTION -F: FLASH SELECTIVE GOLD, MATTE TIN TAIL -L: LIGHT SELECTIVE GOLD, MATTE TIN TAIL (LEAVE BLANK FOR STANDARD -S: SELECTIVE PLATING) LEAD STYLE C XX.XX[XX INCHES x 25.4] ±1% (SEE NOTE 7 & 10) .158 4.00 REF C XX.XX[XX INCHES x 25.4] ±1% (SEE NOTE 7 & 10) .125 3.18 REF (No OF POS x .07874[2.0000]) + .15748[4.0000] REF 2 C .200±.010 5.08±0.254 FLUSH TO .010 0.25 MAX CABLE OVERHANG (TYP) (SEE NOTE 7) COLORED WIRE TO SIDE OF FIRST POS INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. -N OPTION .040 1.02 REF -N OPTION -RN1 OPTION -RN2 OPTION FIRST POSITION INDICATOR -N OPTION 1 -RN1 OPTION -D: (DOUBLE END) -S (SINGLE END) (SAME AS -D UNLESS OTHERWISE STATED) F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-X-XXX-XXX-MKT.SLDDRW 02 COLORED WIRE TO OPPOSITE SIDE OF FIRST POS INDICATOR UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS .040 1.02 REF .125 3.18 REF -N: NOTCH POLARIZATION (USE TCSD-XX-XX-N) (AVAILABLE ON POS 04 THRU 25) (NOT AVAILABLE WITH -RN1 OR -RN2 OPTIONS) ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] 01 -RW: REVERSE WIRING (NOT AVAILABLE WITH -RN1 OR -RN2 OPTIONS) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 MATERIAL: DO NOT SCALE DRAWING INSULATOR: BLACK PBT CONTACT: HEAT TREATED BeCu STRAIN RELIEF: BLACK PBT WIRE: 28 AWG, 7/36, TINNED, COPPER WITH PVC INSULATOR PLATING: -L: .000015 GOLD ON CONTACT AREA, TIN ON REMAINDER -F: .000003 GOLD ON CONTACT AREA, TIN ON REMAINDER (STANDARD PLATING IS .000030 GOLD ON CONTACT AREA, TIN ON REMAINDER) 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-X-XXX-XXX BY: B RAY 11/20/2007 SHEET 1 OF 4 REVISION BD 01 03 02 01 02 02 03 01 01 01 01 COLORED WIRE TO SIDE OF FIRST POS INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. -P"XX": POLARIZED MATING 01 XX±.125 [3.18] (MIN 2") XX .125[3.18] (MIN 2 ") 02 COLORED WIRE TO SIDE OF FIRST POS INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. 01 NOTE: THE SAME POSITION WILL BE POLARIZED ON BOTH ENDS (USE PK-07-N) MIDDLE SOCKET REVERSED WHEN DAISY CHAINED OUTSIDE SOCKET REVERSED WHEN DAISY CHAINED -O: OUTSIDE REVERSED -M: MIDDLE REVERSED (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -M) (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) FIRST CONNECTOR (REQUIRES -D"XX") (NOT AVAILABLE WITH -R OR -O) (MINIMUM 2.00[50.8], 1.00[25.4] INCREMENTS) SECOND CONNECTOR TCSD-05-D-XX-01-RN2 SHOWN 01 01 02 01 01 01 COLORED WIRE TO SIDE OF FIRST POS INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. 02 COLORED WIRE TO SIDE OF FIRST POS INDICATOR * COLORED WIRE MAY BE BLACK, BLUE, OR RED. TCSD-05-D-XX-01-RN1 SHOWN -RN1 OR -RN2 (REVERSE POLARIZATION NOTCH) NOTE: -RN1 = REVERSE NOTCH ON 1ST CONNECTOR ONLY AVAILABLE FOR POSITIONS 4 OR GREATER (NOT AVAILABLE WITH -R OR -RW OPTIONS) -RN2 = REVERSE NOTCH ON 2ND CONNECTOR ONLY (NOT AVAILABLE WITH -R OR -RW OPTIONS) (-RNX NOT AVAILABLE WITH -N & -D"XX" OPTIONS) XX .125[3.18] (MIN 2") -D"XX": DAISY CHAINED .XX .125[3.18][6.70] (MIN 2") (2" MIN LENGTH, 1" INCREMENTS ONLY) * BOTH SOCKETS REVERSED WHEN DAISY CHAINED -R: REVERSE CONNECTOR (-D"XX" OPTIONAL) (SHOWN ABOVE WITH -D"XX") (MINIMUM 2.00 [50.8] WITH 1.00 [25.4] INCREMENTS WHEN USED WITH -D"XX") (NOT AVAILABLE WITH -O, -M, -RN1 OR -RN2) F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-X-XXX-XXX-MKT.SLDDRW 01 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-X-XXX-XXX BY: B RAY 11/20/2007 SHEET 2 OF 4 REVISION BD 6 XX (No. OF POS.) x .07874[2.0000] + .31000[7.8740] REF 2 5.000[127.00] MAX 2.000[50.80] MIN (SEE NOTE 11) .039 1.00 REF 4 .310±.010 7.87±0.25 (MEASURED AT BOTH ENDS) 5 -B"XX": BREAKOUT OPTION (TCSD-10-D-XX.XX-01-X-B05 SHOWN) 3 -SR: STRAIN RELIEF (NOT AVAILABLE WITH -O, -M, -R, -D"XX" OR -B"XX") (SAME AS -D, UNLESS OTHERWISE STATED) (SOLD IN ASSEMBLIES ONLY) (MUST USE HEAT BEND/STRAIN RELIEF TOOL ON POSITIONS 20-25) "XX" = NO. OF CONDUCTORS PER ROW BROKEN OUT FROM THE FIRST POSITION. AND THE BREAKOUT ENDS MUST BE EQUAL TO THE FULL POSITION CONNECTOR. "A" "B" (XX.XX[XX INCHES x 25.4]+.5[19.1]) ±.125[3.175] 3 "A" "B" XX.XX[XX INCHES x 25.4] x 2 +.250[6.35] ±1% FIRST POSITION INDICATOR FIRST POSITION INDICATOR SECTION "B"-"B" SECTION "A"-"A" IN-PROCESS 1 (-SR ONLY) IN-PROCESS (SINGLE END ONLY) * 3 (XX.XX[XX INCHES x 25.4] ±.125[3.175] PROPRIETARY NOTE DO NOT SCALE DRAWING IN-PROCESS 2 SHEET SCALE: 2:1 (-SR ONLY) F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-X-XXX-XXX-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-X-XXX-XXX BY: B RAY 11/20/2007 SHEET 3 OF 4 REVISION BD END VIEW SHOWN WITH TMC-XX-D REMOVED 6 C 5 2 MAX SWAY (TYP) .040 1.02 REF C +.010 +0.25 .140 - .025 3.56 - 0.64 C .065 1.648 .055 1.394 .125 3.18 REF 3 IN-PROCESS VIEW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: 2MM DOUBLE ROW FEMALE IDC ASSEMBLY DWG. NO. TCSD-XX-X-XX.XX-01-X-XXX-XXX F:\DWG\MISC\MKTG\TCSD-XX-X-XX.XX-01-X-XXX-XXX-MKT.SLDDRW BY: B RAY 11/20/2007 SHEET 4 OF 4
TCSD-10-D-12.00-01-N 价格&库存
很抱歉,暂时无法提供与“TCSD-10-D-12.00-01-N”相匹配的价格&库存,您可以联系我们找货
    • 1+128.28240
    库存:3
    • 3+105.88091
    • 10+100.22232
    • 25+94.38237
    • 50+88.13132
    • 100+81.95282
    • 250+75.87104
    • 500+62.49839
    • 1000+52.63214
    库存:102
