2880
2880
    ADAFRUIT
    2-PINJSTSMPLUG+RECEPTACLEC
2880 数据手册
2-pin JST SM Plug + Receptacle Cable Set PRODUCT ID: 2880 DESCRIPTION - These 2-wire cables are 16cm long and come as a set.  One side has a 2-pin JST SM type connector plug on the end.  The other side has a matching 2-pin JST SM type receptacle connector.  They are good for whenever you have 2 wires you want to be able to plug and unplug.  We like the solid and compact nature of these connectors and the latch that keeps the cable from coming apart easily. For more information, check the JST SM connector datasheet These match up with our EL inverters and cables so you can use them for creating custom EL wiring setups. Each order receives one of each connector. https://www.adafruit.com/products/2880 2/19/2016 Technical Details Cable Length: 16cm / 6.3"
很抱歉,暂时无法提供与“2880”相匹配的价格&库存,您可以联系我们找货
  • 1+6.755051+0.84743
库存:185
