FFTP-05-D-18.00-01-N
    SAMTEC(申泰)
FFTP-05-D-18.00-01-N 数据手册
REVISION P DO NOT SCALE FROM THIS PRINT FFTP-XX-X-XX.XX-01-X-X-X NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. ALL ASSEMBLIES TO BE 100 % ELECTRONICALLY TESTED FOR SHORTS AND OPENS. 3. ALL ASSEMBLIES TO BE 100 % HI-POT TESTED AT 630V. 4. TO BE MEASURED FROM BOND LINE. 5. PARTS TO BE PACKAGED PER THE IDC PACKAGING INSTRUCTIONS OF THE PACKAGING MANUAL. 6. SI DATA AVAILABLE FOR STANDARD LENGTHS ONLY. 7. MAX CABLE LENGTH AVAILABLE WITHOUT FLAT: RIBBONIZED SECTION IS 18.61 INCHES. CONTACT SAMTEC FOR NUMBER OF FLAT SECTIONS IF LONGER LENGTH IS REQUIRED. 8. WHEN CUTTING CABLE TO LENGTH, CONDUCTORS SHOULD NOT EXTEND PAST THE CABLE INSULATION, EXTENDING LESS THAN 25% OF CABLE THICKNESS ON CONSECUTIVE AND LESS THAN 50% OF THE CABLE THICKNESS ON NON-CONSECUTIVE STRANDS IS CONSIDERED A PROCESS INDICATOR. 9. FOR CONNECTOR ASSEMBLY SEE DRAWING FFSD-XX-XX-X-N-XXX-SUB. STANDARD POLARIZATION NOTCH -N: POLARIZATION NOTCH (NOT AVAILABLE IN -02 THRU -04) (LEAVE BLANK FOR -02 THRU -04) END ASSEMBLY -D: DOUBLE END (SEE FIGS 1 & 2) ASSEMBLY LENGTH ONLY AVAILABLE IN THESE LENGTHS - 3.85" (USE CBTP-68-30-7/38-025-2) - 8.77" (USE CBTP-68-30-7/38-025-1) -18.00" (USE CBTP-68-30-7/38-025-4) PLATING OPTIONS -LEAVE BLANK FOR STANDARD, USE C-67-L -S: USE C-67-S -F: USE C-67-F LEAD STYLE FFTP-10-D-3.85-01-X-N C .010 MAX CABLE OVERHANG C XX.XX ±.225 BOND LINE (NO OF POS x .050) + .165 REF .075 REF +.150 .250 - .100 (TYP) (SEE NOTE 4) SCALE 2:1 OPTION -R: REVERSED CONNECTOR (SEE FIG 2) -D: DOUBLE END FIG 1 NOTCH DENOTES FIRST POSITION RED WIRE TO SIDE OF 1ST POS INDICATOR .120 REF .040 REF No OF POSITIONS -02 THRU -25 DETAIL 'A' SCALE 2 : 1 C FFC-XX-D +.006 .200 - .003 C 'A' -R FIG 2 FFS-XX-D REVERSED CONNECTOR FFTP-10-D-X.XX-01-X-N-R (SAME AS FIG 1 EXCEPT AS SHOWN) IN PROCESS C XX.XX±.125 (SEE TABLE 1) C +.150 .250 - .100 (SEE NOTE 4) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 INSULATOR: CELANEX 3314, COLOR: BLACK CONTACT OR TERMINAL: PHOS BRONZE WIRE: 30 AWG, 7/38, TINNED, TWISTED PAIR WITH PVC INSULATOR F:\DWG\MISC\MKTG\FFTP-XX-X-XX.XX-01-X-X-X-MKT.SLDDRW DESCRIPTION: .050 X .050 C/L TWISTED PAIR FEMALE IDC ASSEMBLY DWG. NO. FFTP-XX-X-XX.XX-01-X-X-X BY: LENNY K 3/16/07 SHEET 1 OF 1
FFTP-05-D-18.00-01-N 价格&库存
很抱歉,暂时无法提供与“FFTP-05-D-18.00-01-N”相匹配的价格&库存,您可以联系我们找货
  • 1+152.704531+19.82353
  • 10+141.6997610+18.39494
  • 25+132.1947925+17.16104
  • 50+122.1615050+15.85855
  • 100+110.01570100+14.28183
库存:69
