FX5-52P-SH3
FX5-52P-SH3
    HRS(广濑)
FX5-52P-SH3 数据手册
1mm Pitch Connectors for Vertical Connection FX5 Series Connecting Height: Low profile FX5_*P_SH PCB Fig.1 ■Features 1. Header Side : 2 Types Available Connecting Height: High profile Two header types are available, low and high profiles. Combined with various contact positions, the FX5 is versatile to work in many application. (See Fig.1 and 2) FX5_*S2A_DSA FX5_*P_SH3 2. Two-step, Sequential Mating The mating sequence features a 2-step, "first mate-last break" condition that helps to protect the circuit. 3. Mating Guide A guide rib is provided along with a self-alignment range of ± 1mm to allow for easy mating operations. ( 6.6 ) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ( 3.6 ) FX5_*S2A_DSA 4. SMT Coplanarity The coplanarity of SMT soldered area has a high accuracy of 0.1mm. PCB 5. Miniaturization Fig.2 The FX5 uses about 30% less mounting area on the board compared with a 1.27mm pitch connector. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.4w 1 FX5 Series●1mm Pitch Connectors for Vertical Connection ■Product Specifications Current rating 0.5A Operating Temperature Range -55ç to +85ç (Note 1) Storage Temperature Range -10ç to +60ç (Note 2) Voltage rating 100V AC Operating Humidity Range 40% to 80% Storage Humidity Range Ratings Items Specifications 100M ohms min. 250V DC 2. Withstanding voltage No flashover or insulation breakdown. 300V AC/1 minute 3. Contact Resistance 50m ohms max. 5. Moisture Resistance 6. Temperature Cycle Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Conditions 1. Insulation Resistance 4. Vibration Resistance 7. Mating Cycles 8. Resistance to Soldering heat 40% to 70% 100mA Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, No electrical discontinuity of 1μs or more Contact resistance: 60m ohms max. 2 hours in each of the 3 directions. 96 hours at temperature of 40ç and humidity of Insulation resistance: 100M ohms min. Contact resistance: 60m ohms max. 90% to 95% (-55ç: 30 minutes, 15 to 35ç: 2 to 3 minutes Insulation resistance: 100M ohms min. (-85ç: 30 minutes, 15 to 35ç: 2 to 3minutes) 5 cycles Contact resistance: 60m ohms max. 500 cycles SMT No deformation of components affecting performance. DIP Reflow: At the recommended temperature profile Manual soldering: 360°C for 5 seconds Solder Bath: 260ç for 10 seconds Manual soldering: 360ç for 5 seconds Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for a long time prior to use. Operating temperature and humidity range includes a non-conducting state of installed connectors in storage, shipment, or during transportation. ■Material Part Material Finish Remarks Insulator Polyamide Beige UL94V-0 Header Contact Brass Contact area : Gold plated ––––––– Receptacle Contact Phosphor bronze Lead area : Tin plated ––––––– Note : The black dots on the insulater will not affect performance ■Product Number Structure ●Header FX5 – * P – SH 3 q q Series Name w e r t t Connector Height : FX5 w Number of Contacts : 20, 40, 52, 56, 68, 80 Blank : 6.5mm e Connector Type 3 : 9.5mm P: Header r Contact type SH : Right angle SMT type Note: The 56 contact header is for SH 3 type only. ●Receptacle FX5 – * S 2 A – DSA L q q Series Name w : FX5 w Number of Contacts : 20, 40, 52, 56, 68, 80 e Connector Type S: Receptacle r Contact Sequence 2 t Serial No. : A 2 : 2 Stages Sequence e r t y u y Contact type DSA : Straight through hole type u Board prefixed pin Blank : Without board prefixed pin L : With board Prefixed pin FX5 Series●1mm Pitch Connectors for Vertical Connection ■Header ●High profile V' & W& V& +¤%#( V& W&   .#*¤%#( W V 6 7¤%#( 8¤%#* 9¤%#( EdaVg^inBVg` V& V' & * == (number of contacts)/2 V 6 7¤%#( 8¤%#* 9¤%#( EdaVg^inBVg` %î &T%#' .#(¤%#( .#(¤%#( %î &T%#' W W'    (#*  W' W& &#,¤%#(  %#* +¤%#( V& &#,¤%#( V& W& V' : ;¤%#( W V %#* i%#'¤%#%*£l%#'¤%#%* 'T¢'#(¤%#&* +#(*¤%#( (#'¤%#' '#*¤%#(
FX5-52P-SH3
物料型号:HIROSE ELECTRIC CO., LTD.生产的FX5系列,1mm间距垂直连接连接器。
器件简介: - 提供两种头部类型:低轮廓和高轮廓。 - 具有两步顺序配对特性,有助于保护电路。 - 提供配对导向肋和±1mm的自对准范围,便于操作。 - SMT焊接区域的共面性精度高达0.1mm。 - 相比1.27mm间距连接器,FX5占用的板载面积减少约30%。
引脚分配:文档中提供了不同型号的引脚分配和尺寸,例如FX5-20P-SH(71)型号有20个引脚。
参数特性: - 电流额定值:0.5A。 - 工作温度范围:-55°C至+85°C。 - 存储温度范围:-10°C至+60°C。 - 绝缘电阻:最小100MΩ。 - 耐电压:300V AC/1分钟无闪络或绝缘击穿。 - 接触电阻:最大50mΩ。 - 振动抵抗:在特定频率和幅度下2小时内无电气中断。 - 耐湿性:在40°C和90%至95%湿度下96小时后接触电阻最大60mΩ,绝缘电阻最小100MΩ。 - 温度循环:经过特定温度循环5次后,接触电阻最大60mΩ,绝缘电阻最小100MΩ。 - 配对周期:500次。 - 耐焊热:无影响性能的元件变形。
功能详解: - 提供了详细的产品规格和条件,如绝缘电阻、耐电压、接触电阻等。 - 说明了材料构成,例如绝缘体为聚酰胺材料,接触件为黄铜镀金等。
应用信息: - 适用于需要高可靠性的应用,如汽车行业。
封装信息: - 提供了详细的封装尺寸和推荐的温度曲线,以及清洁条件和注意事项。
FX5-52P-SH3 价格&库存
很抱歉,暂时无法提供与“FX5-52P-SH3”相匹配的价格&库存,您可以联系我们找货
