310J101-20-CA003
310J101-20-CA003
    CICOIL
    FLTRIBCBL.050"28AWG20C3'
310J101-20-CA003 数据手册
REVISIONS ASSY PN: 310J100 - -CA LTR NC DESCRIPTION DATE INITIAL RELEASE APPROVAL 10-04-10 JRP LENGTH (FEET):CA003;CA006;CA012 NUMBER OF CONDUCTORS CONNECTOR PN: 71600-0 XXLF XX = NUMBER OF CONDUCTORS A A BILL OF MATERIALS QTY DESC 2 PN CONNECTOR, IDC MFG 71600-0XXLF* FCI NOTES: 1) INSTALL IDC CONNECTORS AS REQUIRED. 2 USE 310J101 CABLE. THE ID OF THIS ASSY IS PRODUCTION PREFERENCE. STRIP AND TIN PER IEC-J-STD-001. ULTRA FLEXIBLE, FINELY STRANDED COPPER VIEW PROJECTION INTERMEDIATE FLEX: 6X CABLE HEIGHT STANDARD TOLERANCES CONTINUOUS FLEX: 10X CABLE HEIGHT UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES OUTER JACKET DUROMETER RATING: 65 (SHORE A) .X± .XX± ASSEMBLY TEMPERATURE RATING: -65°C TO +105° .XXX± .005 CABLE TEMPERATURE RATING: -65°C TO +260°C FRAC± ANGLES± 10) OUTER JACKET DIELECTRIC STRENGTH: 450 VOLTS/MIL (17.7 kv/mm) MM( ) MATL: 11) *OR EQUIVALENT X 3) 4) 5) 6) 7) 8) 9) DASH NO QTY REQD NEXT ASSEMBLY APPLICATION NO INCH SCALE SIGNATURE DO NOT SCALE DRAWING SUPPLIER PN, REV 0 1 JRP 10-04-10 CHECK JRP 10-04-10 ENG. JRP 10-04-10 Q.A. APPR. DESCRIPTION QTY 2 CICOIL DATE DRAWN APPR. FINAL ASSEMBLY CICOIL PN, REV VALENCIA, CALIFORNIA TITLE STANDARD PRODUCT DEFINITION DRAWING, RIBBON CABLE, (IDC) CAGE CODE 19476 SCALE: NONE SIZE DRAWING NUMBER REV A 310J100-XX-CAXXX NC SHEET OF FILE: 310J100-XX-CAXXX
310J101-20-CA003 价格&库存
很抱歉,暂时无法提供与“310J101-20-CA003”相匹配的价格&库存,您可以联系我们找货
310J101-20-CA003
  • 34+221.2545534+28.55959
