FX1-192S-1.27DS(71)
FX1-192S-1.27DS(71)
    HRS(广濑)
FX1-192S-1.27DS(71) 数据手册
1.27mm Pitch Connector FX1 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. DIN duplex density mount has been achieved. (DIN 96 contacts and FX1 192 (96x2) Photo 1 Figure 2 Sequence Structure (Pin contact sequence) The alignment of the mating area in 4-row allows to duplex the number of contacts in the nearly equivalent mount square as for the conventional DIN connector.(Refer to photo (1).) C2 C1 B2 2. High Current and High Voltage 2.5 1.8 Considering insertion/extraction in active power mode and maintenance on the end user side, the FX1 series is designed in a mechanism that can afford the time different contact at two steps. (For details, refer to Figure (2) as shown on the right.) (Effective contact length) 10 2.8 A2 A1 2.2 1 3. Sequence Structure (Contact start position) B1 Two-thirds of total contact numbers are used for half pitch signaling contact, while the other one-third thereof is used for the power ground contact. Power ground contact corresponds to high current (1A) and high voltage (250V). 24.4 1. High density and space saved-DIN Duplex Mount Achieved 13.69 ■Features C2 C1 B2 B1 A2 A1 4. Mis-insertion Prevent Provide the insertion guide on both ends of connector, and widen an inductive area in order to prevent mis-insertion. *FX1 Series (2 step sequence) 1 Row B 2 Row A, row C Setting row B to ground, if active cable insertion and extraction are performed as power supply, arc will occur between contact and contact. The row B contact structure is constructed to separate arc occurrence point a and normal contact point b, and minimizes affects on the contact. A78 FX1 Series●1.27mm Pitch Connector ■Product Specifications Current rating Voltage rating 0.5A Signal Contact: 125V AC Operating Temperature Range-55 to 85ç (Note 1) Storage Temperature Range -10 to +60ç(Note 2) Rating Signal Contact: Power Supply Contact: 1A Power Supply Contact: 250V AC Operating Humidity Range -40 to 80% Operating Humidity Range -40 to 70% (Note 2) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification 1. Insulation Resistance 1000M ohms min. 2. Withstanding Voltage No flashover or insulation breakdown. Condition 250V DC 1 minute Signal contact Power supply contact 300V AC 600V AC 3. Contact Resistance 60m ohms max. (conductor resistance included) 100mA 4. Vibration No electrical discontinuity of 1μs or more Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Contact resistance: 70m ohms max. Insulation resistance: 1000M ohms min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6. Temperature Cycle Contact resistance: 70m ohms max. Insulation resistance: 1000M ohms min. (-55ç: 30 minutes→15- to 35ç: 5 minutes max.→ (-85ç: 30 minutes→15- to 35ç: 5 minutes max.) 5 cycles 7. Durability (Mating/un-mating) Contact resistance: 70 m ohms max. 500 cycles Note 1: Includes temperature rise caused by current flow. Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material ●FX1 Series Parts Insulator Contact Material Header PPS Receptacle PPS/ PTB Straight header Right angle header Brass Phosphor bronze Receptacle Phosphor bronze Prefixed pin Phosphor bronze Finish Remarks Black UL94V-0 Contact area:Tin plated Lead area:Tin plated Tin plated ________ ________ A79 FX1 Series●1.27mm Pitch Connector ■Ordering Information ●FX1 Series FX1 - 192 P - 1.27 DSA L q q Series Name w : FX1 w Number of contacts: 144, 192, 216 e Connector type : P-header Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. : S-receptacle e r t y r Contact pitch: 1.27mm t Contact type: DS : Right angle DSA : Straight y L: Board prefixed pin Note: The cleaning type only is applied on the header side to FX1 series. BApplication Pattern A80 FX1 Series●1.27mm Pitch Connector FX1 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Receptacle : Right Angle Type BPCB mounting pattern Applicable board thickness t=1.6mm Unit: mm Part Number CL No. FX1-144S-1.27DS(71) 571-0003-7-71 FX1-144S-1.27DSL(71) 571-0053-5-71 FX1-192S-1.27DS(71) 571-0004-0-71 FX1-192S-1.27DSL(71) 571-0054-8-71 FX1-216S-1.27DS(71) 571-0005-2-71 FX1-216S-1.27DSL(71) 571-0055-0-71 Number of Contacts A B C 144 73.29 68.08 59.69 192 93.61 88.4 80.01 216 103.77 98.56 90.17 D ____ 67.31 ____ RoHS YES 87.63 ____ 97.79 A81 FX1 Series●1.27mm Pitch Connector Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header : Straight Type BPCB mounting pattern Applicable board thickness t=1.6mm Unit: mm Part Number A82 CL No. FX1-144P-1.27DSA(71) 571-0303-0-71 FX1-144P-1.27DSAL(71) 571-0353-9-71 FX1-192P-1.27DSA(71) 571-0304-3-71 FX1-192P-1.27DSAL(71) 571-0354-1-71 FX1-216P-1.27DSA(71) 571-0305-6-71 FX1-216P-1.27DSAL(71) 571-0355-4-71 Number of Contacts A B 144 73.29 59.69 192 93.61 80.01 216 103.77 90.17 C ____ 69.85 ____ 90.17 ____ 100.33 RoHS YES FX1 Series●1.27mm Pitch Connector Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Header : Right Angle Type BPCB mounting pattern Applicable board thickness t=1.6mm Part Number CL No. FX1-144P-1.27DS(71) 571-0203-6-71 FX1-144P-1.27DSL(71) 571-0253-4-71 Number of Contacts RoHS 144 YES A83 FX1 Series●1.27mm Pitch Connector BPrecautions Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Soldering (1)In the case of manual soldering, complete services under the condition of soldering iron bit temperature below 360ç for 5 seconds max. Please be sure to coat the contacts with solder so that no force is given. (2)In the case of dip soldering bath, complete service under the condition of soldering iron bit temperature below 260ç for 10 seconds max. 2. Prefixed function If the prefixed function is required, please use to the board prefixed pin type. A84
FX1-192S-1.27DS(71)
物料型号:FX1系列
器件简介: - 该系列连接器具有高密度和节省空间的特点,实现了DIN对插式安装。 - 有高电流和高电压的接触点,其中2/3的接触点用于半间距信号接触,其余1/3用于电源地接触,支持高达1A的电流和250V的电压。 - 设计了序列结构,以适应在活动电源模式下插入/拔出和最终用户侧的维护。 - 提供了防误插功能,包括连接器两端的插入导向和感应区域的扩大。
引脚分配: - 引脚分配遵循特定的序列结构,例如C2、C1、B2、B1、A2、A1,以确保正确的插入和连接。
参数特性: - 信号接触的电流额定值为0.5A,电压额定值为125V。 - 电源接触的电流额定值为1A,电压额定值为250V AC。 - 工作温度范围为-55至85°C,存储温度范围为-10至+60°C。 - 绝缘电阻最小为1000MΩ,接触电阻最大为60mΩ。
功能详解: - 连接器设计了两步序列,以减少在电源插入和拔出时产生的电弧影响。
应用信息: - 提供了详细的订购信息和应用模式,包括母板和子板侧的PCB布局。
封装信息: - 绝缘体材料为PPS或PTB,表面处理为黑色,符合UL94V-0标准。 - 接触材料包括黄铜(直头接触)和磷青铜(直角接触和插座接触),接触区域和引线区域均为锡镀。
注意事项: - 提供了焊接和预装功能的指导,以确保连接器的正确使用和长期稳定性。
FX1-192S-1.27DS(71) 价格&库存
很抱歉,暂时无法提供与“FX1-192S-1.27DS(71)”相匹配的价格&库存,您可以联系我们找货
