Low-Angle Mating / Unmating Interface Connectors
EX60B Series
Rotating mating/unmating guide
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Plug
(Cradle mount)
■Features
1. Angle Mating / Unmating
The cradle mount plug incorporates a unique
rotating mating/unmating guide allowing the
portable device to be placed or removed at an
angle, up to 20° max. In addition, the angle mating
force is approximately 3N(29 pos.), with extremely
low unmating forces.
Receptacle
(Portable device mount)
Angle mating/unmating
Lift (rotate)
Mating at 20° angle
20°
2. High durability
Bellow configuration of the contacts guarantees
10,000 angle mating/unmating cycles, without any
degradation of electrical and mechanical
performance.
3. High-Speed Data Transfer
A full eye pattern is maintained at a speed of 2.5 G
bps, making it applicable for high-speed
differential signals of the USB 2.0 and PCIEXPRESS.
High speed data transfer
2.5 Gbps Eye Pattern Output Waveform
4. Secure attachment
Standard or extended flange versions of the
receptacle can be mounted directly to the portable
device’s case. The cradle mount plug is attached
using screws.
5. Low profile - Space-Saving
Small size (4 mm high ∞ 6.8 mm deep) of the
Receptacle allows efficient use of space in a
portable device.
Extended flange mounting
■Applications
PDA and POS terminals, electronic books, tablet
PCs, mobile TVs, media players, digital cameras
and other devices requiring high durability angle
mating/unmating connectors.
Device case
Extended flanges
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.3e
1
EX60B Series●Low-Angle Mating / Unmating Interface Connectors
■Specifications
Current raring 0.5A
Rating
Operating temperature range
Voltage rating 125V AC
Characteristic
Specification
Conditions
1.Insulation resistance 1000Mø min.
250V DC
2.Dielectric withstanding voltage No flashover or insulation breakdown.
250V AC/ one minute
3.Contact resistance
60mø max.
100mA DC
4.Vibration
No electrical discontinuity of 1μ sec. max. Frequency: 10 to 55 Hz, single amplitude of 0.75mm,
Contact resistance: 100mø max.
5.Shock
for 2 hours in 6 axis.
No electrical discontinuity of 1μ sec. max. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform,
6. Mating/un-mating
3 cycles in each of the 6 axis.
Mating:
With corresponding connector.
10N max. (Horizontal),
forces
_55ç to +85ç
5N max. (At 20° angle)
Un-mating: 10N max. (Horizontal),
2N max. (At 20° angle)
7.Durability
5000 cycles (Straight mating)
10000 cycles (At 20° angle)
(mating/un-mating)
8.Temperature cycle
9.Humidity
: -55ç ➝ +15ç to +35ç ➝ +85ç ➝ + 15ç to +35ç
Temperature
➝ +2 to 3 ➝ 30 ➝ +2 to 3
Insulation resistance: 1000M ø min.
Time (Minutes) : -30
96 hours at temperature of 60ç and humidity of 90% to 95%.
5 cycles
Insulation resistance: 5Mø min.(Dry state)
10.Salt spray
5% salt water solution for 48 hours
No corrosions
Note: Includes temperature rise caused by the current flow.
■Materials/ Finish
●Receptacles (Portable device mount)
Component
Material
Finish
Remarks
Insulator
LCP
Color: Black
UL94V-0
Contacts
Copper alloy
Contact area: Gold plated
Stainless steel
Tin plated
Metal shield
●Plugs (Cradle mount)
Component
Insulator
Contacts
Material
Finish
Remarks
Polyamide
Color: Black
UL94V-0
Copper alloy
Metal shield
Stainless steel
Tin-plated
Guide
Stainless steel
Spring
Stainless steel
■Ordering information
EX 60 B - 29 P - FL
1
2
1
3
4
5
1 Series name
: EXB
2 Termination type
: 60 : Right angle SMT
3 Number of contacts : 15, 29
4 Contact type
EX 60 B - 29 S
1
2
2
1
3
4
P : Male contact (Receptacle = device mount)
S : Female contact (Plug = cradle mount)
5 Option
FL : Extended flanges
■Receptacles
A
●15 pos., 29 pos. (Standard)
0.2(Contact width)
6.8
P=0.6
B
C
D
E
4
Part number
CL No.
HRS No.
A
EX60B-29P
29
CL232-0611-5
16.8
EX60B-15P
15
CL232-0621-9
8.4
0.9
0.3
F
1
4.1
0.8
EX60B
G
B
C
D
E
13.65 12.35 14.25 12.95
9.45
8.15 10.05
F
G
13.5
12.2
9.3
8.0
8.75
RoHS
YES
16.8
●29 pos. (Extended flanges)
P=0.6
0.2(Contact width)
1.6
6.8
Extended flanges
13.65
12.35
14.25
14.65
12.95
13.35
CL No.
RoHS
232-0612-8
YES
4
0.3
13.5
1
4.1
0.9
Part number
0.8
EX60B
EX60B-29P-FL
4.05
Contact No. 29
Contact No. 1
12.2
BRecommended PCB mounting pattern
●EX60B-15P
16.8
4
PCB edge
Ø1.6
11.4
12.2
13.4
14.6
10.9
4.7
2.1
Through hole
PCB edge
Pad
0.4
2
4.7
Pad
Through hole
Pad
2
2
Pad
8.4
P=0.6
0.4
0.4
2.1
P=0.6
2.4
Ø1.6
3.7
9.2
2
●EX60B-29P and EX60B-29P-FL
0.4
4.05
Contact No. **
Contact No. 1
7.9
12.1
13.3
3
■Portable device case cutout
A
B
Part number
(1)
4.25
EX60B-29P
EX60B-29P-FL
EX60B
EX60B-15P
A
B
14.5
13.2
10.3
9
Board mounting surface
12
Unreeling direction
4
Ø1
.5
2
1.75
■Packaging specifications
D
(2)
(Ø380)
C
B
A
Unreeling direction
(Ø
13
Part number
EX60B-29P
EX60B-29P-FL
EX60B-15P
Note: 1,200 pieces per reel.
4
A
B
C
D
20.2
40.4
44.0
44.4
14.2
28.4
32.0
32.4
■Plug (Cradle mount)
●15 pos., 29 pos.
A
B
D
C
1.3
(3.1)
8.5
Ø2
.4
0.2(Contact width)
H
Rotating mating
unmating guide
I
Contact No.**
K
L
Part number Number of contacts
HRS No.
A
B
C
EX60B-29S
29
CL232-0613-0 (16.0) (15.6) 13.6
EX60B-15S
15
CL232-0622-1 (11.8) (11.4)
9.4
3.85
J
4.35
0.8
0.9
1.7
Contact No.1
0.3
0.8
2.2
M
D
E
F
G
13.2 11.15 10.75 16.8
9.0
6.95
6.55
8.4
4.1
H
13.3
I
J
K
L
M
12.0 11.85 11.45 15.85 15.45
9.1
7.8
7.65
7.25 11.65 11.25
2.35
RoHS
YES
■Recommended PCB mounting pattern
A
B
C
D
E
F
3.9
0.8(Through hole)
2
0.4
2.2
2.95
P=0.6
1.8
G
2.2(Land)
1.4(Through hole)
R0
.4
R0
.8
1.6(Land)
G
P=0.6
2.2
F
E
PCB edge
Part number
A
B
C
D
E
F
G
EX60B-29S
15.85
15.45
13.6
13.2
11.85
11.45
16.8
EX60B-15S
11.65
11.25
9.4
9.0
7.65
7.25
8.4
Ø2.6(Hole)
5
■Cradle case mounting recommendations - Plug
2MIN
A
1
B
(1)
(4.1)
AX
°M
25
5.5MIN 2
2
Screw attachment
Notes 1
Notes 2
Notes 3
Part number
A
B
EX60B-29S
13.65
12.35
EX60B-15S
9.45
8.15
The maximum opening angle of the rotating mating/unmating guide is 25°. Do not exceed this angle.
Device’s case must have the recommended cutout dimensions.
Assure that there is no interference with the free movement and operation of the mating/unmating guide.
Use screw (not supplied) to attach the receptacle to the case.
■Packaging Specifications (Plug, EX60B-29S)
Ø1
.5
Unreeling direction
16
4
2
1.75
2.4
D
(2)
Center of vacuum
pick-up area
(Ø380)
B
C
14.4
A
Unreeling direction
13
(Ø
Note: 800 pieces per reel.
6
Part number
A
B
C
D
EX60B-29S
26.2
52.4
56.0
56.4
EX60B-15S
20.2
40.4
44.0
44.4
■Mating cross-section
(14)
Flange
(4.75)
EX60B-**P
Receptacle (Portable device mount)
EX60B-**S
Plug (cradle mount)
Flange
■Recommended Temperature Profile
(Tamperature)
(ç)
250ç
230ç min
250
200
150
180ç
150ç
100
90 sec.
30 sec.
50
Preheating
Soldering
(Time)
Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there
is a return to normal temperature between the first and second cycle.
Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the
connector terminals.
7
■Portable device case and cradle design requirements
1. Mating/unmating angles (see illustrations below)
(1) Angle on the Z-axis is 20° max.
(2) Angle on the X-axis is 3° max.
Mating/ unmating angle 3°
(X-axis)
Mating/unmating angle 20°
(Z-axis)
Cradle
2.Dimensional requirements
(1) Distance between the flanges of the receptacle and plug: 0 to 0.7 mm.
(2) Distance between the PCB mounting surface of the plug (cradle) and the PCB surface of the receptacle (portable device):
4.8±0.1 mm.
(1) 0 to 0.7mm
(2) 4.8±0.1mm
Receptacle
front flange surface
Cradle
Cradle connector flange surface
3.Portable device removal
The point of the rotation of the portable device during it’s removal from the cradle should be at the distance of 6.5 mm min.
as illustrated below.
Lift and remove
Point of rotation
Portable device
6.5 min
Cradle
8
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“EX60B-15S”相匹配的价格&库存,您可以联系我们找货
