0.5mm Pitch, Board to Board Connector with Floating Structure
FX20 Series
X direction
Y direction
Floating range
:0.6mm
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Floating range
:0.6∼0.8mm
■Features
Enlarged view of the contact area
1. 0.5mm pitch
2. Connection type: Right angle / Vertical
3. Pin counts : 20, 40, 60, 80, 100, 120 and 140
4. Floating range : ± 0.6 to 0.8mm in the X direction
and ± 0.6mm in the Y direction
5. A double beam contact structure produces a highly
reliable contact (Refer to the figure on the right)
6. Current capacity : 0.5A per pin
7. Effective mating length of 1.5mm
Receptacle-side
contact
This connector utilizes a 1.5mm effective mating length for signal
contacts and provides a sufficient margin for its mating stroke.
8. No conductive trace surface is not specified
9. Contains the vacuum pick up area needed to
allow automatic mounting
10. Self-aligning and self-guiding structure
Header-side contact
Built-in guide posts enable self-alignment and ensure a secure connection
■Stacking height chart
Header
Receptacle
FX20-**S-0.5SV
FX20-**P-0.5SV15
FX20-**P-0.5SV20
h=15mm
h=20mm
h=25mm
h=30mm
FX20-**S-0.5SV10
FX20-**S-0.5SH
Floating range
Right angle connection
X direction
±0.6mm
±0.8mm
Y direction
±0.6mm
±0.6mm
FX20-**S-0.5SV10
FX20-**S-0.5SH
FX20-**S-0.5SV
h=15mm
FX20-**P-0.5SV15
FX20-**P-0.5SV20
h=20mm
h=25mm
h=30mm
Right angle
connection
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
Right angle
connection
2018.7③
1
FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure
■Product Specifications
Ratings
Rated current 0.5A
Rated voltage AC 50V
Item
Operating temperature range : -55 to 85°C (Note 1)
Storage temperature range : -10 to 60°C (Note 2)
Standards
Condition
1. Contact resistance
70mø max.
100mA(DC or 1000Hz)
2. Insulation resistance
100Mø min.
100V DC.
3. Voltage proof
No flashover or breakdown.
Contact resistance : Variation from initial
4. Mechanical operation
value 20mø or less.
No damage, crack and looseness of parts.
5. Vibration
No electrical discontinuity of 1µs.
6. Shock
7. Damp heat
(Steady state)
8. Rapid change of
temperature
value 20mø or less.
Insulation resistance : 100Mø min.
150V AC for 1 min.
50 times insertions and extractions.
Frequency : 10 to 55 to 10Hz, approx 5 min
Single amplitude : 0.75mm, 10 cycles for 3 axial directions.
2
490m/s , duration of pulse 11ms
at 3 times for 3 both axial directions.
Exposed at 40±2°C, 90~95%, 96h.
Temperature : -55 ➝ +85°C
Time :
30 ➝ 30 min.
Under 5 cycles(relocation time to chamber : within 2~3min)
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use.
■Materials / Finish
Part
Material
Header
Receptacle
Header
Receptacle
Insulator
Contacts
Metal Fitting
Finish
PA
Black
LCP
Black
Copper alloy
Contact area: Gold plated
Phosphor bronze Mounting area: Gold plated
Brass
Tin plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Straight receptacle
FX20 − 60 S − 0.5 SV 10
❶
❷
❸
❹
❺
❻
●Straight header
FX20 − 60 P − 0.5 SV 15
❶
❷
❸
❹
❺
❻
●Right angle receptacle
FX20 − 60 S − 0.5 SH
❶
❷
❶ Series name
❸
❹
❺
: FX20
❷ Number (contacts) :
2
❸ Connector type
S : Receptacle type
P : Header type
❹ Contact pitch
: 0.5mm
❺ Housing configuration
: SV : Straight type
❻ Stacking height type
Mating height [mm] =
Height of the receptacle-side + Height of the header-side
SH : Right angle type
UL standard
UL94V-0
UL94V-0
[ FX20-**S-0.5SV ]
A±0.3
B±0.3
2.7±0.2
6.8±0.3
Contact No. G
Contact No. F
C±0.2
P=0.5±0.15
2
1.
C
8.3±0.3
D±0.3
(1.1)
Polarization mark
(1.1)
6.5±0.25
Unit : mm
HRS No.
No. of contacts
A
B
C
D
E
F
G
FX20-20S-0.5SV
Part No.
570-1114-7
16.4
4.5
12.65
10
11
FX20-40S-0.5SV
570-1101-5
40
22.4
21.4
9.5
17.65
40
FX20-60S-0.5SV
570-1102-8
60
27.4
26.4
14.5
22.65
30
31
60
FX20-80S-0.5SV
570-1103-0
80
32.4
31.4
19.5
27.65
40
41
80
FX20-100S-0.5SV
570-1104-3
100
37.4
36.4
24.5
32.65
50
51
100
FX20-120S-0.5SV
570-1105-6
120
42.4
41.4
29.5
37.65
60
61
120
FX20-140S-0.5SV
570-1106-9
140
47.4
46.4
34.5
42.65
70
71
140
A±0.3
B±0.3
C±0.2
Contact No. G
6.8±0.3
2.7±0.2
[ FX20-**S-0.5SV10 ]
Contact No. F
P=0.5±0.15
2
1.
C
Contact No. E
Contact No. 1
t=0.3±0.05×w=0.15±0.03
6±0.3
D±0.3
18.3±0.3
Contact No. 1
t=0.2±0.05×w=0.15±0.03
4.5±0.3
Contact No. E
(1.1)
Polarization mark
(1.1)
6.5±0.25
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
G
FX20-20S-0.5SV10
570-1115-0
16.4
4.5
12.65
FX20-40S-0.5SV10
570-1107-1
40
22.4
21.4
9.5
17.65
10
11
40
FX20-60S-0.5SV10
570-1108-4
60
27.4
26.4
14.5
FX20-80S-0.5SV10
570-1109-7
80
32.4
31.4
19.5
22.65
30
31
60
27.65
40
41
80
FX20-100S-0.5SV10
570-1110-6
100
37.4
36.4
FX20-120S-0.5SV10
570-1111-9
120
42.4
41.4
24.5
32.65
50
51
100
29.5
37.65
60
61
120
FX20-140S-0.5SV10
570-1112-1
140
47.4
46.4
34.5
42.65
70
71
140
3
Contact No. F
A±0.3
B±0.3
Contact No. G
C±0.2
P=0.5±0.15
Contact No. E
C
1
[ FX20-**P-0.5SV15 ]
8.7±0.2
2.7±0.2
●Straight header
Contact No. 1
t=0.15±0.03×w=0.2±0.05
D±0.15
13.2±0.3
4.8±0.15
Polarization mark
(0.85)
6±0.3
(0.85)
9.5±0.25
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
G
FX20-20P-0.5SV15
570-1014-2
16.4
4.5
10.4
10
11
FX20-40P-0.5SV15
570-1001-0
40
22.4
21.4
9.5
15.4
40
FX20-60P-0.5SV15
570-1002-3
60
27.4
26.4
14.5
20.4
30
31
60
570-1003-6
80
32.4
31.4
19.5
25.4
40
41
80
FX20-100P-0.5SV15
570-1004-9
100
37.4
36.4
24.5
30.4
50
51
100
FX20-120P-0.5SV15
570-1005-1
120
42.4
41.4
29.5
35.4
60
61
120
FX20-140P-0.5SV15
570-1006-4
140
47.4
46.4
34.5
40.4
70
71
140
Contact No.F
A±0.3
B±0.3
C±0.2
P=0.5±0.15
Contact No.G
Contact No.E
C
1
[ FX20-**P-0.5SV20 ]
8.7±0.2
2.7±0.2
FX20-80P-0.5SV15
Contact No. 1
D±0.15
18.2±0.3
11±0.3
4.8±0.15
(0.85)
Polarization mark
(0.85)
9.5±0.25
Unit : mm
Part No.
4
HRS No.
No. of contacts
A
B
C
D
E
F
G
FX20-20P-0.5SV20
570-1015-5
16.4
4.5
10.4
10
11
FX20-40P-0.5SV20
570-1007-7
40
22.4
21.4
9.5
15.4
40
FX20-60P-0.5SV20
570-1008-0
60
27.4
26.4
14.5
20.4
30
31
60
FX20-80P-0.5SV20
570-1009-2
80
32.4
31.4
19.5
25.4
40
41
80
FX20-100P-0.5SV20
570-1010-1
100
37.4
36.4
24.5
30.4
50
51
100
FX20-120P-0.5SV20
570-1011-4
120
42.4
41.4
29.5
35.4
60
61
120
FX20-140P-0.5SV20
570-1012-7
140
47.4
46.4
34.5
40.4
70
71
140
[ FX20-**S-0.5SH ]
A±0.2
P=0.5±0.15
W=0.15±0.03
(5.3)
(2)
2.7±0.1
(2)
9.5±0.2
10.4±0.3
Vacuum pick up area
Polarization
mark
(5)
7.15±0.3
6.55±0.3
2.3±0.3
B±0.2
9.45±0.3
(0.2)
C±0.3
D±0.2
P=0.5±0.15
W=0.15±0.03
Contact No. F
Contact No. G
Contact No. E
Contact No. 1
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
G
FX20-20S-0.5SH
570-1611-1
16.4
17.4
4.5
10
11
FX20-40S-0.5SH
570-1601-8
40
9.5
21.4
22.4
9.5
40
FX20-60S-0.5SH
570-1602-0
60
14.5
26.4
27.4
14.5
30
31
60
FX20-80S-0.5SH
570-1603-3
80
19.5
31.4
32.4
19.5
40
41
80
FX20-100S-0.5SH
570-1604-6
100
24.5
36.4
37.4
24.5
50
51
100
FX20-120S-0.5SH
570-1605-9
120
29.5
41.4
42.4
29.5
60
61
120
FX20-140S-0.5SH
570-1606-1
140
34.5
46.4
47.4
34.5
70
71
140
5
BRecommended PCB layout
(PCB thickness: t= 1.6 mm/Stencil thickness: t= 0.15 mm, t= 0.12 mm)
3.2±0.05
FX20-**S-0.5SV
FX20-**S-0.5SV10
7.1
+0.1
A±0.03
P=0.5±0.03
Unit: mm
SMT pad: 0.3 ±0.03
Stencil (t= 0.15): 0.25 ±0.03
Stencil (t= 0.12): 0.3 ±0.03
B±0.05
3±0.05
3±0.05
A
B
13.46
40
9.5
18.46
60
14.5
23.46
80
19.5
28.46
100
24.5
33.46
120
29.5
38.46
140
34.5
43.46
A
●Straight header
FX20-**P-0.5SV15
FX20-**P-0.5SV20
3.2±0.05
A±0.03
10.1
+0.1
P=0.5±0.03
SMT pad: 0.3 ±0.03
B±0.05
3±0.05
3±0.05
Unit: mm
B
13.46
40
9.5
18.46
60
14.5
23.46
80
19.5
28.46
100
24.5
33.46
120
29.5
38.46
140
34.5
43.46
FX20-**S-0.5SH
B±0.05
3±0.05
PCB edge
(Mating side)
6
6.85±0.05
Contact No. (n/2+1)
Contact No. (n/2)
Contact No. n
SMT pad: 0.3 ±0.03
+0.1
Contact No.1
1max
3.2±0.05
P=0.5±0.03
10.05±0.05
1.7 0
+0.1
A±0.03
1.7 0
3±0.05
Unit: mm
A
B
13.46
40
9.5
18.46
60
14.5
23.46
80
19.5
28.46
100
24.5
33.46
120
29.5
38.46
140
34.5
43.46
BTray package drawing
E27
Part No.
FX20-20S-0.5SV
FX20-20S-0.5SV10
FX20-40S-0.5SV
FX20-40S-0.5SV10
FX20-60S-0.5SV
FX20-60S-0.5SV10
FX20-80S-0.5SV
FX20-80S-0.5SV10
FX20-100S-0.5SV
FX20-100S-0.5SV10
FX20-120S-0.5SV
FX20-120S-0.5SV10
FX20-140S-0.5SV
FX20-140S-0.5SV10
E2&,#*
8
6
Quantity
A
B
C
90
42.5
30
240
80
40
35
245
70
50
60
50
45
225
60
47.5
46
230
50
57.5 52.5 210
50
51.5 55.5 222
37.5 225
8
6
Unit: mm
Part No.
FX20-20P-0.5SV15
FX20-20P-0.5SV20
FX20-40P-0.5SV15
FX20-40P-0.5SV20
FX20-60P-0.5SV15
FX20-60P-0.5SV20
FX20-80P-0.5SV15
FX20-80P-0.5SV20
FX20-100P-0.5SV15
FX20-100P-0.5SV20
FX20-120P-0.5SV15
FX20-120P-0.5SV20
FX20-140P-0.5SV15
FX20-140P-0.5SV20
E27
E2&,#*
●Straight header
Quantity
A
B
C
90
42.5
30
240
80
40
35
245
70
50
60
50
45
225
60
47.5
46
230
50
57.5 52.5 210
50
51.5 55.5 222
37.5 225
(325)
(C)
(A)
(P=17.5)
(33.8)
(P=B)
(225)
(157.5)
Unit: mm
Unit: mm
Part No.
FX20- 20S-0.5SH
FX20- 40S-0.5SH
FX20- 60S-0.5SH
FX20- 80S-0.5SH
FX20-100S-0.5SH
FX20-120S-0.5SH
FX20-140S-0.5SH
Quantity
90
80
70
60
60
50
50
A
B
C
42.5 30 240
40
35 245
50 37.5 225
50
45 225
47.5 46 230
57.5 52.5 210
51.5 55.5 222
7
BRecommended Solder
●This temperature profile is based on the setting conditions shown below and is for reference only. For individual applications,
the temperature profile may vary in accordance with the conditions. Please confirm the profile before mounting.
(Peak temperature : MAX250℃)
260
240
220℃
220
200℃
Temperature (℃)
200
180
160
150℃
140
(90 to 120 seconds)
Preheating time(150 to 200℃)
Test PCB dimensions : 110 × 50 × 1.6mm
Material
: Glass epoxy
Solder composition
: Sn- 3 Ag- 0.5 Cu
Flux content
: 11 wt%
Stencil thickness
: 0.12mm, 0.15mm
Reflow count
: 2 times
Reflow area
: 220°C or more, 60 sec max.
Preheating unit
: 150 to 200°C, 90 to 120 sec
* The temperature profile may vary due to external
conditions such as the type of cream solder,
manufacturer, and board size. Please contact the
solder manufacturer for their specifications.
(within 60 seconds)
Soldering time
(220℃ or more)
BCleaning condition
●Organic solvent-based cleaning
Solvent type
IPA (Isopropyl alcohol)
Room temperature cleaning
Heated cleaning
●Water based cleaning
When using water based cleaning agents (including terpene, and alkali saponifiers), pay special attention to how the
cleaning agent will react to specific metals and plastics before selecting one of them. Various cleaning agent manufacturers
publish reaction tables for their cleaning agents. Do not leave connectors with moisture remaining on them.
●Caution when washing
The electrical performance may deteriorate if the flux or cleaning detergent is left on the connector after the cleaning.
Check thoroughly to ensure that there is no residue left on any of the surfaces.
BPrecautions
●Tolerance clearance on mating
The effective contact length of each product is 1.5mm. In the mated condition, the header and receptacle shall have a
clearance or gap between them of no more than 1mm.
Receptacle-side connector
Header-side connector
8
●Using excessive force when mating these connectors may result in damage and alter their performance. Although they
are designed with a prevention mechanism to resist incorrect insertion, do not forcibly mate them. Before mating the
connector, confirm the connector polarity as shown below.
C surface
Δ Mark (polarization mark)
C surface
* Mate them so that both C surfaces or both Δ marks
on the connector outer surface are aligned.
C surface
C surface
●Provide another form of support to the PCB. This connector was not designed to be the main form of support.
●Mating and un-mating with excessive prying force or rotating force may result in damage to the connector or contact failure.
If you have no choice but to mate and un-mate with prying force based on your usage environment, use a point as a pivot
shown by Δ mark in the figure below when you apply those forces. The point shall be a certain distance away from the
connector end and has equal or higher height of the mating height.
(Please refer to the guideline for details including the relationship between the pivot position and the connector position,
and usage examples.)
Minimum of
25 mm
Minimum of
30 mm
Stacking height or higher
●This connector has a floating structure, but the floating range may vary depending on the height of connector on the
header side (which has a floating mechanism).
Y direction (transverse direction)
X direction
(longitudinal direction)
X direction
X direction
h=15mm
Header-side
FX20-**P-0.5SV15
FX20-**P-0.5SV20
FX20-**P-0.5SV15
FX20-**P-0.5SV20
FX20-**P-0.5SV15
FX20-**P-0.5SV20
h=30mm
Receptacle-side
FX20-**S-0.5SV
FX20-**S-0.5SV10
FX20-**S-0.5SH
Stack height
15mm
20mm
25mm
30mm
Floating range
X direction (longitudinal direction)
0.6mm
0.8mm
0.6mm
0.8mm
0.6mm
0.8mm
0.6mm
0.6mm
0.6mm
0.6mm
0.6mm
0.6mm
9
●If the right angle type connector is positioned too far back from the recommended connector mounting position, the
1.
0m
m
M
AX
straight type connector will make contact with the PCB, and these may lead to damaged product or abnormal
connections.
The location of right angle type SMT pad should be set to within 1mm from the edge of the PCB, and the mounting
position should be set so that the clearance from the head of the connector to the edge of the PCB is 1.3mm or less.
10
1.3mm MAX
MEMO :
11
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
12
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
