DF37NC-34DS-0.4V(53)
    HRS(广濑)
DF37NC-34DS-0.4V(53) 数据手册
DF37 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Feb. 2022 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Features 1. Contributes to End Product Size Reduction 4.56mm DF37 10.22mm PCB Mounting Space Comparison( 40pos. , 0. 4mm Pitch, 0. 98mm Height) 2. High Contact Reliability DF37 has an effective mating length of 0. 25mm, one of the longest for connectors with a 1. 0mm mated height. The clear tactile click prevents incomplete mating and the 2- point contact design provides a high mating force. 3. Wide Mating Self- Alignment Range The guide ribs effectively utilize dead space, enabling a self alignment range of 0. 3mm. 4. Robust Design with Shock Absorbing Contacts Header Locks on both sides of the 2- point contact absorb stress on impact. 0.98 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Space- saving design with minimal connector depth and an automatic placement area that does not interfere with mounting( tested) . Depth:When mated 2. 98mm Header 1. 98mm 2.98mm DF30 Receptacle 5. Solder Wicking Prevention The receptacle with nickel barrier and the insert molder header prevent solder wicking. 2 Lock DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors 6. Contamination Protection Contact Area Insulator walls protect the contact areas against flux splatter or other physical particle contamination. The contact area is not exposed to the outside, preventing penetration of flux or other particles. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact Area 3 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Product Specifications Rated Current 0.3A Operating Temperature (Note 1) -35 to +85℃ Rated Voltage 30V AC/DC Storage Temperature (Note 2) -10 to +60℃ Operating Humidity Range 20-80% Storage Humidity Range (Note 2) 40-70% Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Conditions Insulation Resistance 50M Ω Min. 100V DC Withstanding Voltage No flashover or insulation breakdown 100V AC / 1minute Contact Resistance 100m Ω Max. 20mV AC, 1kHz, 1mA Vibration No electrical discontinuity of 1μ s or longer Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours, 3 axis Humidity Contact resistance : 100m Ω Max., Insulation resistance : 25M Ω Min. 96 hours at 40 ± 2℃ and humidity of 90 to 95% No damage or parts dislocation Temperature Cycle Contact resistance : 100m Ω Max., Insulation resistance : 50M Ω Min. -55℃ → +5 to +35℃ → +85℃ → +5 to +35℃ Time: 30 min. → 10 min. → 30 min. → 10 min. 5 cycles Mating Durability Contact resistance : 100m Ω Max. 10 cycles Solder Heat Resistance No deformation of components affecting performance Reflow : At the recommended temperature profile Hand solder : Solder iron temperature of 350℃ for 3 seconds Max. Note 1 : Includes temperature rise caused by current flow. Note 2 : Storage refers to long-term storage of unused items before they are mounted on the PCB. Operating temperature and humidity range apply when the product is not powered after PCB mounting and when temporarily stored during transportation. Materials / Finish Product Part Material Finish Remarks Receptacle Header Insulator LCP Color: Black UL94V-0 Contacts Phosphor Bronze Gold Plated - 4 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ■ Receptacle DF37 # (##) - # DS - 0.4 V (##) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❶ Series Name DF37 ❹ No. of Pos. ❷ Configuration NB : With Retention Tabs NC : Without Retention Tabs ❺ Connector Type DS : Receptacle ❻ Contact Pitch 0.4mm ❼ Termination Type V : SMT Vertical Mount ❽ Packaging (51) Stacking Height 0.98mm : Embossed Tape Packaging (8,000pcs per reel) (51) Stacking Height 1.5mm : Embossed Tape Packaging (5,000pcs per reel) (53) : Embossed Tape Packaging (1,000pcs per reel) ❸ Stacking Height Blank : 0.98mm 1.5 : 1.5mm ■ Header DF37 # - # DP - 0.4 V (##) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name DF37 ❺ Contact Pitch 0.4mm ❷ Configuration B : With Retention Tabs C : Without Retention Tabs ❻ Termination Type V : SMT Vertical Mount ❸ No. of Pos. ❼ Packaging ❹ Connector Type (51) : Embossed Tape Packaging (8,000pcs per reel) (53) : Embossed Tape Packaging (1,000pcs per reel) DP : Double Row Header 5 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Receptacle (Stacking Height=0.98mm) 2.98 2.32 P=0.4 A B Vacuum pick-up area : C 0.08 0.98 0.15 ■ Recommended PCB Layout DF37NC Without Retention Tabs P=0.4±0.02 B±0.02 0 2.02 -0.05 3.28+0.05 0 2.02-00.05 3.28 +0.05 0 P=0.4±0.02 E+0.05 0 0 D -0.05 B±0.02 1.1+0.05 0 DF37NB With Retention Tabs 0.23±0.02 0.23±0.02 ■ Recommended Metal Mask Dimensions 1.1+0.05 0 P=0.4±0.02 D -00.05 B±0.02 P=0.4±0.02 0.23±0.01 2.28±0.01 DF37NC Without Retention Tabs E +0.05 0 3.28±0.01 DF37NB With Retention Tabs 3.28±0.01 2.28±0.01 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.96 (With Retention Tabs only) 0.23±0.01 6 B±0.02 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● With Retention Tabs Unit : mm Part No. HRS No. No. of Pos. A B C D E DF37NB-10DS-0.4V(##) CL0684-3301-6-## 10 4.22 1.6 0.8 3.7 4.46 DF37NB-16DS-0.4V(##) CL0684-3302-9-## 16 5.42 2.8 1.2 4.9 5.66 DF37NB-20DS-0.4V(##) CL0684-3303-1-## 20 6.22 3.6 1.6 5.7 6.46 DF37NB-24DS-0.4V(##) CL0684-3304-4-## 24 7.02 4.4 6.5 7.26 DF37NB-30DS-0.4V(##) CL0684-3305-7-## 30 8.22 5.6 7.7 8.46 DF37NB-34DS-0.4V(##) CL0684-3082-4-## 34 9.02 6.4 8.5 9.26 DF37NB-40DS-0.4V(##) CL0684-3306-0-## 40 10.22 7.6 9.7 10.46 DF37NB-44DS-0.4V(##) CL0684-3407-7-## 44 11.02 8.4 10.5 11.26 DF37NB-50DS-0.4V(##) CL0684-3307-2-## 50 12.22 9.6 11.7 12.46 DF37NB-60DS-0.4V(##) CL0684-3308-5-## 60 14.22 11.6 3.2 13.7 14.46 DF37NB-70DS-0.4V(##) CL0684-3409-2-## 70 16.22 13.6 3.6 15.7 16.46 ● 2 2.4 2.8 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 8,000pcs per reel Without Retention Tabs Unit : mm HRS No. No. of Pos. A B C DF37NC-10DS-0.4V(##) CL0684-3309-8-## 10 4.22 1.6 0.8 DF37NC-16DS-0.4V(##) CL0684-3310-7-## 16 5.42 2.8 1.2 DF37NC-20DS-0.4V(##) CL0684-3311-0-## 20 6.22 3.6 1.6 DF37NC-24DS-0.4V(##) CL0684-3312-2-## 24 7.02 4.4 DF37NC-30DS-0.4V(##) CL0684-3313-5-## 30 8.22 5.6 DF37NC-34DS-0.4V(##) CL0684-3083-7-## 34 9.02 6.4 DF37NC-40DS-0.4V(##) CL0684-3314-8-## 40 10.22 7.6 DF37NC-44DS-0.4V(##) CL0684-3324-1-## 44 11.02 8.4 DF37NC-50DS-0.4V(##) CL0684-3315-0-## 50 12.22 9.6 DF37NC-60DS-0.4V(##) CL0684-3316-3-## 60 14.22 11.6 3.2 DF37NC-70DS-0.4V(##) CL0684-3084-0-## 70 16.22 13.6 3.6 Part No. 1,000pcs per reel Note 1 : The position of the HRS and CAV marks may differ from the diagram. Note 2 : This connector is NOT polarized. 7 Purchase Unit (##) : (51) Purchase Unit (##) : (53) 8,000pcs per reel 1,000pcs. per reel 2 2.4 2.8 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Receptacle (Stacking Height=1.5mm) 2.98 2.32 P=0.4 A B Vacuum pick-up area : C 1.5 0.08 0.15 ■ Recommended PCB Layout P=0.4±0.02 B±0.02 2.02-00.05 2.02-00.05 DF37NC Without Retention Tabs 3.28 +0.05 0 P=0.4±0.02 E+0.05 0 0 D -0.05 B±0.02 1.1+0.05 0 DF37NB With Retention Tabs 3.28 +0.05 0 0.23±0.02 0.23±0.02 ■ Recommended Metal Mask Dimensions DF37NC Without Retention Tabs 3.28±0.01 P=0.4±0.02 0.23±0.01 2.28±0.01 P=0.4±0.02 E+0.05 0 0 D -0.05 B±0.02 1.1+0.05 0 DF37NB With Retention Tabs 3.28±0.01 2.28±0.01 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.96 (With Retention Tabs Only) 0.23±0.01 8 B±0.02 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors ● With Retention Tabs Part No. HRS No. No. of Pos. A B C D E Purchase Unit (##) : (51) Purchase Unit (##) : (53) DF37NB(1.5)-24DS-0.4V(##) CL0684-3602-2-## 24 7.02 4.4 2 6.5 7.26 5,000pcs per reel 1,000pcs per reel ● Without Retention Tabs Unit : mm HRS No. No. of Pos. A B DF37NC(1.5)-24DS-0.4V(##) CL0684-3603-5-## 24 7.02 4.4 DF37NC(1.5)-30DS-0.4V(##) CL0684-3604-8-## 30 8.22 5.6 DF37NC(1.5)-34DS-0.4V(##) CL0684-3618-0-## 34 9.02 6.4 DF37NC(1.5)-40DS-0.4V(##) CL0684-3606-3-## 40 10.22 7.6 DF37NC(1.5)-50DS-0.4V(##) CL0684-3610-0-## 50 12.22 9.6 2.8 DF37NC(1.5)-60DS-0.4V(##) CL0684-3613-9-## 60 14.22 11.6 3.2 DF37NC(1.5)-70DS-0.4V(##) CL0684-3614-1-## 70 16.22 13.6 3.6 Part No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Note 1 : The position of the HRS and CAV marks may differ from the diagram. Note 2 : This connector is NOT polarized. 9 C Purchase Unit (##) : (51) Purchase Unit (##) : (53) 5,000pcs per reel 1,000pcs per reel 2 2.4 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Header 1.98 1.46 P=0.4 A B Vacuum pick-up area : C 0.08 ■ Recommended PCB Layout Without Retention Tabs E+0.05 0 0 D -0.05 B±0.02 P=0.4±0.02 2.28 +0.05 0 0.82-00.05 2.28 +0.05 0 0.82-00.05 B±0.02 P=0.4±0.02 0.68 +0.05 0 With Retention Tabs 0.23±0.02 0.23±0.02 ■ Recommended Metal Mask Dimensions E+0.05 0 0 D -0.05 Without Retention Tabs B±0.02 P=0.4±0.02 2.28±0.01 1.26±0.01 B±0.02 P=0.4±0.02 0.68+0.05 0 With Retention Tabs 2.28±0.01 1.26±0.01 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.76 0.15 0.23±0.02 0.23±0.02 10 0.58 (With Retention Tabs Only) DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ● With Retention Tabs Unit : mm Part No. HRS No. No. of Pos. A B C D E DF37B-10DP-0.4V(##) CL0684-3037-0-## 10 3.14 1.6 0.8 2.62 3.38 DF37B-16DP-0.4V(##) CL0684-3057-7-## 16 4.34 2.8 1.2 3.82 4.58 DF37B-20DP-0.4V(##) CL0684-3008-1-## 20 5.17 3.6 1.6 4.62 5.38 DF37B-24DP-0.4V(##) CL0684-3009-4-## 24 5.94 4.4 5.42 6.18 DF37B-30DP-0.4V(##) CL0684-3010-3-## 30 7.14 5.6 6.62 7.38 DF37B-34DP-0.4V(##) CL0684-3064-2-## 34 7.94 6.4 7.42 8.18 DF37B-40DP-0.4V(##) CL0684-3011-6-## 40 9.14 7.6 8.62 9.38 DF37B-44DP-0.4V(##) CL0684-3408-0-## 44 9.94 8.4 9.42 10.18 DF37B-50DP-0.4V(##) CL0684-3012-9-## 50 11.14 9.6 10.62 11.38 DF37B-60DP-0.4V(##) CL0684-3013-1-## 60 13.14 11.6 3.2 12.62 13.38 DF37B-70DP-0.4V(##) CL0684-3014-4-## 70 15.14 13.6 3.6 14.62 15.38 ● 2 2.4 2.8 Purchase Unit Purchase Unit (##) : (51) (##) : (53) 8,000pcs per reel Without Retention Tabs Unit : mm HRS No. No. of Pos. A B C DF37C-10DP-0.4V(##) CL0684-3039-5-## 10 3.14 1.6 0.8 DF37C-16DP-0.4V(##) CL0684-3058-0-## 16 4.34 2.8 1.2 DF37C-20DP-0.4V(##) CL0684-3024-8-## 20 5.17 3.6 1.6 DF37C-24DP-0.4V(##) CL0684-3025-0-## 24 5.94 4.4 DF37C-30DP-0.4V(##) CL0684-3026-3-## 30 7.14 5.6 DF37C-34DP-0.4V(##) CL0684-3085-2-## 34 7.94 6.4 DF37C-40DP-0.4V(##) CL0684-3027-6-## 40 9.14 7.6 DF37C-44DP-0.4V(##) CL0684-3089-3-## 44 9.94 8.4 DF37C-50DP-0.4V(##) CL0684-3028-9-## 50 11.14 9.6 DF37C-60DP-0.4V(##) CL0684-3029-1-## 60 13.14 11.6 3.2 DF37C-70DP-0.4V(##) CL0684-3030-0-## 70 15.14 13.6 3.6 Part No. 1,000pcs per reel Note 1 : The position of the HRS and CAV marks may differ from the diagram. Note 2 : This connector is NOT polarized. 11 Purchase Unit (##) : (51) Purchase Unit (##) : (53) 8,000pcs per reel 1,000pcs per reel 2 2.4 2.8 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Embossed Carrier Tape Dimensions (JIS C 0806 Standard) Receptacle (Less Than 70 Positions) 2±0.1 4±0.1 F E±0.15 0.3±0.1 F-F G Unreeling Direction G-G F G Receptacle (70 Positions) 8±0.1 2±0.14±0.1 E±0.15 0.3±0.1 28.4±0.1 B±0.3 A±0.1 .1 +00 F F-F 1.75±0.1 ● .5 φ1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.3 A±0.1 .1 +0 0 5 1. φ 8±0.1 1.75±0.1 ● G Unreeling Direction G-G G F 12 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Reel Dimensions Unreeling Direction φ80±1 Part Number Label φ380±2 φ1 3± 0.2 ● Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C±0.5 D±1 Unit : mm Part No. A B C D E 7.5 16 17.5 21.5 DF37#-10DS-0.4V(##) DF37#-16DS-0.4V(##) DF37#-20DS-0.4V(##) DF37#-24DS-0.4V(##) DF37#-30DS-0.4V(##) 1.23 DF37#-34DS-0.4V(##) DF37#-40DS-0.4V(##) DF37#-44DS-0.4V(##) 11.5 24 25.5 29.5 14.2 32 33.5 37.5 DF37#-50DS-0.4V(##) DF37#-60DS-0.4V(##) DF37#-70DS-0.4V(##) # : NB or NC Tape and reel packaging (8,000pcs per reel). Unit : mm Part No. DF37#(1.5)-24DS-0.4V(##) A B C D 7.5 16 17.5 21.5 11.5 24 25.5 29.5 14.2 32 33.5 37.5 E DF37#(1.5)-30DS-0.4V(##) DF37#(1.5)-34DS-0.4V(##) DF37#(1.5)-40DS-0.4V(##) DF37#(1.5)-50DS-0.4V(##) DF37#(1.5)-60DS-0.4V(##) DF37#(1.5)-70DS-0.4V(##) # : NB or NC Tape and reel packaging (5,000pcs per reel). 13 1.75 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Header E Unreeling Direction E F-F Reel Dimensions Unreeling Direction φ80±1 Part Number Label φ380±2 ● F φ1 3± 0.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. F E-E 1±0.15 0.3±0.1 B±0.3 2±0.1 4±0.1 A±0.1 .1 +00 .5 φ1 8±0.1 1.75±0.1 ● C±0.5 D±1 Unit : mm Part No. DF37#-10DP-0.4V(##) A B C D 5.5 12 13.5 17.5 7.5 16 17.5 21.5 11.5 24 25.5 29.5 DF37#-16DP-0.4V(##) DF37#-20DP-0.4V(##) DF37#-24DP-0.4V(##) DF37#-30DP-0.4V(##) DF37#-34DP-0.4V(##) DF37#-40DP-0.4V(##) DF37#-44DP-0.4V(##) DF37#-50DP-0.4V(##) DF37#-60DP-0.4V(##) DF37#-70DP-0.4V(##) # : B, C Tape and reel packaging (8,000pcs per reel). 14 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Usage Precautions 1. Recommended Temperature Profile Temperature (℃) 250℃ 250 220℃ 200 60sec Max. 180℃ 150 150℃ 90~120sec 100 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) 【Conditions】 1.Peak Temperature: Maximum of 250℃ 2.Heating : 220℃ min. for 60 sec. max. 3.Preheating : 150 to 180℃ , 90 to 120 sec. 4.Number of Reflow Cycles : 2 cycles max. Note:The temperature refers to the surface temperature of the board near the connector lead. 2. Recommended Manual Soldering Conditions Soldering Iron Temperature : 340 ± 10℃ ; Soldering Time : within 3 seconds 3. Recommended Metal Mask Thickness and Open Area to PCB Pattern Area Ratio Thickness : 0.12mm Open area ratio : Receptacle Side : 80%(NB/NC), Plug Side : 70% 4. Board Warpage Max. of 0.02mm at the center in reference to both ends of the connector 5. Cleaning Cleaning is not recommended. If you clean this product, please evaluate its performance before using it. (Cleaning may impair the mating/unmating properties and lower resistance to environmental factors) 6. Precautions ■ Be careful when mating/unmating the connector when it is not mounted on the PCB as it may cause damage/deformation to contacts. ■ Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc. ■ Excessive prying during unmating/mating may result in damage.. ■ In the case of hand soldering, please do not apply any flux which could cause flux wicking. ■ This product may have slight color differences due to production lot variability, but this does not affect the performance. ■ Please refer to the following page for handling precautions when inserting and removing. ■ Because the product can disengage if dropped (or other impact), or by FPC routing, it is advised to secure the mated connectors to the board with housings and cushioning materials. 15 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Handling Precautions for Connector Mating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) When aligning, look for the guide port without applying excessive force. If excessive force is applied, the housing may be damaged or shaved resulting in poor contact resistance, so please be careful. 2) When fully aligned the connectors are parallel to each other with restricted longitudinal and lateral movement. Mate them parallel to each other. 16 DF37 Series/0.4mm Pitch, 0.98/1.5mm Stacking Height, FPC-to-Board Connectors Handling Precautions for Connector Removal 1) Pull out the connectors parallel to each other. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2) If the connector cannot be removed by pulling it out parallel to its mating partner, it can be removed by extracting the connector diagonally in the direction of the pitch as shown in the below figure. However, there is a risk that the connector may break if the FPC is not rigid. Please confirm the FPC rigidity at the time of trial production. 3) Do not remove the connector by pulling from the FPC corner as shown below. Pulling from the FPC corner may result in connector and contact damage. 4) Insufficient FPC rigidity may result in connector breakage as shown in the below figure. Please check the repeated mechanical operation of the FPC before use. Please request for evaluation results of FPC rigidity and various items. While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 2/ 2022. Contents are subject to change without notice for the purpose of improvements. 17
物料型号: - 系列名称:DF37 - 引脚间距:0.4mm - 堆叠高度:0.98mm/1.5mm - FPC到板连接器
器件简介: - 有助于产品尺寸减小,具有最小的连接器深度和不干扰安装的自动放置区域。 - 高接触可靠性,DF37具有0.25mm的有效接合长度,是1.0mm接合高度连接器中最长之一。 - 宽接合自对准范围,导向肋有效利用死区,实现0.3mm的自对准范围。 - 具有减震功能的坚固设计,两侧的锁扣可以吸收冲击力。 - 防焊桥接设计,带有镍屏障的插座和插入成型的头文件防止焊锡桥接。
参数特性: - 额定电流:0.3A - 额定电压:30V AC/DC - 操作温度范围:-35至+85°C - 绝缘电阻:最小50MΩ - 耐电压:无闪络或绝缘击穿,100V AC/1分钟 - 接触电阻:最大100mΩ
功能详解: - 插座带有防污染设计,绝缘体壁防止焊剂飞溅或其他物理颗粒污染接触区域。 - 接触区域不暴露在外,防止焊剂或其他颗粒渗透。
应用信息: - 该连接器有助于节省空间,适用于需要小型化的产品。
封装信息: - 提供了详细的产品编号结构,包括系列名称、引脚数量、配置、接触间距、连接器类型、端接类型和堆叠高度等。 - 提供了推荐的PCB布局和金属掩膜尺寸。
DF37NC-34DS-0.4V(53) 价格&库存
很抱歉,暂时无法提供与“DF37NC-34DS-0.4V(53)”相匹配的价格&库存,您可以联系我们找货
  • 1+10.738751+1.29494
  • 10+9.0718610+1.09394
  • 25+8.7035825+1.04953
  • 50+8.5162350+1.02694
  • 100+8.14702100+0.98242
  • 250+7.40604250+0.89307
  • 500+6.66544500+0.80376
库存:1350
  • 1000+4.326471000+0.52171
  • 2000+4.056102000+0.48911
  • 3000+3.920903000+0.47281
  • 5000+3.785695000+0.45650
  • 10000+3.5964110000+0.43368
库存:1350
