P136-000
P136-000
    TRIPPLITE
    P136-000
P136-000 数据手册
DisplayPort to HDMI Adapter Video Converter (M/F), 6-in. (15.24 cm) MODEL NUMBER: P136-000 Highlights ● Connect a HDMI monitor to a computer with a Displayport output ● Displayport Male to HDMI Female, 6 in. ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● Supports 7.1 Audio Surround Sound ● HDCP compliant ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode port System Requirements Connect an HDMI monitor to a computer with a Displayport output connection. ● Computer with a Displayport output ● Display with a HDMI port ● The P136-000 supports transmission of an audio signal as long as it is supported by the Displayport source. Check the documentation for your Displayport source for compatibility. ● The P136-000 is a Passive adapter, and requires that the connected computer has a DP++ ( Displayport ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your Displayport source for compatibility. Features ● Connect a HDMI monitor to a computer with a Displayport output ● Displayport Male to HDMI Female; fully molded ends ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● The P136-000 supports transmission of an audio signal as long as it is supported by the Displayport source. Check the documentation for your Displayport source for compatibility. ● The P136-000 is a Passive adapter, and requires that the connected computer has a DP++ ( Displayport ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your Displayport source for compatibility. ● Supports 7.1 Audio Surround Sound ● HDCP compliant Package Includes ● Specifications OVERVIEW UPC Code 037332148056 Technology HDMI; DisplayPort PHYSICAL Color Black 1/2 DisplayPort to HDMI Converter Adapter (M/F), 6 in. Cable Length (in.) 6 Cable Length (cm) 15.24 Shipping Dimensions (hwd / in.) 7.00 x 9.00 x 0.50 Shipping Dimensions (hwd / cm) 17.78 x 22.86 x 1.27 Shipping Weight (lbs.) 0.09 Shipping Weight (kg) 0.04 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
P136-000 价格&库存
很抱歉,暂时无法提供与“P136-000”相匹配的价格&库存,您可以联系我们找货
