HARTING
Cable 8-wire, Cat. 6A FRNC
Han® 24 Industrial
HPR enlarged
Industrial Cable
Advantages
General
• Suitable for generic cabling Category 6A /
Class EA according ISO/IE11801
respectively prEN 50173-1 especially for
fixed installation
This high-speed data cable was designed for fixed installation
in industrial premises and it’s especially suitable for connections between distribution cabinets and industrial outlets.
• Qualified for transmission up to 10GigaBit
Ethernet 10Gbase-T acc. IEEE802.3an
The four pair / eight wire PIMF-construction allows the
transmission of IT digital and analogue signals like Ethernet
10/100Mbit/s, 1/10GigaBit/s, video and voice services as well
as IP-based data services.
• Based on solid copper wires 23AWG delivers
full 100m channel performance up to 500MHz
• Applicable for industrial premises
• High EMC capability based on the PIMF
construction
• Flame retardant, halogen free and RoHS
compliant
It delivers all characteristics to construct a Generic cabling
system according ISO/IEC 24702:2006 respectively EN
50173-3:2007. Maximum channel length specified up to
100m (transmission channel class EA)
Transmission performance meets Cat.6A specification up
to 500MHz for 10GigaBit Ethernet transmission according
IEEE802.3an.
The cable is fully screened (each pair in metal foil plus an
overall wire braid) and guaranties a very protective signal
transmission and high EMC performance.
FRNC compound is used as jacket material. The cable is
flame retardant, halogen free and RoHS compliant.
Identification
Part number
Drawing
Industrial Ethernet Cable
8-wires, Cat. 6A FRNC
500 m reel
09 45 600 0650
1000 m reel
09 45 600 0660
Wire: bare copper, AWG23/1
Insulation: PE, Ø max. 1.4 mm
Pairs: Aluminium-bonded polyester tape
Overall screen: tinned copper wire braid
Outer sheath: FRNC Compound, flame
Color code: whbu/bu, whor/or, whgn/gn, whbr/br
Color of outer sheath: rape yellow, RAL 1021
Overall diameter: approx. 7.4 mm
All data given is in line with the actual state of art and therefore not binding.
HARTING reserves the right to modify designs without giving the relevant reasons.
HARTING Industrial Cable 8-wire, Cat. 6A FRNC
Technical Characteristics
Performance
Mechanical Characteristics
Minimal bending radius
Category 6A according to EN 50288-10-1
During installation: 8 x diameter
After installation: 4 x diameter
Tensile strength
Crush
max. 110 N
1000 N/100mm
Electrical Characteristics at 20°C
Transfer impedance at 10 MHz
Coupling attenuation up to 1000 MHz
DC loop resistance
Insulation resistance
Mutual capacitance
Capacitive coupling
Signal velocity
Propagation delay
Skew at 100 MHz
Characteristic impedance at 100 MHz
Test voltage
Operating voltage
5 m Ohm/km
80 dB
max. 75 Ohm/km
min. 5 GOhm x km
42 pF/m
1500 pF/km
0.80 c
420 ns/100m
7 ns/100m
100 Ohm +/- 5 Ohm
1000V
max. 125V
Chemical Characteristics
Flame retardant
Halogen free
Smoke density
Fire load
Free of hazardous substances
IEC 60332-1-2
IEC 60754-2
IEC 61034
0.60 MJ/m
RoHS 2002/95/EG
Thermal Characteristics
Temperature range for fixed installation
Temperature range for mobile operation
- 20° C to + 60° C
0° C to + 50° C
Printing
HARTING INDUSTRIAL INSTALLATION CABLE S/FTP CAT
6 FRNC 4x2xAWG23/1 094560001080000 $Charge Number$
$meter marking$
Weight about
55 kg/km
Frequency
MHz
Attenuation
dB/100m
NEXT
dB
PS NEXT
dB
ACR
dB@100m
PS ACR
dB@100m
EL FEXT
dB@100m
PS EL FEXT
dB@100m
Return Loss
dB
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
typ.
Cat 6
max*
1
1.9
2
95
66
92
64
93
64
90
62
91
66
88
63
26
10
5.2
5.9
90
59
87
57
85
53
82
51
96
57
93
54
35.9
25
100
17.7
19
75
44
72
42
57
25
54
23
90
42
87
39
37.2
20.1
200
26.4
27.5
68
40
65
38
42
12
39
10
78
38
75
35
33.1
18
250
29.9
31
66
38
63
36
36
7
33
5
75
36
72
33
30.5
17.3
300
31.9
34.2
65
37
62
35
33
3
30
1
72
35
69
32
29.9
17.3
450
38.9
42.7
63
35
60
33
24
-8
21
-10
69
33
66
30
28.9
17.3
500
41.2
45.3
61
34
58
32
17
-13
66
32
63
29
28.3
17.3
600
46.2
57
54
11
8
60
57
27.2
700
51.4
54
51
3
53
26.2
* EN 50288-10-1
2007-10-08
HARTING Electric GmbH & Co. KG
Wilhelm-Harting-Straße 1 | D-32339 Espelkamp | Postfach 14 73 | D-32328 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-688 | HARTING.Electric@HARTING.com | www.HARTING.com
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
HARTING:
09456000650
很抱歉,暂时无法提供与“09456000650”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+75.70766500+9.79395
