M33360SL002
M33360SL002
    ALPHAWIRE(阿尔法电线)
    CABLE60COND22AWGSLATE500'
M33360SL002 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. M33360 Construction Diameters (In) 1) Component 1 60 X 1 COND a) Conductor 22 (7/30) AWG TC 0.030 b) Insulation 0.010" Wall, Nom. PVC, Semi Rigid 0.050 (1) Color Code Alpha Wire Color Code D Cond Color Cond Color Cond Color 1 BLACK 21 WHITE/BROWN 41 WHITE/GREEN/RED 2 RED 22 WHITE/ORANGE 42 WHITE/GREEN/GREE N 3 WHITE 23 WHITE/SLATE 43 WHITE/GREEN/BLUE 4 GREEN 24 WHITE/VIOLET 44 WHITE/GREEN/BRO WN 5 ORANGE 25 WHITE/BLACK/RED 45 WHITE/GREEN/VIOL ET 6 BLUE 26 WHITE/BLACK/GREE 46 N WHITE/BLUE/BLACK 7 BROWN 27 WHITE/BLACK/YELL OW WHITE/BLUE/RED 8 YELLOW 28 WHITE/BLACK/BLUE 48 WHITE/BLUE/GREEN 9 VIOLET 29 WHITE/BLACK/BROW 49 N WHITE/BLUE/BLUE 10 SLATE 30 WHITE/BLACK/ORAN 50 GE WHITE/BLUE/BROWN 11 PINK 31 51 WHITE/BLUE/VIOLET 12 TAN 32 WHITE/BLACK/VIOLE 52 T WHITE/BROWN/BLAC K 13 RED/GREEN 33 WHITE/BLACK/BLAC K 53 WHITE/BROWN/RED 14 RED/YELLOW 34 WHITE/RED/BLACK 54 WHITE/BROWN/GRE EN 15 RED/BLACK 35 WHITE/RED/RED 55 16 WHITE/BLACK 36 WHITE/RED/GREEN 56 WHITE/BROWN/BRO WN 17 WHITE/RED 37 WHITE/RED/BLUE 57 WHITE/BROWN/VIOL ET 18 WHITE/GREEN 38 WHITE/RED/BROWN 58 WHITE/VIOLET/RED 19 WHITE/YELLOW 39 WHITE/RED/VIOLET 59 WHITE/VIOLET/GREE N 20 WHITE/BLUE 40 WHITE/GREEN/BLAC 60 K WHITE/VIOLET/BLUE 2) Cable Assembly 60 Components Cabled WHITE/BLACK/SLATE 47 WHITE/BROWN/BLUE a) Twists: 1.8 Twists/foot (min) b) Core Wrap Clear Mylar Tape, 25% Overlap, Min. 3) Jacket 0.035" Wall, Nom.,PVC a) Color(s) SLATE b) Print ALPHA WIRE-* P/N M33360 60C 22 AWG EXXXXXXX 75C CMG (UL) C(UL) OR AWM STYLE 2576 CE ROHS * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] 0.523 (0.550 Max.) Applicable Specifications 1) UL 2) CSA International CMG 75°C AWM/STYLE 2576 80°C / 150 VRMS C(UL) TYPE CMG 75°C FT4 3) CE: EU Low Voltage Directive 2006/95/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 80°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 330 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Capacitance 23.5 pf/ft @1 kHz, Nominal Conductor to Conductor 3) Inductance 0.18 µH/ft, Nominal 4) Conductor DCR 16.5 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 30 x 14 x 12 Continuous length b) 500 FT 20 x 11 x 8 Continuous length c) 100 FT 16 x 11 x 8 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: M33360 M33360 , RoHS-Compliant Commencing With 1/1/2006 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/13/2013
M33360SL002 价格&库存
很抱歉,暂时无法提供与“M33360SL002”相匹配的价格&库存,您可以联系我们找货
