5717/1601BK001
5717/1601BK001
    ALPHAWIRE(阿尔法电线)
    CABLE2COND16AWGBLKSHLD1000'
5717/1601BK001 数据手册
Manhattan™ Electrical Cable Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 141 Manhattan™ Electrical Cable Signal transmission made reliable A lpha Wire’s Manhattan brand has been a trusted and reliable source of cable for over 60 years. Whether you need something as simple as a power cord or a cable that can maintain audio-video signal integrity in a noisy environment, you’ll find the breadth and depth of products to ensure an optimum solution to your application. • • • • • • • • • •  udio/video A Computer Thermocouple Control Plenum Coaxial Cords/cordage High temperature Security and data Instrumentation Instrumentation cable Maintain the integrity of analog and digital signals with our broad product portfolio of single and multiple pair shielded and unshielded products. Choose the correct number of conductors, gauge, insulation, shielding, jacket material, UL/CSA/ NEC approvals, and any other parameters to find the right cable for your application. We offer the widest range of shielded and unshielded configurations to satisfy applications including traditional RS-232 and All our cords are UL Listed and CSA Certified; we also offer a wide range of CENELEC-approved products for international use. Options include two- and threeconductor cords, shielded or unshielded, stripped and terminated cable ends, straight or retractile cords, and all common plug and receptacle configurations. We offer UL style TC in a variety of conductor counts, gauges, and shielding options, all with durable PVC/nylon insulation and PVC jackets. We also offer MIL-DTL-16878 cables with 600 V and 1000 V ratings. Alpha Wire’s Manhattan brand of high-temperature cables are available for temperatures ranging from 150°C to 540°C. We make it easy for you select the right cable to meet the demanding hightemperature requirements for control and power applications. Plenum cable Security and data We offer a full range of cables for control, computer interconnections, security, alarms, and building energy management systems in a variety of plenum-rated insulations and jackets. Count on Alpha Wire for a complete product family of security and data cables, optimized for security video, data, and monitoring applications. Thermocouple cable Coaxial cable Computer cable Cords/cordsets High-temperature cable Control cable Audio/video cable 142 RS-422 interfaces, point-of-sale equipment, and modems and multiplexers. For extended distances, we offer cables with very low capacitance. For a complete range of 50, 75, 93, and 100 ohm coaxial, twinaxial, and triaxial cables, we offer a wide range of insulations and jackets meeting the requirements of military specifications and regulatory agencies such as UL and CSA. You can find the perfect Manhattan brand thermocouple cable based on conductor combinations JX, KX, EX, and SX, as well as insulations suited for applications up to 200°C, for quality and accurate temperature measurement. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, SR-PVC/PVC, PVC UL AWM 2509, UL CMG, PVC Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Color Code J UL AWM 2464, 2509, 2576, UL CM, CMG CSA CM, CMG FT4 Part No. Conductors M13302 2 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM, CMG) Conductor Color Coding • See tables Materials • S  tranded tinned copper conductors • PVC or semirigid PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Jacket Thickness Inch mm 0.025 0.64 UL AWM 2576, UL CM, PVC Insulation (150 V) 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Applications • U  nbalanced intercom and sound systems • Remote circuit control • Low-voltage circuits Nominal Diameter Inch mm 0.174 4.42 Part No. Conductors M13303 M13304 M13305 M13306 M13307 M13308 M13309 M13310 M13312 M13315 M13320 M13325 M13330 M13340 M13350 3 4 5 6 7 8 9 10 12 15 20 25 30 40 50 Nominal Diameter Inch mm 0.172 4.37 0.185 4.70 0.200 5.08 0.215 5.46 0.215 5.46 0.230 5.84 0.246 6.25 0.264 6.71 0.272 6.91 0.310 7.87 0.342 8.69 0.380 9.65 0.401 10.19 0.445 11.30 0.498 12.65 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.045 1.14 Color Code Black, Green, Red O O O O O O O O F F F F F F UL AWM 2464, UL CM, PVC Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.013 (0.33 mm) Part No. Conductors M13404 M13405 M13407 M13409 M13412 M13415 4 5 7 9 12 15 Nominal Diameter Inch mm 0.219 5.56 0.238 6.05 0.257 6.53 0.303 7.70 0.336 8.53 0.374 9.50 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.040 1.02 Color Code O O O O O F UL AWM 2509, UL CMG, PVC Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Color Code J Part No. Conductors M13402 2 Nominal Diameter Inch mm 0.180 4.57 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.020 0.51 143 Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, SR-PVC, PVC UL AWM 2509, UL CMG, PVC Insulation 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Color Code J UL AWM 2463, 2464, 2509, 2576, 2598 UL CM, CMG UL CL2, CL3 CSA CM, CMG FT4 Applications • U  nbalanced intercom and sound systems • Remote circuit control • Low-voltage circuits Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM, CMG, CL2, CL3) Part No. Conductors M13502 2 Nominal Diameter Inch mm 0.198 5.03 Jacket Thickness Inch mm 0.020 0.51 UL AWM 2598, UL CM, PVC Insulation 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.018 (0.46 mm) Part No. Conductors M13503 M13504 M13505 M13507 M13509 M13512 M13515 M13519 M13525 3 4 5 7 9 12 15 19 25 Nominal Diameter Inch mm 0.249 6.32 0.272 6.91 0.297 7.54 0.333 8.46 0.387 9.83 0.437 11.10 0.485 12.32 0.520 13.21 0.636 16.15 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.037 0.94 0.037 0.94 0.040 1.02 0.045 1.14 0.045 1.14 0.060 1.52 Color Code O O O O O F F F F UL AWM 2576, UL CM, PVC Insulation Conductor Color Coding 16 AWG (1.32 mm2) • See tables Stranding: 19/0.0117 (19 x 0.30 mm) Color Code F Materials • S  tranded tinned copper conductors • PVC or semirigid PVC insulation • Slate PVC jacket Part No. Conductors M13572 M13574 2 4 Nominal Diameter Inch mm 0.274 6.96 0.378 9.60 (Minimums may apply) Insulation Thickness Inch mm 0.023 0.58 0.030 0.76 UL AWM 2463, UL CL2 or CL3, PVC Insulation 14 AWG (2.08 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.045 1.14 Stranding: 19/0.0147 (19 x 0.37 mm) Insulation thickness: 0.032 (0.81 mm) Color Code F Part No. Conductors M13582 M13584 2 4 Nominal Diameter Inch mm 0.346 8.79 0.404 10.26 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 Approval CL2 CL3 UL AWM 2463, UL CL3, PVC Insulation 12 AWG (3.29 mm2) Stranding: 19/0.0185 (19 x 0.47 mm) Insulation thickness: 0.032 (0.81 mm) Color Code F 144 Part No. Conductors M13590 2 Nominal Diameter Inch mm 0.394 10.00 Jacket Thickness Inch mm 0.040 1.02 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, PVC, PVC 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.032 (0.81 mm) UL AWM 2463 (600 V) VW-1 Applications • U  nbalanced intercom and sound systems • Remote circuit control • Low-voltage circuits Part No. Conductors M3704 M3705 M3707 M3709 M3712 M3715 M3719 M3725 4 5 7 9 12 15 19 25 Nominal Diameter Inch mm 0.392 9.96 0.428 10.87 0.465 11.81 0.574 14.58 0.637 16.17 0.691 17.55 0.742 18.85 0.904 22.96 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 Operating Temperature • -20°C to +80°C Conductor Color Coding • Chart F (page 532) Materials • Stranded  tinned copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 145 Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V Manhattan™ Audio/Video Cable 300 V Braid Shield, Multiconductor, PE, PVC 24 AWG (0.20 mm2) Stranding: 10/34 (10 x 0.16 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2092, 2093, 2094 UL CM Part No. Conductors M1102 M1103 M1104 M1105 M1106 2 3 4 5 6 Nominal Diameter Inch mm 0.177 4.50 0.186 4.72 0.200 5.08 0.217 5.51 0.234 5.94 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2092 2093 2094 2094 2094 Applications 22 AWG (0.38 mm2) • S  ensing, recording, monitoring devices, and telemetry Operating Temperature • - 20°C to +75°C (CM) • -20°C to +60°C (AWM) Conductor Color Coding • Chart H (page 533) Materials • Stranded  tinned copper conductors • Polyethylene insulation • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 146 Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M1112 M1113 M1114 M1115 M1116 M1118 2 3 4 5 6 8 Nominal Diameter Inch mm 0.193 4.90 0.203 5.16 0.220 5.59 0.239 6.07 0.258 6.55 0.278 7.06 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2092 2093 2094 2094 2094 2094 20 AWG (0.52 mm2) Stranding: 26/34 (26 x 0.16 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M1122 M1123 M1124 M1125 M1126 M1128 M1130 M1132 M1135 M1140 2 3 4 5 6 8 10 12 15 20 Nominal Diameter Inch mm 0.229 5.82 0.246 6.25 0.264 6.71 0.285 7.24 0.306 7.77 0.328 8.33 0.375 9.53 0.386 9.80 0.417 10.59 0.464 11.79 Jacket Thickness Inch mm 0.032 0.81 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 UL AWM 2092 2093 2094 2094 2094 2094 2094 2094 2094 2094 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V Manhattan™ Audio/Video Cable 300 V Braid Shield, Multiconductor, PE, PVC 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2092, 2093, 2094 UL CM Part No. Conductors M1142 M1143 M1144 M1146 2 3 4 6 Applications • - 20°C to +75°C (CM) • -20°C to +60°C (AWM) Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 UL AWM 2092 2093 2094 2094 16 AWG (1.31 mm2) • S  ensing, recording, monitoring devices, and telemetry Operating Temperature Nominal Diameter Inch mm 0.253 6.43 0.265 6.73 0.286 7.26 0.333 8.46 Stranding: 65/34 (65 x 0.16 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M1162 M1163 M1164 2 3 4 Nominal Diameter Inch mm 0.277 7.04 0.291 7.39 0.308 7.82 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 UL AWM 2092 2093 2094 Conductor Color Coding • Chart H (page 533) Materials • Stranded  tinned copper conductors • Polyethylene insulation • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 147 Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield, Overall > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Overall, Multiconductor, PP, HDPE Direct Burial 20 AWG (0.51 mm2) Stranding: : 10/30 (10 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) UL AWM 2092, 2093, 2094 UL CM Applications • D  irect burial audio and data transmission Part No. Conductors M39047 M39048 M39049 M39050 2 3 10 15 Nominal Diameter Inch mm 0.193 4.90 0.202 5.13 0.319 8.10 0.363 9.22 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.040 1.02 0.045 1.14 Color Code O O O F Mutual capacitance: 22.2 pF/ft (72.8 pF/m) Ground capacitance: 40 pF/ft (131.2 pF/m) Except Part No. M39047: Mutual capacitance: 24.5 pF/ft (80.3 pF/m) Ground capacitance: 44 pF/ft (144.3 pF/m) Operating Temperature • -20°C to +80°C Conductor Color Coding • See table Materials • S  olid tinned copper conductors • Polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward 22 AWG (0.32 mm2) solid tinned copper drain wire • Black high-density polyethylene jacket Features • Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk (Minimums may apply) 148 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 350 V Manhattan™ Audio/Video Cable 350 V Individually Foil Shielded Pairs, Multipair, PP, HDPE Direct Burial 20 AWG (0.51 mm2) Stranding: 10/30 (10 x 0.25) Insulation thickness: 0.013 (0.33 mm) Part No. Pairs M39051 M39052 3 6 UL AWM 2092, 2093, 2094 UL CM Nominal Diameter Inch mm 0.336 8.53 0.446 11.33 Jacket Thickness Inch mm 0.040 1.02 0.045 1.14 Mutual capacitance: 24.5 pF/ft (80.3 pF/m) Ground capacitance: 44 pF/ft (144.3 pF/m) Applications • D  irect burial audio and data transmission Operating Temperature • -20°C to +80°C Conductor Color Coding • Chart K (page 529) Materials • Stranded  tinned copper conductors • Polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward 22 AWG (0.35 mm2) stranded tinned copper drain wire • Black high-density polyethylene jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 149 Cable > Manhattan > Audio/Video Cable > Multipair > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multipair, PVC, PVC AWM 2576, CMG 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) UL AWM 2464, 2576 (150 V) UL CMG CSA CMG FT4 (150 V) Applications • Speakers and sound systems Operating Temperature • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) Part No. Pairs M13001 M13002 M13003 M13004 M13005 M13006 M13008 M13009 M13013 M13019 M13027 1 2 3 4 5 6 8 9 13 19 27 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) • Chart K (page 529) Materials Part No. Pairs • Solid  or stranded tinned copper conductors • PVC insulation • Slate PVC jacket M13032 M13033 M13034 M13036 M13039 M13042 M13045 M13049 M13057 2 3 4 6 9 12 15 19 27 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.037 0.94 0.040 1.02 0.045 1.14 AWM 2576, CMG Conductor Color Coding Availability Nominal Diameter Inch mm 0.157 3.98 0.215 5.46 0.226 5.74 0.246 6.24 0.267 6.78 0.289 7.34 0.318 8.07 0.342 8.68 0.392 9.95 0.452 11.48 0.547 13.89 Nominal Diameter Inch mm 0.231 5.86 0.244 6.19 0.265 6.73 0.320 8.13 0.375 9.52 0.424 10.76 0.460 11.68 0.493 12.52 0.598 15.18 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.037 0.94 0.040 1.02 0.040 1.02 0.040 1.02 0.045 1.14 (Minimums may apply) 150 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multipair > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multipair, PVC, PVC AWM 2464, CMG 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2464, 2576 (150 V) UL CMG CSA CMG FT4 (150 V) Part No. Pairs M13063 M13066 M13069 M13072 3 6 9 15 18 AWG (0.81 mm2) • Speakers and sound systems • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • Chart K (page 529) Materials • Solid  or stranded tinned copper conductors • PVC insulation • Slate PVC jacket Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.040 1.02 AWM 2464, CMG Applications Operating Temperature Nominal Diameter Inch mm 0.224 5.68 0.284 7.21 0.328 8.33 0.405 10.28 Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs M13081 M13082 M13083 M13084 M13085 M13086 M13088 M13089 M13092 M13095 M13099 1 2 3 4 5 6 8 9 12 15 19 Nominal Diameter Inch mm 0.225 5.72 0.326 8.28 0.346 8.79 0.380 9.65 0.418 10.62 0.458 11.63 0.508 12.90 0.554 14.07 0.633 16.08 0.700 17.78 0.761 19.33 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.037 0.94 0.040 1.02 0.046 1.17 0.051 1.30 0.055 1.40 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 151 Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield, Overall > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Overall, Multiconductor, PE, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) 24 AWG (0.22 mm2) drain wire UL AWM 2092, 2093, 2094 UL CMG CSA CMG CSA FT4 Part No. Conductors M3222 M3223 M3224 2 3 4 Operating Temperature Part No. Conductors M3226 M3227 M3228 2 3 4 2092 2093 2094 Nominal Diameter Inch mm 0.171 4.34 0.181 4.60 0.197 5.00 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2092 2093 2094 20 AWG (0.56 mm2) Conductor Color Coding Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.56 mm2) drain wire Part No. Conductors M3232 M3233 M3234 2 3 4 Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate PVC jacket UL AWM Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 22 AWG (0.35 mm2) drain wire • - 20°C to +75°C (CMG) • -20°C to +60°C (AWM) • AWM  2092: 1 Black, 2 Red (except Part No. M3222: Black, Natural) • AWM 2093: 1 Black, 2 Red, 3 Natural • AWM 2094: 1 Black, 2 Red, 3 Natural, 4 Green Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 22 AWG (0.35 mm2) Applications • A  udio and sound systems requiring small-diameter cable with 100% shield coverage Nominal Diameter Inch mm 0.159 4.04 0.168 4.27 0.182 4.62 Nominal Diameter Inch mm 0.187 4.75 0.198 5.03 0.216 5.49 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2092 2093 2094 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.56 mm2) drain wire Part No. Conductors M3242 M3243 M3244 2 3 4 Nominal Diameter Inch mm 0.205 5.21 0.217 5.51 0.238 6.05 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2092 2093 2094 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 152 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield, Overall > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Overall, Multiconductor, PE, PVC 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) 18 AWG (0.81 mm2) drain wire Part No. Conductors M3247 M3248 2 3 UL AWM 2092, 2093, 2094 UL CMG UL CL2 (150 V) CSA CMG CSA FT4 UL AWM 2092 2093 Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) 16 AWG (1.32 mm2) drain wire Part No. Conductors • A  udio and sound systems requiring small-diameter cable with 100% shield coverage M3249 2 Nominal Diameter Inch mm 0.288 7.32 Jacket Thickness Inch mm 0.030 0.76 UL Style CL2 12 AWG (3.29 mm2) Operating Temperature Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) 14 AWG (2.08 mm2) drain wire • - 20°C to +75°C (CMG) • -20°C to +60°C (AWM) • AWM  2092 and CL2: 1 Black, 2 Red • AWM 2093: 1 Black, 2 Red, 3 Natural Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 14 AWG (2.08 mm2) Applications Conductor Color Coding Nominal Diameter Inch mm 0.229 5.82 0.243 6.17 Part No. Conductors M3250 2 Nominal Diameter Inch mm 0.326 8.28 Jacket Thickness Inch mm 0.030 0.76 UL Style CL2 Materials • S  tranded tinned copper conductors • Polyethylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 153 Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Audio/Video Cable 300 V Individually Foil Shielded Pairs, Multipair, PP/PE/SR-PVC, PVC AWM 2493, UL CM, Polypropylene Insulation 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) UL AWM 2464, 2493, 2919 (30 V) UL CM CSA CM Part No. Pairs M39039 M39040 M39041 M39042 6 9 11 15 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.008 (0.20 mm) • Audio and sound systems • -20°C to +80°C (AWM 2464) • -20°C to +75°C (CM) • -20°C to +60°C (AWM 2919, 2493) Part No. Pairs M4473 2 Materials • S  olid or stranded tinned copper conductors • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor (unless noted) • Polyethylene, polypropylene, or semirigid PVC insulation (see tables) • Slate PVC jacket Availability Nominal Diameter Inch mm 0.150 3.81 Jacket Thickness Inch mm 0.19 0.48 AWM 2919, UL CM, Polypropylene Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • AWM 2919: Chart K (page 529) • AWM 2493: Chart A (page 528) • AWM 2464 and CM: Black/Red, Green/White Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 UL CM, Polypropylene Insulation Applications Operating Temperature Nominal Diameter Inch mm 0.362 9.19 0.415 10.54 0.459 11.66 0.507 12.88 Part No. Pairs M13103 M13106 M13109 M13111 M13112 M13115 M13117 M13119 M13127 M13130 3 6 9 11 12 15 17 19 27 37 Nominal Diameter Inch mm 0.271 6.88 0.349 8.86 0.412 10.46 0.466 11.84 0.466 11.84 0.537 13.64 0.577 14.66 0.577 14.66 0.685 17.40 0.766 19.46 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 AWM 2464, UL CM, SR-PVC Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M13142 2 Nominal Diameter Inch mm 0.284 7.21 Jacket Thickness Inch mm 0.032 0.81 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 154 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Audio/Video Cable 300 V Individually Foil Shielded Pairs, Multipair, PP/PE/SR-PVC, PVC AWM 2919, UL CM, Polyethylene Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.013 (0.25 mm) UL AWM 2464, 2493, 2919 (30 V) UL CM CSA CM Applications Part No. Pairs M13143 M13146 M13149 M13151 M13152 M13155 3 6 9 11 12 15 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Drain wire: 20 AWG (0.56 mm2) Operating Temperature Conductor Color Coding • AWM 2919: Chart K (page 529) • AWM 2493: Chart A (page 528) • AWM 2464 and CM: Black/Red, Green/White Jacket Thickness Inch mm 0.032 0.64 0.043 1.09 0.043 1.09 0.050 1.27 0.050 1.27 0.050 1.27 AWM 2919, UL CM, Polyethylene Insulation • Audio and sound systems • -20°C to +80°C (AWM 2464) • -20°C to +75°C (CM) • -20°C to +60°C (AWM 2919, 2493) Nominal Diameter Inch mm 0.324 8.23 0.448 11.38 0.522 13.26 0.579 14.71 0.598 15.19 0.650 16.51 Part No. Pairs M13173 M13176 M13179 M13182 M13185 3 6 9 12 15 Nominal Diameter Inch mm 0.380 9.65 0.541 13.74 0.632 16.05 0.737 18.72 0.817 20.75 Jacket Thickness Inch mm 0.032 0.81 0.050 1.27 0.050 1.27 0.065 1.65 0.065 1.65 Materials • S  olid or stranded tinned copper conductors • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor (unless noted) • Polyethylene, polypropylene, or semirigid PVC insulation (see tables) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 155 Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Audio/Video Cable 300 V Individually Foil Shielded Pairs, Multipair, PP, PVC 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.015 (0.38 mm) Part No. Pairs M14604 4 Nominal Diameter Inch mm 0.365 9.27 Jacket Thickness Inch mm 0.030 0.76 Mutual capacitance: 23 pF/ft (75.5 pF/m) Ground capacitance: 41 pF/ft (134.5 pF/m) UL CMG VW-1 CSA CMG Applications • C  ommunication and instrumentation systems requiring special wiring • Audio process-control computer systems Operating Temperature • -20°C to +105°C Conductor Color Coding • 1 Black–Red, 2 Green–White, 3 White/Red–White/Black, 4 White/Yellow–White/Green Materials • S  tranded tinned copper conductors • Polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min Foil facing inward 22 AWG (0.35 mm2) stranded tinned copper drain wire • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 156 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Single Conductor > Braid or Spiral Shield Manhattan™ Audio/Video Cable Braid or Spiral Shield, Single Conductor, PE, PVC Microphone Cable Applications • High-impedance microphones • Hi-fi interconnection systems • Instruments and tape recorders Operating Temperature Materials • S  tranded tinned copper conductors* • Polyethylene insulation Voltage M3601* M3633* M3605 M3635 M3611 300 1000 3500 1000 4000 Wire Size AWG 30 26 24 24 20 mm2 0.05 0.14 0.20 0.20 0.52 Stranding AWG 7/38* 7/34* 10/34 10/34 26/34 mm 7 x 0.10 7 x 0. 16 10 x 0.16 10 x 0. 16 26 x 0.16 Nominal Diameter Inch mm 0.086 2.18 0.101 2.57 0.146 3.71 0.106 2.69 0.180 4.57 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length • –20°C to +60°C Part No. • B  raided tinned copper or spiral wrapped tinned copper shield • Slate PVC jacket Shield Braid Spiral Braid Spiral Braid (Minimums may apply) Jacket Thickness Inch mm 0.016 0.41 0.020 0.50 0.030 0.76 0.020 0.50 0.030 0.76 Insulation Thickness Inch mm 0.012 0.30 0.016 0.41 0.020 0.50 0.016 0.41 0.030 0.76 Capacitance pF/ft 32 35 36 41 39 pF/m 105.0 114.8 118.1 134.5 128.0 *M3601 and M3633 have 3 strands of tinned copper and 4 strands of tinned Copperweld. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 157 Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V Manhattan™ Audio/Video Cable 300 V Braid Shield, Multiconductor, PVC, PVC Microphone Cable 22 AWG (0.32 mm2) Stranding: Solid Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M14461 2 Nominal Diameter Inch mm 0.195 4.95 Jacket Thickness Inch mm 0.028 0.71 Mutual capacitance: 41 pF/ft (134.5 pF/m) Ground capacitance: 74 pF/ft (242.8 pF/m) UL AWM 2095 UL CMG CSA CMG FT4 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Operating Temperature • -20°C to +80°C (AWM) • –20°C to +75°C (CMG) Conductor Color Code Part No. Conductors M14462 2 Nominal Diameter Inch mm 0.205 5.21 Jacket Thickness Inch mm 0.028 0.71 Mutual capacitance: 43 pF/ft (141.3 pF/m) Ground capacitance: 77 pF/ft (252.6 pF/m) • 1 Black, 2 Red Materials • S  olid or stranded tinned copper conductors • PVC insulation • Tinned copper braid shield, 88% coverage Drain wire equivalent to conductors • Black PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 158 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, PVC, PVC UL AWM 2509, UL CMG 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Color Code D UL AWM 2509, 2576 UL CL2 UL CMG CSA CMG FT4 Applications • U  nbalanced intercom and sound systems • Remote circuit controls • Telephones • Low-voltage circuits Part No. Conductors M33402 M33403 M33404 M33406 M33408 M33410 M33412 M33415 M33419 2 3 4 6 8 10 12 15 19 Conductor Color Coding • Chart D (page 531) Materials • Stranded  tinned copper conductors • PVC insulation • Slate PVC jacket Availability Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 UL AWM 2509, UL CMG 18 AWG (0.81 mm2) Stranding: 16/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Color Code D Operating Temperature • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG and CL2) Nominal Diameter Inch mm 0.183 4.65 0.191 4.85 0.209 5.31 0.251 6.38 0.273 6.93 0.320 8.13 0.331 8.41 0.362 9.19 0.390 9.91 Part No. Conductors M33502 M33503 M33504 M33505 M33506 M33507 M33508 M33510 M33512 M33515 M33519 M33525 2 3 4 5 6 7 8 10 12 15 19 25 Nominal Diameter Inch mm 0.208 5.28 0.220 5.59 0.241 6.12 0.264 6.71 0.288 7.32 0.288 7.32 0.313 7.95 0.366 9.30 0.378 9.60 0.423 10.74 0.465 11.81 0.544 13.82 Jacket Thickness Inch Mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.035 0.89 0.035 0.89 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 159 Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, PVC, PVC UL AWM 2509, UL CMG 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Color Code D UL AWM 2509, 2576 UL CL2 UL CMG CSA CMG FT4 Part No. Conductors M33572 M33573 M33574 M33576 M33578 2 3 4 6 8 Nominal Diameter Inch mm 0.232 5.89 0.246 6.25 0.273 6.93 0.327 8.31 0.356 9.04 Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 0.025 0.64 UL AWM 2576, UL CL2 Applications • U  nbalanced intercom and sound systems • Remote circuit controls • Telephones • Low-voltage circuits Operating Temperature • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG and CL2) 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors M33582 M33583 2 3 Materials • Stranded  tinned copper conductors • PVC insulation • Slate PVC jacket Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 UL AWM 2576, UL CL2 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Conductor Color Coding • Chart D (page 531) Nominal Diameter Inch mm 0.295 7.49 0.313 7.95 Part No. Conductors M33590 M33591 2 3 Nominal Diameter Inch mm 0.333 8.45 0.354 8.99 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 160 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded, Multiconductor, SR-PVC, PVC UL AWM 2464, UL CMG 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Color Code E UL AWM 2464, 2509, 2576 UL CMG CSA CMG FT4 Applications • U  nbalanced intercom and sound systems • Remote circuit controls • Telephones • Low-voltage circuits Operating Temperature Part No. Conductors M38902 M38903 M38904 M38906 M38908 M38910 M38915 M38920 M38925 M38930 M38940 M38950 2 3 4 6 8 10 15 20 25 30 40 50 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Color Code D Conductor Color Coding Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 UL AWM 2576, UL CMG • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) • Chart  E (page 532) for AWM 2464 • Chart D (page 531) for AWM 2576 Nominal Diameter Inch mm 0.155 3.94 0. 162 4.11 0.173 4.39 0.200 5.08 0.213 5.41 0.243 6.17 0.269 6.83 0.297 7.54 0.331 8.41 0.349 8.86 0.389 9.88 0.426 10.82 Part No. Conductors M33302 M33303 M33304 M33305 M33306 M33308 M33310 M33312 M33315 M33320 M33325 M33330 M33340 M33350 M33360 2 3 4 5 6 8 10 12 15 20 25 30 40 50 60 Nominal Diameter Inch mm 0.164 4.16 0.175 4.45 0.188 4.78 0.203 5.16 0.218 5.54 0.233 5.92 0.267 6.78 0.275 6.99 0.297 7.54 0.329 8.36 0.367 9.32 0.388 9.86 0.432 10.97 0.481 12.22 0.523 13.28 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 161 Cable > Manhattan > Audio/Video Cable > Multiconductor > Spiral Wrap Copper Shield > 300 V Manhattan™ Audio/Video Cable 300 V Spiral Wrap Copper Shield, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2095 UL AWM 1108 (Single conductor) UL CMG CSA CMG FT4 Part No. Conductors M3261 M3262 M3263 M3264 M3266 1 2 3 4 6 Operating Temperature • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding Stranding: 10/30 (10 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M3271 M3272 M3273 M3274 M3276 1 2 3 4 6 • 1 Black, 2 Red, 3 White, 4 Green, 5 Yellow, 6 Blue • Part No. M13282: 1 Red, 2 White Materials • S  tranded tinned copper conductors • PVC insulation • Spiral wrapped tinned copper shield, 90% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 162 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.50 mm2) Applications • Audio and RF frequencies Nominal Diameter Inch mm 0.112 2.84 0.177 4.50 0.187 4.75 0.206 5.23 0.243 6.17 Nominal Diameter Inch mm 0.119 3.02 0.191 4.85 0.202 5.13 0.223 5.66 0.264 6.71 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.56 mm2) Stranding: 7/28 (10 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M13272 2 Nominal Diameter Inch mm 0.203 5.16 Jacket Thickness Inch mm 0.025 0.64 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M3281 M3282 M3283 M3284 1 2 3 4 Nominal Diameter Inch mm 0.129 3.28 0.214 5.44 0.226 5.74 0.247 6.27 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Spiral Wrap Copper Shield > 300 V Manhattan™ Audio/Video Cable 300 V Spiral Wrap Copper Shield, Multiconductor, PVC, PVC 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.022 (0.56 mm) UL AWM 2095 UL AWM 1108 (Single conductor) UL CMG CSA CMG FT4 Applications • Audio and RF frequencies Part No. Conductors M13282 M13283 2 3 Stranding: 26/30 (26 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M3287 M3288 2 3 Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.023 (0.58 mm) Part No. Conductors M13287 2 Nominal Diameter Inch mm 0.286 7.26 Jacket Thickness Inch mm 0.030 0.76 14 AWG (2.08 mm2) Materials • S  tranded tinned copper conductors • PVC insulation • Spiral wrapped tinned copper shield, 90% coverage • Slate PVC jacket Nominal Diameter Inch mm 0.240 6.10 0.254 6.45 16 AWG (1.32 mm2) • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) • 1 Black, 2 Red, 3 White, 4 Green, 5 Yellow, 6 Blue • Part No. M13282: 1 Red, 2 White Jacket Thickness Inch mm 0.028 0.71 0.028 0.71 16 AWG (1.32 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.256 6.50 0.270 6.86 Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors M3289* M3290* 2 3 Nominal Diameter Inch mm 0.295 7.49 0.312 7.92 Jacket Thickness Inch mm 0.025 0.64 0.025 0.64 *450 V. Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 163 Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V Manhattan™ Audio/Video Cable 300 V Braid Shield, Multiconductor, PVC, PVC UL 2095 22 AWG (0.035mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2095, 2464 CSA CMG FT4 Applications Part No. Conductors M3202 M13203 M3204 2 3 4 Operating Temperature • - 20°C to +80°C (AMW) • -20°C to +75°C (CMG) Conductor Color Coding • C  hart D (page 531), unless otherwise noted UL 2095 Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M3206 M3207 M3208 M13209* M13210* 2 3 4 6 12 164 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.032 0.81 0.040 1.02 UL 2095 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) • S  tranded tinned copper conductors • PVC insulation • Tinned copper braid shield, 85% coverage • Slate PVC jacket (Minimums may apply) Nominal Diameter Inch mm 0.205 5.21 0.216 5.49 0.234 5.94 0.300 7.62 0.396 10.06 *UL AWM 2464. Conductor color code Chart F (page 532). Materials 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.56 mm2) • A  udio and sound systems experiencing high flexing and needing additional tensile strength Availability Nominal Diameter Inch mm 0.189 4.80 0.199 5.05 0.215 5.46 Part No. Conductors M3212 M3213 M3214 2 3 4 Nominal Diameter Inch mm 0.223 5.66 0.235 5.97 0.256 6.50 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 UL 2095 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M3216 M3217 2 3 Nominal Diameter Inch mm 0.247 6.27 0.261 6.63 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V Manhattan™ Audio/Video Cable 300 V Braid Shield, Multiconductor, PVC, PVC 450 V; Not UL Recognized 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) UL AWM 2095, 2464 CSA CMG FT4 Part No. Conductors M33218 M33219 2 3 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 450 V; Not UL Recognized 12 AWG (3.29 mm2) Applications • A  udio and sound systems experiencing high flexing and needing additional tensile strength Nominal Diameter Inch mm 0.299 7.59 0.317 8.05 Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.020 (0.51 mm) Part No. Conductors M33220 M33221 2 3 Nominal Diameter Inch mm 0.337 8.56 0.358 9.09 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 Operating Temperature • - 20°C to +80°C (AMW) • -20°C to +75°C (CMG) Conductor Color Coding • C  hart D (page 531), unless otherwise noted Materials • S  tranded tinned copper conductors • PVC insulation • Tinned copper braid shield, 85% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 165 Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Multiconductor, PE or SR-PVC, PVC Polyethylene Insulation 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) 24 AWG (0.22 mm2) drain wire UL AWM 2092, 2093, 2094, 2464, 20253 UL CM, CMG, CL2 CSA CMG FT4 Part No. Conductors M13222 2 Nominal Diameter Inch mm 0. 166 Operating Temperature • - 20°C to +80°C (AWM 2464, 20253) • -20°C to +75°C (CM, CMG) • -20°C to +60°C (AWM 2092, 2093, 2094) Conductor Color Coding (Unless noted) • 2-conductor: Black, clear • 3-conductor: Black, red, clear • 4-conductor: Black, red, white, green Materials • P  olyethylene or semirigid PVC insulation (see tables) • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate PVC jacket Availability 4.22 0.025 0.64 Approval Color Code 2092, CM Black, Clear Mutual capacitance: 18 pF/ft (59 pF/m) Ground capacitance: 32 pF/ft (105 pF/m) Semi-Rigid PVC Insulation 24 AWG (0.22 mm2) Applications • L  ightweight, low-cost smalldiameter cable for audio and sound systems Jacket Thickness Inch mm Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.51 mm) 24 AWG (0.22 mm2) drain wire Part No. Conductors M39024 M39025 M39026 M39027 M39028 M39029 M39030 M39031 M39032 M39033 M39034 M39035 M39036 M39037 3 4 5 6 7 8 9 10 15 20 25 30 40 50 Nominal Diameter Inch mm 0.166 4.22 0.174 4.42 0.187 4.75 0.201 5.11 0.201 5.11 0.214 5.44 0.228 5.79 0.247 6.27 0.273 6.93 0.301 7.65 0.335 8.51 0.369 9.37 0.409 10.39 0.456 11.58 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.040 1.02 0.040 1.02 0.045 1.14 Approval Color Code 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG 2464, CMG O O O O O O O O F F F F F F Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190.3 pF/m) Polyethylene Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors M13226 M13227 2 3 Nominal Diameter Inch mm 0.178 4.52 0.204 5.18 Jacket Thickness Inch mm 0.025 0.64 0.033 0.84 Approvals 2092, CM 2093, CM Mutual capacitance: 20 pF/ft (65.6 pF/m) Ground capacitance: 36 pF/ft (118.1 pF/m) 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 166 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Multiconductor, PE or SR-PVC, PVC PVC Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) 22 AWG (0.35 mm2) drain wire UL AWM 2092, 2093, 2094, 2464, 20253 UL CM, CMG, CL2 CSA CMG FT4 Part No. Conductors M13229 2 Approvals 2464, CMG Color code: black, red. Polyethylene Insulation 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) 20 AWG (0.56 mm2) drain wire • L  ightweight, low-cost smalldiameter cable for audio and sound systems Part No. Conductors Operating Temperature M13232 M13233 2 3 Nominal Diameter Inch mm 0.200 5.08 0.221 5.61 Jacket Thickness Inch mm 0.028 0.71 0.033 0.84 Approvals 2092, CM 2093, CM Mutual capacitance: 23 pF/ft (75.4 pF/m) Ground capacitance: 41 pF/ft (134.5 pF/m) Polyethylene Insulation 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.019 (0.48 mm) 20 AWG (0.56 mm2) drain wire Conductor Color Coding (Unless noted) • 2-conductor: Black, clear • 3-conductor: Black, red, clear • 4-conductor: Black, red, white, green Jacket Thickness Inch mm 0.035 0.64 Mutual capacitance: 48 pF/ft (157.4 pF/m) Ground capacitance: 86 pF/ft (282.1 pF/m) Applications • - 20°C to +80°C (AWM 2464, 20253) • -20°C to +75°C (CM, CMG) • -20°C to +60°C (AWM 2092, 2093, 2094) Nominal Diameter Inch mm 0.189 4.80 Part No. Conductors M13242 M13243 2 3 Nominal Diameter Inch mm 0.230 5.84 0.253 6.43 Jacket Thickness Inch mm 0.028 0.71 0.033 0.84 Approvals 2092, CM 2093, CM Mutual capacitance: 24.1 pF/ft (79.1 pF/m) Ground capacitance: 43 pF/ft (141.1 pF/m) Materials • P  olyethylene or semirigid PVC insulation (see tables) • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate PVC jacket SR-PVC Insulation 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) 20 AWG (0.56 mm2) drain wire Part No. Conductors M13244 4 Availability Nominal Diameter Inch mm 0.249 6.32 Jacket Thickness Inch mm 0.035 0.89 Approvals 2464, CMG Mutual capacitance: 47 pF/ft (154.2 pF/m) Ground capacitance: 85 pF/ft (278.9 pF/m) 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 167 Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Multiconductor, PE or SR-PVC, PVC Polyethylene Insulation 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.032 (0.81 mm) 18 AWG (0.81 mm2) drain wire UL AWM 2092, 2093, 2094, 2464, 20253 UL CM, CMG, CL2 CSA CMG FT4 Part No. Conductors M13247 M13248 2 3 Nominal Diameter Inch mm 0.317 8.05 0.336 8.53 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 Approvals 20253, CM, CL2 20253, CM, CL2 Mutual capacitance: 20.5 pF/ft (67.2 pF/m) Ground capacitance: 37 pF/ft (121.4 pF/m) Polyethylene Insulation 14 AWG (2.08 mm2) Applications • L  ightweight, low-cost smalldiameter cable for audio and sound systems Operating Temperature • - 20°C to +80°C (AWM 2464, 20253) • -20°C to +75°C (CM, CMG) • -20°C to +60°C (AWM 2092, 2093, 2094) Stranding: 19/0.0147 (19 x 0.37 mm) Insulation thickness: 0.032 (0.81 mm) 16 AWG (1.31 mm2) drain wire Part No. Conductors M13249 2 Jacket Thickness Inch mm 0.035 0.89 Approvals 20253, CM, CL2 Mutual capacitance: 22.5 pF/ft (73.8 pF/m) Ground capacitance: 40 pF/ft (131.2 pF/m) Polyethylene Insulation 12 AWG (3.29 mm2) Stranding: 19/0.0185 (19 x 0.47 mm) Insulation thickness: 0.037 (0.81 mm) 14 AWG (2.08 mm2) drain wire Conductor Color Coding (Unless noted) • 2-conductor: Black, clear • 3-conductor: Black, red, clear • 4-conductor: Black, red, white, green Nominal Diameter Inch mm 0.345 8.78 Part No. Conductors M13250 2 Nominal Diameter Inch mm 0.421 10.69 Jacket Thickness Inch mm 0.040 1.02 Approvals 20253, CM, CL2 Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 44 pF/ft (144.3 pF/m) Materials • P  olyethylene or semirigid PVC insulation (see tables) • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 168 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Multiconductor, PVC, PVC 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.013 (0.33 mm) Part No. Conductors M14429 2 Nominal Diameter Inch mm 0.199 5.05 Jacket Thickness Inch mm 0.032 0.81 Mutual capacitance: 54 pF/ft (177.2 pF/m) Ground capacitance: 97 pF/ft (318.2 pF/m) UL AWM 2464 UL CMG CSA CMG FT4 Applications • A  udio, broadcast, and sound systems • Instrumentation Operating Temperature • - 20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • 1 Black, 2 Red Materials • Stranded  tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward 22 AWG (0.35 mm2) stranded tinned copper drain wire • Slate PVC jacket Availability Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 169 Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Audio/Video Cable 300 V Foil Shield, Multiconductor, PP, PVC Miniature 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.008 (0.20 mm) Part No. Conductors M14328* 2 Nominal Diameter Inch mm 0.124 3.15 Jacket Thickness Inch mm 0.020 0.51 Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) UL CM CSA CM *Black jacket. 22 AWG (0.35 mm2) Applications • A  udio, broadcast, and sound systems • Instrumentation Operating Temperature Stranding: Solid Insulation thickness: 0.008 (0.20 mm) Part No. Conductors M4325 2 Nominal Diameter Inch mm 0.122 3.10 Jacket Thickness Inch mm 0.018 0.46 Mutual capacitance: 28 pF/ft (91.8 pF/m) Ground capacitance: 50 pF/ft 164 pF/m) • -20°C to +75°C Conductor Color Coding 22 AWG (0.35 mm2) • 1 Black, 2 Red Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.008 (0.20 mm) Materials • S  olid or stranded tinned copper conductors • Polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket (except black where noted) Part No. Conductors M4326 M14327* 2 Nominal Diameter Inch mm 0.139 3.53 Jacket Thickness Inch mm 0.020 0.51 Mutual capacitance: 28 pF/ft (91.8 pF/m) Ground capacitance: 50 pF/ft 164 pF/m) *Black jacket. Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 170 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor Composite > Unshielded and Shielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded and Shielded, Multiconductor Composite, PVC/PE/PP, PVC UL AWM 2717 (300 V) UL AWM 2094, 2576 (150 V) UL CM, CMG CSA CMG, CMG Materials • Stranded  tinned copper conductors • PVC insulation (polypropylene or polyethylene, as noted) • Aluminum/polyester foil shield, 25% minimum overlap Stranded tinned copper drain wire (see tables for size) • PVC jacket (see tables for colors) Operating Temperature • - 20°C to +80°C (AWM 2717) • -20°C to +75°C (CM, CMG, except where noted) • -20°C to +60°C (AWM 2094) Conductor Color Coding Availability • See tables 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) 22 AWG Composite Shielded and Unshielded, UL CM, Slate Jacket 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) 22 AWG (0.035 mm2) drain wire (M4475) 24 AWG (0.22 mm2) drain wire (M4451) Nominal Diameter Inch mm Insulation Thickness Inch mm Jacket Thickness Inch mm Part No. Conductors M4475 3 0.190 4.83 0.013 0.33 0.032 0.81 M4451 4 0.161 4.09 0.008 0.20 0.019 0.48 Configuration Shielded Unshielded 2 1 Black, White Brown 2 2 Red, Black Green, White Insulation PVC PP 20 AWG Composite Shielded and Unshielded, UL CMG, Slate Jacket 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation Thickness: 0.015 (0.38 mm) 22 AWG (0.35 mm2) drain wire Part No. Pairs M4452 4 Nominal Diameter Inch mm 0.226 Jacket Thickness Inch mm 5.74 0.028 Configuration Shielded Unshielded 2 2 Red, Black Green, White 0.71 Insulation PVC 22 AWG Composite Shielded and Unshielded, AWM 2717 and UL CM, Polypropylene Insulation, Slate Jacket 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) 24 AWG (0.22 mm2) drain wire Nominal Diameter Inch mm Part No. Pairs M14474 2 0.243 M14476* 2 0.220 Insulation Thickness Inch mm Jacket Thickness Inch mm 5.17 0.010 0.25 0.028 0.71 5.59 0.008 0.20 0.030 0.81 Configuration Shielded Unshielded 2 — Red, Black 1 1 Red, Black Green, White *Not CMG Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 171 Cable > Manhattan > Audio/Video Cable > Multiconductor Composite > Unshielded and Shielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded and Shielded, Multiconductor Composite, PVC/PE/PP, PVC UL AWM 2717 (300 V) UL AWM 2094, 2576 (150 V) UL CM, CMG CSA CMG, CMG Materials • Stranded  tinned copper conductors • PVC insulation (polypropylene or polyethylene, as noted) • Aluminum/polyester foil shield, 25% minimum overlap Stranded tinned copper drain wire (see tables for size) • PVC jacket (see tables for colors) Operating Temperature • - 20°C to +80°C (AWM 2717) • -20°C to +75°C (CM, CMG, except where noted) • -20°C to +60°C (AWM 2094) Conductor Color Coding Availability • See tables 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) 24/22 AWG Composite Shielded and Unshielded, UL CM, Slate Jacket Part No. M14477 M14478* 24 AWG (0.22 mm2) 22 AWG (0.35 mm2) Stranding: 7/32 (7 x 0.20 mm) 22 AWG (0.35 mm2) drain wire (M14477) 24 AWG (0.22 mm2) drain wire (M14478) Stranding: 7/30 (7 x 0.25 mm) Nominal Diameter Inch mm Conductors 4 (24 AWG) 2 (22 AWG) 8 (24 AWG) 2 (22 AWG) 0.239 6.07 0.295 7.49 Insulation Thickness Inch mm 0.016 0.41 0.012 0.30 0.015 0.38 Jacket Thickness Inch mm 0.028 0.71 0.030 0.81 Configuration Shielded Unshielded 4** — 2 — Blue, White — 8† 2 — White, Blue Insulation PVC PVC PE PVC *Cable has two quads of four shielded conductors, each quad individually shielded. One quad has a red shield; the other has a green shield. Not CMG. **Conductor color coding: Black, green, red, yellow. †Conductor color coding: Slate, white, blue, green, brown, red, yellow, orange. 22 AWG Shielded, UL CM, Brown Jacket 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation Thickness 0.008 (0.20 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors M14475 3 Nominal Diameter Inch mm 0.143 3.63 Jacket Thickness Inch mm 0.020 0.51 Configuration Shielded Unshielded 3* — Insulation PP *Conductor color coding: Black, red, white. 172 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Audio/Video Cable > Multiconductor Composite > Unshielded and Shielded > 300 V Manhattan™ Audio/Video Cable 300 V Unshielded and Shielded, Multiconductor Composite, PVC/PE, PVC UL AWM 2717 (300 V) UL AWM 2094, 2576 (150 V) UL CM, CMG CSA CMG, CMG Materials • - 20°C to +80°C (AWM 2717) • -20°C to +75°C (CM, CMG, except where noted) • -20°C to +60°C (AWM 2094) • Stranded  tinned copper conductors • PVC or PE insulation • Aluminum/polyester foil shield, 25% minimum overlap Stranded tinned copper drain wire (see tables for size) • PVC jacket (see tables for colors) Conductor Color Coding Availability Operating Temperature • See tables 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) 22 and 18 AWG Unshielded, UL CM Only, Slate Jacket 22 AWG (0.35 mm2) 18 AWG (0.81 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.018 (0.46 mm) Conductors* 22 AWG 18 AWG 4 2 Part No. M4406 Nominal Diameter Inch mm 0.255 6.48 Jacket Thickness Inch mm 0.032 0.81 Insulation PVC Conductor color coding: 22 AWG: Red, green, brown, blue. 18 AWG: Black, white. 20 Foil Shielded and 18 AWG Unshielded, AWM 2094, CM, Beige Jacket 20 AWG (0.56 mm2) 18 AWG (0.81 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.20 (0.50 mm) 22 AWG (0.35 mm2) drain wire Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.019 (0.48 mm) Part No. M13291 Conductors 20 AWG 18 AWG 2 2 Nominal Diameter Inch mm 0.264 6.71 Jacket Thickness Inch mm 0.032 0.81 Insulation PE Conductor color coding: 22 AWG: Black, red. 18 AWG: Green, white. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 173 Cable > Manhattan > Security and Data Cable > Multiconductor > Unshielded > 300 V Manhattan™ Security and Data Cable 300 V Unshielded, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL CMR CSA CMR Part No. Conductors M213302 M213303 M213304 M213305 M213308 2 3 4 5 8 Nominal Diameter Inch mm 0.130 3.30 0.138 3.51 0.151 3.84 0.166 4.22 0.196 4.98 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 Operating Temperature 20 AWG (0.56 mm2) • -20°C to +75°C Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • 1 Black, 2 Red, 3 White, 4 Green, 5 Brown, 6 Blue, 7 Orange, 8 Yellow, 9 Violet, 10 Slate Materials Part No. Conductors M213402 M213403 M213404 2 3 4 • S  tranded bare copper conductors • PVC insulation • Slate PVC jacket Nominal Diameter Inch mm 0.146 3.71 0.155 3.94 0.170 4.32 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Availability Part No. Conductors 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length M213502 M213503 M213504 2 3 4 Nominal Diameter Inch mm 0.166 4.22 0.177 4.50 0.195 4.95 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 (Minimums may apply) 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.010 (0.25 mm) 174 Part No. Conductors M213572 M213573 M213574 2 3 4 Nominal Diameter Inch mm 0.188 4.77 0.200 5.08 0.221 5.61 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Security and Data Cable > Multiconductor > Foil Shielded > 300 V Manhattan™ Security and Data Cable 300 V Foil Shielded, Multiconductor, PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL CMR CSA CMR Part No. Conductors M239023 M239024 M239025 2 3 4 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) • -20°C to +75°C • 1 Black, 2 Red, 3 White, 4 Green, 5 Brown, 6 Blue, 7 Orange, 8 Yellow, 9 Violet, 10 Slate Part No. Conductors M113226 M113227 2 3 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.134 3.40 0.142 3.61 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 20 AWG (0.56 mm2) Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire one even AWG size smaller than conductor (except 24 AWG, which is the same size as the conductors) • Slate PVC jacket Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.122 3.10 0.129 3.28 0.140 3.56 Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M113232 M113233 2 3 Nominal Diameter Inch mm 0.150 3.81 0.159 4.04 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M113242 M113243 M113244 2 3 4 Nominal Diameter Inch mm 0.170 4.32 0.181 4.60 0.199 5.05 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 16 AWG (1.32 mm2) (Minimums may apply) Stranding: 19/0.0117 (7 x 0.30 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M113247 M113248 2 3 Nominal Diameter Inch mm 0.192 4.88 0.204 5.18 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 175 Cable > Manhattan > Security and Data Cable > Multipair > Unshielded > 300 V Manhattan™ Security and Data Cable 300 V Unshielded, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL CMR CSA CMR Part No. Pairs M2210 M2211 M2212 2 3 4 Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) • -20°C to +75°C • Chart A1 (page 528) Materials • S  tranded bare copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 20 AWG (0.56 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.194 4.93 0.207 5.26 0.228 5.79 Part No. Pairs M2222 M2223 M2224 M2226 2 3 4 6 Nominal Diameter Inch mm 0.220 5.59 0.235 5.97 0.260 6.60 0.317 8.05 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M2215 M2216 M2217 2 3 4 Nominal Diameter Inch mm 0.253 6.43 0.270 6.86 0.300 7.62 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 (Minimums may apply) 176 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Security and Data Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Security and Data Cable 300 V, Individually Foil Shielded Pairs, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL CMR CSA CMR Part No. Pairs M213102 M213103 M213104 M213106 2 3 4 6 Operating Temperature • Chart A1 (page 528) Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Slate PVC jacket Availability Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 20 AWG (0.56 mm2) • -20°C to +75°C Conductor Color Coding Nominal Diameter Inch mm 0.229 5.82 0.244 6.20 0.269 6.83 0.325 8.26 Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M213142 M213143 M213144 M213146 2 3 4 6 Nominal Diameter Inch mm 0.257 6.53 0.274 6.96 0.303 7.70 0.367 9.32 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 18 AWG (0.89 mm2) Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M213172 M213173 M213174 M213176 2 3 4 6 Nominal Diameter Inch mm 0.292 7.42 0.312 7.92 0.345 8.76 0.420 10.67 Jacket Thickness Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 177 Cable > Manhattan > Security and Data Cable > Multipair > Overall Foil Shield > 300 V Manhattan™ Security and Data Cable 300 V Overall Foil Shield, Multipair, PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL CMR CSA CMR Part No. Pairs M213191 M213192 M213193 2 3 4 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) • -20°C to +75°C • Chart A1 (page 528) Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire one even AWG size smaller than conductor (except 24 AWG, which is the same size as the conductors) • Slate PVC jacket Part No. Pairs M213222 M213223 M213224 2 3 4 (Minimums may apply) 178 Nominal Diameter Inch mm 0.198 5.03 0.211 5.36 0.232 5.89 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M213202 M213203 M213204 M213206 2 3 4 6 Nominal Diameter Inch mm 0.224 5.69 0.239 6.07 0.264 6.71 0.331 8.41 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 0.020 0.51 18 AWG (0.89 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.178 4.52 0.190 4.83 0.209 5.31 Stranding: 7/26 (7 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M213182 M213183 M213184 2 3 4 Nominal Diameter Inch mm 0.257 6.53 0.274 6.96 0.304 7.72 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multiconductor, PVC, PVC, Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP FT6 Part No. Conductors M244837 M244838 M244839 2 3 4 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) 24 AWG (0.22 mm2) drain wire • -20°C to +75°C • 1 Black, 2 Red, 3 White, 4 Green, 5 Brown, 6 Blue, 7 Orange, 8 Yellow, 9 Violet, 10 Slate Materials • S  tranded bare copper conductors • Plenum-rated PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • White plenum-rated PVC jacket Availability Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.122 3.10 0.129 3.28 0.140 3.56 Part No. Conductors M244800 M244801 M244802 M244804 M244806 M244808 2 3 4 6 8 10 Nominal Diameter Inch mm 0.134 3.40 0.142 3.61 0.155 3.94 0.178 4.52 0.200 5.08 0.234 5.94 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors M244816 M244817 M244818 2 3 4 Nominal Diameter Inch mm 0.150 3.81 0.159 4.04 0.174 4.42 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.015 0.38 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 179 Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multiconductor, PVC, PVC, Plenum Rated 18 AWG (0.89 mm2) Stranding: 7/26 (16 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) 20 AWG (0.56 mm2) drain wire UL CMP CSA CMP FT6 Part No. Conductors M244825 M244826 M244827 2 3 4 Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.010 (0.25 mm) 18 AWG (0.89 mm2) drain wire • -20°C to +75°C • 1 Black, 2 Red, 3 White, 4 Green, 5 Brown, 6 Blue, 7 Orange, 8 Yellow, 9 Violet, 10 Slate Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.015 0.38 16 AWG (1.32 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.146 3.71 0.181 4.60 0.199 5.05 Part No. Conductors M244834 M244835 M244836 2 3 4 Nominal Diameter Inch mm 0.192 4.88 0.204 5.18 0.225 5.71 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 Materials • S  tranded bare copper conductors • Plenum-rated PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • White plenum-rated PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 180 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multiconductor, FEP, PVDF, Plenum Rated 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire Part No. Conductors M413226 2 UL CMR CSA CMP FT6 Conductor Color Coding Jacket Thickness Inch mm 0.015 0.38 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.007 (0.18 mm) 20 AWG (0.56 mm2) drain wire Operating Temperature • -40°C to +125°C Nominal Diameter Inch mm 0.118 3.00 Part No. Conductors M413242 2 Nominal Diameter Inch mm 0.162 4.11 Jacket Thickness Inch mm 0.015 0.38 • Chart D (page 531) Materials • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Red PVDF jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 181 Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multiconductor, FEP, FEP, Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP FT6 Operating Temperature • -20°C to +150°C Conductor Color Coding • C  hart F (page 532), unless noted Part No. Conductors M64837 M64838 M64839 M64840 M64841 M64842 M64843 M64844 M64845 M64846 M64847 2 3 4 5 6 7 8 9 10 12 15 Materials 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 22 AWG (0.35 mm2) • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Slate FEP jacket Availability Nominal Diameter Inch mm 0.096 2.44 0.102 2.59 0.111 2.82 0.122 3.10 0.133 3.38 0.133 3.38 0.168 4.26 0.159 4.04 0.172 4.37 0.178 4.52 0.193 4.90 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire Part No. Conductors M64800 M64801 M64802 M64803 M64804 M64805 M64806 M64807 M64808 M64809 M64812 2 3 4 5 6 7 8 9 10 12 15 Nominal Diameter Inch mm 0.108 2.74 0.115 2.92 0.126 3.20 0.138 3.51 0.151 3.84 0.151 3.84 0.168 4.27 0.181 4.60 0.196 4.98 0.203 5.16 0.221 5.61 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 (Minimums may apply) 182 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multiconductor, FEP, FEP, Plenum Rated -80 to +150°C Temperature Rating, Color Code D 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire Part No. Conductors M613226 1 UL CMP CSA CMP FT6 Conductor Color Coding • C  hart F (page 532), unless noted Materials • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire (see tables for size) • Slate FEP jacket Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.006 (0.15 mm) 22 AWG (0.35 mm2) drain wire Part No. Conductors M64816 M64817 M64818 M64820 M64822 M64824 2 3 4 6 8 10 (Minimums may apply) Nominal Diameter Inch mm 0.124 3.15 0.132 3.35 0.145 3.68 0.175 4.45 0.194 4.93 0.228 5.79 Jacket Thickness Inch Mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 -80 to +150°C Temperature Rating, Color Code D 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.007 (0.18 mm) 20 AWG (0.60 mm2) drain wire Part No. Conductors M613242 2 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.015 0.38 20 AWG (0.56 mm2) Operating Temperature • -20°C to +150°C Nominal Diameter Inch mm 0.118 2.99 Nominal Diameter Inch mm 0.162 4.11 Jacket Thickness Inch mm 0.015 0.38 18 AWG (0.89 mm2) Stranding: 7/26 (16 x 0.40 mm) Insulation thickness: 0.009 (0.23 mm) 20 AWG (0.56 mm2) drain wire Part No. Conductors M64825 M64826 M64827 M64829 M64831 2 3 4 6 8 Nominal Diameter Inch mm 0.160 4.06 0.166 4.22 0.188 4.78 0.227 5.77 0.247 6.27 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 16 AWG (1.43 mm2) Stranding: 7/24 (7 x 0.51 mm) Insulation thickness: 0.009 (0.23 mm) 18 AWG (0.89 mm2) drain wire Part No. Conductors M64834 M64835 M64836 2 3 4 Nominal Diameter Inch mm 0.180 4.57 0.196 4.98 0.217 5.51 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 183 Cable > Manhattan > Plenum Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Plenum Cable 300 V Individually Foil Shielded Pairs, Multipair, PVC, PVC Plenum Rated 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.007 (0.18mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP Part No. Pairs M44473 M43103 M43106 2 3 6 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) 22 AWG (0.35 mm2) drain wire • -20°C to +75°C • C  hart A1 (page 528) (Part number M243473: Black, white, green/yellow) Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.024 0.60 22 AWG (0.35 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.192 4.88 0.211 5.36 0.301 7.65 Part No. Pairs M243473 M243103 M243106 2 3 6 Nominal Diameter Inch mm 0.219 5.56 0.227 5.77 0.316 8.03 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.020 0.51 Materials • S  tranded bare copper conductors • Plenum-rated PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • White plenum-rated PVC jacket 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) 22 AWG (0.35 mm2) drain wire Part No. Pairs M243142 M243143 M243144 2 3 4 Nominal Diameter Inch mm 0.241 6.12 0.258 6.55 0.295 7.49 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.020 0.51 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 184 18 AWG (0.89 mm2) Stranding: 7/26 (16 x 0.40 mm) Insulation thickness: 0.010 (0.25 mm) 20 AWG (0.56 mm2) drain wire Part No. Pairs M243172 M243173 2 3 Nominal Diameter Inch mm 0.276 7.01 0.295 7.49 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Plenum Cable > Multipair > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multipair, FEP, PVC, Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP FT6 Operating Temperature • -20°C to +75°C Part No. Pairs M52893 M52894 M52895 M52896 M52897 M52898 M52900 M52902 1 2 3 4 5 6 9 12.5 Nominal Diameter Inch mm 0.155 3.94 0.155 3.94 0.164 4.17 0.180 4.57 0.197 5.00 0.215 5.46 0.252 6.40 0.282 7.16 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 Conductor Color Coding • Chart K (page 529) Materials • S  tranded tinned copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire (see tables for size) • Slate plenum-rated PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 185 Cable > Manhattan > Plenum Cable > Multipair > Overall Foil Shield > 300 V Manhattan™ Plenum Cable 300 V Overall Foil Shield, Multipair, FEP, FEP, Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.006 (0.15 mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP Part No. Pairs M613190 M613191 M613192 M613193 M613194 1 2 3 4 5 Nominal Diameter Inch mm 0.155 3.94 0.155 3.94 0.164 4.17 0.180 4.57 0.197 5.00 Jacket Thickness Inch mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 Operating Temperature • -80°C to +150°C Conductor Color Coding • Chart K (page 529) Materials • Stranded bare copper pairs • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire sized the same as conductors • Red FEP jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 186 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Plenum Cable > Multipair > Individually Foil Shielded Pairs > 300 V Manhattan™ Plenum Cable 300 V Individually Foil Shielded Pairs, Multipair, FEP, PVDF Plenum Rated 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) 24 AWG (0.22 mm2) drain wire UL CMP CSA CMP Operating Temperature • -20°C to +150°C • -20°C to +75°C (CMP) Part No. Pairs M42891 M42892 M42893 M42894 M42895 M42896 M42897 M42898 M42899 2 3 4 5 6 7 9 12 18 Nominal Diameter Inch mm 0.192 4.88 0.205 5.21 0.244 6.20 0.250 6.35 0.274 6.96 0.274 6.96 0.325 8.26 0.367 9.32 0.446 11.33 Jacket Thickness Inch Mm 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.020 0.51 Conductor Color Coding • Chart M (page 530) Materials • S  tranded bare copper conductors • FEP insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire sized the same as conductors • Slate PVDF jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 187 Cable > Manhattan > Control Cable > Multiconductor > Braid Shield > 600 V Manhattan™ Control Cable 600 V Braid Shield, Multiconductor, PVC, PVC MIL-DTL-16878/1 Conductors 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) MIL-DTL-16878/1 and /17 Conductors (Types B and B/N) UL VW-1 Operating Temperature • -55°C to +105°C Conductor Color Coding Part No. Conductors M1411* M1412 M1604 M1605 M1606 M1608 M1610 M1612 1 2 4 5 6 8 10 12 • S  tranded tinned copper conductors • PVC or PVC/nylon insulation • Tinned copper braid shield, 90% coverage • White PVC jacket (Minimums may apply) 188 Color Code P P F F F F F F MIL-DTL-16878/17 Conductors 26 AWG (0.14 mm2) Stranding: 7/34 (7 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Part No. Conductors M1421 M1422 M1423 1 2 3 Nominal Diameter Inch mm 0.083 2.11 0.140 3.56 0.147 3.73 Jacket Thickness Inch mm 0.010 0.25 0.014 0.36 0.014 0.36 MIL-DTL-16878/17 Conductors 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.013 0.33 0.014 0.36 0.015 0.38 0.017 0.43 0.018 0.46 0.020 0.51 *Black jacket. All others slate. • C  hart P (page 535) unless otherwise noted Materials Nominal Diameter Inch mm 0.073 1.85 0.116 2.95 0.132 3.35 0.144 3.66 0.157 3.99 0.175 4.45 0.201 5.11 0.210 5.33 Part No. Conductors M1431 M1432 M1433 1 2 3 Nominal Diameter Inch mm 0.093 2.36 0.156 3.96 0.164 4.17 Jacket Thickness Inch mm 0.010 0.25 0.016 0.41 0.016 0.41 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Braid Shield > 600 V Manhattan™ Control Cable 600 V Braid Shield, Multiconductor, PVC, PVC MIL-DTL-16878/17 Conductors 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon MIL-DTL-16878/1 and /17 Conductors (Types B and B/N) UL VW-1 Operating Temperature Part No. Conductors M1441 M1442 M1443 M1444 M1644 M1645 M1646 M1648 M1650* 1 2 3 4 4 5 6 8 10 • -55°C to +105°C *Black jacket. All others slate. Conductor Color Coding MIL-DTL-16878/17 Conductors • S  tranded tinned copper conductors • PVC or PVC/nylon insulation • Tinned copper braid shield, 90% coverage • White PVC jacket (Minimums may apply) Color Code P P P P F F F F F Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Part No. Conductors M1451 M1452 M1453 M1454 1 2 3 4 Nominal Diameter Inch mm 0.108 2.74 0.194 4.93 0.214 5.44 0.232 5.89 Jacket Thickness Inch mm 0.010 0.25 0.020 0.51 0.025 0.64 0.025 0.64 MIL-DTL-16878/17 Conductors 18 AWG (0.96 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.010 0.25 0.020 0.51 0.020 0.51 0.020 0.51 0.019 0.48 0.020 0.51 0.020 0.51 0.025 0.64 0.026 0.66 20 AWG (0.62 mm2) • C  hart P (page 535) unless otherwise noted Materials Nominal Diameter Inch mm 0.100 2.54 0.178 4.52 0.187 4.75 0.202 5.13 0.203 5.16 0.222 5.64 0.240 6.10 0.268 6.81 0.309 7.85 Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon Part No. Conductors M1461 M1462 M1463 1 2 3 Nominal Diameter Inch mm 0.122 3.10 0.216 5.49 0.230 5.84 Jacket Thickness Inch mm 0.012 0.30 0.021 0.53 0.022 0.56 MIL-DTL-16878/17 Conductors 16 AWG (1.23 mm2) Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.011 (0.28 mm) PVC/0.004 (0.10 mm) nylon Part No. Conductors M1471 M1472 M1473 M1474 1 2 3 4 Nominal Diameter Inch mm 0.144 3.66 0.240 6.10 0.257 6.53 0.280 7.11 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.018 0.46 0.023 0.58 0.025 0.64 0.025 0.64 189 Cable > Manhattan > Control Cable > Multiconductor > Braid Shield > 1000 V Manhattan™ Control Cable 1000 V Braid Shield, Multiconductor, PVC, PVC MIL-DTL-16878/2 Conductors 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) MIL-DTL-16878/2 and /18 Conductors (Types C and C/N) UL VW-1 Operating Temperature • -55°C to +105°C Part No. Conductors M1704 M1705 M1706 M1708 M1710 M1712 M1714 M1716 4 5 6 8 10 12 14 16 Jacket Thickness Inch mm 0.023 0.58 0.025 0.64 0.030 0.76 0.032 0.81 0.035 0.89 0.035 0.89 0.040 1.02 0.046 1.17 MIL-DTL-16878/18 Conductors 16 AWG (1.23 mm2) Conductor Color Coding Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.017 (0.43 mm) PVC/0.004 (0.10 mm) nylon • Chart F (page 532) Materials • S  tranded tinned copper conductors • PVC or PVC/nylon insulation • Tinned copper braid shield, 90% coverage • Slate PVC jacket Availability Nominal Diameter Inch mm 0.269 6.83 0.297 7.54 0.332 8.43 0.362 9.19 0.423 10.74 0.442 11.23 0.473 12.01 0.509 12.93 Part No. Conductors M1764 M1765 M1766 M1768 M1772 M1776 M1779 M1787 4 5 6 8 12 16 19 27 Nominal Diameter Inch mm 0.324 8.23 0.357 9.07 0.390 9.91 0.431 10.95 0.532 13.51 0.598 15.19 0.636 16.15 0.768 19.51 Jacket Thickness Inch mm 0.031 0.79 0.033 0.84 0.035 0.89 0.040 1.02 0.047 1.19 0.053 1.35 0.057 1.45 0.067 1.70 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 190 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 600 V Manhattan™ Control Cable 600 V Unshielded, Multiconductor, PVC/Nylon, PVC 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart J (page 533) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Black PVC jacket Part No. Conductors M3800 M3801 M3802 M3803 M3804 M3805 M3806 M3807 M3808 M3810 M3815 M3819 M3822 M3821 M3823 M3825 2 3 4 5 6 7 8 9 10 12 15 19 24 25 30 37 Features 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 16 AWG (1.31 mm2) • UL Sunlight Resistant • UL Direct Burial Availability Nominal Diameter Inch mm 0.185 x 0.273 4.70 x 6.93 0.287 7.29 0.310 7.87 0.336 8.53 0.362 9.19 0.362 9.19 0.390 9.91 0.417 10.59 0.449 11.40 0.463 11.76 0.533 13.54 0.569 14.45 0.646 16.41 0.657 16.69 0.694 17.63 0.745 18.92 Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M3826 M3828 M3829 M3830 M3831 M3832 M3833 M3834 M3835 M3837 M3838 M3839 M3840 M3843 M3841 M3842 2 3 4 5 6 7 8 9 10 12 15 19 24 25 30 37 Nominal Diameter Inch mm 0.197 x 0.297 5.00 x 7.54 0.310 7.87 0.339 8.61 0.368 9.35 0.398 10.11 0.398 10.11 0.429 10.90 0.461 11.71 0.497 12.62 0.545 13.84 0.588 14.94 0.630 16.00 0.717 18.21 0.729 18.52 0.770 19.56 0.869 22.07 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 191 Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 600 V Manhattan™ Control Cable 600 V Unshielded, Multiconductor, PVC/Nylon, PVC 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.62 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart J (page 533) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Black PVC jacket Part No. Conductors M3845 M3847 M3848 M3849 M3850 M3851 M3852 M3853 M3854 M3856 M3857 M3858 M3859 M3862 M3860 M3861 2 3 4 5 6 7 8 9 10 12 15 19 24 25 30 37 Features 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 192 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 0.083 2.11 0.083 2.11 12 AWG (3.30 mm2) • UL Sunlight Resistant • UL Direct Burial Availability Nominal Diameter Inch mm 0.212 x 0.32 5.38 x 8.31 0.345 8.76 0.375 9.53 0.409 10.39 0.444 11.28 0.444 11.28 0.479 12.17 0.547 13.89 0.589 14.96 0.607 15.42 0.657 16.69 0.705 17.91 0.805 20.45 0.859 21.82 0.907 23.04 0.974 24.74 Stranding: 7/0.0305 (7 x 0.78 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M3865 M3867 M3868 M3869 M3870 M3871 M3872 M3873 M3874 M3876 M3877 M3878 M3879 M3880 M3883 M3881 M3882 2 3 4 5 6 7 8 9 10 12 15 16 19 24 25 30 37 Nominal Diameter Inch mm 0.231 x 0.365 5.87 x 9.27 0.386 9.80 0.421 10.69 0.460 11.68 0.501 12.73 0.501 12.73 0.575 14.61 0.617 15.67 0.665 16.89 0.686 17.42 0.744 18.90 0.759 19.28 0.800 20.32 0.957 24.31 0.973 24.71 1.029 26.14 1.107 28.12 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 0.083 2.11 0.083 2.11 0.083 2.11 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 600 V Manhattan™ Control Cable 600 V Unshielded, Multiconductor, PVC/Nylon, PVC 10 AWG (5.26 mm2) Stranding: 7/0.0385 (7 x 0.98 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart J (page 533) Materials Part No. Conductors M3902 M3903 M3904 M3905 M3906 M3907 M3908 M3910 M3911 M3913 M3915 M3916 2 3 4 5 6 7 8 9 10 12 14 15 Nominal Diameter Inch mm 0.267 x 0.365 6.78 x 9.27 0.464 11.79 0.540 13.72 0.590 14.99 0.641 16.28 0.641 16.28 0.694 17.63 0.748 19.00 0.809 20.55 0.875 22.23 0.920 23.37 0.950 24.13 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 0.083 2.11 0.083 2.11 • S  tranded bare copper conductors • PVC/nylon insulation • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 193 Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 600 V Manhattan™ Control Cable 600 V Unshielded, Multiconductor, PVC/Nylon, PVC 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M39056 2 UL TC Nominal Diameter Inch mm 0.283 7.19 Jacket Thickness Inch mm 0.048 1.22 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Operating Temperature • -25°C to +90°C Conductor Color Coding Part No. Conductors M39057 2 Nominal Diameter Inch mm 0.301 7.65 Jacket Thickness Inch mm 0.048 1.22 • Chart D (page 531) Materials 14 AWG (2.08 mm2) • S  tranded tinned copper conductors • PVC/nylon insulation • Black PVC jacket Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M39058 2 Nominal Diameter Inch mm 0.355 9.02 Jacket Thickness Inch mm 0.048 1.22 Features • UL Sunlight Resistant • UL Direct Burial 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Part No. Conductors M39059 2 Nominal Diameter Inch mm 0.393 9.98 Jacket Thickness Inch mm 0.048 1.22 (Minimums may apply) 194 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Foil Shield > 600 V Manhattan™ Control Cable 600 V Foil Shield, Multiconductor, PVC/Nylon, PVC 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding Part No. Conductors M33800 M33801 M33802 M33803 M33805 M33807 M33810 M33815 M33819 2 3 4 5 7 9 12 15 19 Nominal Diameter Inch mm 0.277 7.04 0.291 7.39 0.314 7.98 0.340 8.64 0.366 9.30 0.421 10.69 0.467 11.86 0.537 13.64 0.573 14.55 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 • Chart J (page 533) 16 AWG (1.31 mm2) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M33826 M33828 M33829 M33830 M33832 M33834 M33837 M33838 M33839 2 3 4 5 7 9 12 15 19 • UL Sunlight Resistant • UL Direct Burial (Minimums may apply) Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 14 AWG (2.08 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.301 7.65 0.317 8.05 0.343 8.71 0.372 9.45 0.402 10.21 0.465 11.81 0.549 13.94 0.592 15.04 0.634 16.10 Stranding: 7/0.0242 (7 x 0.62 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M33845 M33847 M33848 M33849 M33851 M33853 M33856 M33857 M33858 2 3 4 5 7 9 12 15 19 Nominal Diameter Inch mm 0.331 8.41 0.349 8.86 0.379 9.63 0.413 10.49 0.448 11.38 0.551 14.00 0.611 15.52 0.661 16.79 0.709 18.01 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 195 Cable > Manhattan > Control Cable > Multiconductor > Foil Shield > 600 V Manhattan™ Control Cable 600 V Foil Shield, Multiconductor, PVC/Nylon, PVC 12 AWG (3.30 mm2) Stranding: 7/0.0305 (7 x 0.78 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart J (page 533) Part No. Conductors M33865 M33867 M33868 M33869 M33870 M33871 M33873 M33876 M33877 M33879 2 3 4 5 6 7 9 12 15 19 Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features Nominal Diameter Inch mm 0.369 9.37 0.390 9.91 0.425 10.80 0.464 11.79 0.505 12.83 0.505 12.83 0.621 15.77 0.690 17.53 0.748 19.00 0.804 20.42 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 10 AWG (5.26 mm2) Stranding: 7/0.0385 (7 x 0.98 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M33902 M33903 M33904 M33905 M33906 M33907 M33910 M33912 2 3 4 5 6 7 9 12 Nominal Diameter Inch mm 0.441 11.20 0.468 11.89 0.544 13.82 0.594 15.09 0.645 16.38 0.645 16.38 0.752 19.10 0.879 22.33 Jacket Thickness Inch mm 0.047 1.19 0.047 1.19 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.083 2.11 • UL Sunlight Resistant • UL Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 196 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Foil Shield > 600 V Manhattan™ Control Cable 600 V Foil Shield, Multiconductor, PVC/Nylon, PVC 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M39109 2 UL TC Conductor Color Coding Jacket Thickness Inch mm 0.048 1.22 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Operating Temperature • -25°C to +90°C Nominal Diameter Inch mm 0.287 7.29 Part No. Conductors M39110 2 Nominal Diameter Inch mm 0.305 7.75 Jacket Thickness Inch mm 0.048 1.22 • Chart D (page 531) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M39111 2 Nominal Diameter Inch mm 0.359 9.11 Jacket Thickness Inch mm 0.048 1.22 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors M39112 2 Nominal Diameter Inch mm 0.397 10.08 Jacket Thickness Inch mm 0.048 1.22 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 197 Cable > Manhattan > Control Cable > Multiconductor > Foil Shield > 600 V Manhattan™ Control Cable 600 V Foil Shield, Multiconductor, PVC/Nylon, PVC 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Conductors 7616/6 6 UL TC Nominal Diameter Inch mm 0.401 10.19 Jacket Thickness Inch mm 0.048 1.22 14 AWG (2.08 mm2) Stranding: 7/0.0242 (41 x 0.62 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Operating Temperature • -25°C to +90°C Conductor Color Coding Part No. Conductors 7614/6 6 Nominal Diameter Inch mm 0.447 11.35 Jacket Thickness Inch mm 0.048 1.22 • Chart J1 (page 533) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductors • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Availability Bulk, cut to length (Minimums may apply) 198 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 300 V Manhattan™ Control Cable 300 V Unshielded, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39071 M39072 2 3 UL PLTC, ITC UL CMG CSA CMG FT4 Operating Temperature • -20°C to +105°C Conductor Color Coding Nominal Diameter Inch mm 0.203 5.16 0.213 5.41 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39073 M39074 2 3 Nominal Diameter Inch mm 0.223 5.66 0.234 5.94 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 • Chart D (page 531) 18 AWG (0.96 mm2) Materials • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket Features Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39075 M39076 2 3 Nominal Diameter Inch mm 0.243 6.17 0.256 6.50 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 • UL Sunlight Resistant 16 AWG (1.32 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Stranding: 19/0.0117 (7 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39077 M39078 2 3 Nominal Diameter Inch mm 0.261 6.63 0.275 6.99 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) Part No. Conductors M39079* M39080* 2 3 Nominal Diameter Inch mm 0.325 8.26 0.343 8.71 Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 *Not CMG approved. 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.032 (0.81 mm) Part No. Conductors M39081* 2 Nominal Diameter Inch mm 0.423 10.74 Jacket Thickness Inch mm 0.053 1.35 *Not CMG approved. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 199 Cable > Manhattan > Control Cable > Multipair > Foil Shield, Individual Pairs > 300 V Manhattan™ Control Cable 300 V Foil Shield, Individual Pairs, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) UL PLTC, ITC UL CMG CSA CMG Operating Temperature • -20°C to +105°C Part No. Pairs M39147 M39148 M39149 M39150 M39151 M39152 M39153 M39154 M39155 M39156 2 3 4 6 9 11 15 19 27 51 Nominal Diameter Inch mm 0.320 8.13 0.338 8.59 0.368 9.35 0.457 11.61 0.529 13.44 0.563 14.30 0.582 14.78 0.646 16.41 0.763 19.38 1.005 25.53 Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.075 1.91 Conductor Color Coding • Chart BR (page 529) 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Slate PVC jacket Part No. Pairs M39157 M39158 M39159 M39160 M39161 M39162 M39163 2 3 4 6 9 11 15 Nominal Diameter Inch mm 0.410 10.41 0.434 11.02 0.473 12.01 0.563 14.30 0.677 17.20 0.731 18.57 0.820 20.83 Jacket Thickness Inch mm 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 Features • UL Sunlight Resistant Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 200 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Control Cable > Multipair > Overall Foil Shield > 300 V Manhattan™ Control Cable 300 V Overall Foil Shield, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) UL PLTC, ITC UL CMG CSA CMG Operating Temperature • -20°C to +105°C Part No. Pairs M39130 M39131 M39132 M39133 M39134 M39135 M39136 M39137 M39138 M39139 2 3 4 6 9 11 15 19 27 51 Nominal Diameter Inch mm 0.296 7.52 0.312 7.92 0.339 8.61 0.420 10.67 0.483 12.27 0.520 13.21 0.580 14.73 0.642 16.31 0.759 19.28 0.995 25.27 Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.075 1.91 Conductor Color Coding • Chart BR (page 529) 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Slate PVC jacket Part No. Pairs M39140 M39141 M39142 M39143 M39144 M39145 M39146 2 3 4 6 9 11 15 Nominal Diameter Inch mm 0.362 9.19 0.403 10.24 0.438 11.13 0.518 13.16 0.622 15.80 0.671 17.04 0.751 19.08 Jacket Thickness Inch mm 0.043 1.09 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 Features • UL Sunlight Resistant Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 201 Cable > Manhattan > Control Cable > Multiconductor > Overall Foil Shield > 300 V Manhattan™ Control Cable 300 V Overall Foil Shield, Multiconductor, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39113 M39114 2 3 UL PLTC, ITC UL CMG CSA CMG FT4 Nominal Diameter Inch mm 0.207 5.26 0.214 5.44 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) Operating Temperature • -20°C to +105°C Conductor Color Coding Part No. Conductors M39115 M39116 2 3 Nominal Diameter Inch mm 0.227 5.77 0.238 6.05 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 • Chart D (page 531) 18 AWG (0.96 mm2) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester tape shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Slate PVC jacket Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M39117 M39118 2 3 Stranding: 19/0.0117 (7 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors • UL Sunlight Resistant M39119 M39120 2 3 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 16 AWG (1.32 mm2) Features Availability Nominal Diameter Inch mm 0.247 6.27 0.260 6.60 Nominal Diameter Inch mm 0.265 6.73 0.279 7.09 Jacket Thickness Inch mm 0.038 0.97 0.038 0.97 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.022 (0.56 mm) Part No. Conductors M39121* M39122* 2 3 Nominal Diameter Inch mm 0.329 8.36 0.347 8.81 Jacket Thickness Inch mm 0.043 1.09 0.043 1.09 *Not CMG approved. 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.032 (0.41 mm) Part No. Conductors M39123* 2 Nominal Diameter Inch mm 0.427 10.85 Jacket Thickness Inch mm 0.053 1.35 *Not CMG approved. 202 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Unshielded > 300 V Manhattan™ Instrumentation Cable 300 V Unshielded Pairs, PVC, PVC 20 AWG (0.52 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs M9500010 1 UL PLTC, ITC UL CL3 CSA CMG FT4 Operating Temperature • -20°C to +105°C Nominal Diameter Inch mm 0.215 5.46 Jacket Thickness Inch mm 0.038 0.97 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs M9508010 1 Nominal Diameter Inch mm 0.235 5.97 Jacket Thickness Inch mm 0.038 0.97 Conductor Color Coding 16 AWG (1.31 mm2) • Black, white Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded bare copper conductors • PVC insulation • Black PVC jacket Part No. Pairs M9506010 1 Nominal Diameter Inch mm 0.259 6.58 Jacket Thickness Inch mm 0.038 0.97 Features • UL Sunlight Resistant Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 203 Cable > Manhattan > Instrumentation Cable > Overall Foil Shield > 300 V Manhattan™ Instrumentation Cable 300 V Overall Foil Shield, Pair, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) 22 AWG (0.35 mm2) drain wire Part No. Pairs 5610B2201 1 UL PLTC, ITC UL CL3 CSA CMG FT4 Nominal Diameter Inch mm 0.192 4.88 Jacket Thickness Inch mm 0.038 0.97 20 AWG (0.52 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) Operating Temperature • -20°C to +105°C Part No. Pairs M9520010 1 Nominal Diameter Inch mm 0.219 5.56 Jacket Thickness Inch mm 0.038 0.97 Conductor Color Coding • Black, white 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG smaller than conductor • Black PVC jacket Features Part No. Pairs M9528010 1 Nominal Diameter Inch mm 0.239 6.07 Jacket Thickness Inch mm 0.038 0.97 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs M9526010 1 Nominal Diameter Inch mm 0.263 6.68 Jacket Thickness Inch mm 0.038 0.97 • UL Sunlight Resistant 14 AWG (2.08 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Stranding: 7/0.0242 (7 x 0.62 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Pairs M9524010* 1 Nominal Diameter Inch mm 0.303 7.70 Jacket Thickness Inch mm 0.043 1.09 *Not CMG approved. 12AWG (3.29 mm2) Stranding: 19/0.0185 (7 x 0.47 mm) Insulation thickness: 0.022 (0.56 mm) 16 AWG (1.31 mm2) drain wire Part No. Pairs 5610B1201* 1 Nominal Diameter Inch mm 0.368 9.35 Jacket Thickness Inch mm 0.045 1.14 *Not CMG approved. 204 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Overall Foil Shield > 600 V Manhattan™ Instrumentation Cable 600 V Pairs, Overall Foil Shield, PVC/Nylon, PVC 20 AWG (0.52 mm2) Stranding: 7/0.0121 (7 x 0.51 mm) Insulation thickness: 0.013 (0.33 mm) PVC/0.003 (0.08 mm) nylon Part No. Pairs 5616B2001 1 UL TC Conductor Color Coding • Chart BW (page 529) Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Jacket Thickness Inch mm 0.040 1.02 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Operating Temperature • -25°C to +90°C Nominal Diameter Inch mm 0.220 5.59 Part No. Pairs M8528010 M8708020 M8708040 M8708060 M8708080 M8708120 M8708160 M8708240 M8708360 M8708500 1 2 4 6 8 12 16 24 36 50 Nominal Diameter Inch mm 0.279 7.09 0.396 10.06 0.456 11.58 0.572 14.53 0.617 15.67 0.737 18.72 0.856 21.74 1.025 26.04 1.188 30.18 1.356 34.44 Jacket Thickness Inch mm 0.048 1.22 0.050 1.27 0.050 1.27 0.065 1.65 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs M8526010 M8706020 M8706040 M8706060 M8706080 M8706120 M8706160 M8706240 M8706360 M8706500 1 2 4 6 8 12 16 24 36 50 Nominal Diameter Inch mm 0.303 7.70 0.435 11.05 0.504 12.80 0.631 16.03 0.682 17.32 0.858 21.79 0.949 24.10 1.141 28.98 1.325 33.66 1.517 38.53 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.048 1.22 0.050 1.27 0.050 1.27 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 205 Cable > Manhattan > Instrumentation Cable > Overall Foil Shield > 600 V Manhattan™ Instrumentation Cable 600 V Pairs, Overall Foil Shield, PVC/Nylon, PVC 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.61 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart BW (page 529) Part No. Pairs M8524010 M8704020 M8704040 M8704060 M8704080 M8704120 M8704160 M8704240 M8704360 M8704500 1 2 4 6 8 12 16 24 36 50 Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Nominal Diameter Inch mm 0.333 8.46 0.484 12.29 0.593 15.06 0.706 17.93 0.764 19.41 0.961 24.41 1.064 27.03 1.286 32.66 1.498 38.05 1.778 45.16 Jacket Thickness Inch mm 0.048 1.22 0.050 1.27 0.065 1.65 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.115 2.92 12AWG (3.29 mm2) Stranding: 19/0.0185 (19 x 0.47 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs 5616B1201 1 Nominal Diameter Inch mm 0.374 9.50 Jacket Thickness Inch mm 0.050 1.27 Features • UL Sunlight Resistant • UL Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 206 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Pairs > 600 V Manhattan™ Instrumentation Cable 600 V Pairs, Overall and Individually Foil Shielded Pairs, PVC/Nylon, PVC 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature • -25°C to +90°C Conductor Color Coding • Chart BW (page 529) Part No. Pairs M8748020 M8748040 M8748060 M8748080 M8748120 M8748160 M8748200 M8748240 M8748360 M8748500 2 4 6 8 12 16 20 24 36 50 Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial (Minimums may apply) Jacket Thickness Inch mm 0.050 1.27 0.050 1.27 0.065 1.65 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs M8746020 M8746040 M8746060 M8746080 M8746120 M8746160 M8746200 M8746240 M8746360 M8746500 2 4 6 8 12 16 20 24 36 50 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.429 10.90 0.497 12.62 0.622 15.80 0.672 17.07 0.806 20.47 0.935 23.75 1.020 25.91 1.123 28.52 1.306 33.17 1.497 38.02 Nominal Diameter Inch mm 0.471 11.96 0.577 14.66 0.686 17.42 0.742 18.85 9.33 23.70 1.034 26.26 1.130 28.70 1.247 31.67 1.454 36.93 1.730 43.94 Jacket Thickness Inch mm 0.050 1.27 0.065 1.65 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.115 2.92 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.61 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs M8744020 M8744040 M8744060 M8744080 M8744120 M8744160 M8744200 M8744240 M8744360 M8744500 2 4 6 8 12 16 20 24 36 50 Nominal Diameter Inch mm 0.523 13.28 0.641 16.28 0.765 19.43 0.869 22.07 1.043 26.49 1.158 29.41 1.267 32.18 1.401 35.59 1.638 41.61 1.945 49.40 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.050 1.27 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.085 2.16 0.115 2.92 207 Cable > Manhattan > Instrumentation Cable > Unshielded Pairs > 600 V Manhattan™ Instrumentation Cable 600 V Unshielded Pairs, PVC/Nylon, PVC 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs 5606B1801 1 UL TC Nominal Diameter Inch mm 0.276 7.01 Jacket Thickness Inch mm 0.050 1.27 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Operating Temperature • -25°C to +90°C Conductor Color Coding Part No. Pairs 5606B1601 1 Nominal Diameter Inch mm 0.300 7.62 Jacket Thickness Inch mm 0.050 1.27 • Black, white Materials • S  tranded bare copper conductors • PVC/nylon insulation • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Availability 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 208 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Unshielded Triads > 300 V Manhattan™ Instrumentation Cable 300 V Unshielded Triads, PVC, PVC 20 AWG (0.52 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Triads M9600010 1 UL PLTC, ITC UL CL3 CSA CMG FT4 Operating Temperature • -20°C to +105°C Nominal Diameter Inch mm 0.226 5.74 Jacket Thickness Inch mm 0.038 0.97 18 AWG (0.81 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Triads M9608010 1 Nominal Diameter Inch mm 0.247 6.27 Jacket Thickness Inch mm 0.038 0.97 Conductor Color Coding 16 AWG (1.31 mm2) • Black, white, red Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) Materials • S  tranded bare copper conductors • PVC insulation • Black PVC jacket Part No. Triads M9606010 1 Nominal Diameter Inch mm 0.293 7.44 Jacket Thickness Inch mm 0.038 0.97 Features • UL Sunlight Resistant Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 209 Cable > Manhattan > Instrumentation Cable > Foil Shield, Triads > 300 V Manhattan™ Instrumentation Cable 300 V Foil Shield, Triads, PVC, PVC 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.013 (0.33 mm) 22 AWG (0.35 mm2) drain wire Part No. Triads 5640B2201 1 UL PLTC, ITC UL CL3 CSA CMG FT4 Nominal Diameter Inch mm 0.201 5.11 Jacket Thickness Inch mm 0.038 0.96 20 AWG (0.52 mm2) Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) Operating Temperature • -20°C to +105°C Conductor Color Coding • Black, white, red Part No. Triads M9620010 5640B2004 5640B2012 1 4 12 Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant Nominal Diameter Inch mm 0.230 5.84 0.410 10.41 0.640 16.28 Jacket Thickness Inch mm 0.038 0.97 0.055 1.39 0.065 1.65 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Triads M9628010 1 Nominal Diameter Inch mm 0.251 6.38 Jacket Thickness Inch mm 0.038 0.97 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Triads M9626010 1 Nominal Diameter Inch mm 0.287 7.29 Jacket Thickness Inch mm 0.043 1.09 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.61 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Triads M9624010* 1 Nominal Diameter Inch mm 0.319 8.10 Jacket Thickness Inch mm 0.043 1.09 *Not CMG approved. 210 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Triads > 300 V Manhattan™ Instrumentation Cable 300 V Overall and Individually Foil Shielded Triads, PVC, PVC 20 AWG (0.51 mm2) Stranding: 7/0.0121 (7 x 0.54 mm) Insulation thickness: 0.013 (0.33 mm) 22 AWG (0.35 mm2) drain wire UL PLTC CSA CMG FT4 Part No. Triads 5650B2004 5650B2008 5650B2012 4 8 12 Nominal Diameter Inch mm 0.458 11.63 0.586 14.88 0.723 18.36 Jacket Thickness Inch mm 0.055 1.39 0.055 1.39 0.065 1.65 Operating Temperature • -20°C to +105°C • -20°C to +60°C (CMG) Conductor Color Coding • Black, white, red • White conductors are numbered Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant Availability 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 211 Cable > Manhattan > Instrumentation Cable > Overall Foil Shield, Triads > 600 V Manhattan™ Instrumentation Cable 600 V Overall Foil Shield, Triads, PVC/Nylon, PVC 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature Part No. Triads M8628010 M8808020 M8808040 M8808080 M8808120 M8808240 1 2 4 8 12 24 Nominal Diameter Inch mm 0.293 7.44 0.450 11.43 0.552 14.02 0.708 17.98 0.890 22.61 1.186 30.12 Jacket Thickness Inch mm 0.048 1.22 0.050 1.27 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 • -25°C to +90°C Conductor Color Coding 16 AWG (1.31 mm2) • Black, white, red • White conductors are numbered Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Triads M8626010 M8806020 M8806040 M8806080 M8806120 M8806240 1 2 4 8 12 24 Nominal Diameter Inch mm 0.319 8.10 0.497 12.62 0.609 15.47 0.785 19.94 0.987 25.07 1.323 33.60 Jacket Thickness Inch mm 0.048 1.22 0.050 1.27 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.62 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Triads M8624010 M8804020 M8804040 M8804080 M8804120 M8804240 1 2 4 8 12 24 Nominal Diameter Inch mm 0.351 8.92 0.585 14.86 0.680 17.27 0.923 23.44 1.109 28.17 1.495 37.97 Jacket Thickness Inch mm 0.048 1.22 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 (Minimums may apply) 212 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Multitriads > 600 V Manhattan™ Instrumentation Cable 600 V Overall and Individually Foil Shielded Multitriads, PVC/Nylon, PVC 18 AWG (0.81 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon UL TC Operating Temperature Part No. Triads M8848020 M8848040 M8848080 M8848120 M8848240 2 4 8 12 24 • -25°C to +90°C Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min., on both individual triads and overall cable Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductor • Black PVC jacket Features • UL Sunlight Resistant • UL Direct Burial Jacket Thickness Inch mm 0.050 1.27 0.065 1.65 0.085 2.16 0.085 2.16 0.065 2.16 16 AWG (1.31 mm2) Conductor Color Coding • Black, white, red • White conductors are numbered Nominal Diameter Inch mm 0.501 12.73 0.614 15.60 0.832 21.13 0.996 25.30 1.336 33.93 Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Triads M8846020 M8846040 M8846080 M8846120 M8846240 2 4 8 12 24 Nominal Diameter Inch mm 0.583 14.81 0.677 17.20 0.918 23.32 1.104 28.04 1.488 37.80 Jacket Thickness Inch mm 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.085 2.16 14 AWG (2.08 mm2) Stranding: 7/0.0242 (7 x 0.61 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Triads M8844020 M8844040 M8844080 M8844120 M8844240 2 4 8 12 24 Nominal Diameter Inch mm 0.648 16.46 0.755 19.18 1.026 26.06 1.238 31.45 1.738 44.15 Jacket Thickness Inch mm 0.065 1.65 0.065 1.65 0.085 2.16 0.085 2.16 0.115 2.92 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 213 Cable > Manhattan > Instrumentation Cable > Overall Foil Shield, Composite > 300 V Manhattan™ Instrumentation Cable 300 V Overall Foil Shield, Composite, PVC/Nylon, PVC 20 AWG (0.52 mm2) Pairs Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) UL PLTC, ITC UL CL3 CSA CMG FT4 Operating Temperature • -20°C to +105°C Conductor Color Coding Part No. Pairs M9700020 M9700040 M9700060 M9700080 M9700120 M9700160 5610B2020* M9700240 M9700360 M9700500 2 4 6 8 12 16 20 24 36 50 Nominal Diameter Inch mm 0.321 8.15 0.400 10.16 0.451 11.46 0.511 12.98 0.581 14.76 0.660 16.76 0.677 17.20 0.791 20.09 0.925 23.50 1.069 27.15 Jacket Thickness Inch mm 0.045 1.14 0.053 1.35 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.065 1.65 0.063 1.60 0.073 1.85 0.073 1.85 *No communication wire. • Chart BW (page 529) 18 AWG (0.81 mm2) Pairs Materials • S  tranded bare copper conductors • PVC insulation • Communications wire is 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) sttranding, bare copper with 0.016 (0.41 mm) thick insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG smaller than conductor • Black PVC jacket Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon Part No. Pairs M9708020 M9708040 M9708060 M9708080 M9708120 M9708160 M9708240 M9708360 M9708500 2 4 6 8 12 16 24 36 50 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 214 Jacket Thickness Inch mm 0.045 1.14 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.073 1.85 0.073 1.85 0.073 1.85 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC Features • UL Sunlight Resistant Nominal Diameter Inch mm 0.353 8.97 0.431 10.95 0.499 12.67 0.558 14.17 0.664 16.87 0.735 18.67 0.905 22.99 1.049 26.64 1.199 30.45 Part No. Pairs M9706020 M9706040 M9706060 M9706080 M9706120 M9706160 M9706240 M9706360 M9706500 2 4 6 8 12 16 24 36 50 Nominal Diameter Inch mm 0.409 10.39 0.471 11.96 0.559 14.20 0.639 16.23 0.747 18.97 0.829 21.06 1.023 25.98 1.189 30.20 1.382 35.10 Jacket Thickness Inch mm 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 0.073 1.85 0.073 1.85 0.083 2.11 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Pairs > 300 V Manhattan™ Instrumentation Cable 300 V Overall and Individually Foil Shielded Pairs, Composite PVC/Nylon, PVC 20 AWG (0.52 mm2)* Stranding: 7/0.0121 (7 x 0.31 mm) Insulation thickness: 0.016 (0.41 mm) UL PLTC, ITC UL CL3 CSA CMG FT4 Operating Temperature • -20°C to +105°C Conductor Color Coding • Chart BW (page 529) Part No. Pairs M9740020 M9740040 M9740060 M9740080 M9740120 M9740160 5620B2020** M9740240 M9740360 M9740500 2 4 6 8 12 16 20 24 36 50 Features • UL Sunlight Resistant Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.045 1.14 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.065 1.65 0.073 1.85 0.073 1.85 0.073 1.85 *Communications wire is 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) stranding, bare copper with 0.016 (0.41 mm) thick insulation. **0.013 (0.33 mm) insulation thickness. Materials • S  tranded bare copper conductors • PVC/nylon insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire one even AWG size smaller than conductors • Black PVC jacket Nominal Diameter Inch mm 0.349 8.86 0.427 10.85 0.493 12.52 0.539 13.69 0.643 16.33 0.724 18.39 0.752 19.10 0.882 22.40 1.011 25.68 1.169 29.69 18 AWG (0.82 mm2) Stranding: 7/0.0152 (7 x 0.39 mm) Insulation thickness: 0.016 (0.41 mm) PVC Part No. Pairs M9748020 M9748040 M9748060 M9748080 M9748120 M9748160 5620B1820 M9748240 M9748360 M9748500 2 4 6 8 12 16 20 24 36 50 Nominal Diameter Inch mm 0.401 10.19 0.463 11.76 0.547 13.89 0.616 15.65 0.712 18.08 0.805 20.45 0.921 23.36 0.983 24.97 1.130 28.70 1.349 34.26 Jacket Thickness Inch mm 0.053 1.35 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 0.075 1.91 0.073 1.85 0.073 1.85 0.083 2.11 *Communications wire is 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) stranding, bare copper with 0.016 (0.41 mm) thick insulation. 16 AWG (1.31 mm2) Stranding: 7/0.0192 (7 x 0.49 mm) Insulation thickness: 0.016 (0.41 mm) PVC (Minimums may apply) Part No. Pairs M9746020 M9746040 M9746060 M9746080 M9746120 M9746160 M9746240 M9746360 M9746500 2 4 6 8 12 16 24 36 50 Nominal Diameter Inch mm 0.441 11.20 0.512 13.00 0.630 16.00 0.690 17.53 0.819 20.80 0.929 23.60 1.123 28.52 1.328 33.73 1.521 38.63 Jacket Thickness Inch mm 0.053 1.35 0.053 1.35 0.063 1.60 0.063 1.60 0.063 1.60 0.073 1.85 0.073 1.85 0.083 2.11 0.083 2.11 *Communications wire is 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) stranding, bare copper with 0.016 (0.41 mm) thick insulation. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 215 Cable > Manhattan > Computer Cable > Multiconductor > Unshielded > 300 V Manhattan™ Computer Cable 300 V Unshielded, Multiconductor, PVC, PVC 20 AWG (0.50 mm2) Stranding: 10/30 (10 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2464 UL CL2 CSA AWM I/II A/B FT4 Applications • Control and signal wiring • Computers • Instrumentation Part No. Conductors 882002 882003 882004 882005 882006 882007 882008 882010 882012 882015 882020 882025 2 3 4 5 6 7 8 10 12 15 20 25 Nominal Diameter Inch mm 0.202 5.13 0.213 5.41 0.231 5.87 0.251 6.38 0.272 6.91 0.272 6.91 0.293 7.44 0.318 8.08 0.338 8.59 0.389 9.88 0.430 10.92 0.471 11.96 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Color Code R R R R R R R R R F R R Operating Temperature • -20°C to +105°C (CSA) • -20°C to +90°C (CL2) • -20°C to +80°C (AWM) 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Conductor Color Coding Part No. Conductors • See tables 881802 881803 881804 881805 881806 881807 881808 881809 881812 881815 881820 881825 2 3 4 5 6 7 8 9 12 15 20 25 Materials • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Nominal Diameter Inch mm 0.222 5.64 0.234 5.94 0.255 6.48 0.278 7.06 0.289 7.34 0.302 7.67 0.341 8.66 0.379 9.63 0.408 10.36 0.465 11.81 0.511 12.98 0.600 15.24 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Color Code R F R R R R R R F F R F (Minimums may apply) 216 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Unshielded > 300 V Manhattan™ Computer Cable 300 V Unshielded, Multiconductor, PVC, PVC 16 AWG (1.32 mm2) Stranding: 26/30 (26 x 0.25 mm) Insulation thickness: 0.032 (0.81 mm) UL AWM 2464 UL CL2 CSA AWM I/II A/B FT4 Part No. Conductors 881602 881603 881604 881605 881606 881607 881610 2 3 4 5 6 7 10 Nominal Diameter Inch mm 0.312 7.92 0.329 8.36 0.375 9.53 0.405 10.29 0.410 10.41 0.455 11.56 0.578 14.68 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 Color Code F F F F R F R Applications • Control and signal wiring • Computers • Instrumentation 14 AWG (2.08 mm2) Stranding: 41/30 (65 x 0.25 mm) Insulation thickness: 0.031 (0.78 mm) Operating Temperature Part No. Conductors • -20°C to +105°C (CSA) • -20°C to +90°C (CL2) • -20°C to +80°C (AWM) 881403 881404 881405 3 4 5 Nominal Diameter Inch mm 0.378 9.60 0.434 11.02 0.485 12.32 Jacket Thickness Inch mm 0.035 0.89 0.045 1.14 0.060 1.52 Color Code F F F Conductor Color Coding • See tables 12 AWG (3.29 mm2) Stranding: 65/30 (65 x 0.25 mm) Insulation thickness: 0.031 (0.78 mm) Materials • S  tranded tinned copper conductors • PVC insulation • Slate PVC jacket Part No. Conductors 881202 881203 2 3 Nominal Diameter Inch mm 0.396 10.06 0.423 10.74 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 Color Code F F Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 217 Cable > Manhattan > Computer Cable > Multiconductor > Unshielded > 300 V Manhattan™ Computer Cable 300 V Unshielded, Multiconductor, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CL2 CSA AWM I/II A/B FT4 Part No. Conductors 882402 882403 882404 882406 2 3 4 6 Operating Temperature • -20°C to +105°C (CSA) • -20°C to +90°C (CL2) • -20°C to +80°C (AWM) Conductor Color Coding • See tables Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Slate PVC jacket Availability Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Color Code E E E E 22 AWG (0.35 mm2) Applications • Control and signal wiring • Computers • Instrumentation Nominal Diameter Inch mm 0.152 3.86 0.159 4.04 0.170 4.32 0.197 5.00 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 882202 882203 882204 882205 882206 882207 882208 882209 882210 882212 882215 882220 882225 882230 882240 882250 882260 2 3 4 5 6 7 8 9 10 12 15 20 25 30 40 50 60 Nominal Diameter Inch mm 0.164 4.17 0.172 4.37 0.185 4.70 0.200 5.08 0.215 5.46 0.215 5.46 0.230 5.84 0.246 6.25 0.264 6.71 0.272 6.91 0.294 7.47 0.326 8.28 0.364 9.25 0.385 9.78 0.429 10.90 0.478 12.14 0.520 13.21 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.035 0.89 Color Code R R R R R R R R R R F F F F F F F 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) (Minimums may apply) 218 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Unshielded > 300 V Manhattan™ Computer Cable 300 V Unshielded, Multiconductor, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (10 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2343 UL CMG CSA CMG FT4 Part No. Conductors M4501 M4502 M4503 M4504 M4506 7 12 15 19 37 Applications • Control and signal wiring • Computers • Instrumentation Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • Chart E (page 532) Nominal Diameter Inch mm 0.262 6.65 0.312 7.92 0.332 8.43 0.349 8.86 0.437 11.10 Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M4508 M4510 M4511 M4512 M4513 M4514 M4515 2 7 12 15 19 27 37 Nominal Diameter Inch mm 0.229 5.82 0.280 7.11 0.337 8.56 0.360 9.14 0.379 9.63 0.437 11.10 0.479 12.17 Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M4517 M4518 M4519 M4520 M4522 M4523 M4524 2 5 7 12 19 27 37 Nominal Diameter Inch mm 0.245 6.22 0.287 7.29 0.304 7.72 0.370 9.40 0.419 10.64 0.486 12.34 0.535 13.59 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 219 Cable > Manhattan > Computer Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multiconductor, PVC, PVC 20 AWG (0.56 mm2) Stranding: 7/28 (10 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Color Code D UL AWM 2464 UL CMG CSA CMG FT4 Applications • Control and signal wiring • Computers • Instrumentation Operating Temperature Part No. Conductors M4660 M4661 M4662 M4664 M4665 M4666 M4668 M4670 M4672 M4673 M4675 M4677 2 3 4 6 8 10 15 20 25 30 40 50 • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 0.053 1.35 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Color Code D Conductor Color Coding • See tables Nominal Diameter Inch mm 0.211 5.36 0.222 5.64 0.240 6.10 0.282 7.16 0.304 7.72 0.351 8.92 0.393 9.98 0.437 11.10 0.491 12.47 0.520 13.21 0.625 15.88 0.685 17.40 Part No. Conductors M4690 M4691 M4692* M4693* M4694 M4696 M4697 M4698 M4700 M4702 M4704 M4706 M4708 2 3 2 3 4 6 8 10 15 20 25 30 40 Nominal Diameter Inch mm 0.229 5.82 0.241 6.12 0.229 5.82 0.241 6.12 0.262 6.65 0.309 7.85 0.334 8.48 0.387 9.83 0.436 11.07 0.485 12.32 0.545 13.84 0.620 15.75 0.690 17.53 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 0.053 1.35 *Conductor color coding: 1 Brown, 2 Blue, 3 Green/Yellow. (Minimums may apply) 220 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multiconductor, PVC, PVC 16 AWG (1.32 mm2) Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Color Code R UL AWM 2464 UL CMG CSA CMG FT4 Applications • Control and signal wiring • Computers • Instrumentation Operating Temperature Part No. Conductors M4720 M4721 M4722* M4723* M4724 M4726 M4728 M4730 M4732 M4734 M4736 2 3 2 3 4 6 8 10 15 20 30 Nominal Diameter Inch mm 0.253 6.43 0.267 6.78 0.253 6.43 0.267 6.78 0.291 7.39 0.345 8.76 0.374 9.50 0.435 11.05 0.489 12.42 0.547 13.89 0.697 17.70 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 *Conductor color coding: 1 Brown, 2 Blue, 3 Green/Yellow. • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • See tables Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 221 Cable > Manhattan > Computer Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multiconductor, PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CL2 CSA AWM I/II A/B FT4 Part No. Conductors 1012405 1012407 1012409 5 7 9 Nominal Diameter Inch mm 0.190 4.83 0.205 5.21 0.236 5.99 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 Applications • Sound broadcast • Instrumentation Operating Temperature • -20°C to +80°C Conductor Color Coding • Chart R (page 535) Materials • S  tranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 222 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multiconductor, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CMG CSA CMG FT4 Applications • C  omputer and control applications Operating Temperature Part No. Conductors M4602 M4603 M4604 M4606 M4607 M4608 M4610 M4612 M4614 M4616 M4618 M4620 2 3 4 6 8 10 15 20 25 30 40 50 • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • Chart E (page 532) Nominal Diameter Inch mm 0.159 4.04 0.166 4.22 0.178 4.52 0.204 5.18 0.217 5.51 0.247 6.27 0.273 6.93 0.301 7.65 0.335 8.51 0.353 8.97 0.393 9.98 0.430 10.92 Part No. Conductors M4633 M4634 M4635 M4636 M4638 M4640 M4642 M4644 M4646 M4648 M4650 M4652 2 3 4 6 8 10 15 20 25 30 40 50 Nominal Diameter Inch mm 0.171 4.34 0.179 4.55 0.192 4.88 0.222 5.64 0.237 6.02 0.271 6.88 0.301 7.65 0.333 8.46 0.371 9.42 0.392 9.96 0.436 11.07 0.479 12.17 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 223 Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multiconductor, SR-PVC, PVC 65% Braid Coverage 28 AWG (0.08 mm2) Stranding: 7/36 (7 x 0.12 mm) Insulation thickness: 0.010 (0.25 mm) Color Code D UL AWM 2464 UL CMG CSA CMG FT4 Applications • • • •  S-232 R Modems Multiplexers Serial data interfaces Part No. Conductors M2403 M2404 M2405 M2406 M2407 M2408 M2409 M2410 M2412 M2414 M2416 M2420 3 4 5 6 7 8 9 10 15 25 37 50 70% Braid Coverage 24 AWG (0.22 mm2) Conductor Color Coding Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Color Code E • See tables Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% or 70% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Nominal Diameter Inch mm 0.165 4.19 0.175 4.45 0.185 4.70 0.196 4.98 0.196 4.98 0.206 5.23 0.217 5.51 0.230 5.84 0.251 6.38 0.300 7.62 0.335 8.51 0.376 9.55 Part No. Conductors M5302 M5303 M5304 M5306 M5307 M5308 M5310 M5312 M5314 M5316 M5318 M5320 2 3 4 6 8 10 15 20 25 30 40 50 Nominal Diameter Inch mm 0.181 4.60 0.188 4.78 0.199 5.05 0.226 5.74 0.239 6.07 0.269 6.83 0.295 7.49 0.323 8.20 0.357 9.07 0.375 9.53 0.415 10.54 0.452 11.48 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190.3 pF/m) Part No. M5302: Mutual capacitance: 35 pF/ft (114.8 pF/m) Ground capacitance: 63 pF/ft (206.7 pF/m) (Minimums may apply) 224 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multiconductor, SR-PVC, PVC 65% Braid Coverage 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CMG CSA CMG FT4 Applications • • • •  S-232 R Modems Multiplexers Serial data interfaces Part No. Conductors M2438 M2439 M2440 M2441 M2442 M2443 M2444 M2445 M2447 M2449 M2452 M2455 3 4 5 6 7 8 9 10 15 25 37 50 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Color Code O O O O O O O O F F F F Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190 pF/m) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Nominal Diameter Inch mm 0.185 4.70 0.196 4.98 0.209 5.31 0.223 5.66 0.223 5.66 0.236 5.99 0.250 6.35 0.266 6.76 0.292 7.42 0.354 8.99 0.398 10.11 0.449 11.40 70% Braid Coverage 22 AWG (0.35 mm2) Conductor Color Coding Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Color Code E • See tables Materials Part No. Conductors • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% or 70% coverage • Slate PVC jacket M5333 M5334 M5335 M5336 M5338 M5340 M5342 M5344 M5346 M5348 M5350 M5352 2 3 4 6 8 10 15 20 25 30 40 50 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Nominal Diameter Inch mm 0.193 4.90 0.201 5.11 0.214 5.44 0.244 6.20 0.259 6.58 0.293 7.44 0.323 8.20 0.355 9.02 0.393 9.98 0.414 10.52 0.458 11.63 0.501 12.73 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Mutual capacitance: 36 pF/ft (118.1 pF/m) Ground capacitance: 65 pF/ft (213.3 pF/m) Part No. M5333: Mutual capacitance: 39 pF/ft (128 pF/m) Ground capacitance: 70 pF/ft (229.7 pF/m) (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 225 Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multiconductor, SR-PVC, PVC 65% Braid Coverage 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2464 UL CMG CSA CMG FT4 Applications • • • •  S-232 R Modems Multiplexers Serial data interfaces Operating Temperature Part No. Conductors M2473 M2474 M2475 M2476 M2477 M2478 M2479 M2480 M2481 M2482 M2483 M2485 3 4 5 6 7 8 9 10 15 25 37 50 Nominal Diameter Inch mm 0.198 5.03 0.211 5.36 0.226 5.74 0.241 6.12 0.241 6.12 0.256 6.50 0.272 6.91 0.290 7.37 0.320 8.13 0.390 9.91 0.440 11.18 0.504 12.80 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.86 Color Code O O O O O O O O F F F F Mutual capacitance: 36 pF/ft (118.1 pF/m) Ground capacitance: 65 pF/ft (213.3 pF/m) • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • See table Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% or 70% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 226 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multiconductor, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 2343 UL CMG CSA CMG FT4 Applications • C  omputer and control applications Part No. Conductors M5500 M5501 M5502 M5503 M5504 M5505 M5506 M5507 M5508 5 7 12 15 19 27 37 48 60 22 AWG (0.35 mm2) • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding Part No. Conductors • Chart E (page 532) M5509 M5510 M5511 M5512 M5513 M5514 M5515 M5516 M5517 5 7 12 15 19 27 37 48 60 • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 70% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Mutual capacitance: 32 pF/ft (105 pF/m) Ground capacitance: 58 pF/ft (190 pF/m) Operating Temperature Materials Nominal Diameter Inch mm 0.274 6.96 0.288 7.32 0.338 8.59 0.357 9.07 0.375 9.53 0.426 10.82 0.463 11.76 0.514 13.06 0.551 14.00 Nominal Diameter Inch mm 0.291 7.39 0.306 7.77 0.363 9.22 0.385 9.78 0.405 10.29 0.463 11.76 0.505 12.83 0.563 14.30 0.605 15.37 Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Mutual capacitance: 36 pF/ft (118.1 pF/m) Ground capacitance: 65 pF/ft (213.3 pF/m) 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors M5518 M5519 M5520 M5521 M5522 M5523 M5524 M5525 M5526 5 7 12 15 19 27 37 48 60 Nominal Diameter Inch mm 0.312 7.92 0.330 8.38 0.396 10.06 0.421 10.69 0.445 11.30 0.512 13.00 0.561 14.25 0.628 15.95 0.683 17.35 Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Mutual capacitance: 40 pF/ft (131.2 pF/m) Ground capacitance: 72 pF/ft (236.2 pF/m) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 227 Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Low Capacitance, Multiconductor, FPE, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2919 (30 V) UL CM VW-1 CSA CM FT4 Applications • • • •  S-232, RS-422 R Modems Multiplexers Serial data interfaces Part No. Conductors M2456 M2457 M2458 M2459 M2460 M2461 M2462 M2463 M2465 M2467 M2470 3 4 5 6 7 8 9 10 15 25 37 Nominal Diameter Inch mm 0.217 5.51 0.231 5.87 0.248 6.30 0.265 6.73 0.265 6.73 0.282 7.16 0.300 7.62 0.320 8.13 0.353 8.97 0.432 10.97 0.488 12.40 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 Color Code O O O O O O O O F F F Mutual capacitance: 11.9 pF/ft (39 pF/m) Ground capacitance: 21.4 pF/ft (70.2 pF/m) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CM) Conductor Color Coding • See table Materials • S  tranded tinned copper conductors • Foam polyethylene insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 228 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multiconductor, PVC, PVC 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) UL AWM 2464 UL CMG CSA CMG FT4 Applications • Computer and control Operating Temperature Part No. Conductors M5360 M5361 M5362 M5364 M5365 M5366 M5368 M5370 M5372 M5375 M5377 2 3 4 6 8 10 15 20 25 40 50 • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Materials • S  tranded tinned copper conductors • PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 70% coverage • Slate PVC jacket Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M5390 M5391 M5392* M5393* M5394 M5396 M5397 M5398 M5400 M5402 M5404 M5406 2 3 2 3 4 6 8 10 15 20 25 30 (Minimums may apply) Nominal Diameter Inch mm 0.251 6.38 0.263 6.68 0.251 6.38 0.263 6.68 0.284 7.21 0.328 8.33 0.356 9.04 0.409 10.39 0.456 11.58 0.507 12.88 0.609 15.47 0.648 16.46 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 0.053 1.35 *Conductor color coding: 1 Brown, 2 Blue, 3 Green/Yellow. 16 AWG (1.32 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 0.053 1.35 18 AWG (0.81 mm2) Conductor Color Coding • Chart D (page 531) Nominal Diameter Inch mm 0.233 5.92 0.241 6.12 0.262 6.65 0.304 7.72 0.326 8.28 0.373 9.47 0.415 10.54 0.459 11.66 0.513 13.03 0.653 16.59 0.713 18.11 Stranding: 19/0.0117 (19 x 0.30 mm) Insulation thickness: 0.016 (0.41 mm) Part No. Conductors M5420 M5421 M5422* M5423* M5424 M5426 M5428 M5430 M5432 M5434 M5436 2 3 2 3 4 6 8 10 15 20 25 Nominal Diameter Inch mm 0.275 6.99 0.289 7.34 0.275 6.99 0.289 7.34 0.313 7.95 0.367 9.32 0.396 10.06 0.457 11.61 0.511 12.98 0.611 15.52 0.687 17.45 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 0.053 1.35 *Conductor color coding: 1 Brown, 2 Blue, 3 Green/Yellow. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 229 Cable > Manhattan > Computer Cable > Multipair > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multipair, PVC, PVC 22 AWG (0.35 mm2) Stranding: Solid Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M3191 M3192 51 102 UL AWM 2464 UL CMG CSA CMG FT4 Nominal Diameter Inch mm 0.710 18.03 1.120 28.45 Jacket Thickness Inch mm 0.050 1.27 0.085 2.16 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.016 (0.41 mm) Applications • Modems • Multiplexers • General data interfaces Operating Temperature Part No. Pairs M4785 M4786 M4789 M4791 2 3 12 19 • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Materials • S  olid or stranded tinned copper conductors • PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 18 AWG (0.81 mm2) Stranding: 16/30 (16 x 0.25 mm) Insulation thickness: 0.016 (0.41 mm) Conductor Color Coding • Chart A (page 528) Nominal Diameter Inch mm 0.301 7.65 0.319 8.10 0.548 13.92 0.688 17.48 Part No. Pairs M4799 M4793 M4794 2 3 6 Nominal Diameter Inch mm 0.330 8.38 0.350 8.89 0.462 11.73 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 230 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multipair > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Multipair, SR-PVC or PP, PVC SR-PVC Insulation 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Color Code K UL AWM 2464 UL CMG CSA CMG FT4 Applications • • • •  S-232 R Modems Multiplexers Serial data interfaces Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding Part No. Pairs M13190 M13191 M13192 M13193 M13194 M13195 M13196 M13197 M13198 M13199 M4758* M13200 M3189 M13201 M4761* M13202** 1 2 3 4 5 6 7 8 9 10 11 15 19 25 27 50 Nominal Diameter Inch mm 0.159 4.04 0.215 5.46 0.227 5.77 0.246 6.25 0.267 6.78 0.289 7.34 0.289 7.34 0.311 7.90 0.334 8.48 0.360 9.14 0.360 9.14 0.402 10.21 0.432 10.97 0.510 12.95 0.515 13.08 0.666 16.92 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.035 0.89 0.032 0.89 0.035 0.89 *Color code Chart B (page 528) **Color code Chart A1 (page 528) • See tables Materials • S  olid or stranded tinned copper conductors • Semirigid PVC or polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length SR-PVC Insulation 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Color Code B Part No. Pairs M4770 M4771 M4772 M4773 M4774 M4775 M4776 M4777 M4778 M4779 2 3 4 5 6 9 11 15 19 27 Nominal Diameter Inch mm 0.235 5.97 0.248 6.30 0.269 6.83 0.293 7.44 0.318 8.08 0.369 9.37 0.399 10.13 0.448 11.38 0.481 12.22 0.618 15.70 Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.053 1.35 Polypropylene Insulation (Minimums may apply) 22 AWG (0.35 mm2) Stranding: Solid Insulation thickness: 0.008 (0.20 mm) Color Code K Part No. Pairs M3190 38 Nominal Diameter Inch mm 0.610 15.49 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.045 1.14 231 Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multipair, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) UL AWM 1061 UL AWM 2343 UL CMG CSA CMG FT4 Part No. Pairs M5650 M5651 M5652 M5653 M5654 M5655 M5656 5 7 12 15 19 27 37 Part No. M5650 Mutual capacitance: 25 pF/ft (82 pF/m) Ground capacitance: 45 pF/ft (147.6 pF/m) • C  ontrol, signal, and data transmission computers • Industrial and electronic equipment 22 AWG (0.35 mm2) Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) Conductor Color Coding • Chart B (page 528) Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 70% coverage • Slate PVC jacket 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Mutual capacitance: 23.1 pF/ft (75.8 pF/m) Ground capacitance: 42 pF/ft (137.8 pF/m) Applications Availability Nominal Diameter Inch mm 0.351 8.92 0.373 9.47 0.455 11.56 0.486 12.34 0.516 13.11 0.599 15.21 0.666 16.92 Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M5660 M5661 M5662 M5665 M5666 5 7 12 27 37 Nominal Diameter Inch mm 0.377 9.58 0.402 10.21 0.496 12.60 0.666 16.92 0.735 18.67 Jacket Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Ground capacitance: 49 pF/ft (160.8 pF/m) 20 AWG (0.56 mm2) Stranding: 7/28 (7 x 0.32 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Pairs M5670 M5671 M5673 M5674 M5675 5 7 15 19 27 Nominal Diameter Inch mm 0.413 10.49 0.442 11.23 0.592 15.04 0.631 16.03 0.746 18.95 Jacket Thickness Inch Mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Mutual capacitance: 27 pF/ft (88.6 pF/m) Ground capacitance: 49 pF/ft (160.8 pF/m) Part No. M5670 Mutual capacitance: 29 pF/ft (95.1 pF/m) Ground capacitance: 52 pF/ft (170.6pF/m) (Minimums may apply) 232 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multipair > Foil Shield > 300 V Manhattan™ Computer Cable 300 V Foil Shield, Low Capacitance, 100 ohm, Multipair, FPP, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.0185 (0.47 mm) UL AWM 2493 UL CM CSA CM FT4 Applications • R  S-232 • RS-422 Part No. Pairs M39249 M39250 M39251 M39252 M39254 M39256 M39257 M39259 M39260 M39262 M39268 2 3 4 6 9 11 12 15 17 19 27 Operating Temperature • -20°C to +75°C (CM) • -20°C to +60°C (AWM) Nominal Diameter Inch mm 0.323 8.20 0.340 8.64 0.369 9.37 0.436 11.07 0.506 12.85 0.580 14.73 0.597 15.16 0.646 16.41 0.682 17.32 0.693 17.60 0.821 20.85 Jacket Thickness Inch mm 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.065 1.65 0.065 1.65 0.065 1.65 0.065 1.65 0.065 1.65 0.065 1.65 Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 23 pF/ft (75.5 pF/m) Part No. 39256 Mutual capacitance: 11.9 pF/ft (39 pF/m) Ground capacitance: 21.4 pF/ft (70.2 pF/m) Conductor Color Coding • Chart K (page 529) Materials • S  tranded tinned copper conductors • Foam polypropylene insulation • Aluminum/polyester foil shield, 25% overlap min. Foil facing inward Stranded tinned copper drain wire equal in size to conductor • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 233 Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multipair, FPP, PVC 28 AWG (0.09 mm2) Stranding: 7/36 (7 x 0.13 mm) Insulation thickness: 0.0145 (0.37 mm) UL AWM 2919 (30 V) UL CM CSA CM Applications • R  S-422 • Modems • Multiplexers Operating Temperature Part No. Pairs M2487 M2488 M2489 M2490 M2492 M2493 M2494 M2495* M2496 M2497 M2498 2 3 4 5 7 8 10 12.5 15 18 25 *Discrete conductor is polyethylene insulated. 24 AWG (0.22 mm2) Conductor Color Coding Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.0125 (0.32 mm) • Chart M (page 530) • S  tranded tinned copper conductors • Foam polypropylene insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.048 1.22 Mutual capacitance: 11 pF/ft (36.1 pF/m) Ground capacitance: 20 pF/ft (65.6 pF/m) • -20°C to +80°C (AWM) • -20°C to +75°C (CM) Materials Nominal Diameter Inch mm 0.240 6.10 0.252 6.40 0.271 6.88 0.292 7.42 0.314 7.98 0.336 8.53 0.385 9.78 0.395 10.03 0.427 10.85 0.457 11.61 0.555 14.10 Part No. Pairs M3420 M3421 M3422 M3423 M3424 M3425 M3426 M3427 M3428* M3429 M3430 M3431 2 3 4 5 6 7 8 10 12.5 15 18 25 Nominal Diameter Inch mm 0.257 6.53 0.269 6.83 0.290 7.37 0.314 7.98 0.338 8.59 0.338 8.59 0.363 9.22 0.417 10.59 0.429 10.90 0.475 12.07 0.524 13.31 0.608 15.44 Jacket Thickness Inch mm 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.040 1.02 0.048 1.22 0.050 1.27 Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 22 pF/ft (72.2 pF/m) *Discrete conductor is polyethylene insulated. 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 234 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Low Capacitance, Multipair, FPP, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.0185 (0.47 mm) UL AWM 2343 UL CM CSA CM Applications • R  S-422 • Modems • Multiplexers Part No. Pairs M3475 M3476 M3477 M3478 M3479 M3480 M3481 M3482 M3483 M3484 M3485 2 3 4 5 6 7 8 10 15 18 25 Operating Temperature • -20°C to +75°C (AWM) • -20°C to +75°C (CM) Nominal Diameter Inch mm 0.346 8.79 0.363 9.22 0.392 9.96 0.425 10.80 0.459 11.66 0.459 11.66 0.494 12.55 0.603 15.32 0.669 16.99 0.716 18.19 0.832 21.13 Jacket Thickness Inch mm 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.048 1.22 0.065 1.65 0.065 1.65 0.065 1.65 0.065 1.65 Mutual capacitance: 12.5 pF/ft (41 pF/m) Ground capacitance: 23 pF/ft (23 pF/m) Part No. M3484 and 3485: Mutual capacitance: 11.9 pF/ft (39 pF/m) Ground capacitance: 21.4 pF/ft (21.4 pF/m) Conductor Color Coding • Chart K (page 529) Materials • S  tranded tinned copper conductors • Foam polypropylene insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 65% coverage • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 235 Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Low Capacitance, 100 Ohm, Multipair, PE, PVC UL AWM 2960, CM 28 AWG (0.08 mm2) Stranding: 7/36 (7 x 0.12 mm) Insulation thickness: 0.010 (0.25 mm) Color Code K UL AWM 2960 (30 V) UL 2919 (30 V) UL CM CSA CM Applications • R  S-422 • Modems • Multiplexers Part No. Pairs M3970 M3971 M3972 M3973 M3974 M3975 M3977 M3931 M3978 M3979 M3932 2 3 4 5 7 9 12 13 18 25 31 UL AWM 2919, CM 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.016 (0.25 mm) Color Code M Conductor Color Coding • See tables Part No. Pairs Materials M3993† M3980* M3990† M3981* M3991† M3982* M3992† M3983* M3940* M3984* M3985* M3986* M3987* M3988* M3989* 1 2 2 3 3 4 4 5 6 7 9 10 12 18 25 • S  tranded tinned copper conductors • Polyethylene insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire equal in size to conductor Tinned copper braid, 90% coverage (65% where noted) • Slate PVC jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Jacket Thickness Inch mm 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 Mutual capacitance: 15.5 pF/ft (50.9 pF/m) Ground capacitance: 27.5 pF/ft (90.2 pF/m) Operating Temperature • -20°C to +80°C (AWM 2919) • -20°C to +75°C (CM) • -20°C to +60°C (AWM 2960) Nominal Diameter Inch mm 0.205 5.21 0.214 5.44 0.229 5.82 0.246 6.25 0.263 6.68 0.299 7.59 0.329 8.36 0.335 8.51 0.377 9.58 0.440 11.18 0.470 11.94 Nominal Diameter Inch mm 0.208 5.28 0.274 6.96 0.280 7.11 0.288 7.32 0.294 7.47 0.312 7.92 0.318 8.08 0.339 8.61 0.367 9.32 0.367 9.32 0.424 10.77 0.457 11.61 0.482 12.24 0.560 14.22 0.671 17.04 Jacket Thickness Inch mm 0.035 0.89 0.032 0.81 0.035 0.89 0.032 0.81 0.035 0.89 0.032 0.81 0.035 0.89 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.032 0.81 0.037 0.94 0.047 1.19 0.047 1.19 Mutual capacitance: 15.5 pF/ft (50.9 pF/m) Ground capacitance: 27.5 pF/ft (90.2 pF/m) †120-ohm impedance Mutual capacitance: 12.8 pF/ft (42 pF/m) Ground capacitance: 23 pF/ft (75 pF/m) *65% braid coverage. (Minimums may apply) 236 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V Manhattan™ Computer Cable 300 V Foil/Braid Shield, Multipair, SR-PVC, PVC 24 AWG (0.22 mm2) Stranding: 7/32 (7 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Color Code M UL AWM 2464 UL CMG CSA CMG FT4 Applications • R  S-422 • Modems • Multiplexers Part No. Pairs M3446 M3447 M3448 M3449 M3450 M3451 M3452 M3453 M3454 M3455 2 3 4 5 6 7 8 10 12 15 Nominal Diameter Jacket Thickness Inch mm Inch mm 0.234 0.246 0.265 0.286 0.308 0.308 0.330 0.379 0.389 0.421 5.94 6.25 6.73 7.26 7.82 7.82 8.38 9.63 9.88 10.69 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 Capacitance Mutual pF/ft pF/m 28 92 25 82 25 82 25 82 23.1 75.8 23.1 75.8 23.1 75.8 23.1 75.8 23.1 75.8 23.1 75.8 Ground pF/ft pF/m 50 164 45 147.6 45 147.6 45 147.6 42 137.8 42 137.8 42 137.8 42 137.8 42 137.8 42 137.8 Operating Temperature • -20°C to +80°C (AWM) • -20°C to +75°C (CMG) 22 AWG (0.35 mm2) Stranding: 7/30 (7 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Color Code A Conductor Color Coding • See tables Materials • S  tranded tinned copper conductors • Semirigid PVC insulation • Foil + braid shield Aluminum/polyester foil shield, 25% overlap min. Foil facing outward Stranded tinned copper drain wire, 24 AWG (0.22 mm2), 7/32 (7 x 0.20 mm) stranding Tinned copper braid, 65% coverage • Slate PVC jacket Part No. Pairs M3433 M3434 M3435 M3436 M3437 M3438 M3439 M3440 M3441 M3442 M3443 M3444 2 3 4 5 6 7 8 10 12 15 18 25 Nominal Diameter Jacket Thickness Inch mm Inch mm 0.254 0.267 0.288 0.312 0.337 0.337 0.363 0.418 0.430 0.473 0.506 0.588 6.45 6.78 7.32 7.92 8.56 8.56 9.22 10.62 10.92 12.01 12.85 14.94 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.032 0.035 0.035 0.035 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 0.81 Capacitance Mutual pF/ft pF/m 31 101.7 27 88.6 27 88.6 27 88.6 27 88.6 24.9 81.7 24.9 81.7 24.9 81.7 24.9 81.7 24.9 81.7 24.9 81.7 24.9 81.7 Ground pF/ft pF/m 56 183.7 49 160.8 49 160.8 49 160.8 49 160.8 45 147.6 45 147.6 45 147.6 45 147.6 45 147.6 45 147.6 45 147.6 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 237 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Coaxial and Twinax Cable For a complete range of 50, 75, 93, and 100 ohm coaxial and twinaxial, we offer a wide range of insulations and jackets meeting the requirements of military specifications and regulatory agencies such as UL and CSA. For broadcast-quality video transmission, our precision video cables use FEP dielectrics to achieve low capacitance, high velocities of propagation, and tight tolerances for maximum signal integrity. Availability A. 100 ft (30.5 m) B. 500 ft (152 m) C. 500 ft (152 m) boxed D. 1000 ft (305 m) E. 1000 ft (305 m) boxed F. 2000 ft (610 m) G. Bulk, cut to length (Minimums may apply) Part No. 50-Ohm Transmission and Computer Cables RG-55B/U, RG-58/U, RG-58A/U, and RG-58C/U Coaxial Cables Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) Jacket Material Dia., In. (mm) 9058 20 (0.52) Solid BC PE 0.116 (2.95) TC Braid, 80% Black Type I PVC 0.195 (4.95) 9058A 20 (0.48) 19/0.0071 (19 x 0.18) TC PE 0.116 (2.95) TC Braid, 95% Black Type I PVC 0.195 (4.95) 9058AC 20 (0.48) 19/0.0071 (19 x 0.18) TC PE 0.116 (2.95) TC Braid, 95% Black Type I PVC 0.195 (4.95) 9058C 20 (0.48) 19/0.0072 (19 x 0.18) TC PE 0.116 (2.95) TC Braid, 95% Black Type IIA PVC 0.195 (4.95) 9058X 20 (0.52) Solid BC PE 0.116 (2.95) TC Braid, 95% Black Type I PVC 0.195 (4.95) 9158S 20 (0.52) Solid BC FEP 0.107 (2.72) TC Braid, 95% Black FEP 0.159 (4.04) M4210 20 (0.62) 19/32 (19 x 0.20) TC Foam PE 0.116 (2.95) TC Braid, 93% Black or White Type I PVC 0.193 (4.90) M4213 20 (0.48) 19/0.0072 (19 x 0.18) TC PE 0.116 (2.95) TC Braid, 94% Black Type IIA PVC 0.195 (4.95) M4219 20 (0.48) 19/0.0071 (19 x 0.18) TC PE 0.117 (2.97) TC Braid, 91% Black Type I PVC 0.203 (5.16) M44209 20 (0.52) Solid BC FEP 0.107 (2.72) TC Braid, 95% White Plenum PVC 0.159 (4.04) 9848 18 (0.82) Solid BC Foam PE 0.116 (2.95) TC Braid, 95% Black Type I PVC 0.195 (4.95) 238 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 50-Ohm Transmission and Computer Cables RG-55B/U, RG-58/U, RG-58A/U, and RG-58C/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9058 53 66 28.5 (93.5) UL AWM 1354 JAN-C-17A/RG-58/U A, B, D 9058A 50 66 30.8 (101.1) JAN-C-17A/RG-58A/U Type A, B, C, D, E 9058AC 50 66 30.8 (101.1) CL2 JAN-C-17A/RG-58A/U Type A, B, D, E 9058C 50 66 30.8 (101.1) MIL-DTL-17/28B RG 58C/U A, B, D, E 9058X 53.5 66 28.5 (93.5) 9158S 50 70 30 (98.4) M4210 52 76 26 (85.3) M4213 50 66 30.8 (101.1) M4219 50 66 30.8 (101.1) M44209 53 69.5 26.4 (86.6) 9848 50 78 26 (85.3) UL AWM 1354 UL CL2 JAN-C-17A/RG-58/U UL CL2P CSA CMP FT6 MIL-DTL-17/28 RG-58/U Type UL AWM 1354 UL CM CSA CM JAN-C-17A/RG-58/U MIL-DTL-17/28B RG-58C/U UL CM CSA CM JAN-C-17A/RG-58A/U Type UL CMP CSA CMP FT6 MIL-DTL-17/RG-58/U Type UL AWM 1354 MIL-DTL-17/28B RG-58/U Type Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. A, B, C, D, E B, D A, B, D A, B, D A, B, D A, B, D, G A, B, D, E 239 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. 9055B Part No. 50-Ohm Transmission and Computer Cables RG-55B/U Coaxial Cables Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) 20 (0.52) Solid SPC PE 0.116 (2.95) Dbl TC Braid, 95% 50-Ohm Transmission and Computer Cables RG-8/U and RG-8A/U Type Coaxial Cables Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) Jacket Material Dia., In. (mm) Black PE 0.201 (5.11) Jacket Material Dia., In. (mm) 9008 13 (2.90) 7/21 (7 x 0.72) M4201 13 (2.90) 7/21 (7 x 0.72) BC PE 0.285 (7.24) BC Braid, 95% Black Type IIA PVC 0.405 (10.29) M4206 11 (4.60) 7/19 (7 x 0.91) BC Foam PE 0.285 (7.24) BC Braid, 96% Black PVC 0.403 (10.24) 240 BC PE 0.285 (7.24) BC Braid, 94% Black Type I PVC 0.405 (10.29) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 50-Ohm Transmission and Computer Cables RG-55B/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9055B 53.5 66 28.8 (94.5) MIL-DTL-17D/26A RG-55B/U A, B, D 50-Ohm Transmission and Computer Cables RG-8/U and RG-8A/U Type Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9008 52 66 29.5 (96.8) JAN-C-17A/RG-8/U A, B, D M4201 52 66 28.5 (93.5) M4206 50 78 26 (85.3) UL AWM 1354 UL CMX CSA CMX MIL-DTL-17D/3A RG-8A/U UL AWM 1354 UL CM CSA CM MIL-DTL-17/RG-8/U Type Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. A, B, D A, B, D 241 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 50-Ohm Transmission and Computer Cables RG-142B/U, RG-174 Type, RG-178B/U, RG-188A/U, RG-196A/U, RG-213 Type, RG-214 Type, RG-217/U, RG-223/U, RG-316/U Coaxial Cables Center Conductor Dielectric Jacket Shield Material, Part No. Coverage Material Dia., In. (mm) AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) 9178B 30 (0.05) 7/38 (7 x 0.10) SCW PTFE 0.034 (0.86) SPC Braid, 94% Natural Tan FEP 0.071 (1.80) 9196A 30 (0.05) 7/38 (7 x 0.10) SCW PTFE 0.034 (0.86) SPC Braid, 94% Natural PTFE Tape 0.075 (1.91) 9174 26 (0.14) 7/34 (7 x 0.16) BCW PE 0.060 (1.52) TC Braid, 85% Black or Red Type I PVC 0.102 (2.59) 9188A 25 (0.16) 7/0.0067 (7 x 0.17) SCW PTFE 0.060 (1.52) SPC Braid, 94% White PTFE Tape 0.105 (2.67) 9316 25 (0.16) 7/0.0067 (7 x 0.17) SCW PTFE 0.060 (1.52) SPC Braid, 94% Natural Tan FEP 0.098 (2.49) 9223 19 (0.62) Solid SPC PE 0.116 (2.95) Dbl SPC Braid, 95% Black Type IIA PVC 0.212 (5.38) M4251 19 (0.69) Solid SCW PTFE 0.116 (2.95) Dbl SPC Braid, 95% Natural Tan FEP 0.195 (4.95) 9213 13 (3.11) 7/0.0296 (7 x 0.75) BC PE 0.285 (7.24) BC Braid, 96% Black Type IIA PVC 0.405 (10.29) 9214 13 (3.11) 7/0.0296 (7 x 0.75) SPC PE 0.285 (7.34) Dbl SPC Braid, 95% Black Type IIA PVC 0.425 (10.80) 9217 10 (5.70) Solid BC PE 0.370 (9.40) Dbl BC Braid, 95% Black Type IIA PVC 0.545 (13.84) 242 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 50-Ohm Transmission and Computer Cables RG-142B/U, RG-174 Type, RG-178B/U, RG-188A/U, RG-196A/U, RG-213 Type, RG-214 Type, RG-217/U, RG-223/U, RG-316/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9178B 50 70 29.3 (96.1) MIL-DTL-17/RG-178B/U A, B, D, G 9196A 50 70 29.3 (96.1) MIL-DTL-17/RG-196A/U A, B, D, G 9174 50 66 30.8 (101.1) UL AWM 1354 MIL-DTL-17D/119F RG-174/U A, B, D 9188A 50 70 29.3 (96.1) MIL-DTL-17/69B RG-188A/U A, B, D, G 9316 50 70 29.3 (96.1) AWM 1971 CSA CMX FT4 MIL-DTL-17 M17/113 RG-316 A, B, D, G 9223 50 66 30.8 (101.1) MIL-DTL-17D/84B RG-223/U A, B, D M4251 50 70 29 (95.1) MIL-DTL-17/RG-142B/U A, B, D, G 9213 50 66 30.8 (101.1) MIL-DTL-17/74A RG-213 Type A, B, D 9214 50 66 30.8 (101.1) AWM 1354 MIL-DTL-17/75D RG-214/U A, B, D, G 9217 50 66 30.8 (101.1) MIL-DTL-17D/78A RG-217/U A, B, D, G Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 243 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. 93-Ohm Coaxial Cables RG-62A/U, RG-22B/U Coaxial Cables Center Conductor Dielectric Shield Material, Coverage Material Dia., In. (mm) AWG (mm2) Stranding (mm) Material Jacket Material Dia., In. (mm) 9062A 22 (0.32) Solid BCW Semisolid PE 0.146 (3.71) BC Braid, 95% Black Type IIA PVC 0.242 (6.15) 9062AC 22 (0.32) Solid BCW Semisolid PE 0.146 (3.71) BC Braid, 95% Black Type IIA PVC* 0.242 (6.15) M4276 22 (0.32) Solid BCW Semisolid PE 0.146 (3.71) BC Braid, 95% Black Type IIA PVC 0.239 (6.07) M44276 22 (0.32) Solid BCW Semisolid FEP 0.142 (3.61) BC Braid, 94% White Plenum PVC 0.202 (5.13) M44276F 22 (0.32) Solid BCW Foam FEP 0.146 (3.71) BC Braid, 94% White Plenum PVC 0.204 (5.18) *Also available in white, green, blue, orange, yellow, and slate. Part No. 95-Ohm Coaxial Cables RG-180B/U Coaxial, RG-22B/U Twinax Cables Center Conductor Dielectric Shield Material, Coverage Material Dia., In. (mm) AWG (mm2) Stranding (mm) Material 9180B 30 (0.05) 7/38 (7 x 0.10) M4203 18 (0.87) 7/0.0152 (7 x 0.39) Jacket Material Dia., In. (mm) SCW PTFE 0.102 (2.59) SPC Braid, 91% Natural Tan FEP 0.141 (3.58) BC* PE 0.090 (2.85) Dbl TC Braid, 95% Black Type IIA PVC 0.420 (10.67) *For identification, one conductor includes a single tinned copper strand. 244 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 93-Ohm Coaxial Cables RG-62A/U, RG-22B/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9062A 93 83 13.2 (43.3) UL AWM 1478 MIL-DTL-17/30B RG-62A/U A, B, D, E, F 9062AC 93 83 13.5 (44.3) M4276 93 84 13.5 (44.3) M44276 93 85 12.8 (42) M44276F 93 85 12.5 (41) UL AWM 1478 UL CL2 CSA CMH MIL-DTL-17/30B RG-62A/U UL AWM 1478 UL CL2 UL CM CSA CM MIL-DTL-17/RG-62A/U Type UL CMP CSA CMP MIL-DTL-17/RG-62A/U Type UL CMP CSA CMP MIL-DTL-17/RG-62U Type A, B, D, E, F A, B, D, G A, B, D, G A, B, D, G 95-Ohm Coaxial Cables RG-180B/U Coaxial, RG-22B/U Twinax Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9180B 95 70 15.4 (50.5) MIL-DTL-17/RG-180B/U A, B, D, G M4203 95 66 16 (52.5) UL AWM 2498 MIL-DTL-17/RG-22B/U Type A, B, D, G Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 245 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. Twinax Cables 78-Ohm Twinax Cables Dielectric Center Conductor AWG (mm2) Stranding (mm) Material Jacket Material Dia., In. (mm) Shield Material, Coverage Material Dia., In. (mm) 9888C 22 (0.35) 7/30 (7 x 0.25) TC White and Blue HDPE 0.056 (1.42) TC Braid, 85% Apple Smoke Slate PVC 0.184 (4.67) 9108 20 (0.56) 7/28 (7 x 0.32) TC Blue and Clear FEP 0.074 (1.88) TC Braid, 95% Blue FEP 0.198 (5.03) M4154 20 (0.56) 7/28 (7 x 0.32) TC Blue and Clear PE 0.076 (1.93) A/P Tape TC Braid, 55% Blue PVC 0.238 (6.05) M4220 20 (0.56) 7/28 (7 x 0.32) TC* Natural PE 0.079 (2.01) TC Braid, 85% Black Type II PVC 0.235 (5.97) *For identification, one conductor includes a bare copper strand Type IIA. Part No. Twinax Cables 100-Ohm Twinax Cables Dielectric Center Conductor Jacket Material Dia., In. (mm) Shield Material, Coverage BC TC FEP 0.072 (1.83) TC Braid, 95% Slate PVDF 0.252 (6.40) AWG (mm ) Stranding (mm) Material 2 Material Dia., In. (mm) 9109 20 (0.56) 7/28 (7 x 0.32) 9817 20 (0.56) 7/28 (7 x 0.32) BC TC PE 0.083 (2.11) TC Braid, 85% Black PVC 0.330 (8.38) M4271 20 (0.56) 7/28 (7 x 0.32) BC TC PE 0.083 (2.11) A/P/A Tape TC Braid, 85% Black PVC 0.330 (8.38) Part No. Twinax Cables 124- and 150-Ohm Twinax Cables Dielectric Center Conductor AWG (mm2) Stranding (mm) Material Jacket Material Dia., In. (mm) Shield Material, Coverage Material Dia., In. (mm) 9823 22 (0.38) 19/34 (19 x 0.16) TC Black and Yellow Foam PE 0.120 (3.05) A/P/A Tape Black PVC 0.329 (8.36) M4158 16 (1.31) Solid BC Blue and Clear Foam PE 0.161 (4.09) A/P/A Tape TC Braid, 90% Black PVC 0.440 (11.18) 246 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Twinax Cables 78-Ohm Twinax Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9888C 78 66 19.7 (64.6) UL AWM 2726 UL CM CSA CMG FT4 D, E 9108 78 69.5 18.4 (60.4) UL CMP CSA CMP B, D M4154 78 66 19.7 (64.6) UL AWM 2464 UL CM CSA CM A, B, D, G M4220 78 66 19.7 (64.6) MIL-DTL-17/RG-108 Type A, B, D, G Twinax Cables 100-Ohm Twinax Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9109 100 69 13.3 (43.6) UL CMP UL CL2P CSA CMP D 9817 100 66 14.5 (47.6) UL AWM 2498 A, B, D M4271 100 66 14.5 (47.6) UL CMG UL CL2 CSA CMG A, B, D, G Twinax Cables 124- and 150-Ohm Twinax Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9823 150 78 8.8 (28.9) UL AWM 2668 A, B, D, G M4158 124 78 10.9 (35.8) UL AWM 2448 UL CMX CSA CMX A, B, D, G Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 247 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. Center Conductor AWG (mm2) Stranding (mm) Material Miniature Coaxial Cables Dielectric Shield Material, Coverage Material Dia., In. (mm) Jacket Material Dia., In. (mm) M4243 30 (0.05) 7/38 (7 x 0.10) M4242 28 (0.08) Solid TC PP 0.023 (0.58) TC Braid, 90% Black PVC 0.054 (1.37) M4244 27 (0.11) 7/35 (7 x 0.142) BCW PE 0.100 (2.54) TC Braid, 93% Black PVC 0.150 (3.81) 248 TC Foam HDPE 0.058 (1.47) TC Braid, 89% Black PVC 0.097 (2.46) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Miniature Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability M4243 75 78 17.3 (56.8) UL AWM 1375 A, B, D, G M4242 32 66 55.2 (181.1) UL CMH CSA CMH A, B, D, G M4244 75 66 20.5 (67.3) UL AWM 1354 A, B, D, G Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 249 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. 75-Ohm Video Cable RG-59/U, RG-59B/U Coaxial Cables Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) Jacket Material Dia., In. (mm) 9059B 23 (0.26) Solid BCW PE 0.146 (3.71) BC Braid, 94% Black Type IIA PVC 0.242 (6.15) 9159 23 (0.26) Solid BCW FEP 0.132 (3.35) BC Braid, 95% Black PVDF 0.190 (4.83) 9810 23 (0.26) Solid BC PE 0.146 (3.71) A/P/A Tape TC Braid, 95% Black Type IIIA PE 0.220 (5.59) M4223 23 (0.26) Solid BCW PE 0.146 (3.71) BC Braid, 94% Black Type IIA PVC 0.241 (6.12) 9059 22 (0.32) Solid BCW PE 0.146 (3.71) BC Braid, 95% Black, White, Slate Type I PVC 0.242 (6.15) 9059C 22 (0.32) Solid BCW PE 0.146 (3.71) BC Braid, 95% Black, Red, Blue, Green, Slate Type I PVC 0.242 (6.15) 9830 22 (0.32) Solid BCW PE 0.146 (3.71) BC Braid, 85% Black Type I PVC 0.242 (6.15) M4212 22 (0.32) Solid BCW Foam PE 0.146 (3.71) BC Braid, 85% Black Type I PVC 0.242 (6.15) M4237 22 (0.35) 7/30 (7 x 0.25) BC Foam PE 0.146 (3.71) BC Braid, 95% Black Type I PVC 0.240 (6.10) M44212F 20 (0.52) Solid BCW Foam FEP 0.140 (3.56) A/P/A Tape TC Braid, 94% White Plenum PVC 0.202 (5.13) 9102 20 (0.52) Solid BCW Foam FEP 0.140 (3.56) A/P/A Tape TC Braid, 94% Black PVDF 0.212 (5.38) 250 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 75-Ohm Video Cable RG-59/U, RG-59B/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) 9059B 75 66 20.5 (67.3) 9159 75 69.5 19.5 (64) 9810 75 66 21 (68.9) MIL-DTL-17/RG-59/U Type A, D M4223 75 66 20.5 (67.3) UL AWM 1354 UL CMX CSA CMX MIL-DTL-17D/29B RG-59B/U A, B, D 9059 73 66 21 (68.9) UL AWM 1354 JAN-C-17A/RG-59/U A, B, D 9059C 73 66 21 (68.9) 9830 75 66 21.5 (70.5) M4212 80 78 16.3 (53.5) M4237 75 78 17.3 (56.8) M44212F 75 82 16.5 (54.1) 9102 75 82 16.5 (54.1) Specifications UL CL2X CSA CMH FT1 MIL-DTL-17D/29B RG-59B/U UL CL2P UL CMP CSA CMP FT6 MIL-DTL-17/RG-59B/U Type UL AWM 1354 UL CL2 CSA CMG FT4 JAN-C-17A /RG-59/U UL AWM 1354 UL CMX CSA CMX JAN-C-17A/RG-59/U UL AWM 1354 UL CM CSA CM JAN-C-17A/RG-59/U UL AWM 1354 UL CM CSA CM MIL-DTL-17/RG-59/U Type UL CMP UL CATVP CSA CMP FT6 MIL-DTL-17/RG-59/U Type UL CMP UL CL2P CSA CMP FT6 MIL-DTL-17/RG-59U Type Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability A, B, C, D, E D A, B, C, D, E A, B, D A, B, D A, B, D A, B, D, G B, D 251 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. Center Conductor AWG (mm2) Stranding (mm) Material 75-Ohm Video Cable RG-6U Type, RG-6A/U Type Dielectric Shield Material, Coverage Material Dia., In. (mm) Jacket Material Dia., In. (mm) M4204 21 (0.41) Solid BCW PE 0.185 (4.70) Dbl BC Braid, 95% Black PE 0.332 (8.43) 9104 18 (0.82) Solid BCW Foam FEP 0.170 (4.32) A/P Tape TC Braid, 95% Black PVDF 0.232 (5.89) M4182 18 (0.82) Solid BC Foam PE 0.180 (4.57) A/P/A Tape TC Braid, 60% Black Type I PVC 0.270 (6.86) Part No. 75-Ohm Video Cable RG-11/U, RG-11/U Type, RG-11A/U Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) Jacket Material Dia., In. (mm) 9011A 18 (0.89) 7/26 (7 x 0.40) TC PE 0.285 (7.24) BC Braid, 95% Black Type IIA PVC 0.405 (10.29) M4207 18 (0.89) 7/26 (7 x 0.40) TC PE 0.285 (7.24) BC Braid, 95% Black Type I PVC 0.405 (10.29) 9105 14 (2.08) Solid BC Foam FEP 0.274 (6.96) A/P/A Tape TC Braid, 60% Black FEP 0.346 (8.79) M4208 14 (2.08) Solid BC Foam PE 0.285 (7.24) BC Braid, 95% Black PE 0.405 (10.29) 252 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 75-Ohm Video Cable RG-6U Type, RG-6A/U Type Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications M4204 75 66 20.5 (67.3) MIL-DTL-17/RG-6A/U Type 9104 75 82 16.5 (54.1) M4182 75 82 16.2 (53.1) UL CMP UL CATVP CSA CMP FT6 MIL-DTL-17/RG-6U Type UL AWM 1354 UL CM CSA CM MIL-DTL-17/ RG 6/U Type Availability B, D A, B, D 75-Ohm Video Cable RG-11/U, RG-11/U Type, RG-11A/U Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) 9011A 75 66 20.5 (67.3) M4207 75 66 20.5 (67.3) 9105 75 83 16.3 (53.5) M4208 75 84 16.1 (52.8) Specifications UL CL2X CSA CMH FT1 MIL-DTL-17D/6B RG 11A/U UL CM CSA CM JAN-C-17A/ RG 11/U UL CMP UL CL2P UL CATVP CSA CMP FT6 MIL-DTL-17/RG-11/U Type MIL-DTL-17/RG-11A/U Type Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability A, B, D A, B, D B, D A, B, D 253 Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable Part No. 75-Ohm Video Cables RG-179B/U and RG-187A/U Coaxial Cables Center Conductor Dielectric Shield Material, Coverage AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) 9179B 30 (0.05) 7/38 (7 x 0.10) 9187A 30 (0.05) 7/38 (7 x 0.10) Jacket Material Dia., In. (mm) SCW PTFE 0.063 (1.60) SPC Braid, 93% Natural Tan FEP 0.100 (2.54) SCW PTFE 0.063 (1.60) SPC Braid, 93% Natural PTFE Tape 0.105 (2.67) Ethernet Transceiver Cables Pairs Part No. 9852C 9853C 9854C Type AWG (mm2) Stranding (mm) Material Material Dia., In. (mm) Data (3) 22 (0.35) 7/30 (7 x 0.25) TC Foam HDPE 0.064 (1.63) Power (1) 20 (0.56) 7/28 (7 x 0.32) TC SR-PVC 0.058 (1.47) Data (3) 20 (0.56) 7/28 (7 x 0.32) TC Foam HDPE 0.077 (1.96) Power (1) 20 (0.56) 7/28 (7 x 0.32) TC SR-PVC 0.058 (1.47) Data (3) 28 (0.08) 7/36 (7 x 0.12) TC PP 0.033 (0.84) Power (1) 24 (0.23) 7/32 (7 x 0.20) TC SR-PVC 0.044 (1.12) Key to Abbreviations A/P A/P/A BC BCW FEP HDPE PE PP PTFE PVC PVDF SCW SPC SR-PVC TC 254 Dielectric Shield Material, Coverage A/P (pairs) A/P/A (overall) TC Braid, 95% A/P (pairs) A/P (overall) TC Braid, 95% A/P (pairs) A/P/A (overall) TC Braid, 90% Color Coding Aluminum/polyester Aluminum/polyester/aluminum Bare copper Bare copper-coated steel Fluorinated ethylene propylene High-density polyethylene Polyethylene Polypropylene Polytetrafluoroethylene Polyvinyl chloride Polyvinylidene fluoride Silver-coated, copper-coated steel Silver-plated copper Semirigid PVC Tinned copper Conductor Data 1 Data 2 Data 3 Power Color Code 9852C, 9854C 9853C Green-Blue White-Gray YellowYellowOrange Orange WhiteGreen-Blue Brown Blue-Red Black-Red Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Coaxial Cable Manhattan™ Coaxial Cable 75-Ohm Video Cables RG-179B/U and RG-187A/U Coaxial Cables Part No. Nom. Impedance (Ω) Vp (%) Capacitance, pF/ft (pF/m) Specifications Availability 9179B 75 70 19.5 (64) MIL-DTL-17/RG-179B/U A, B, D, G 9187A 75 70 19.5 (64) MIL-DTL-17/RG-187A/U A, B, D, G Part No. Jacket Ethernet Transceiver Cables Electrical Characteristics—Data Pairs Nom. Impedance Capacitance, pF/ft Vp (%) (Ω) (pF/m) Specifications Availability 16.7 (54.8) UL AWM 2919 UL CM CSA CMG FT4 D 78 16.7 (54.8) UL CM CSA CMG FT4 D 66 19.7 (64.6) UL AWM 2919 UL CM CSA CMG FT4 D Material Dia., In. (mm) 9852C Slate PVC 0.375 (9.53) 78 78 9853C Slate PVC 0.401(10.19) 78 9854C Slate PVC 0.250 (6.35) 78 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 255 Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V Manhattan™ High-Temperature Wire and Cable 600 V, Multiconductor, PTFE, PTFE, Braid Shield High Temperature 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.009 (0.24 mm) NEMA WC27500 Type RC SAE AS22759/11 Part No. Conductors 24RC2S06 24RC3S06 24RC4S06 2 3 4 Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.009 (0.24 mm) • -55°C to +200°C • Per SAE AS22759/11 Materials • S  tranded silver-plated conductors • PTFE insulation • Silver-plated braid shield, 85% coverage • Natural PTFE jacket Availability 100 ft (30.5 m) Bulk, cut to length Spools may contain multiple lengths Part No. Conductors 22RC2S06 22RC3S06 22RC4S06 2 3 4 Nominal Diameter Inch mm 0.136 3.45 0.143 3.63 0.156 3.96 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 20RC2S06 20RC3S06 20RC4S06 2 3 4 Nominal Diameter Inch mm 0.154 3.91 0.163 4.14 0.184 4.67 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 18 AWG (0.96 mm2) (Minimums may apply) 256 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 22 AWG (0.38 mm2) Operating Temperature Conductor Color Coding Nominal Diameter Inch mm 0.124 3.15 0.130 3.30 0.142 3.61 Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.011 (0.28 mm) Part No. Conductors 18RC2S06 2 Nominal Diameter Inch mm 0.180 4.57 Jacket Thickness Inch mm 0.010 0.25 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V Manhattan™ High-Temperature Wire and Cable 600 V, Multiconductor, ETFE, ETFE, Braid Shield High Temperature 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.011 (0.28 mm) Part No. Conductors 275002402 2 NEMA WC27500 Type TE SAE AS22759/16 Operating Temperature • -55°C to +150°C Conductor Color Coding • Per SAE AS22759/16 Nominal Diameter Inch mm 0.132 3.35 Jacket Thickness Inch mm 0.010 0.25 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.011 (0.28 mm) Part No. Conductors 275002201 275002202 275002203 275002204 1 2 3 4 Nominal Diameter Inch mm 0.088 2.24 0.146 3.71 0.154 3.91 0.168 4.27 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 Materials • S  tranded tinned copper conductors • ETFE insulation • Tinned copper braid shield, 85% coverage • Natural ETFE jacket Availability 100 ft (30.5 m) Bulk, cut to length Spools may contain multiple lengths 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.011 (0.28 mm) Part No. Conductors 275002001 275002002 275002003 275002004 1 2 3 4 Nominal Diameter Inch mm 0.096 2.44 0.162 4.11 0.171 4.34 0.187 4.75 Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 18 AWG (0.96 mm2) (Minimums may apply) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.012 (0.30 mm) Part No. Conductors 275001801 275001802 1 2 Nominal Diameter Inch mm 0.107 2.72 0.182 4.62 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Thickness Inch mm 0.010 0.25 0.010 0.25 257 Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V Manhattan™ High-Temperature Wire and Cable 600 V, Multiconductor, PTFE, PTFE, Braid Shield NEMA HP3-EXBEE 26 AWG (0.14 mm2) Stranding: 7/34 (7 x 0.16 mm) Insulation thickness: 0.010 (0.25 mm) MIL-W-16878/4 (Type E) NEMA HP3 Operating Temperature Part No. Conductors M1201 M1202 M1203 M1204 1 2 3 4 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 NEMA HP3-EXBEE 24 AWG (0.24 mm2) • -55°C to +200°C Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.010 (0.25 mm) Conductor Color Coding • Chart P (page 535) Materials • Silver-plated copper conductors • PTFE insulation • Silver-plated copper braid shield, 85% coverage • White PTFE jacket Part No. Conductors M1211 M1212 M1213 M1214 1 2 3 4 Nominal Diameter Inch mm 0.087 2.21 0.136 3.45 0.143 3.63 0.155 3.94 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 NEMA HP3-EXBFE 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.009 (0.23 mm) Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Spools may contain multiple lengths Nominal Diameter Inch mm 0.081 2.06 0.124 3.15 0.130 3.30 0.140 3.56 Part No. Conductors M1221 M1222 M1223 M1224 1 2 3 4 Nominal Diameter Inch mm 0.092 2.34 0.146 3.71 0.154 3.91 0.167 4.24 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 (Minimums may apply) NEMA HP3-EXBGE 20 AWG (0.61 mm2) Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.009 (0.23 mm) Part No. Conductors M1231 M1232 M1233* M1234 1 2 3 4 Nominal Diameter Inch mm 0.100 2.54 0.158 4.01 0.171 4.34 0.186 4.72 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.010 0.25 0.012 0.30 *NEMA HP3-EXBJE. 258 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V Manhattan™ High-Temperature Wire and Cable 600 V, Multiconductor, PTFE, PTFE, Braid Shield NEMA HP3-EXBHE 18 AWG (0.96 mm2) Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) MIL-W-16878/14 (Type E) NEMA HP3 Operating Temperature • -55°C to +200°C Part No. Conductors M1241* M1242 M1243 M1244 1 2 3 4 Materials • Silver-plated copper conductors • PTFE insulation • Silver-plated copper braid shield, 85% coverage • White PTFE jacket Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 *NEMA HP3-EXBGE. NEMA HP3-EXBJE 16 AWG (1.23 mm2) Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.012 (0.30 mm) Conductor Color Coding • Chart P (page 535) Nominal Diameter Inch mm 0.112 2.84 0.186 4.72 0.197 5.00 0.215 5.46 Part No. Conductors M1251 M1252 M1253 M1254 1 2 3 4 Nominal Diameter Inch mm 0.122 3.10 0.206 5.23 0.219 5.56 0.240 6.10 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 259 Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V Manhattan™ High-Temperature Wire and Cable 600 V, Multiconductor, PTFE, FEP, Braid Shield 24 AWG (0.24 mm2) Stranding: 19/36 (19 x 0.13 mm) Insulation thickness: 0.0095 (0.24 mm) Part No. Conductors 72402 2 MIL-W-16878/4 (Type E) Components Operating Temperature • -55°C to +200°C Nominal Diameter Inch mm 0.136 3.45 Jacket Thickness Inch mm 0.012 0.30 22 AWG (0.38 mm2) Stranding: 19/34 (19 x 0.16 mm) Insulation thickness: 0.0095 (0.24 mm) Part No. Conductors 72203 3 Nominal Diameter Inch mm 0.154 3.91 Jacket Thickness Inch mm 0.012 0.30 Conductor Color Coding • Chart P (page 535) 20 AWG (0.61 mm2) Materials • Silver-plated copper conductors • PTFE insulation • Silver-plated copper braid shield, 85% coverage • White FEP jacket Stranding: 19/32 (19 x 0.20 mm) Insulation thickness: 0.0095 (0.24 mm) Part No. Conductors 72001 1 (Minimums may apply) Jacket Thickness Inch mm 0.010 0.25 18 AWG (0.96 mm2) Availability 100 ft (30.5 m) 500 ft (152 m) Bulk, cut to length Spools may contain multiple lengths Nominal Diameter Inch mm 0.100 2.54 Stranding: 19/30 (19 x 0.25 mm) Insulation thickness: 0.010 (0.25 mm) Part No. Conductors 71801 71802 1 2 Nominal Diameter Inch mm 0.112 2.84 0.186 4.72 Jacket Thickness Inch mm 0.010 0.25 0.012 0.30 16 AWG (1.23 mm2) Stranding: 19/29 (19 x 0.29 mm) Insulation thickness: 0.012 (0.030 mm) 260 Part No. Conductors 71602 2 Nominal Diameter Inch mm 0.206 5.23 Jacket Thickness Inch mm 0.012 0.30 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 125/250 V Manhattan™ Cordsets 125 and 250 V M.A.P. Multiple Application Power Cords Twin-End Jumper and Power Cords NEMA 5-15P Connector IEC C-13 Connector SJT UL Standard 817 CSA C22.2 No. 21 Materials • S  tranded bare copper conductors • PVC insulation • Black PVC jacket Operating Temperature • -20°C to +60°C IEC C-14 Connector IEC C-13 Connector Availability Conductor Color Coding 25-piece packages • Black, white, green (NEC) (Minimums may apply) 6-ft (1.8 m) Overall Length; Individual Leg Length Is 2 ft (0.6 m) Part No. Wire Size Stranding AWG mm Jumper Power AWG mm2 468 472 18 0.82 41/34 41 x 0.16 470 474 16 1.32 65/34 65 x 0.16 Nominal Diameter Inch mm 0.300 7.62 0.325 8.26 Watts 1250 3250 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Power Rating Amps 10 13 Volts 125 250 261 Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Power Cords 3-Conductor NEMA 5-15P Connector SJ, SJT, SVT UL 62 and 817 CSA C22.2 No. 21 and 49 Materials Operating Temperature • -20°C to +60°C Conductor Color Coding • B  lack, white, green or green/yellow (NEC) • Blue, brown, green/yellow (ICC) • S  tranded bare copper conductors • PVC or rubber insulation • Aluminum/polyester foil shield (where specified) Foil facing inward 22 AWG (0.35 mm2) tinned copper drain wire • Black PVC, rubber, or neoprene jacket (slate where marked) Availability 25-piece packages B suffix = 100-piece packages (Minimums may apply) PVC Jacket, PVC Insulation, Unshielded, SJT Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Part No. Cord Length Wire Size Stranding AWG mm 25 pc 100 pc Ft m AWG mm2 501 501B 6’ 7” 2 18 0.82 41/34 41 x 0.16 502 502B 9’ 10” 3 18 0.82 41/34 41 x 0.16 780* 780B* 6’ 0” 1.8 18 0.81 16/30 16 x 0.25 779* 779B* 8’ 0” 2.4 18 0.81 16/30 16 x 0.25 503 — 6’ 7” 2 16 1.32 65/34 65 x 0.16 505 505B 6’ 7” 2 14 2.08 41/30 41 x 0.25 506 — 9’ 10” 3 14 2.08 41/30 41 x 0.25 Nominal Diameter Inch mm 0.330 8.38 0.330 8.38 0.330 (0.300)** 8.38 (7.62)** 0.300 (0.330)† 7.62 (8.38)† 0.331 8.41 0.380 9.65 0.380 9.65 Power Rating Watts Amps 1250 10 1250 10 1250 10 1250 10 1625 13 1875 15 1875 15 Color Code ICC ICC NEC NEC ICC ICC ICC *Slate jacket **Diameter for part no. 780B †Diameter for part no. 779B PVC Jacket, PVC Insulation, Shielded, SVT Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Part No. Cord Length Wire Size 25 pc 100 pc Ft m AWG mm2 777* 777B* 6’ 0” 1.8 18 0.82 787* 787B* 8’ 0” 2.4 18 0.82 507F — 6’ 7” 2 18 0.82 508F — 9’ 10” 3 18 0.82 Stranding AWG mm 41/34 41 x 0.16 41/34 41 x 0.16 41/34 41 x 0.16 41/34 41 x 0.16 Nominal Diameter Inch mm 0.250 6.35 0.250 6.35 0.260 6.60 0.260 6.60 Power Rating Watts Amps 1250 10 1250 10 1250 10 1250 10 Color Code NEC NEC ICC ICC *Slate jacket 262 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Power Cords 3-Conductor NEMA 5-15P Connector SJ, SJT, SVT UL 62 and 817 CSA C22.2 No. 21 and 49 Operating Temperature • -20°C to +60°C Conductor Color Coding • B  lack, white, green or green/yellow (NEC) • Blue, brown, green/yellow (ICC) Materials • S  tranded bare copper conductors • PVC or rubber insulation • Aluminum/polyester foil shield (where specified) Foil facing inward 22 AWG (0.35 mm2) tinned copper drain wire • Black PVC, rubber, or neoprene jacket (slate where marked) Availability 25-piece packages (Minimums may apply) Rubber Jacket, Rubber Insulation, Unshielded, SJ Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. AWG mm Ft m AWG mm2 615 6’ 0” 1.8 18 0.81 16/30 16 x 0.25 616 9’ 0” 2.7 18 0.81 16/30 16 x 0.25 778 8’ 0” 2.4 18 0.81 16/30 16 x 0.25 782 12’ 0” 3.7 18 0.81 16/30 16 x 0.25 783 9’ 0” 2.7 16 1.31 26/30 26 x 0.25 784 12’ 0” 3.7 16 1.31 26/30 26 x 0.25 788 9’ 0” 2.7 14 2.08 41/30 41 x 0.25 789 15’ 0” 4.5 14 2.08 41/30 41 x 0.25 Nominal Diameter Inch mm 0.320 7.13 0.320 8.13 0.320 8.13 0.320 8.13 0.340 8.64 0.340 8.64 0.380 9.65 0.380 9.65 Power Rating Watts Amps 1250 10 1250 10 1250 10 1250 10 1625 13 1625 13 1875 15 1875 15 Color Code Neoprene Jacket, Rubber Insulation, Unshielded, SJO Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 781 8’ 0” 2.4 18 0.81 16/30 16 x 0.25 Nominal Diameter Inch mm 0.330 8.38 Power Rating Watts Amps 1250 10 Color Code Rubber Jacket, Rubber Insulation, Unshielded, SV Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. AWG mm Ft m AWG mm2 775 6’ 0” 1.8 18 0.82 41/34 41 x 0.16 776 8’ 0” 2.4 18 0.82 41/34 41 x 0.16 Nominal Diameter Inch mm 0.260 6.60 0.260 6.60 Power Rating Watts Amps 1250 10 1250 10 Color Code Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. NEC NEC NEC NEC NEC NEC NEC NEC NEC NEC NEC 263 Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Electronic Line Cords 3-Conductor SJT, SVT UL 62 and 817 CSA C22.2 No. 21 and 49 IEC C-13 Connector • A  luminum/polyester foil shield (where specified) Foil facing inward 20 AWG (0.56 mm2) tinned copper drain wire • PVC jacket, black (slate where marked) Operating Temperature • -20°C to +60°C IEC C-13 Right-Angle Connector Conductor Color Coding • Blue, brown, green/yellow (ICC) Availability 25-piece packages (Minimums may apply) Materials • S  tranded bare copper conductors • PVC insulation PVC, Unshielded, Type SJT Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 511 6’ 7” 2 18 0.82 41/34 41 x 0.16 512 9’ 10” 3 18 0.82 41/34 41 x 0.16 513 6’ 7” 2 16 1.32 65/34 65 x 0.16 514 9’ 10” 3 16 1.32 65/34 65 x 0.16 Nominal Diameter Inch mm 0.300 7.62 0.300 7.72 0.331 8.41 0.331 8.41 Power Rating Watts Amps 1250 10 1250 10 1625 13 1625 13 PVC, Shielded, Right Angle, Type SJT Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 521F 6’ 7” 2 14 2.08 41/30 41 x 0.25 Nominal Diameter Inch mm 0.380 9.65 Power Rating Watts Amps 1825 15 PVC, Shielded, Type SVT Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 523 7’ 5” 2.3 18 0.82 41/34 41 x 0.16 Nominal Diameter Inch mm 0.250 6.35 Power Rating Watts Amps 1250 10 264 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Jumper Cords NEMA and IEC Connectors IEC C-13 Connector IEC C-14 Connector SJ, SJT, SVT, SPT-1 UL 62 and 817 CSA C22.2 No. 21 and 49 Operating Temperature • -20°C to +60°C Jumper Cords Conductor Color Coding • A  luminum/polyester foil shield (where specified) Foil facing inward 22 AWG (0.35 mm2) tinned copper drain wire • Black PVC or rubber jacket (Part 601B available in white or slate jacket) • Blue, brown, green/yellow (ICC) • Black, white, green (NEC) Availability Materials (Minimums may apply) 25-piece packages • S  tranded bare copper conductors • PVC or rubber insulation PVC, Unshielded, Type SJT Cord Length Part No. Ft m 551 3’ 3” 1 Wire Size AWG mm2 18 0.82 Stranding AWG mm 41/34 41 x 0.16 Nominal Diameter Inch mm 0.300 7.62 Power Rating Watts Amps 1250 10 Color Code PVC, Shielded, Type SVT Cord Length Part No. Ft m 560F 3’ 3” 1 Wire Size AWG mm2 18 0.82 Stranding AWG mm 41/34 41 x 0.16 Nominal Diameter Inch mm 0.260 6.60 Power Rating Watts Amps 1250 10 Color Code Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. ICC ICC 265 Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Jumper Cords NEMA and IEC Connectors NEMA 5-15P Connector NEMA 5-15R Connector Extension Cords Rubber, Unshielded, Type SJ Cord Length Part No. Ft m 633 10’ 0” 3.1 640 15’ 0” 4.6 Wire Size AWG mm2 16 1.32 16 1.32 Stranding AWG mm 26/30 26 x 0.25 26/30 26 x 0.25 Nominal Diameter Inch mm 0.340 8.64 0.340 8.64 Power Rating Watts Amps 1625 13 1625 13 Color Code NEC NEC NEMA 1-15P Connector Parallel Lamp Cords PVC, Unshielded, Type SPT-1 Leads: Conductors Split 1” (25.4 mm) and Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 601B* 6’ 0” 1.8 18 0.82 41/34 41 x 0.16 Nominal Dimension Inch mm 0.110 x 0.220 2.79 x 5.69 Power Rating Watts Amps 1250 10 *100-piece packages. 266 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Detachable Power Supply Cords 3-Conductor NEMA 5-15P Connector IEC C-13 Connector SJT, SVT UL 62 and 817 CSA C22.2 No. 21 and 49 Materials Operating Temperature • -20°C to +60°C NEMA 5-15P Connector IEC C-13 Right-Angle Connector Conductor Color Coding • Blue, brown, green/yellow (ICC) • Black, white, green or green/yellow (NEC) • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield Foil facing inward Tinned copper drain wire (see tables for size) • Black PVC jacket Availability 25-piece packages B suffix = 100-piece packages (Minimums may apply) Unshielded, Straight, Types SVT and SJT Part No. Cord Length Wire Size 25 pc 100 pc Ft m AWG mm2 545 535 545B 535B 7’ 5” 7’ 5” 2.3 2.3 18 18 0.82 0.82 531 532 533 546 534 531B 532B — — 534B 6’ 7” 9’ 10” 6’ 7” 7’ 5” 9’ 10” 2 3 2 2.3 3 18 18 16 16 16 0.82 0.82 1.32 1.32 1.32 Shielded, Straight, Types SVT and SJT Cord Length Wire Size Part No. Ft m AWG mm2 547F 548F 6’ 7” 9’ 10” 2 3 18 18 0.82 0.82 531F 532F 536F 6’ 7” 9’ 10” 9’ 10” 2 3 3 18 18 14 0.82 0.82 2.08 Stranding AWG mm Type SVT 41/34 41 x 0.16 41/34 41 x 0.16 Type SJT 41/34 41 x 0.16 41/34 41 x 0.16 65/34 65 x 0.16 65/34 65 x 0.16 65/34 65 x 0.16 Stranding AWG mm Type SVT 41/34 41 x 0.16 41/34 41 x 0.16 Type SJT 41/34 41 x 0.16 41/34 41 x 0.16 41/30 41 x 0.25 Nominal Diameter Inch mm Drain Wire* Power Rating Watts Amps Color Code 0.250 0.250 6.35 6.35 1250 1250 10 10 NEC NEC 0.330 0.330 0.350 0.350 0.331 8.38 8.38 8.89 8.89 8.41 1250 1250 1625 1625 1625 10 10 13 13 13 NEC NEC ICC ICC NEC Power Rating Watts Amps Color Code Nominal Diameter Inch mm A A 0.260 0.260 6.60 6.60 1250 1250 10 10 ICC ICC B B C 0.317 0.317 0.400 8.05 8.05 10.16 1250 1250 1875 10 10 15 ICC ICC ICC *Drain Wire: A = 22 AWG (mm2), 7/30 (7 x 0.25 mm) stranding. B = 18 AWG (0.82 mm2), 41/34 (41 x 0.16 mm) stranding. C = 14 AWG (2.08 mm2), 41/30 (41 x 0.25 mm) stranding. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 267 Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Detachable Power Supply Cords 3-Conductor Unshielded, Right Angle, Type SJT Part No. Cord Length 25 pc 100 pc Ft m 537 537B 6’ 7” 2 538 9’ 10” 3 540 — 9’ 10” 3 Shielded, Right Angle, Type SVT Cord Length Part No. Ft m 550F 9’ 10” 3 Wire Size AWG mm2 18 0.82 18 0.82 16 1.32 Wire Size AWG mm2 18 0.82 Stranding AWG mm 41/34 41 x 0.16 41/34 41 x 0.16 65/34 65 x 0.16 Stranding AWG mm 41/34 41 x 0.16 Drain Wire* A Nominal Diameter Inch mm 0.330 8.38 0.330 8.38 0.331 8.41 Power Rating Watts Amps 1250 10 1250 10 1625 13 Color Code Nominal Diameter Inch mm 0.260 6.60 Power Rating Watts Amps 1250 10 Color Code ICC ICC ICC ICC *Drain Wire: A = 22 AWG (mm2), 7/30 (7 x 0.25 mm) stranding. NEMA 5-15P Connector Unshielded, Straight, Type SVT Cord Length Part No. Ft m 543* 7’ 5” 2.3 Wire Size AWG mm2 18 0.82 Stranding AWG mm 41/34 41 x 0.16 Nominal Diameter Inch mm 0.240 6.09 Power Rating Watts Amps 1250 7 Color Code ICC *Also available with slate jacket. 268 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 125 V Manhattan™ Cordsets 125 V Medical-Grade Power Supply Cordsets 3-Conductor SJT UL 62 and 817 CSA C22.2 No. 21 and 49 CSA FT2 Operating Temperature Materials • S  tranded bare copper conductors • PVC insulation • Black or slate PVC jacket • -20°C to +60°C Availability Conductor Color Coding (Minimums may apply) 25-piece packages • Black, white, green NEMA 5-15P Connector Leads: Jacket Stripped 2” (50 mm). Leads Stripped 5/8” (16 mm) Cord Length Wire Size Stranding Part No. Ft m AWG mm2 AWG mm 801 10’ 0” 3.0 18 1.20 43/34 43 x 0.16 802 10’ 0” 3.0 18 1.20 43/34 43 x 0.16 NEMA 5-15P Connector Part No. 820 821 822 830 831 832 Cord Length Ft m 10’ 0” 3.0 10’ 0” 3.0 10’ 0” 3.0 10’ 0” 3.0 10’ 0” 3.0 10’ 0” 3.0 Nominal Diameter Inch mm 0.31 7.8 0.31 7.8 Power Ratings Watts Amps 1250 10 1250 10 Colors Jacket Plug Black Clear Slate Slate IEC C-13 Connector Wire Size AWG mm2 18 1.20 18 1.20 18 1.20 16 1.50 16 1.50 16 1.50 Stranding AWG mm 43/34 43 x 0.16 43/34 43 x 0.16 43/34 43 x 0.16 68/34 68 x 0.16 68/34 68 x 0.16 68/34 68 x 0.16 Nominal Diameter Inch mm 0.31 7.8 0.31 7.8 0.31 7.8 0.33 8.5 0.33 8.5 0.33 8.5 Power Ratings Watts Amps 1250 10 1250 10 1250 10 1625 13 1625 13 1625 13 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Jacket Black Slate Slate Black Slate Slate Colors Plug Clear Slate Clear Clear Slate Clear Recept. Black Slate Clear Black Slate Clear 269 Cable > Manhattan > Cordsets > 250 V Manhattan™ Cordsets 250 V Internationally Approved Power Supply Cordsets CE ENEC-11 T-Mark JET UL CSA C-Tick Conductor Color Coding • Blue, brown, yellow/green Materials • S  tranded bare copper conductors • PVC insulation • Black PVC jacket Operating Temperature Availability • -15°C to +70°C 25-piece packages (Minimums may apply) XVI Plug Connector IEC C-7 Connector 2-Conductor Unshielded. Cordage Type HO3VVH2F2XO.75 Cord Length Wire Size Part No. Ft m AWG mm2 952 5’ 6” 1.7 18 0.75 VIIG Plug Connector Stranding AWG mm 23/32 23 x 0.20 Nominal Diameter Inch mm 0.133 x 0.22 4.00 x 5.60 Power Rating Watts Amps 625 2.5 IEC C-13 Connector 3-Conductor Unshielded. Cordage Type HO5VVF3G1.00 Ft 8’ 2” IEC C-13 Connector m 2.5 AWG 16 mm2 1.00 mm 31 x 0.20 Inch 0.268 mm 6.81 Watts 2500 Amps 2.5 IEC C-14 Connector 3-Conductor Unshielded. Cordage Type HARSJT3X18AWG Cord Length Wire Size Part No. Ft m AWG mm2 953 8’ 2” 2.5 18 1.00 270 AWG 31/32 Stranding AWG mm 56/34 56 x 0.15 Nominal Diameter Inch mm 0.314 8.0 Power Rating Watts Amps 2500 10 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 250 V Manhattan™ Cordsets 250 V Power Supply Cords, 3-Conductor Australia SAA Materials • S  tranded bare copper conductors • PVC insulation • Black PVC jacket • Cord Type: HO5VVF3G1.00 Operating Temperature • -15°C to +70°C Conductor Color Coding • Blue, brown, yellow/green Availability 25-piece packages (Minimums may apply) SAA 3 Connector IEC C-13 Connector Stranding AWG Mm 31/32 31 x 0.20 Nominal Diameter Inch mm 0.270 6.80 Power Rating Watts Amps 2500 10 Leads: Jacket Stripped 30 mm (1.2”). Leads Stripped 6 mm (0.24”) Cord Length Wire Size Stranding Part No. AWG Mm Ft m AWG mm2 911 8.2 2.5 16 1.00 31/32 31 x 0.20 Nominal Diameter Inch mm 0.270 6.80 Power Rating Watts Amps 2500 10 Part No. 910 Cord Length Ft m 8.2 2.5 Wire Size AWG mm2 16 1.00 SAA 3 Connector Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 271 Cable > Manhattan > Cordsets > 300, 600 V Manhattan™ Cordsets 300 V and 600 V Conductor Cordage CPE SVO, SJOW, SOOW UL 62 CSA C22.2 No. 49 CSA FT2 Operating Temperature • -40°C to +90°C • S  tranded bare copper conductors • Rubber insulation • Black chlorinated polyethylene (CPE) jacket Availability Conductor Color Coding 250 ft (76.2 m) • Black, white (2 conductors) • Black, white, green (3 conductors) • Black, white, green, red (4 conductors) (Minimums may apply) CPE Jacket, 2-Conductor Cords, Types SVO, SJOW, and SOOW Wire Size Stranding Insulation Thickness Part No. AWG mm2 AWG Mm Inch mm Type SVO, 300 V 1931 18 0.82 41/34 41 x 0.16 0.017 0.43 Type SJOW, 300 V 1932 18 0.81 16/30 16 x 0.25 0.032 0.81 1933 16 1.32 26/30 26 x 0.25 0.032 0.81 Type SOOW, 600 V 1934 18 0.81 16/30 16 x 0.25 0.031 0.79 1935 16 1.32 26/30 26 x 0.25 0.031 0.79 1936 14 2.08 41/30 41 x 0.25 0.048 1.22 1937 12 3.29 65/30 65 x 0.25 0.050 1.27 CPE Jacket, 3-Conductor Cords, Types SJOW and SOOW Wire Size Stranding Part No. AWG mm2 AWG mm 1932/3 1933/3 18 16 0.81 1.32 16/30 26/30 1934/3 1935/3 1936/3 1937/3 1938/3 18 16 14 12 10 0.81 1.32 1.08 3.29 5.32 16/30 26/30 41/30 65/30 105/30 Insulation Thickness Inch mm Type SJOW, 300 V 16 x 0.25 0.032 0.81 26 x 0.25 0.032 0.81 Type SOOW, 600 V 16 x 0.25 0.031 0.79 26 x 0.25 0.031 0.79 41 x 0.25 0.048 1.22 65 x 0.25 0.050 1.27 105 x 0.25 0.050 1.27 CPE Jacket, 4-Conductor Cords, Type SOOW, 600 V Wire Size Stranding Part No. AWG mm AWG mm2 1934/4 18 0.81 16/30 16 x 0.25 1935/4 16 1.32 26/30 26 x 0.25 1936/4 14 2.08 41/30 41 x 0.25 1937/4 12 3.29 65/30 65 x 0.25 1938/4 10 5.32 105/30 105 x 0.25 272 Materials Insulation Thickness Inch mm 0.031 0.79 0.031 0.79 0.048 1.22 0.050 1.27 0.050 1.27 Jacket Thickness Inch mm Cable Dimension Inch mm 0.034 0.86 0.236 5.99 0.034 0.034 0.86 0.86 0.294 0.320 7.47 8.13 0.065 0.065 0.085 0.100 1.65 1.65 2.16 2.54 0.356 0.382 0.516 0.592 9.04 9.70 13.11 15.04 Jacket Thickness Inch mm Cable Dimension Inch mm 0.034 0.034 0.86 0.86 0.330 0.358 7.85 8.64 0.065 0.065 0.085 0.100 0.100 1.65 1.65 2.16 2.54 2.54 0.373 0.401 0.543 0.623 0.642 9.47 10.19 13.79 15.82 16.31 Jacket Thickness Inch mm 0.065 1.65 0.065 1.65 0.085 2.16 0.100 2.54 0.100 2.54 Cable Dimension Inch mm 0.400 10.16 0.437 11.10 0.589 14.96 0.674 17.12 0.735 18.67 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V 3-Conductor Cordage PVC SJT, SVT UL 62 CSA C22.2 No. 49 Materials • S  tranded bare copper conductors • PVC insulation • Aluminum/polyester foil shield Foil facing inward Tinned copper drain wire one even AWG size smaller than conductor • Black or slate PVC jacket Operating Temperature • -30°C to +105°C Conductor Color Coding • B  lack, white, green/yellow (NEC) • Blue, brown, green/yellow (IEC 60446) Availability 250 ft (76.2 m) (Minimums may apply) 3-Conductor Cords (Unshielded) Wire Size Part No. AWG mm2 Stranding AWG mm 1952/3T 1953/3T 18 16 0.82 1.32 41/34 65/34 41 x 0.16 65 x 0.16 1951/3T 18 0.82 41/34 41 x 0.16 1941/3* 1942/3* 1943/3* 18 16 14 0.82 1.32 2.08 41/34 65/34 41/30 41 x 0.16 65 x 0.16 41 x 0.25 Insulation Thickness Inch mm Type SJT 0.032 0.81 0.032 0.81 Type SVT 0.016 0.41 Type SJT 0.032 0.81 0.032 0.81 0.032 0.81 Jacket Thickness Inch mm Cable Dimension Inch mm Color Code 0.032 0.032 0.81 0.81 0.309 0.335 7.85 8.51 NEC NEC 0.032 0.81 0.241 6.12 NEC 0.032 0.032 0.032 0.81 0.81 0.81 0.310 0.336 0.368 7.87 8.53 9.35 IEC IEC IEC *Black jacket only. 3-Conductor Cords (Foil Shield) Wire Size Part No. AWG mm2 1941/3F* 1942/3F* 1943/3F* 18 16 14 0.82 1.32 2.08 Stranding AWG mm 41/34 65/34 41/30 41 x 0.16 65 x 0.16 41 x 0.25 Insulation Thickness Inch mm Type SJT 0.032 0.81 0.032 0.81 0.032 0.81 Jacket Thickness Inch mm Cable Dimension Inch mm 0.032 0.032 0.032 0.314 0.340 0.372 0.81 0.81 0.81 7.98 8.64 9.45 Color Code IEC IEC IEC *Black jacket only. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 273 Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V 3-Conductor Cordage Rubber SJ, SV UL 62 CSA C22.2 No. 49 Materials • -30°C to +90°C • S  tranded bare copper conductors • Rubber insulation • Black chlorinated polyethylene jacket Conductor Color Coding Availability • Black, white, green 250 ft (76.2 m) Operating Temperature (Minimums may apply) 3-Conductor Cords (Unshielded) Wire Size Part No. AWG mm2 Stranding AWG mm 1952/3 1953/3 18 16 0.81 1.32 16/30 26/30 16 x 0.25 26 x 0.25 1951/3 18 0.82 41/34 41 x 0.16 274 Insulation Thickness Inch mm Type SJ 0.032 0.81 0.032 0.81 Type SV 0.017 0.43 Jacket Thickness Inch mm Cable Dimension Inch mm 0.034 0.034 0.86 0.86 0.309 0.340 7.85 8.64 0.036 0.91 0.256 6.50 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V Retractile Communications Cords UL AWM 2464 Materials Operating Temperature • -20°C to +80°C Conductor Color Coding • See table • S  tranded tinned copper conductors • Polypropylene insulation • Black PVC Jacket Availability 1-piece packages (Minimums may apply) Unshielded, 1 A Cord Length: 1 ft (0.30 m) Retracted, 5 ft (1.5 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 12” (304 mm) Part No. Conductors 702R 703R 704R 705R 706R 707R 2 3 4 5 6 7 Coil Diameter Inch 0.688 0.688 0.750 0.875 0.875 0.875 Jacket Diameter mm 17.48 17.48 19.05 22.23 22.23 22.23 Inch 0.190 0.200 0.220 0.230 0.230 0.250 mm 4.83 5.08 5.59 5.84 5.84 6.35 Unshielded, 1 A Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 702/2R 703/2R 704/2R 705/2R 706/2R 707/2R 2 3 4 5 6 7 Coil Diameter Inch 0.625 0.688 0.688 0.750 0.875 0.875 Jacket Diameter mm 15.88 17.48 17.48 19.05 22.23 22.23 Inch 0.180 0.190 0.200 0.215 0.230 0.230 mm 4.57 4.83 5.08 5.46 5.84 5.84 Unshielded, 1 A Cord Length: 3 ft (0.91 m) Retracted, 15 ft (4.5 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 704/3R 705/3R 706/3R 707/3R 4 5 6 7 Coil Diameter Inch 0.688 0.750 0.875 0.875 Jacket Diameter mm 17.48 19.05 22.23 22.23 Inch 0.200 0.210 0.230 0.230 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. mm 5.08 5.33 5.84 5.84 275 Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V Retractile Communications Cords UL AWM 2464 Materials • S  tranded tinned copper conductors • Polypropylene insulation • Black PVC Jacket Operating Temperature • -20°C to +80°C Conductor Color Coding Availability • See table 1-piece packages (Minimums may apply) Unshielded, 1 A Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 703/4R 704/4R 705/4R 706/4R 707/4R 708/4R 710/4R 712/4R 715/4R 3 4 5 6 7 8 10 12 15 Coil Diameter Inch 0.688 0.688 0.750 0.875 0.875 0.875 0.938 1.000 1.063 Jacket Diameter mm 17.48 17.48 19.05 22.23 22.23 22.23 23.83 25.40 27.00 Inch 0.190 0.200 0.220 0.230 0.230 0.250 0.280 0.290 0.310 mm 4.83 5.08 5.59 5.84 5.84 6.35 7.11 7.37 7.87 Shielded: Spiral Wrapped Tinned Copper, 1A Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 722/2R 723/2R Coil Diameter Cord Diameter mm 5.33 2 Inch 0.750 mm 19.05 Inch 0.210 3 0.750 19.05 0.200 6 Blue 7 Yellow 8 Brown 9 Slate 10 Pink 11 Violet 12 Tan 13 White/Black 14 Red/Black 15 Green/Black 5.08 Shielding Individual conductors 2 unshielded 1 shielded Conductor Color Coding 1 Black 2 White 3 Red 4 Green 5 Orange 276 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V Retractile Communications Cords UL AWM 4182, 4194, 4195, 4196, 4197, 4198 Materials • -20°C to +60°C • S  tranded tinned copper conductors • Rubber insulation • Black neoprene jacket Conductor Color Coding Availability • See table 1-piece packages Operating Temperature (Minimums may apply) Unshielded, 1 A Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: Lead length, each end: 6” (152 mm) Part No. Conductors 680/2 681/2 682/2 683/2 684/2 685/2 2 3 4 5 6 7 Coil Diameter Inch 0.750 0.813 0.938 1.063 1.125 1.250 mm 19.05 20.65 23.83 27.00 28.58 31.75 Cord Diameter Inch mm 0.220 5.59 0.220 5.59 0.250 6.35 0.290 7.37 0.310 7.87 0.320 8.13 AWM 4194 4195 4196 4197 4198 4182 Unshielded, 1 A Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended 23 AWG (0.27 mm2) Stranding: 21/36 (21 x 0.13 mm) Insulation thickness: Lead length, each end: 6” (152 mm) Part No. Conductors 680/4 681/4 682/4 683/4 684/4 685/4 2 3 4 5 6 7 Coil Diameter Inch 0.743 0.753 0.875 1.008 1.110 1.140 mm 18.87 19.13 22.23 25.60 28.19 28.96 Cord Diameter Inch mm 0.215 5.46 0.220 5.59 0.250 6.35 0.285 7.24 0.305 7.75 0.320 8.13 AWM 4194 4195 4196 4197 4198 4182 Conductor Color Coding 1 Black 2 White 3 Red 4 Green 5 Blue 6 Yellow 7 Brown Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 277 Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V Retractile Communications Cords SO, SVO, SJO UL 62 CSA C22.2 No. 49 Materials • S  tranded bare copper conductors • Rubber insulation • Black rubber jacket Operating Temperature • -20°C to +90°C Availability Conductor Color Coding 1-piece packages • 1 Black, 2 White, 3 Red, 4 Green (Minimums may apply) Types SV and SJO Cord Length: 1 ft (0.30 m) Retracted, 5 ft (1.5 m) Extended 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Lead length, each end: 6” (152 mm) Part No. Conductors Coil Diameter Cord Diameter Inch mm Inch mm 22.73 0.220 5.59 32.08 0.33 9.4 Type SVO 725 2 0.895 Type SJO 727 3 1.263 Type SVO Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 760/2 3 Coil Diameter Inch 1.000 Cord Diameter mm 25.40 Inch 0.27 mm 7.0 Type SVO Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 760/4 3 278 Coil Diameter Inch 1.000 Cord Diameter mm 25.40 Inch 0.27 mm 7.0 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 300 V/600 V Manhattan™ Cordsets 300 V/600 V Retractile Communications Cords SO, SVO, SJO UL 62 CSA C22.2 No. 49 Materials • S  tranded bare copper conductors • Rubber insulation • Black rubber jacket Operating Temperature • -20°C to +90°C Availability Conductor Color Coding 1-piece packages • 1 Black, 2 White, 3 Red, 4 Green (Minimums may apply) Type SJO, 300 V Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended 16 AWG (1.31 mm2) Stranding: 65/34 (65 x 0.16 mm) Insulation thickness: 0.030 (0.76 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 665/4 3 Coil Diameter Inch 1.335 Cord Diameter mm 33.91 Inch 0.385 mm 9.78 Type SO, 600 V Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.030 (0.76 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 674/2 4 Coil Diameter Inch 2.055 Cord Diameter mm 52.20 Inch 0.610 mm 15.49 Type SO, 600 V Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended 14 AWG (2.08 mm2) Stranding: 41/30 (41 x 0.25 mm) Insulation thickness: 0.030 (0.76 mm) Lead length, each end: 6” (152 mm) Part No. Conductors 674/4 4 Coil Diameter Inch 2.055 Cord Diameter mm 52.20 Inch 0.610 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. mm 15.49 279 Cable > Manhattan > Cordsets > 300 V Manhattan™ Cordsets 300 V Retractile Power Cords NEMA 5-15 Connector SVO, SJO UL 62 and 817 Materials Conductor Color Coding • S  tranded bare copper conductors • Rubber insulation • Black neoprene jacket • Molded NEMA 5-15P male plug, one end • 1 Black, 2 White, 3 Green or Green/Yellow Availability Operating Temperature • -20°C to +60°C 1-piece packages (Minimums may apply) Types SVO and SJO Cord Length: 1 ft (0.30 m) Retracted, 5 ft (1.5 m) Extended 18 AWG (0.82 mm2) Stranding: 41/34 (41 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Jacket stripped 1.5” (38.1 mm); insulation stripped 0.5” (12.7 mm) Part No. Conductors 654 2 Coil Diameter Inch mm Cord Diameter Inch mm Power Rating Watts Amps Type SVO 0.875 22.23 0.240 6.10 1250 10 0.330 8.38 1250 10 Type SJO 656 3 1.375 34.93 Type SJO Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended 16 AWG (1.31 mm2) Stranding: 65/34 (65 x 0.16 mm) Insulation thickness: 0.015 (0.38 mm) Jacket stripped 1.5” (38.1 mm); insulation stripped 0.5” (12.7 mm) Part No. Conductors 659 3 280 Coil Diameter Inch mm 1.333 33.86 Cord Diameter Inch mm 0.350 8.89 Power Rating Watts Amps 1625 13 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 30 V Manhattan™ Cordsets 30 V Miniature Retractile Communications Cords UL AWM 20013 Operating Temperature • -20°C to +60°C Conductor Color Coding • 1 Black, 2 White, 3 Red, 4 Green Materials • S  tranded tinned copper conductors • PVC insulation • Black PVC Jacket Availability 1-piece packages Cord length: 2 ft (0.61 m) retracted, 10 ft (3.0 m) extended 28 AWG (0.09 mm2) Part No. Conductors 651 652 2 4 Stranding: 19/40 (19 x 0.08 mm) Insulation thickness: 0.012 (0.30 mm) Lead length, each end: 6 (152 mm) Coil Diameter Inch mm 0.471 11.96 0.592 15.04 Cord Diameter Inch 0.135 0.150 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. mm 3.43 3.81 281 Cable > Manhattan > Cordsets > 5000 V Manhattan™ Cordsets 5000 V Retractile Test Lead Wire Operating Temperature Materials • -30°C to +60°C • S  tranded tinned copper conductors • Rubber insulation • Black jacket Conductor Color Coding • Black or red Availability 1-piece packages (Minimums may apply) 20 AWG (0.53 mm2) Stranding: 41/36 (41 x 0.13 mm) Insulation thickness: 0.050 (1.52 mm) Jacket stripped 1.5” (38.1 mm); insulation stripped 0.50” (12.7 mm) Part No. Conductors 650* 1 Coil Diameter Inch mm 0.580 14.73 Cord Diameter Inch mm 0.165 4.19 Power Rating Watts Amps 1250 10 *Not UL Listed 282 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Cordsets > 2000 V Manhattan™ Cordsets 2000 V Portable Power Cable Type W ICEA Accepted NEMA Accepted Materials • -30°C to +90°C • S  tranded bare copper conductors • Thermoset insulation • Black chlorinated polyethylene (CPE) jacket Conductor Color Coding Availability • See tables Cut to specific length Operating Temperature (Minimums may apply) 1-Conductor Cable Part No. 7431 7432 7434 7436 7437 7439 Wire Size AWG 6 4 2 1/0 2/0 4/0 mm2 13.57 21.55 34.45 53.1 67.08 107 Stranding AWG 133/27 133/25 133/23 259/24 259/23 259/21 mm 133 x 0.36 133 x 0.45 133 x 0.57 259 x 0.51 259 x 0.57 259 x 0.72 Insulation Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.078 1.98 0.078 1.98 0.078 1.98 Jacket Thickness Inch mm 0.080 2.03 0.080 2.03 0.080 2.03 0.080 2.03 0.080 2.03 0.080 2.03 Nominal Diameter Inch mm 0.510 12.95 0.570 14.48 0.660 16.76 0.770 19.56 0.820 20.83 0.930 23.62 Current-Carrying Capacity* Amps 85 110 150 200 235 315 Insulation Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 Jacket Thickness Inch mm 0.095 2.41 0.095 2.41 0.110 2.79 0.140 3.56 Nominal Diameter Inch mm 0.810 20.57 0.930 23.62 1.080 27.43 1.270 32.26 Current-Carrying Capacity* Amps 50 65 90 125 Insulation Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 Jacket Thickness Inch mm 0.140 3.56 0.140 3.56 0.140 3.56 Nominal Diameter Inch mm 0.910 23.11 1.010 25.65 1.170 29.72 Current-Carrying Capacity* Amps 50 65 85 Conductor color coding: black. *Single conductor at 40°C ambient. 2-Conductor Cable Part No. 7680 7681 7682 7684 Wire Size AWG 8 6 4 2 mm2 8.61 13.57 21.55 34.45 Stranding AWG 133/29 133/27 133/25 133/23 mm 133 x 0.28 133 x 0.36 133 x 0.45 133 x 0.57 Conductor color coding: black, white. *Single conductor at 40°C ambient. 3-Conductor Cable Part No. 7700 7701 7702 Wire Size AWG 8 6 4 mm2 8.61 13.57 21.6 Stranding AWG 133/29 133/27 133/25 mm 133 x 0.28 133 x 0.36 133 x 0.45 Conductor color coding: black, white, green. *Single conductor at 40°C ambient. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 283 Cable > Manhattan > Cordsets > 2000 V Manhattan™ Cordsets 2000 V Portable Power Cable Type W ICEA Accepted NEMA Accepted Materials • -30°C to +90°C • S  tranded bare copper conductors • Thermoset insulation • Black chlorinated polyethylene (CPE) jacket Conductor Color Coding Availability • See tables Cut to specific length Operating Temperature (Minimums may apply) 4-Conductor Cable Part No. 7800 7801 Wire Size AWG 8 6 Stranding mm2 8.61 13.57 AWG 133/29 133/27 mm 133 x 0.28 133 x 0.36 Insulation Thickness Inch mm 0.063 1.60 0.063 1.60 Jacket Thickness Inch mm 0.110 2.79 0.110 2.79 Nominal Diameter Inch mm 0.990 25.15 1.010 25.65 Current-Carrying Capacity* Amps 40 50 Conductor color coding: black, white, green, red. *Single conductor at 40°C ambient. 4-Conductor Cable with Ground Part No. 7760 7761 7762 7764 7765 7766 Wire Size AWG 8 6 4 2 1 1/0 mm2 8.61 13.6 21.6 34.4 42.4 53.0 Stranding AWG 133/29 133/0.0140 133/0.0177 133/0.0223 133/0.0251 259/24 mm 133 x 0.28 133 x 0.36 133 x 0.45 133 x 0.57 133 x 0.64 259 x 0.51 Insulation Thickness Inch mm 0.063 1.60 0.063 1.60 0.063 1.60 0.063 1.60 0.078 1.98 0.078 1.98 Nominal Diameter Inch mm 0.990 25.15 1.100 27.94 1.270 32.26 1.480 37.59 1.680 42.67 1.790 45.47 Current-Carrying Capacity* Amps 55 55 75 100 110 130 Ground Wire** AWG 12 12 10 9 8 7 mm2 3.08 3.08 5.32 7.00 8.63 10.5 Conductor color coding: black, white, red, orange. *Single conductor at 40°C ambient. **Ground wire is stranded bare copper with insulation. 284 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Manhattan™ Thermocouple Cable Temperature Measurement and Control The measurement of temperature is one of the most vital functions in the control of manufacturing and processing operations. As demands for greater quality, reliability, and economy increase, the demands for more precise measurement and control increase. Newer and more sophisticated electronic circuitry is employed creating stringent demands on the wire and cable used to sense and transmit temperature measurements. To meet these ever-increasing demands, Alpha has a full line of thermocouplegrade wire and thermocouple extension wire and cable. The Thermocouple At the heart of all temperature measurements is the thermocouple. Although involving very complex design parameters, the fundamental concept of all thermocouples is the same. Two wires of dissimilar metal are joined together at one end. An increase in temperature creates an electromotive force (EMF) or signal, which is transmitted through these wires to a monitoring device which “reads” this signal and displays it on a previously calibrated meter or digital device. The monitoring device is usually at a location some distance away from the actual thermocouple. To connect the thermocouple to the monitor requires wire or cable (for multiple thermocouple installations) that will maintain the integrity of the temperature-EMF Limits of Error for Thermocouple Grade ANSI Type Material J Iron/Constantan K Chromel/Alumel T Copper/Constantan E Chromel/Constantan R Platinum 13% Rhodium/ Platinum S Platinum 10% Rhodium/ Platinum Temperature Range (°C) 0 to 277 277 to 760 0 to 277 277 to 1260 -184 to -101 -101 to -59 -59 to 93 93 to 371 0 to 316 316 to 871 0 to 538 538 to 1482 0 to 538 538 to 1482 signal generated by the primary wires in the thermocouple. Conductor Materials The range and accuracy of temperature measurement are dependent on the conductor materials employed. Pairs of various metal alloys will react differently with changes in temperature. The following tables give the temperature range and tolerances for the most popular alloy combinations. All Alpha thermocouple wire and cable is tested and calibrated to the standard limits of error as indicated. Where situations require closer tolerances, wire and cable calibrated to the special error limits is available under special order. Standard Limits (±) 2.22°C 0.75% 2.22°C 0.75% — 2% 0.83°C 0.75% 1.67°C 0.5% 1.39°C 0.25% 1.39°C 0.25% Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Special Limits (±) 1.11°C 0.375% 1.11°C 0.375% 1% 1% 0.42°C 0.375% 1.25°C 0.375% — — — — 285 Manhattan™ Thermocouple Cable Limits of Error for Thermocouple Extension Wire ANSI Type Material JX Iron/Constantan KX Chromel/Alumel TX Copper/Constantan EX Chromel/Constantan RSX Copper/Copper Alloy 11 Insulation and Jacket Material Properties Temperature (°C) Material Continuous Intermittent PVC 105 — FEP 200 — TFE Tape 260 — Glass Braid 510 650 High-Temp Glass Braid 700 870 Temperature Range (°C) -18 to 204 -18 to 204 -59 to 93 -18 to 204 24 to 204 Flame G E E E E Standard Limits (±) 2.22°C 2.22°C 0.83°C 2.22°C 6.67°C Mechanical Abrasion Flexibility G G E G E E F/G G F/G G Solvents F E E E E Special Limits (±) 1.11°C 1.11°C 0.42°C 1.11°C — Chemical Resistance Acids Bases G G E E E E E E E E Moisture G E E F/G F/G E = Excellent, G = Good, F = Fair ISA/ANSI Thermocouple Color Coding Positive Wire ANSI Type Material Insul. Color J, JX Iron White K, KX Chromel Yellow T, TX Copper Blue E, EX Chromel Violet RX, SX Copper Black 286 Negative Wire Material Constantan Alumel Constantan Constantan Alloy 11 Insul. Color Red Red Red Red Red Grade Brown Brown Brown Brown — Jacket Color Tracer Black Yellow Blue Violet — Extension Black Yellow Blue Violet Green Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Thermocouple Grade Wire Manhattan™ Thermocouple Grade Wire ISA MC 96.1 Operating Temperature • -20°C to +510°C Conductor Color Coding • ISA color-coded insulation and jacket Materials • Solid or stranded alloy wire • Braided fiberglass or FEP insulation • Braided fiberglass or FEP jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length Duplex Parallel: Glass Braid Insulation, Glass Braid Jacket Conductor Size Outer Dimension Part No. Inch mm AWG mm2 Type J: Iron/Constantan 5769/1 30 0.05 0.030 x 0.048 0.76 x 1.22 5766 24 0.20 0.040 x 0.068 1.02 x 1.73 5767H* 24 0.20 0.064 x 0.102 1.63 x 2.59 5763H* 20 0.51 0.084 x 0.142 2.13 x 3.61 5762S** 20 0.56 0.090 x 0.154 2.29 x 3.91 M9180012 20 0.51 0.060 x 0.106 1.53 x 2.69 Type K: Chromel/Alumel 5776 24 0.20 0.040 x 0.068 1.02 x 1.73 5772S** 20 0.56 0.060 x 0.108 1.53 x 2.74 5773H * 20 0.51 0.084 x 0.142 2.13 x 3.61 M9180013 20 0.51 0.060 x 0.106 1.53 x 2.69 Type T: Copper/Constantan M9180014 20 0.51 0.060 x 0.106 1.53 x 2.69 *High temperature **7/28 (7 x 0.32 mm) stranding Duplex Parallel: FEP Insulation, FEP Jacket Conductor Size Outer Dimension Part No. Inch mm AWG mm2 Type J: Iron/Constantan M9160012 20 0.5 0.072 x 0.124 1.83 x 3.15 Type K: Chromel/Alumel M9160013 20 0.5 0.072 x 0.124 1.83 x 3.15 Type T: Copper/Constantan M9160014 20 0.5 0.072 x 0.124 1.83 x 3.15 (Minimums may apply) Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 287 Cable > Manhattan > Thermocouple Extension Wire > Unshielded Manhattan™ Thermocouple Extension Wire Duplex Parallel, Unshielded Part No. 5716 5710 5724 5724S* 5721 ISA MC 96.1 Operating Temperature • -20°C to +105°C Conductor Color Coding • ISA color-coded insulation and jacket Materials • Solid or stranded alloy wire • PVC, glass braid, or FEP insulation • PVC, glass braid, or FEP jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 288 5731 5731S* 5730 5740 Conductor Size Outer Dimension Inch mm AWG mm2 Type JX: Iron/Constantan 20 0.51 0.092 x 0.154 2.34 x 3.91 14 2.08 0.124 x 0.218 3.15 x 5.54 Type KX: Chromel/Alumel 20 0.51 0.092 x 0.154 2.34 x 3.91 20 0.56 0.098 x 0.166 2.49 x 4.22 16 1.31 0.111 x 0.192 2.82 x 4.88 Type TX: Copper/Constantan 20 0.51 0.092 x 0.154 2.34 x 3.91 20 0.56 0.098 x 0.166 2.49 x 4.22 16 1.31 0.111 x 0.192 2.82 x 4.88 Type RSX: Copper/Copper Alloy 11 16 1.31 0.111 x 0.192 2.82 x 4.88 *7/28 (7 x 0.32 mm) stranding Glass Braid Insulation, Glass Braid Jacket Conductor Size Outer Dimension Part No. AWG mm2 Inch mm Type JX: Iron/Constantan 5714 16 1.31 0.085 x 0.150 2.16 x 3.81 Type SX: Copper/Copper Alloy 11 5741H* 16 1.31 0.085 x 0.150 2.16 x 3.81 *High temperature FEP Insulation, FEP Jacket Part No. 5715 Conductor Size Outer Dimension Inch mm AWG mm2 Type JX: Iron/Constantan 16 1.31 0.087 x 0.154 2.21 x 3.91 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Cable > Manhattan > Thermocouple Extension Wire > Single and Multipair > Unshielded and Foil Shield > 300 V Manhattan™ Thermocouple Extension Wire 300 V, Single and Multipair, Unshielded and Foil Shield ISA MC 96.1 UL PLTC, ITC Operating Temperature • -20°C to +105°C • -80°C to +200°C (Hightemperature versions) Conductor Color Coding • ISA color-coded insulation and jacket Materials • Solid alloy wire • PVC or FEP insulation • Aluminum/polyester shield, 25% overlap min. Foil facing inward Tinned copper drain wire • PVC or FEP jacket Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) Unshielded Single Pair, PVC Insulation, PVC Jacket UL PLTC/ITC, 300 V, 105°C Conductor Size Outer Dimension Part No. Inch mm AWG mm2 Type EX: Chromel/Constantan M9000011 20 0.51 0.205 5.21 M9006011 16 1.31 0.235 5.97 Type JX: Iron/Constantan M9000012 20 0.51 0.205 5.21 M9006012 16 1.31 0.235 5.97 Type KX: Chromel/Alumel M9000013 20 0.51 0.205 5.21 M9006013 16 1.31 0.235 5.97 Type TX: Copper/Constantan M9000014 20 0.51 0.205 5.21 M9006014 16 1.31 0.235 5.97 Foil Shielded Individual and Overall, Twisted Pairs, PVC Insulation, PVC Jacket UL PLTC/ITC, 300 V, 105°C Conductor Size Outer Dimension Part No. Pairs AWG mm2 Inch mm Type EX: Chromel/Constantan M9020011 20 0.51 1 0.205 5.21 M9240041 20 0.51 4 0.440 11.18 M9240081 20 0.51 8 0.550 13.97 M9240121 20 0.51 12 0.665 16.89 M9240241 20 0.51 24 0.875 22.23 M9026011 16 1.31 1 0.235 5.97 Type JX: Iron/Constantan M9020012 20 0.51 1 0.205 5.21 M9240042 20 0.51 4 0.440 11.18 M9240082 20 0.51 8 0.550 13.97 M9240122 20 0.51 12 0.665 16.89 M9240162 20 0.51 16 0.740 18.80 M9240242 20 0.51 24 0.875 22.23 M9240362 20 0.51 36 1.010 25.65 M9026012 16 1.31 1 0.235 5.97 Type KX: Chromel/Alumel M9020013 20 0.51 1 0.205 5.21 M9240043 20 0.51 4 0.440 11.18 M9240083 20 0.51 8 0.550 13.97 M9240123 20 0.51 12 0.665 16.89 M9240243 20 0.51 24 0.875 22.23 M9026013 16 1.31 1 0.235 5.97 Type TX: Copper/Constantan M9020014 20 0.51 1 0.205 5.21 M9240044 20 0.51 4 0.440 11.18 M9240084 20 0.51 8 0.550 13.97 M9240124 20 0.51 12 0.665 16.89 M9240244 20 0.51 24 0.875 22.23 M9026014 16 1.31 1 0.235 5.97 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 289 Cable > Manhattan > Thermocouple Extension Wire > Single and Multipair > Unshielded and Foil Shield > 300 V Manhattan™ Thermocouple Extension Wire 300 V, Single and Multipair, Unshielded and Foil Shield ISA MC 96.1 UL PLTC, ITC Operating Temperature • -20°C to +105°C • -80°C to +200°C (Hightemperature versions) Conductor Color Coding • ISA color-coded insulation and jacket Materials • Solid alloy wire • PVC or FEP insulation • Aluminum/polyester shield, 25% overlap min. Foil facing inward Tinned copper drain wire • PVC or FEP jacket Foil Shielded Overall, Twisted Pairs, Solid Conductors, PVC Insulation, PVC Jacket UL PLTC, 300 V, 105°C Conductor Size Outer Dimension Part No. Pairs Inch mm AWG mm2 Type JX: Iron/Constantan 5711/2004 20 0.51 4 0.369 9.37 5711/2008 20 0.51 8 0.480 12.19 5711/2012 20 0.51 12 0.557 14.15 Type KX: Chromel/Alumel 5712/2002 20 0.51 2 0.325 8.26 5712/2004 20 0.51 4 0.369 9.37 5712/2008 20 0.51 8 0.480 12.19 5712/2024 20 0.51 24 0.828 21.03 5712/2036 20 0.51 36 0.956 24.28 Type TX: Copper/Constantan 5713/2004 20 0.51 4 0.369 9.37 5713/2012 20 0.51 12 0.557 14.15 5713/2024 20 0.51 24 0.828 21.03 Type RSX: Copper/Copper Alloy 5714/1601 16 1.31 2 0.256 6.50 Foil Shielded Twisted Pairs, FEP Insulation, FEP Jacket High Temperature: -80°C to 200°C Conductor Size Part No. Pairs AWG mm2 Type JX: Iron/Constantan 5717/2001 20 0.51 1 5717/1601 16 1.31 1 Type KX: Chromel/Alumel 5718/2001 20 0.51 1 5718/1601 16 1.31 1 Outer Dimension Inch mm 0.150 0.188 3.81 4.78 0.150 0.188 3.81 4.78 Availability 100 ft (30.5 m) 500 ft (152 m) 1000 ft (305 m) Bulk, cut to length (Minimums may apply) 290 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
5717/1601BK001
物料型号: - 该文档列出了多种不同型号的电缆,例如9059B、9159、9810、M4223等,它们都是符合特定规格的同轴电缆。
器件简介: - 文档中提到的电缆主要是用于视频传输的75欧姆同轴电缆,以及一些高温多导体电缆和伸缩式通信电缆。
引脚分配: - 文档中没有提到具体的引脚分配信息,因为它主要描述的是电缆而不是带有引脚的电子元件。
参数特性: - 电缆的参数特性包括标称阻抗(如75欧姆)、Vp(电压驻波比的百分比)、电容(如每英尺或每米的皮法拉)、以及符合的规格和可用性。
功能详解: - 文档中描述了不同类型电缆的功能,例如用于视频传输的同轴电缆,以及一些具有高温耐受性的电缆,它们可以在极端温度下正常工作。
应用信息: - 这些电缆广泛应用于需要视频传输或在高温环境下需要电气连接的场合。
封装信息: - 文档提供了电缆的物理尺寸信息,包括中心导体的尺寸、绝缘材料的厚度、屏蔽层的覆盖率和外护套的尺寸。
5717/1601BK001 价格&库存
很抱歉,暂时无法提供与“5717/1601BK001”相匹配的价格&库存,您可以联系我们找货
