M5656SL002
M5656SL002
    ALPHAWIRE(阿尔法电线)
    MULTI-PAIR74COND24AWG500'
M5656SL002 数据手册
Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742), Web: www.alphawire.com Customer Specification PART NO. M5656 Construction Diameters (In) 1) Component 1 37 X 1 PAIR a) Conductor 24 (7/32) AWG TC 0.024 b) Insulation 0.010" Wall, Nom. PVC, Semi Rigid 0.044 (1) Color Code Alpha Wire Color Code B Pair Color Pair Color Pair Color 1 WHITE-BLACK 14 BLACK-GREEN 27 RED-GREEN 2 WHITE-BROWN 15 BLACK-BLUE 28 RED-BLUE 3 WHITE-RED 16 BLACK-VIOLET 29 RED-VIOLET 4 WHITE-ORANGE 17 BLACK-SLATE 30 RED-SLATE 5 WHITE-YELLOW 18 BROWN-RED 31 ORANGE-YELLOW 6 WHITE-GREEN 19 BROWN-ORANGE 32 ORANGE-GREEN 7 WHITE-BLUE 20 BROWN-YELLOW 33 ORANGE-BLUE 8 WHITE-VIOLET 21 BROWN-GREEN 34 ORANGE-VIOLET 9 WHITE-SLATE 22 BROWN-BLUE 35 ORANGE-SLATE 10 BLACK-BROWN 23 BROWN-VIOLET 36 YELLOW-GREEN 11 BLACK-RED 24 BROWN-SLATE 37 YELLOW-BLUE 12 BLACK-ORANGE 25 RED-ORANGE 13 BLACK-YELLOW 26 RED-YELLOW c) Pair 2/Cond Cabled Together (1) Twists: 9.6 Twists/foot (min) 2) Cable Assembly 37 Components Cabled a) Twists: 1.6 Twists/foot (min) b) Core Wrap Clear Mylar Tape, 25% Overlap, Min. 3) Shield: Alum/Mylar Tape, 25% Overlap, Min. a) Foil Direction Foil Facing Out b) Drain Wire 24 (7/32) AWG TC c) Braid TC,70% Coverage, Min. 4) Jacket 0.063" Wall, Nom.,PVC a) Color(s) SLATE b) Ripcord 1 End 810 Denier Nylon c) Print ALPHA WIRE-* P/N M5656 37PR 24 AWG EXXXXXX SHIELDED 75C CMG (UL) C(UL) OR AWM 2343 CE ROHS * = Factory Code [Note: Product may have c(UL) or CSA markings depending upon plant of manufacture.] Applicable Specifications 0.666 (0.702 Max.) 1) UL a) Component 1 AWM/STYLE 1061 80°C / 300 VRMS b) Overall CMG 75°C AWM/STYLE 2343 80°C / 300 VRMS 2) CSA International FT4 C(UL) TYPE CMG 3) CE: 75°C EU Low Voltage Directive 2006/95/EC Environmental 1) CE: EU Directive 2011/65/EU(RoHS2): This product complies with European Directive 2011/65/EU (RoHS Directive) of the European Parliament and of the Council of 8 June 2011. No Exemptions are required for RoHS Compliance on this item. Consult Alpha Wire's web site for RoHS C of C. 2) REACH Regulation (EC 1907/2006): This product does not contain Substances of Very High Concern (SVHC) listed on the European Union's REACH candidate list in excess of 0.1% mass of the item. For up-to-date information, please see Alpha's REACH SVHC Declaration. 3) California Proposition 65: The outer surface materials used in the manufacture of this part meet the requirements of California Proposition 65. Properties Physical & Mechanical Properties 1) Temperature Range -20 to 80°C 2) Bend Radius 10X Cable Diameter 3) Pull Tension 278 Lbs, Maximum Electrical Properties (For Engineering purposes only) 1) Voltage Rating 300 VRMS 2) Mutual Capacitance 23.1 pf/ft @1 kHz, Nominal 3) Ground Capacitance 42 pf/ft @1 kHz, Nominal 4) Characteristic Impedance 82 Ω 5) Inductance 0.19 µH/ft, Nominal 6) Conductor DCR 26 Ω/1000ft @20°C, Nominal 7) OA Shield DCR 1.28 Ω/1000ft @20°C, Nominal Other Packaging Flange x Traverse x Barrel (inches) a) 1000 FT 36 x 14 x 12 Continuous length b) 500 FT 24 x 14 x 12 Continuous length c) 100 FT 16 x 11 x 8 Continuous length d) Bulk(Made-to-order) [Spool dimensions may vary slightly] www.alphawire.com Alpha Wire | 711 Lidgerwood Avenue, Elizabeth, NJ 07207 Tel: 1-800-52 ALPHA (25742) Although Alpha Wire (“Alpha”) makes every reasonable effort to ensure their accuracy at the time of publication, information and specifications described herein are subject to errors or omissions and to changes without notice, and the listing of such information and specifications does not ensure product availability. Alpha provides the information and specifications herein on an “AS IS” basis, with no representations or warranties, whether express, statutory or implied. In no event will Alpha be liable for any damages (including consequential, indirect, incidental, special, punitive, or exemplary) whatsoever, even if Alpha had been advised of the possibility of such damages, whether in an action under contract, negligence or any other theory, arising out of or in connection with the use, or inability to use, the information or specifications described herein. ALPHA WIRE - CONFIDENTIAL AND PROPRIETARY Notice to persons receiving this document and/or technical information. This document is confidential and is the exclusive property of ALPHA WIRE, and is merely on loan and subject to recall by ALPHA WIRE at any time.  By taking possession of this document, the recipient acknowledges and agrees that this document cannot be used in any manner adverse to the interests of ALPHA WIRE, and that no portion of this document may be copied or otherwise reproduced without the prior written consent of ALPHA WIRE.  In the case of conflicting contractual provisions, this notice shall govern the status of this document.  ©2013 ALPHA WIRE - all rights reserved. EU/China ROHS CERTIFICATE OF COMPLIANCE To Whom It May Concern: Alpha Wire Part Number: M5656 M5656 , RoHS-Compliant Commencing With 7/1/2005 Production This document certifies that the Alpha part number cited above is manufactured in accordance with Directive 2011/65/EU of the European Parliament, better known as the RoHS Directive, with regards to restrictions of the use of certain hazardous substances used in the manufacture of electrical and electronic equipment. The reader is referred to this Directive for the specific definitions and extents of this Directive. No Exemptions are required for RoHS Compliance on this item. It should be noted that this product does not fall within the scope of Directive 2011/65/EU, but this Certificate is offered for cases where this product will be used within EEE that does fit within the Directive's scope.  Additionally, Alpha certifies that the listed part number is in compliance with China RoHS “Marking for Control of Pollution by Electronic Information Products” standard SJ/T 113642006. Substance Maximum Control Value Lead 0.1% by weight (1000 ppm) Mercury 0.1% by weight (1000 ppm) Cadmium 0.01% by weight (100 ppm) Hexavalent Chromium 0.1% by weight (1000 ppm ) Polybrominated Biphenyls (PBB) 0.1% by weight (1000 ppm) Polybrominated Diphenyl Ethers (PBDE) , Including Deca-BDE 0.1% by weight (1000 ppm) The information provided in this document and disclosure is correct to the best of Alpha Wire's knowledge, information and belief at the date of its release. The information provided is designed only as a general guide for the safe handling, storage, and any other operation of the product itself or the one that it will become part of. The intent of this document is not to be considered a warranty or quality specification. Regulatory information is for guidance purposes only. Product users are responsible for determining the applicability of legislation and regulations based on their individual usage of the product. Authorized Signatory for the Alpha Wire Company: Dave Watson, Director of Engineering & QA 5/14/2013
M5656SL002
物料型号:M5656 器件简介:Alpha Wire 的屏蔽电缆,具有37对绞合线对,使用24 AWG实心导体,PVC绝缘,符合UL、CSA和CE认证。
引脚分配:37对线对,包括白色-黑色、白色-棕色、白色-红色等颜色编码。
参数特性:工作温度范围为-20至80°C,最小弯曲半径为电缆直径的10倍,最大拉力为278磅。
功能详解:电缆组件提供屏蔽功能,使用铝箔和编织层作为屏蔽,外层为PVC护套。
应用信息:适用于需要屏蔽的电子设备连接,如医疗设备、工业控制系统等。
封装信息:电缆直径为0.666英寸(最大0.702英寸),护套颜色为SLATE,一端带有810Denier尼龙撕裂绳。
M5656SL002 价格&库存
很抱歉,暂时无法提供与“M5656SL002”相匹配的价格&库存,您可以联系我们找货
