NEED
CUSTOMS?
Hi-Flex, Hi-Temp IDC Ribbon Cable
See Page
25
Ultra Flexible Ribbon Cable for standard IDC Connectors
Available with up to 64 Conductors in .050˝ or 1mm Pitch
-65°C to +260°C Rating – Ideal for the Harshest Environments
Cicoil’s high performance line of flat ribbon cable is ideal for
electronic applications that require better flexibility, broader
temperature and harsh environment capabilities than those
offered by PVC or other ribbon cables. Cicoil’s patented Flexx-Sil™
jacket provides the highest flex, highest performance ribbon cable
available.
UL
RoHS
MEETS 94V-0
COMPLIANT
REACH
COMPLIANT
FAA
FLAME TESTED
Applications
Aerospace, Robotics, Medical, Semiconductor,
Packaging, Surgical Systems
Cable
Gauge Pitch
Data & Video
28 AWG
.050˝
28 AWG
1mm
Dimensions
Amp
Rating1
Dimensions
No. of
Conductors
Width
Span
Height
10
14
16
28
30
34
40
44
50
60
64
10
16
30
34
40
44
50
0.50˝
0.70˝
0.80˝
1.00˝
1.30˝
1.40˝
1.50˝
1.70˝
2.00˝
2.20˝
2.50˝
3.00˝
3.20˝
10 mm
16 mm
20 mm
26 mm
30 mm
34 mm
40 mm
44 mm
50 mm
0.45˝
0.65˝
0.75˝
0.95˝
1.25˝
1.35˝
1.45˝
1.65˝
1.95˝
2.15˝
2.45˝
2.95˝
3.15˝
9 mm
15 mm
19 mm
25 mm
29 mm
33 mm
39 mm
43 mm
49 mm
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.04˝ max.
0.94 mm
0.94 mm
0.94 mm
0.94 mm
0.94 mm
0.94 mm
0.94 mm
0.94 mm
0.94 mm
5
5
310J101-10
310J101-14
310J101-16
310J101-20
310J101-26
310J101-28
310J101-30
310J101-34
310J101-40
310J101-44
310J101-50
310J101-60
310J101-64
666K101-10
666K101-16
666K101-20
666K101-26
666K101-30
666K101-34
666K101-40
666K101-44
666K101-50
Note
1. Amp rating is the maximum value for each conductor at room temperature of 70°F (21°C). Amp rating decreases as
temperature increases.
Cable Specifications
Mechanical
Conductors: Ultra flexible, finely stranded
copper
Minimum Bend Radius:
- 6x cable height for intermediate flex
- 10x cable height for continuous flex
Outer Jacket Durometer Rating: 65 (Shore A)
HEIGHT
Cable Assemblies
Please contact Cicoil for other
connectors and length options.
Flexible Flat Cables & Cable Assemblies
Part Number Addition
3
6
12
-CA003
-CA006
-CA012
Assembly Dimensions
J1
J1
CABLE LENGTH
Connectors
• Signal (J1): Berg or equivalent (XX = Position Quantity)
.050˝ Pitch: P/N 71602-00XX
1mm Pitch: P/N 89361-1XX
Environmental
Temperature Rating: -65°C to +260°C
Moisture Rating: Submersible, Salt Water Resistant
Clean Room Rating: Class 1, Zero Particulates
Extreme Environments: Sunlight, UV Light, Alcohol, Chemical and Oil Resistant
Electrical
Outer Jacket Dielectric Strength: 450 volts/mil (17.7 kv/mm)
Cable Length (feet)
Notes
1. Append onto base cable Part Number for complete
assembly. Example: 310J101-10-CA003
2. Connector ratings may differ from cable ratings; refer to
manufacturer specifications.
All engineering values are nominal and subject to change.
See Electrical Rating Chart on Page 47
WIDTH
SPAN
Part
Number
Options
Page
Additional Conductors
Low Friction Options
StripMount™ Integrated Mounting Strip
Integrated Tubing
SuperTuff™ Jacket
Colored Jacketing
Strip and Tin Cable Ends
FlexRail™ Self-Supporting Cable
Complete Assembly
661-295-1295
26
28
28
29
29
29
29
30
31
Cicoil.com
很抱歉,暂时无法提供与“310J101-50”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+159.153961+20.62939
- 5+126.892975+16.44775
- 10+114.9984810+14.90600
- 25+100.9598025+13.08632
- 50+91.5179050+11.86247
- 100+83.01233100+10.75998
- 国内价格 香港价格
- 200+78.38045200+10.15960
- 400+71.24779400+9.23507
- 600+67.42640600+8.73975
- 1000+62.954481000+8.16010
- 1400+61.138421400+7.92471
