530-26-08-BL-1000F
530-26-08-BL-1000F
    CNC
    CABLE MOD FLAT 8COND REEL 1000'
530-26-08-BL-1000F 数据手册
Extract from the online catalog     MSTB 2,5/ 2-ST Order No.: 1754449 The figure shows a 10-position version of the product http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449   Plug component, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Connection type: Screw connection, Color: green   Product notes WEEE/RoHS-compliant since: 01/01/2003 Commercial data EAN 4017918028619 Pack 50 pcs. Customs tariff 85366990 Weight/Piece 0.00366 KG Catalog page information Page 198 (CC-2009) http:// www.download.phoenixcontact.com Please note that the data given here has been taken from the online catalog. For comprehensive information and data, please refer to the user documentation. The General Terms and Conditions of Use apply to Internet downloads. Technical data Dimensions / positions Pitch 5 mm Dimension a 5 mm Number of positions 2 Screw thread M3 PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 1 / 6 Feb 24, 2010 MSTB 2,5/ 2-ST Order No.: 1754449 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449 Tightening torque, min 0.5 Nm Tightening torque max 0.6 Nm Technical data Insulating material group I Rated surge voltage (III/3) 4 kV Rated surge voltage (III/2) 4 kV Rated surge voltage (II/2) 4 kV Rated voltage (III/2) 320 V Rated voltage (II/2) 630 V Connection in acc. with standard EN-VDE Nominal current IN 12 A Nominal voltage UN 250 V Nominal cross section 2.5 mm² Maximum load current 12 A (with 2.5 mm conductor cross section) Insulating material PA Inflammability class acc. to UL 94 V0 Internal cylindrical gage A3 Stripping length 7 mm 2 Connection data Conductor cross section solid min. 0.2 mm² Conductor cross section solid max. 2.5 mm² Conductor cross section stranded min. 0.2 mm² Conductor cross section stranded max. 2.5 mm² Conductor cross section stranded, with ferrule without plastic sleeve min. 0.25 mm² Conductor cross section stranded, with ferrule without plastic sleeve max. 2.5 mm² Conductor cross section stranded, with ferrule with plastic sleeve min. 0.25 mm² Conductor cross section stranded, with ferrule with plastic sleeve max. 2.5 mm² Conductor cross section AWG/kcmil min. 24 Conductor cross section AWG/kcmil max 12 2 conductors with same cross section, solid min. 0.2 mm² 2 conductors with same cross section, solid max. 1 mm² PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 2 / 6 Feb 24, 2010 MSTB 2,5/ 2-ST Order No.: 1754449 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449 2 conductors with same cross section, stranded min. 0.2 mm² 2 conductors with same cross section, stranded max. 1.5 mm² 2 conductors with same cross section, stranded, ferrules without plastic sleeve, min. 0.25 mm² 2 conductors with same cross section, stranded, ferrules without plastic sleeve, max. 1 mm² 2 conductors with same cross section, stranded, TWIN ferrules with plastic sleeve, min. 0.5 mm² 2 conductors with same cross section, stranded, TWIN ferrules with plastic sleeve, max. 1.5 mm² Certificates / Approvals Certification CB, CSA, CUL, GOST, UL, VDE-PZI CSA Nominal voltage UN 300 V Nominal current IN 10 A AWG/kcmil 28-12 CUL Nominal voltage UN 300 V Nominal current IN 10 A AWG/kcmil 30-12 UL Nominal voltage UN 300 V Nominal current IN 10 A AWG/kcmil 30-12 PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 3 / 6 Feb 24, 2010 MSTB 2,5/ 2-ST Order No.: 1754449 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449 Accessories Item Designation Description 1733169 EBP 2- 5 Insertion bridge, fully insulated, for plug connectors with 5.0 or 5.08 mm pitch, no. of positions: 2 1803934 KGG-MSTB 2,5/ 2 Cable housing, Number of positions: 2, Dimension a: 10 mm, Color: green SK 5/3,8:FORTL.ZAHLEN Marker card, printed horizontally, self-adhesive, 12 identical decades marked 1-10, 11-20 etc. up to 91-(99)100, sufficient for 120 terminal blocks CP-MSTB Keying profile, is inserted into the slot on the plug or inverted header, red insulating material SZS 0,6X3,5 Screwdriver, bladed, matches all screw terminal blocks up to 4.0 mm² connection cross section, blade: 0.6 x 3.5 mm, without VDE approval General Marking 0804183 Plug/Adapter 1734634 Tools 1205053 Additional products Item Designation Description 0707109 DFK-MSTB 2,5/ 2-G Plug component, Nominal current: 12 A, Nom. voltage: 320 V, Nom. voltage: 320 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Direct mounting 1899841 EMSTBA 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Assembly: Press-in 1914852 EMSTBVA 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 200 V, Pitch: 5 mm, Number of positions: 2, Assembly: Press-in 1762046 MDSTB 2,5/ 2-G Header, Nominal current: 10 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1846519 MDSTBA 2,5/ 2-G Header, Nominal current: 10 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1763032 MDSTBV 2,5/ 2-G Header, Nominal current: 10 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1845785 MDSTBVA 2,5/ 2-G Header, Nominal current: 10 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Assembly: Soldering General PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 4 / 6 Feb 24, 2010 MSTB 2,5/ 2-ST Order No.: 1754449 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449 1802443 MDSTBW 2,5/ 2-G Header, Nominal current: 10 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Assembly: Soldering 1754436 MSTB 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1768189 MSTB 2,5/ 2-G-LA Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Assembly: Soldering 1757475 MSTBA 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1770481 MSTBA 2,5/ 2-G-LA Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Assembly: Soldering 1753437 MSTBV 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1755516 MSTBVA 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1736111 MSTBW 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1769230 SMSTB 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering 1769803 SMSTBA 2,5/ 2-G Header, Nominal current: 12 A, Nom. voltage: 250 V, Pitch: 5 mm, Number of positions: 2, Color: green, Assembly: Soldering Diagrams/Drawings Dimensioned drawing PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 5 / 6 Feb 24, 2010 MSTB 2,5/ 2-ST Order No.: 1754449 http://eshop.phoenixcontact.de/phoenix/treeViewClick.do?UID=1754449 Address PHOENIX CONTACT Deutschland GmbH Flachsmarktstr. 8 32825 Blomberg,Germany Phone +49 5235 3 12000 Fax +49 5235 3 41200 http://www.phoenixcontact.de © 2010 Phoenix Contact Technical modifications reserved; PHOENIX CONTACT Deutschland GmbH http://www.phoenixcontact.de Page 6 / 6 Feb 24, 2010
530-26-08-BL-1000F 价格&库存
很抱歉,暂时无法提供与“530-26-08-BL-1000F”相匹配的价格&库存,您可以联系我们找货
530-26-08-BL-1000F
  • 2000+3.367462000+0.43192
