Manhattan™ Electrical Cable
Alpha Wire | www.alphawire.com | 1-800-52 ALPHA
Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
141
Signal transmission made reliable
A
lpha Wire’s Manhattan
brand has been a trusted
and reliable source of
cable for over 60 years. Whether
you need something as simple
as a power cord or a cable that
can maintain audio-video signal
integrity in a noisy environment,
you’ll find the breadth and depth
of products to ensure an optimum
solution to your application.
udio/video
A
Computer
Thermocouple
Control
Plenum
Coaxial
Cords/cordage
High temperature
Security and data
Instrumentation
Instrumentation cable
Maintain the integrity of analog
and digital signals with our broad
product portfolio of single
and multiple pair shielded and
unshielded products.
Choose the correct number of
conductors, gauge, insulation,
shielding, jacket material, UL/CSA/
NEC approvals, and any other
parameters to find the right cable
for your application.
We offer the widest range of
shielded and unshielded
configurations to satisfy applications
including traditional RS-232 and
All our cords are UL Listed and
CSA Certified; we also offer a
wide range of CENELEC-approved
products for international use.
Options include two- and threeconductor cords, shielded or
unshielded, stripped and terminated
cable ends, straight or retractile
cords, and all common plug and
receptacle configurations.
We offer UL style TC in a variety
of conductor counts, gauges,
and shielding options, all with
durable PVC/nylon insulation and
PVC jackets. We also offer
MIL-DTL-16878 cables with 600 V
and 1000 V ratings.
Alpha Wire’s Manhattan brand
of high-temperature cables are
available for temperatures ranging
from 150°C to 540°C. We make it
easy for you select the right cable
to meet the demanding hightemperature requirements for
control and power applications.
Plenum cable
Security and data
We offer a full range of cables for
control, computer interconnections,
security, alarms, and building
energy management systems in a
variety of plenum-rated insulations
and jackets.
Count on Alpha Wire for a
complete product family of
security and data cables, optimized
for security video, data, and
monitoring applications.
Thermocouple cable
Coaxial cable
Computer cable
Cords/cordsets
High-temperature cable
Control cable
Audio/video cable
142
RS-422 interfaces, point-of-sale
equipment, and modems and
multiplexers. For extended
distances, we offer cables with
very low capacitance.
For a complete range of 50, 75,
93, and 100 ohm coaxial, twinaxial,
and triaxial cables, we offer a wide
range of insulations and jackets
meeting the requirements of military
specifications and regulatory
agencies such as UL and CSA.
You can find the perfect
Manhattan brand thermocouple
cable based on conductor
combinations JX, KX, EX, and SX,
as well as insulations suited for
applications up to 200°C, for
quality and accurate temperature
measurement.
Cable > Manhattan > Audio/Video Cable > Multiconductor > Unshielded > 300 V
Manhattan™ Audio/Video Cable
300 V Unshielded, Multiconductor, SR-PVC/PVC, PVC
UL AWM 2509, UL CMG, PVC Insulation
22 AWG (0.35 mm2)
Stranding: 7/30 (7 x 0.25 mm)
Insulation thickness: 0.016 (0.41 mm)
Color Code J
UL AWM 2464, 2509, 2576,
UL CM, CMG
CSA CM, CMG FT4
Part No.
Conductors
M13302
2
Operating Temperature
• -20°C to +80°C (AWM)
• -20°C to +75°C (CM, CMG)
Conductor Color Coding
• See tables
Materials
• S
tranded tinned copper
conductors
• PVC or semirigid PVC insulation
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
(Minimums may apply)
Jacket Thickness
Inch
mm
0.025
0.64
UL AWM 2576, UL CM, PVC Insulation (150 V)
22 AWG (0.35 mm2)
Insulation thickness: 0.010 (0.25 mm)
Applications
• U
nbalanced intercom and
sound systems
• Remote circuit control
• Low-voltage circuits
Nominal Diameter
Inch
mm
0.174
4.42
Part No.
Conductors
M13303
M13304
M13305
M13306
M13307
M13308
M13309
M13310
M13312
M13315
M13320
M13325
M13330
M13340
M13350
3
4
5
6
7
8
9
10
12
15
30
40
50
Nominal
Diameter
Inch
mm
0.172
4.37
0.185
4.70
0.200 5.08
0.215
5.46
0.215
5.46
0.230
5.84
0.246
6.25
0.264
6.71
0.272
6.91
0.310
7.87
0.342
8.69
0.380
9.65
0.401
10.19
0.445 11.30
0.498 12.65
Jacket
Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.040
1.02
0.040
1.02
0.040
1.02
0.040
1.02
0.040
1.02
0.045
1.14
Color Code
Black, Green, Red
O
O
O
O
O
O
O
O
F
F
F
F
F
F
UL AWM 2464, UL CM, PVC Insulation
20 AWG (0.56 mm2)
Stranding: 7/28 (7 x 0.32 mm)
Insulation thickness: 0.013 (0.33 mm)
Part No.
Conductors
M13404
M13405
M13407
M13409
M13412
M13415
4
5
7
9
12
15
Nominal Diameter
Inch
mm
0.219
5.56
0.238
6.05
0.257
6.53
0.303
7.70
0.336
8.53
0.374
9.50
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.035
0.89
0.040
1.02
Color
Code
O
O
O
O
O
F
20 AWG (0.56 mm2)
Color Code J
Part No.
Conductors
M13402
2
Nominal Diameter
Inch
mm
0.180
4.57
Jacket Thickness
Inch
mm
0.020
0.51
143
300 V Unshielded, Multiconductor, SR-PVC, PVC
18 AWG (0.81 mm2)
Stranding: 16/30 (16 x 0.25 mm)
Color Code J
UL AWM 2463, 2464, 2509,
2576, 2598
UL CM, CMG
UL CL2, CL3
CSA CM, CMG FT4
Applications
• U
sound systems
• -20°C to +75°C (CM, CMG,
CL2, CL3)
Part No.
Conductors
M13502
2
Nominal Diameter
Inch
mm
0.198
5.03
Jacket Thickness
Inch
mm
0.020
0.51
UL AWM 2598, UL CM, PVC Insulation
18 AWG (0.96 mm2)
Stranding: 19/30 (19 x 0.25 mm)
Insulation thickness: 0.018 (0.46 mm)
Part No.
Conductors
M13503
M13504
M13505
M13507
M13509
M13512
M13515
M13519
M13525
3
4
5
7
9
12
15
19
25
Nominal Diameter
Inch
mm
0.249
6.32
0.272
6.91
0.297
7.54
0.333
8.46
0.387
9.83
0.437
11.10
0.485
12.32
0.520
13.21
0.636
16.15
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.037
0.94
0.037
0.94
0.040
1.02
0.045
1.14
0.045
1.14
0.060
1.52
Color
Code
O
O
O
O
O
F
F
F
F
16 AWG (1.32 mm2)
• See tables
Stranding: 19/0.0117 (19 x 0.30 mm)
Color Code F
Materials
• S
conductors
• Slate PVC jacket
Part No.
Conductors
M13572
M13574
2
4
Nominal Diameter
Inch
mm
0.274
6.96
0.378
9.60
Insulation Thickness
Inch
mm
0.023
0.58
0.030
0.76
UL AWM 2463, UL CL2 or CL3, PVC Insulation
14 AWG (2.08 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.045
1.14
Stranding: 19/0.0147 (19 x 0.37 mm)
Insulation thickness: 0.032 (0.81 mm)
Color Code F
Part No.
Conductors
M13582
M13584
2
4
Nominal Diameter
Inch
mm
0.346
8.79
0.404
10.26
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
Approval
CL2
CL3
UL AWM 2463, UL CL3, PVC Insulation
12 AWG (3.29 mm2)
Stranding: 19/0.0185 (19 x 0.47 mm)
Color Code F
144
Part No.
Conductors
M13590
2
Nominal Diameter
Inch
mm
0.394
10.00
Jacket Thickness
Inch
mm
0.040
1.02
300 V Unshielded, Multiconductor, PVC, PVC
16 AWG (1.32 mm2)
UL AWM 2463 (600 V) VW-1
Applications
• U
sound systems
Part No.
Conductors
M3704
M3705
M3707
M3709
M3712
M3715
M3719
M3725
4
5
7
9
12
15
19
25
Nominal Diameter
Inch
mm
0.392
9.96
0.428
10.87
0.465
11.81
0.574
14.58
0.637
16.17
0.691
17.55
0.742
18.85
0.904
22.96
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
• -20°C to +80°C
• Chart F (page 532)
Materials
• Stranded
tinned copper
conductors
• PVC insulation
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
145
Cable > Manhattan > Audio/Video Cable > Multiconductor > Braid Shield > 300 V
300 V Braid Shield, Multiconductor, PE, PVC
24 AWG (0.20 mm2)
Stranding: 10/34 (10 x 0.16 mm)
UL AWM 2092, 2093, 2094
UL CM
Part No.
Conductors
M1102
M1103
M1104
M1105
M1106
2
3
4
5
6
Nominal Diameter
Inch
mm
0.177
4.50
0.186
4.72
0.200
5.08
0.217
5.51
0.234
5.94
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM
2092
2093
2094
2094
2094
Applications
22 AWG (0.38 mm2)
• S
ensing, recording, monitoring
devices, and telemetry
• - 20°C to +75°C (CM)
• -20°C to +60°C (AWM)
• Chart H (page 533)
Materials
• Stranded
tinned copper
conductors
• Polyethylene insulation
• Tinned copper braid shield,
90% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
146
Stranding: 19/34 (19 x 0.16 mm)
Part No.
Conductors
M1112
M1113
M1114
M1115
M1116
M1118
2
3
4
5
6
8
Nominal Diameter
Inch
mm
0.193
4.90
0.203
5.16
0.220
5.59
0.239
6.07
0.258
6.55
0.278
7.06
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM
2092
2093
2094
2094
2094
2094
20 AWG (0.52 mm2)
Stranding: 26/34 (26 x 0.16 mm)
Part No.
Conductors
M1122
M1123
M1124
M1125
M1126
M1128
M1130
M1132
M1135
M1140
2
3
4
5
6
8
10
12
15
Nominal Diameter
Inch
mm
0.229
5.82
0.246
6.25
0.264
6.71
0.285
7.24
0.306
7.77
0.328
8.33
0.375
9.53
0.386
9.80
0.417
10.59
0.464
11.79
Jacket Thickness
Inch
mm
0.032
0.81
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
UL AWM
2092
2093
2094
2094
2094
2094
2094
2094
2094
2094
18 AWG (0.82 mm2)
Stranding: 41/34 (41 x 0.16 mm)
UL CM
Part No.
Conductors
M1142
M1143
M1144
M1146
2
3
4
6
Applications
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
UL AWM
2092
2093
2094
2094
16 AWG (1.31 mm2)
• S
Nominal Diameter
Inch
mm
0.253
6.43
0.265
6.73
0.286
7.26
0.333
8.46
Stranding: 65/34 (65 x 0.16 mm)
Part No.
Conductors
M1162
M1163
M1164
2
3
4
Nominal Diameter
Inch
mm
0.277
7.04
0.291
7.39
0.308
7.82
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
UL AWM
2092
2093
2094
Materials
• Stranded
tinned copper
conductors
90% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
147
Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield, Overall > 300 V
300 V Foil Shield, Overall, Multiconductor, PP, HDPE
Direct Burial
20 AWG (0.51 mm2)
Stranding: : 10/30 (10 x 0.25 mm)
UL CM
Applications
• D
irect burial audio and
data transmission
Part No.
Conductors
M39047
M39048
M39049
M39050
2
3
10
15
Nominal Diameter
Inch
mm
0.193
4.90
0.202
5.13
0.319
8.10
0.363
9.22
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.040
1.02
0.045
1.14
Color
Code
O
O
O
F
Mutual capacitance: 22.2 pF/ft (72.8 pF/m)
Ground capacitance: 40 pF/ft (131.2 pF/m)
Except Part No. M39047:
Mutual capacitance: 24.5 pF/ft (80.3 pF/m)
Ground capacitance: 44 pF/ft (144.3 pF/m)
• -20°C to +80°C
• See table
Materials
• S
olid tinned copper conductors
• Polypropylene insulation
• Aluminum/polyester foil shield,
25% overlap min.
Foil facing inward
22 AWG (0.32 mm2) solid tinned
copper drain wire
• Black high-density
polyethylene jacket
Features
• Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk
148
Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 350 V
350 V Individually Foil Shielded Pairs, Multipair, PP, HDPE
Direct Burial
20 AWG (0.51 mm2)
Stranding: 10/30 (10 x 0.25)
Part No.
Pairs
M39051
M39052
3
6
UL CM
Nominal Diameter
Inch
mm
0.336
8.53
0.446
11.33
Jacket Thickness
Inch
mm
0.040
1.02
0.045
1.14
Applications
• D
irect burial audio and data
transmission
• -20°C to +80°C
• Chart K (page 529)
Materials
• Stranded
tinned copper
conductors
25% overlap min.
Foil facing inward
22 AWG (0.35 mm2) stranded
tinned copper drain wire
polyethylene jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
149
Cable > Manhattan > Audio/Video Cable > Multipair > Unshielded > 300 V
300 V Unshielded, Multipair, PVC, PVC
AWM 2576, CMG
22 AWG (0.32 mm2)
Stranding: Solid
UL AWM 2464, 2576 (150 V)
UL CMG
CSA CMG FT4 (150 V)
Applications
• Speakers and sound systems
• - 20°C to +80°C (AWM)
• -20°C to +75°C (CMG)
Part No.
Pairs
M13001
M13002
M13003
M13004
M13005
M13006
M13008
M13009
M13013
M13019
M13027
1
2
3
4
5
6
8
9
13
19
27
22 AWG (0.35 mm2)
Materials
Part No.
Pairs
• Solid
or stranded tinned
copper conductors
• PVC insulation
• Slate PVC jacket
M13032
M13033
M13034
M13036
M13039
M13042
M13045
M13049
M13057
2
3
4
6
9
12
15
19
27
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.035
0.89
0.037
0.94
0.040
1.02
0.045
1.14
AWM 2576, CMG
Availability
Nominal Diameter
Inch
mm
0.157
3.98
0.215
5.46
0.226
5.74
0.246
6.24
0.267
6.78
0.289
7.34
0.318
8.07
0.342
8.68
0.392
9.95
0.452
11.48
0.547
13.89
Nominal Diameter
Inch
mm
0.231
5.86
0.244
6.19
0.265
6.73
0.320
8.13
0.375
9.52
0.424
10.76
0.460
11.68
0.493
12.52
0.598
15.18
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.037
0.94
0.040
1.02
0.040
1.02
0.040
1.02
0.045
1.14
150
AWM 2464, CMG
20 AWG (0.56 mm2)
UL CMG
CSA CMG FT4 (150 V)
Part No.
Pairs
M13063
M13066
M13069
M13072
3
6
9
15
18 AWG (0.81 mm2)
Materials
• Solid
or stranded tinned
copper conductors
• PVC insulation
• Slate PVC jacket
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
0.040
1.02
AWM 2464, CMG
Applications
Nominal Diameter
Inch
mm
0.224
5.68
0.284
7.21
0.328
8.33
0.405
10.28
Part No.
Pairs
M13081
M13082
M13083
M13084
M13085
M13086
M13088
M13089
M13092
M13095
M13099
1
2
3
4
5
6
8
9
12
15
19
Nominal Diameter
Inch
mm
0.225
5.72
0.326
8.28
0.346
8.79
0.380
9.65
0.418
10.62
0.458
11.63
0.508
12.90
0.554
14.07
0.633
16.08
0.700
17.78
0.761
19.33
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.037
0.94
0.040
1.02
0.046
1.17
0.051
1.30
0.055
1.40
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
151
300 V Foil Shield, Overall, Multiconductor, PE, PVC
24 AWG (0.22 mm2)
Stranding: 7/32 (7 x 0.20 mm)
24 AWG (0.22 mm2) drain wire
UL CMG
CSA CMG
CSA FT4
Part No.
Conductors
M3222
M3223
M3224
2
3
4
Part No.
Conductors
M3226
M3227
M3228
2
3
4
2092
2093
2094
Nominal Diameter
Inch
mm
0.171
4.34
0.181
4.60
0.197
5.00
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM
2092
2093
2094
20 AWG (0.56 mm2)
20 AWG (0.56 mm2) drain wire
Part No.
Conductors
M3232
M3233
M3234
2
3
4
Materials
• S
conductors
25% overlap min.
Foil facing inward
Stranded tinned copper drain
wire (see tables for size)
• Slate PVC jacket
UL AWM
22 AWG (0.35 mm2) drain wire
• - 20°C to +75°C (CMG)
• AWM
2092: 1 Black, 2 Red
(except Part No. M3222: Black,
Natural)
• AWM 2093: 1 Black, 2 Red,
3 Natural
• AWM 2094: 1 Black, 2 Red,
3 Natural, 4 Green
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
22 AWG (0.35 mm2)
Applications
• A
udio and sound systems
requiring small-diameter cable
with 100% shield coverage
Nominal Diameter
Inch
mm
0.159
4.04
0.168
4.27
0.182
4.62
Nominal Diameter
Inch
mm
0.187
4.75
0.198
5.03
0.216
5.49
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM
2092
2093
2094
18 AWG (0.81 mm2)
Part No.
Conductors
M3242
M3243
M3244
2
3
4
Nominal Diameter
Inch
mm
0.205
5.21
0.217
5.51
0.238
6.05
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM
2092
2093
2094
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
152
16 AWG (1.32 mm2)
18 AWG (0.81 mm2) drain wire
Part No.
Conductors
M3247
M3248
2
3
UL CMG
UL CL2 (150 V)
CSA CMG
CSA FT4
UL AWM
2092
2093
Stranding: 41/30 (41 x 0.25 mm)
Insulation thickness: 0.020 (0.51 mm)
16 AWG (1.32 mm2) drain wire
Part No.
Conductors
• A
M3249
2
Nominal Diameter
Inch
mm
0.288
7.32
Jacket Thickness
Inch
mm
0.030
0.76
UL Style
CL2
12 AWG (3.29 mm2)
Stranding: 65/30 (65 x 0.25 mm)
14 AWG (2.08 mm2) drain wire
• AWM
2092 and CL2: 1 Black,
2 Red
3 Natural
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
14 AWG (2.08 mm2)
Applications
Nominal Diameter
Inch
mm
0.229
5.82
0.243
6.17
Part No.
Conductors
M3250
2
Nominal Diameter
Inch
mm
0.326
8.28
Jacket Thickness
Inch
mm
0.030
0.76
UL Style
CL2
Materials
• S
conductors
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
153
Cable > Manhattan > Audio/Video Cable > Multipair > Individually Foil Shielded Pairs > 300 V
300 V Individually Foil Shielded Pairs, Multipair, PP/PE/SR-PVC, PVC
AWM 2493, UL CM, Polypropylene Insulation
22 AWG (0.32 mm2)
Stranding: Solid
UL AWM 2464, 2493, 2919
(30 V)
UL CM
CSA CM
Part No.
Pairs
M39039
M39040
M39041
M39042
6
9
11
15
22 AWG (0.35 mm2)
Insulation thickness: 0.008 (0.20 mm)
• Audio and sound systems
• -20°C to +80°C (AWM 2464)
• -20°C to +75°C (CM)
• -20°C to +60°C (AWM 2919,
2493)
Part No.
Pairs
M4473
2
Materials
• S
olid or stranded tinned copper
conductors
25% overlap min.
Foil facing inward
wire equal in size to conductor
(unless noted)
• Polyethylene, polypropylene,
(see tables)
• Slate PVC jacket
Availability
Nominal Diameter
Inch
mm
0.150
3.81
Jacket Thickness
Inch
mm
0.19
0.48
AWM 2919, UL CM, Polypropylene Insulation
22 AWG (0.35 mm2)
• AWM 2919: Chart K (page 529)
• AWM 2493: Chart A (page 528)
• AWM 2464 and CM: Black/Red,
Green/White
Jacket Thickness
Inch
mm
0.050
1.27
0.050
1.27
0.050
1.27
0.050
1.27
Applications
Nominal Diameter
Inch
mm
0.362
9.19
0.415
10.54
0.459
11.66
0.507
12.88
Part No.
Pairs
M13103
M13106
M13109
M13111
M13112
M13115
M13117
M13119
M13127
M13130
3
6
9
11
12
15
17
19
27
37
Nominal Diameter
Inch
mm
0.271
6.88
0.349
8.86
0.412
10.46
0.466
11.84
0.466
11.84
0.537
13.64
0.577
14.66
0.577
14.66
0.685
17.40
0.766
19.46
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.035
0.89
0.050
1.27
0.050
1.27
0.050
1.27
0.050
1.27
0.050
1.27
AWM 2464, UL CM, SR-PVC Insulation
20 AWG (0.56 mm2)
Part No.
Pairs
M13142
2
Nominal Diameter
Inch
mm
0.284
7.21
Jacket Thickness
Inch
mm
0.032
0.81
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
154
AWM 2919, UL CM, Polyethylene Insulation
20 AWG (0.56 mm2)
Insulation thickness: 0.013 (0.25 mm)
(30 V)
UL CM
CSA CM
Applications
Part No.
Pairs
M13143
M13146
M13149
M13151
M13152
M13155
3
6
9
11
12
15
18 AWG (0.81 mm2)
Drain wire: 20 AWG (0.56 mm2)
Green/White
Jacket Thickness
Inch
mm
0.032
0.64
0.043
1.09
0.043
1.09
0.050
1.27
0.050
1.27
0.050
1.27
2493)
Nominal Diameter
Inch
mm
0.324
8.23
0.448
11.38
0.522
13.26
0.579
14.71
0.598
15.19
0.650
16.51
Part No.
Pairs
M13173
M13176
M13179
M13182
M13185
3
6
9
12
15
Nominal Diameter
Inch
mm
0.380
9.65
0.541
13.74
0.632
16.05
0.737
18.72
0.817
20.75
Jacket Thickness
Inch
mm
0.032
0.81
0.050
1.27
0.050
1.27
0.065
1.65
0.065
1.65
Materials
• S
conductors
25% overlap min.
Foil facing inward
(unless noted)
(see tables)
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
155
300 V Individually Foil Shielded Pairs, Multipair, PP, PVC
20 AWG (0.56 mm2)
Insulation thickness: 0.015 (0.38 mm)
Part No.
Pairs
M14604
4
Nominal Diameter
Inch
mm
0.365
9.27
Jacket Thickness
Inch
mm
0.030
0.76
Mutual capacitance: 23 pF/ft (75.5 pF/m)
Ground capacitance: 41 pF/ft (134.5 pF/m)
UL CMG VW-1
CSA CMG
Applications
• C
ommunication and
instrumentation systems
requiring special wiring
• Audio process-control
computer systems
• -20°C to +105°C
• 1 Black–Red, 2 Green–White,
3 White/Red–White/Black,
4 White/Yellow–White/Green
Materials
• S
conductors
25% overlap min
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
156
Cable > Manhattan > Audio/Video Cable > Single Conductor > Braid or Spiral Shield
Braid or Spiral Shield, Single Conductor, PE, PVC
Microphone Cable
Applications
• High-impedance microphones
• Hi-fi interconnection systems
• Instruments and tape recorders
Materials
• S
conductors*
Voltage
M3601*
M3633*
M3605
M3635
M3611
300
1000
3500
1000
4000
Wire Size
AWG
30
26
24
24
mm2
0.05
0.14
0.20
0.20
0.52
Stranding
AWG
7/38*
7/34*
10/34
10/34
26/34
mm
7 x 0.10
7 x 0. 16
10 x 0.16
10 x 0. 16
26 x 0.16
Nominal
Diameter
Inch
mm
0.086
2.18
0.101
2.57
0.146
3.71
0.106
2.69
0.180
4.57
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
• –20°C to +60°C
Part No.
• B
raided tinned copper or spiral
wrapped tinned copper shield
• Slate PVC jacket
Shield
Braid
Spiral
Braid
Spiral
Braid
Jacket
Thickness
Inch
mm
0.016
0.41
0.020
0.50
0.030
0.76
0.020
0.50
0.030
0.76
Insulation
Thickness
Inch
mm
0.012 0.30
0.016 0.41
0.020 0.50
0.016 0.41
0.030 0.76
Capacitance
pF/ft
32
35
36
41
39
pF/m
105.0
114.8
118.1
134.5
128.0
*M3601 and M3633 have 3 strands of tinned copper and 4 strands of tinned Copperweld.
157
300 V Braid Shield, Multiconductor, PVC, PVC
Microphone Cable
22 AWG (0.32 mm2)
Stranding: Solid
Part No.
Conductors
M14461
2
Nominal Diameter
Inch
mm
0.195
4.95
Jacket Thickness
Inch
mm
0.028
0.71
Mutual capacitance: 41 pF/ft (134.5 pF/m)
Ground capacitance: 74 pF/ft (242.8 pF/m)
UL AWM 2095
UL CMG
CSA CMG FT4
22 AWG (0.35 mm2)
• –20°C to +75°C (CMG)
Conductor Color Code
Part No.
Conductors
M14462
2
Nominal Diameter
Inch
mm
0.205
5.21
Jacket Thickness
Inch
mm
0.028
0.71
Mutual capacitance: 43 pF/ft (141.3 pF/m)
Ground capacitance: 77 pF/ft (252.6 pF/m)
• 1 Black, 2 Red
Materials
• S
copper conductors
• PVC insulation
88% coverage
Drain wire equivalent to
conductors
• Black PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
158
UL AWM 2509, UL CMG
20 AWG (0.56 mm2)
Color Code D
UL AWM 2509, 2576
UL CL2
UL CMG
CSA CMG FT4
Applications
• U
sound systems
• Remote circuit controls
• Telephones
Part No.
Conductors
M33402
M33403
M33404
M33406
M33408
M33410
M33412
M33415
M33419
2
3
4
6
8
10
12
15
19
• Chart D (page 531)
Materials
• Stranded
tinned copper
conductors
• PVC insulation
• Slate PVC jacket
Availability
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
UL AWM 2509, UL CMG
18 AWG (0.81 mm2)
Stranding: 16/30 (7 x 0.25 mm)
Color Code D
• -20°C to +75°C (CMG and CL2)
Nominal Diameter
Inch
mm
0.183
4.65
0.191
4.85
0.209
5.31
0.251
6.38
0.273
6.93
0.320
8.13
0.331
8.41
0.362
9.19
0.390
9.91
Part No.
Conductors
M33502
M33503
M33504
M33505
M33506
M33507
M33508
M33510
M33512
M33515
M33519
M33525
2
3
4
5
6
7
8
10
12
15
19
25
Nominal Diameter
Inch
mm
0.208
5.28
0.220
5.59
0.241
6.12
0.264
6.71
0.288
7.32
0.288
7.32
0.313
7.95
0.366
9.30
0.378
9.60
0.423
10.74
0.465
11.81
0.544
13.82
Jacket Thickness
Inch
Mm
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.030
0.76
0.035
0.89
0.035
0.89
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
159
UL AWM 2509, UL CMG
16 AWG (1.32 mm2)
Color Code D
UL AWM 2509, 2576
UL CL2
UL CMG
CSA CMG FT4
Part No.
Conductors
M33572
M33573
M33574
M33576
M33578
2
3
4
6
8
Nominal Diameter
Inch
mm
0.232
5.89
0.246
6.25
0.273
6.93
0.327
8.31
0.356
9.04
Jacket Thickness
Inch
mm
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
0.025
0.64
UL AWM 2576, UL CL2
Applications
• U
sound systems
• Telephones
14 AWG (2.08 mm2)
Part No.
Conductors
M33582
M33583
2
3
Materials
• Stranded
tinned copper
conductors
• PVC insulation
• Slate PVC jacket
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
UL AWM 2576, UL CL2
12 AWG (3.29 mm2)
Nominal Diameter
Inch
mm
0.295
7.49
0.313
7.95
Part No.
Conductors
M33590
M33591
2
3
Nominal Diameter
Inch
mm
0.333
8.45
0.354
8.99
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
160
UL AWM 2464, UL CMG
24 AWG (0.22 mm2)
Color Code E
UL CMG
CSA CMG FT4
Applications
• U
sound systems
• Telephones
Part No.
Conductors
M38902
M38903
M38904
M38906
M38908
M38910
M38915
M38920
M38925
M38930
M38940
M38950
2
3
4
6
8
10
15
30
40
50
22 AWG (0.35 mm2)
Color Code D
Materials
• S
conductors
• Semirigid PVC insulation
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
UL AWM 2576, UL CMG
• Chart
E (page 532) for
AWM 2464
• Chart D (page 531) for
AWM 2576
Nominal Diameter
Inch
mm
0.155
3.94
0. 162
4.11
0.173
4.39
0.200
5.08
0.213
5.41
0.243
6.17
0.269
6.83
0.297
7.54
0.331
8.41
0.349
8.86
0.389
9.88
0.426
10.82
Part No.
Conductors
M33302
M33303
M33304
M33305
M33306
M33308
M33310
M33312
M33315
M33320
M33325
M33330
M33340
M33350
M33360
2
3
4
5
6
8
10
12
15
30
40
50
60
Nominal Diameter
Inch
mm
0.164
4.16
0.175
4.45
0.188
4.78
0.203
5.16
0.218
5.54
0.233
5.92
0.267
6.78
0.275
6.99
0.297
7.54
0.329
8.36
0.367
9.32
0.388
9.86
0.432
10.97
0.481
12.22
0.523
13.28
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.035
0.89
161
Cable > Manhattan > Audio/Video Cable > Multiconductor > Spiral Wrap Copper Shield > 300 V
300 V Spiral Wrap Copper Shield, Multiconductor, PVC, PVC
22 AWG (0.35 mm2)
UL AWM 2095
UL AWM 1108
(Single conductor)
UL CMG
CSA CMG FT4
Part No.
Conductors
M3261
M3262
M3263
M3264
M3266
1
2
3
4
6
Stranding: 10/30 (10 x 0.25 mm)
Part No.
Conductors
M3271
M3272
M3273
M3274
M3276
1
2
3
4
6
• 1 Black, 2 Red, 3 White, 4 Green,
5 Yellow, 6 Blue
• Part No. M13282: 1 Red, 2 White
Materials
• S
conductors
• PVC insulation
• Spiral wrapped tinned copper
shield, 90% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
162
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
20 AWG (0.50 mm2)
Applications
• Audio and RF frequencies
Nominal Diameter
Inch
mm
0.112
2.84
0.177
4.50
0.187
4.75
0.206
5.23
0.243
6.17
Nominal Diameter
Inch
mm
0.119
3.02
0.191
4.85
0.202
5.13
0.223
5.66
0.264
6.71
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
20 AWG (0.56 mm2)
Stranding: 7/28 (10 x 0.32 mm)
Part No.
Conductors
M13272
2
Nominal Diameter
Inch
mm
0.203
5.16
Jacket Thickness
Inch
mm
0.025
0.64
18 AWG (0.81 mm2)
Part No.
Conductors
M3281
M3282
M3283
M3284
1
2
3
4
Nominal Diameter
Inch
mm
0.129
3.28
0.214
5.44
0.226
5.74
0.247
6.27
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
18 AWG (0.89 mm2)
Stranding: 7/26 (7 x 0.40 mm)
Insulation thickness: 0.022 (0.56 mm)
UL AWM 2095
UL AWM 1108
(Single conductor)
UL CMG
CSA CMG FT4
Applications
Part No.
Conductors
M13282
M13283
2
3
Stranding: 26/30 (26 x 0.25 mm)
Part No.
Conductors
M3287
M3288
2
3
Jacket Thickness
Inch
mm
0.025
0.64
0.025
0.64
Insulation thickness: 0.023 (0.58 mm)
Part No.
Conductors
M13287
2
Nominal Diameter
Inch
mm
0.286
7.26
Jacket Thickness
Inch
mm
0.030
0.76
14 AWG (2.08 mm2)
Materials
• S
conductors
• PVC insulation
• Slate PVC jacket
Nominal Diameter
Inch
mm
0.240
6.10
0.254
6.45
16 AWG (1.32 mm2)
5 Yellow, 6 Blue
Jacket Thickness
Inch
mm
0.028
0.71
0.028
0.71
16 AWG (1.32 mm2)
Nominal Diameter
Inch
mm
0.256
6.50
0.270
6.86
Part No.
Conductors
M3289*
M3290*
2
3
Nominal Diameter
Inch
mm
0.295
7.49
0.312
7.92
Jacket Thickness
Inch
mm
0.025
0.64
0.025
0.64
*450 V.
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
163
UL 2095
22 AWG (0.035mm2)
UL AWM 2095, 2464
CSA CMG FT4
Applications
Part No.
Conductors
M3202
M13203
M3204
2
3
4
• - 20°C to +80°C (AMW)
• C
hart D (page 531), unless
otherwise noted
UL 2095
Part No.
Conductors
M3206
M3207
M3208
M13209*
M13210*
2
3
4
6
12
164
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.032
0.81
0.040
1.02
UL 2095
18 AWG (0.81 mm2)
• S
conductors
• PVC insulation
85% coverage
• Slate PVC jacket
Nominal Diameter
Inch
mm
0.205
5.21
0.216
5.49
0.234
5.94
0.300
7.62
0.396
10.06
*UL AWM 2464. Conductor color code Chart F (page 532).
Materials
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
20 AWG (0.56 mm2)
• A
experiencing high flexing
and needing additional
tensile strength
Availability
Nominal Diameter
Inch
mm
0.189
4.80
0.199
5.05
0.215
5.46
Part No.
Conductors
M3212
M3213
M3214
2
3
4
Nominal Diameter
Inch
mm
0.223
5.66
0.235
5.97
0.256
6.50
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
UL 2095
16 AWG (1.32 mm2)
Part No.
Conductors
M3216
M3217
2
3
Nominal Diameter
Inch
mm
0.247
6.27
0.261
6.63
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
450 V; Not UL Recognized
14 AWG (2.08 mm2)
UL AWM 2095, 2464
CSA CMG FT4
Part No.
Conductors
M33218
M33219
2
3
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
12 AWG (3.29 mm2)
Applications
• A
tensile strength
Nominal Diameter
Inch
mm
0.299
7.59
0.317
8.05
Part No.
Conductors
M33220
M33221
2
3
Nominal Diameter
Inch
mm
0.337
8.56
0.358
9.09
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
• C
otherwise noted
Materials
• S
conductors
• PVC insulation
85% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
165
Cable > Manhattan > Audio/Video Cable > Multiconductor > Foil Shield > 300 V
300 V Foil Shield, Multiconductor, PE or SR-PVC, PVC
24 AWG (0.22 mm2)
UL AWM 2092, 2093, 2094,
2464, 20253
UL CM, CMG, CL2
CSA CMG FT4
Part No.
Conductors
M13222
2
Nominal Diameter
Inch
mm
0. 166
• - 20°C to +80°C (AWM 2464,
20253)
• -20°C to +60°C (AWM 2092,
2093, 2094)
(Unless noted)
• 2-conductor: Black, clear
• 3-conductor: Black, red, clear
• 4-conductor: Black, red,
white, green
Materials
• P
olyethylene or semirigid PVC
insulation (see tables)
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
4.22
0.025
0.64
Approval
Color
Code
2092, CM
Black,
Clear
Mutual capacitance: 18 pF/ft (59 pF/m)
Ground capacitance: 32 pF/ft (105 pF/m)
Semi-Rigid PVC Insulation
24 AWG (0.22 mm2)
Applications
• L
ightweight, low-cost smalldiameter cable for audio and
sound systems
Jacket Thickness
Inch
mm
Insulation thickness: 0.010 (0.51 mm)
Part No.
Conductors
M39024
M39025
M39026
M39027
M39028
M39029
M39030
M39031
M39032
M39033
M39034
M39035
M39036
M39037
3
4
5
6
7
8
9
10
15
30
40
50
Nominal Diameter
Inch
mm
0.166
4.22
0.174
4.42
0.187
4.75
0.201
5.11
0.201
5.11
0.214
5.44
0.228
5.79
0.247
6.27
0.273
6.93
0.301
7.65
0.335
8.51
0.369
9.37
0.409
10.39
0.456
11.58
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.040
1.02
0.040
1.02
0.045
1.14
Approval
Color
Code
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
2464, CMG
O
O
O
O
O
O
O
O
F
F
F
F
F
F
Mutual capacitance: 32 pF/ft (105 pF/m)
Ground capacitance: 58 pF/ft (190.3 pF/m)
22 AWG (0.35 mm2)
Part No.
Conductors
M13226
M13227
2
3
Nominal Diameter
Inch
mm
0.178
4.52
0.204
5.18
Jacket Thickness
Inch
mm
0.025
0.64
0.033
0.84
Approvals
2092, CM
2093, CM
Mutual capacitance: 20 pF/ft (65.6 pF/m)
Ground capacitance: 36 pF/ft (118.1 pF/m)
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
166
PVC Insulation
22 AWG (0.35 mm2)
2464, 20253
UL CM, CMG, CL2
CSA CMG FT4
Part No.
Conductors
M13229
2
Approvals
2464, CMG
Color code: black, red.
20 AWG (0.56 mm2)
• L
sound systems
Part No.
Conductors
M13232
M13233
2
3
Nominal Diameter
Inch
mm
0.200
5.08
0.221
5.61
Jacket Thickness
Inch
mm
0.028
0.71
0.033
0.84
Approvals
2092, CM
2093, CM
Mutual capacitance: 23 pF/ft (75.4 pF/m)
18 AWG (0.81 mm2)
Insulation thickness: 0.019 (0.48 mm)
(Unless noted)
white, green
Jacket Thickness
Inch
mm
0.035
0.64
Mutual capacitance: 48 pF/ft (157.4 pF/m)
Ground capacitance: 86 pF/ft (282.1 pF/m)
Applications
20253)
2093, 2094)
Nominal Diameter
Inch
mm
0.189
4.80
Part No.
Conductors
M13242
M13243
2
3
Nominal Diameter
Inch
mm
0.230
5.84
0.253
6.43
Jacket Thickness
Inch
mm
0.028
0.71
0.033
0.84
Approvals
2092, CM
2093, CM
Mutual capacitance: 24.1 pF/ft (79.1 pF/m)
Ground capacitance: 43 pF/ft (141.1 pF/m)
Materials
• P
25% overlap min.
Foil facing inward
• Slate PVC jacket
SR-PVC Insulation
18 AWG (0.96 mm2)
Part No.
Conductors
M13244
4
Availability
Nominal Diameter
Inch
mm
0.249
6.32
Jacket Thickness
Inch
mm
0.035
0.89
Approvals
2464, CMG
Mutual capacitance: 47 pF/ft (154.2 pF/m)
Ground capacitance: 85 pF/ft (278.9 pF/m)
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
167
16 AWG (1.32 mm2)
2464, 20253
UL CM, CMG, CL2
CSA CMG FT4
Part No.
Conductors
M13247
M13248
2
3
Nominal Diameter
Inch
mm
0.317
8.05
0.336
8.53
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
Approvals
20253, CM, CL2
20253, CM, CL2
Mutual capacitance: 20.5 pF/ft (67.2 pF/m)
Ground capacitance: 37 pF/ft (121.4 pF/m)
14 AWG (2.08 mm2)
Applications
• L
sound systems
20253)
2093, 2094)
16 AWG (1.31 mm2) drain wire
Part No.
Conductors
M13249
2
Jacket Thickness
Inch
mm
0.035
0.89
Approvals
20253, CM, CL2
Mutual capacitance: 22.5 pF/ft (73.8 pF/m)
12 AWG (3.29 mm2)
Insulation thickness: 0.037 (0.81 mm)
(Unless noted)
white, green
Nominal Diameter
Inch
mm
0.345
8.78
Part No.
Conductors
M13250
2
Nominal Diameter
Inch
mm
0.421
10.69
Jacket Thickness
Inch
mm
0.040
1.02
Approvals
20253, CM, CL2
Mutual capacitance: 25 pF/ft (82 pF/m)
Materials
• P
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
168
300 V Foil Shield, Multiconductor, PVC, PVC
20 AWG (0.56 mm2)
Part No.
Conductors
M14429
2
Nominal Diameter
Inch
mm
0.199
5.05
Jacket Thickness
Inch
mm
0.032
0.81
Mutual capacitance: 54 pF/ft (177.2 pF/m)
Ground capacitance: 97 pF/ft (318.2 pF/m)
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• A
udio, broadcast, and sound
systems
• Instrumentation
• 1 Black, 2 Red
Materials
• Stranded
tinned copper
conductors
• PVC insulation
25% overlap min.
Foil facing outward
• Slate PVC jacket
Availability
Bulk, cut to length
169
300 V Foil Shield, Multiconductor, PP, PVC
Miniature
24 AWG (0.22 mm2)
Part No.
Conductors
M14328*
2
Nominal Diameter
Inch
mm
0.124
3.15
Jacket Thickness
Inch
mm
0.020
0.51
Ground capacitance: 45 pF/ft (147.6 pF/m)
UL CM
CSA CM
*Black jacket.
22 AWG (0.35 mm2)
Applications
• A
systems
• Instrumentation
Stranding: Solid
Part No.
Conductors
M4325
2
Nominal Diameter
Inch
mm
0.122
3.10
Jacket Thickness
Inch
mm
0.018
0.46
Mutual capacitance: 28 pF/ft (91.8 pF/m)
Ground capacitance: 50 pF/ft 164 pF/m)
• -20°C to +75°C
22 AWG (0.35 mm2)
• 1 Black, 2 Red
Materials
• S
conductors
25% overlap min.
Foil facing outward
• Slate PVC jacket (except black
where noted)
Part No.
Conductors
M4326
M14327*
2
Nominal Diameter
Inch
mm
0.139
3.53
Jacket Thickness
Inch
mm
0.020
0.51
*Black jacket.
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
170
Cable > Manhattan > Audio/Video Cable > Multiconductor Composite > Unshielded and Shielded > 300 V
300 V Unshielded and Shielded, Multiconductor Composite,
PVC/PE/PP, PVC
UL AWM 2717 (300 V)
UL AWM 2094, 2576 (150 V)
UL CM, CMG
CSA CMG, CMG
Materials
• Stranded
tinned copper
conductors
• PVC insulation (polypropylene
or polyethylene, as noted)
25% minimum overlap
• PVC jacket (see tables
for colors)
• - 20°C to +80°C (AWM 2717)
except where noted)
• -20°C to +60°C (AWM 2094)
Availability
• See tables
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
22 AWG Composite Shielded and Unshielded, UL CM, Slate Jacket
22 AWG (0.35 mm2)
22 AWG (0.035 mm2) drain wire (M4475)
24 AWG (0.22 mm2) drain wire (M4451)
Nominal Diameter
Inch
mm
Inch
mm
Jacket Thickness
Inch
mm
Part No.
Conductors
M4475
3
0.190
4.83
0.013
0.33
0.032
0.81
M4451
4
0.161
4.09
0.008
0.20
0.019
0.48
Configuration
Shielded
Unshielded
2
1
Black, White
Brown
2
2
Red, Black
Green, White
Insulation
PVC
PP
20 AWG Composite Shielded and Unshielded, UL CMG, Slate Jacket
20 AWG (0.56 mm2)
Insulation Thickness: 0.015 (0.38 mm)
Part No.
Pairs
M4452
4
Nominal Diameter
Inch
mm
0.226
Jacket Thickness
Inch
mm
5.74
0.028
Configuration
Shielded
Unshielded
2
2
Red, Black
Green, White
0.71
Insulation
PVC
22 AWG Composite Shielded and Unshielded, AWM 2717 and UL CM, Polypropylene Insulation, Slate Jacket
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
Part No.
Pairs
M14474
2
0.243
M14476*
2
0.220
Inch
mm
Jacket Thickness
Inch
mm
5.17
0.010
0.25
0.028
0.71
5.59
0.008
0.20
0.030
0.81
Configuration
Shielded
Unshielded
2
Red, Black
1
1
Red, Black Green, White
*Not CMG
171
PVC/PE/PP, PVC
UL AWM 2717 (300 V)
UL CM, CMG
CSA CMG, CMG
Materials
• Stranded
tinned copper
conductors
25% minimum overlap
for colors)
except where noted)
Availability
• See tables
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
24/22 AWG Composite Shielded and Unshielded, UL CM, Slate Jacket
Part No.
M14477
M14478*
24 AWG (0.22 mm2)
22 AWG (0.35 mm2)
22 AWG (0.35 mm2) drain wire (M14477)
24 AWG (0.22 mm2) drain wire (M14478)
Nominal Diameter
Inch
mm
Conductors
4 (24 AWG)
2 (22 AWG)
8 (24 AWG)
2 (22 AWG)
0.239
6.07
0.295
7.49
Inch
mm
0.016
0.41
0.012
0.30
0.015
0.38
Jacket Thickness
Inch
mm
0.028
0.71
0.030
0.81
Configuration
Shielded
Unshielded
4**
2
Blue, White
8†
2
White, Blue
Insulation
PVC
PVC
PE
PVC
*Cable has two quads of four shielded conductors, each quad individually shielded. One quad has a red shield; the other has a green shield. Not CMG.
**Conductor color coding: Black, green, red, yellow.
†Conductor color coding: Slate, white, blue, green, brown, red, yellow, orange.
22 AWG Shielded, UL CM, Brown Jacket
22 AWG (0.35 mm2)
Insulation Thickness 0.008 (0.20 mm)
Part No.
Conductors
M14475
3
Nominal Diameter
Inch
mm
0.143
3.63
Jacket Thickness
Inch
mm
0.020
0.51
Configuration
Shielded
Unshielded
3*
Insulation
PP
*Conductor color coding: Black, red, white.
172
PVC/PE, PVC
UL AWM 2717 (300 V)
UL CM, CMG
CSA CMG, CMG
Materials
except where noted)
• Stranded
tinned copper
conductors
• PVC or PE insulation
25% minimum overlap
for colors)
Availability
• See tables
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
22 and 18 AWG Unshielded, UL CM Only, Slate Jacket
22 AWG (0.35 mm2)
18 AWG (0.81 mm2)
Conductors*
22 AWG
18 AWG
4
2
Part No.
M4406
Nominal Diameter
Inch
mm
0.255
6.48
Jacket Thickness
Inch
mm
0.032
0.81
Insulation
PVC
22 AWG: Red, green, brown, blue.
18 AWG: Black, white.
20 Foil Shielded and 18 AWG Unshielded, AWM 2094, CM, Beige Jacket
20 AWG (0.56 mm2)
18 AWG (0.81 mm2)
Insulation thickness: 0.20 (0.50 mm)
Part No.
M13291
Conductors
20 AWG
18 AWG
2
2
Nominal Diameter
Inch
mm
0.264
6.71
Jacket Thickness
Inch
mm
0.032
0.81
Insulation
PE
22 AWG: Black, red.
18 AWG: Green, white.
173
Cable > Manhattan > Security and Data Cable > Multiconductor > Unshielded > 300 V
Manhattan™ Security and Data Cable
22 AWG (0.35 mm2)
UL CMR
CSA CMR
Part No.
Conductors
M213302
M213303
M213304
M213305
M213308
2
3
4
5
8
Nominal Diameter
Inch
mm
0.130
3.30
0.138
3.51
0.151
3.84
0.166
4.22
0.196
4.98
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
20 AWG (0.56 mm2)
• -20°C to +75°C
5 Brown, 6 Blue, 7 Orange, 8
Yellow, 9 Violet, 10 Slate
Materials
Part No.
Conductors
M213402
M213403
M213404
2
3
4
• S
tranded bare copper
conductors
• PVC insulation
• Slate PVC jacket
Nominal Diameter
Inch
mm
0.146
3.71
0.155
3.94
0.170
4.32
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
18 AWG (0.89 mm2)
Availability
Part No.
Conductors
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
M213502
M213503
M213504
2
3
4
Nominal Diameter
Inch
mm
0.166
4.22
0.177
4.50
0.195
4.95
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
16 AWG (1.32 mm2)
174
Part No.
Conductors
M213572
M213573
M213574
2
3
4
Nominal Diameter
Inch
mm
0.188
4.77
0.200
5.08
0.221
5.61
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
Cable > Manhattan > Security and Data Cable > Multiconductor > Foil Shielded > 300 V
300 V Foil Shielded, Multiconductor, PVC, PVC
24 AWG (0.22 mm2)
UL CMR
CSA CMR
Part No.
Conductors
M239023
M239024
M239025
2
3
4
• -20°C to +75°C
8 Yellow, 9 Violet, 10 Slate
Part No.
Conductors
M113226
M113227
2
3
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Nominal Diameter
Inch
mm
0.134
3.40
0.142
3.61
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
20 AWG (0.56 mm2)
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing outward
wire one even AWG size smaller
than conductor (except 24
AWG, which is the same size as
the conductors)
• Slate PVC jacket
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
0.122
3.10
0.129
3.28
0.140
3.56
Part No.
Conductors
M113232
M113233
2
3
Nominal Diameter
Inch
mm
0.150
3.81
0.159
4.04
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
18 AWG (0.89 mm2)
Part No.
Conductors
M113242
M113243
M113244
2
3
4
Nominal Diameter
Inch
mm
0.170
4.32
0.181
4.60
0.199
5.05
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
16 AWG (1.32 mm2)
Stranding: 19/0.0117 (7 x 0.30 mm)
Part No.
Conductors
M113247
M113248
2
3
Nominal Diameter
Inch
mm
0.192
4.88
0.204
5.18
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
175
Cable > Manhattan > Security and Data Cable > Multipair > Unshielded > 300 V
22 AWG (0.35 mm2)
UL CMR
CSA CMR
Part No.
Pairs
M2210
M2211
M2212
2
3
4
• -20°C to +75°C
• Chart A1 (page 528)
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
20 AWG (0.56 mm2)
Nominal Diameter
Inch
mm
0.194
4.93
0.207
5.26
0.228
5.79
Part No.
Pairs
M2222
M2223
M2224
M2226
2
3
4
6
Nominal Diameter
Inch
mm
0.220
5.59
0.235
5.97
0.260
6.60
0.317
8.05
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
18 AWG (0.89 mm2)
Part No.
Pairs
M2215
M2216
M2217
2
3
4
Nominal Diameter
Inch
mm
0.253
6.43
0.270
6.86
0.300
7.62
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
176
Cable > Manhattan > Security and Data Cable > Multipair > Individually Foil Shielded Pairs > 300 V
300 V, Individually Foil Shielded Pairs, Multipair, PVC, PVC
22 AWG (0.35 mm2)
UL CMR
CSA CMR
Part No.
Pairs
M213102
M213103
M213104
M213106
2
3
4
6
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing inward
than conductor
• Slate PVC jacket
Availability
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
20 AWG (0.56 mm2)
• -20°C to +75°C
Nominal Diameter
Inch
mm
0.229
5.82
0.244
6.20
0.269
6.83
0.325
8.26
Part No.
Pairs
M213142
M213143
M213144
M213146
2
3
4
6
Nominal Diameter
Inch
mm
0.257
6.53
0.274
6.96
0.303
7.70
0.367
9.32
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
18 AWG (0.89 mm2)
Part No.
Pairs
M213172
M213173
M213174
M213176
2
3
4
6
Nominal Diameter
Inch
mm
0.292
7.42
0.312
7.92
0.345
8.76
0.420
10.67
Jacket Thickness
Inch
mm
0.020
0.51
0.020
0.51
0.020
0.51
0.020
0.51
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
177
Cable > Manhattan > Security and Data Cable > Multipair > Overall Foil Shield > 300 V
300 V Overall Foil Shield, Multipair, PVC, PVC
24 AWG (0.22 mm2)
UL CMR
CSA CMR
Part No.
Pairs
M213191
M213192
M213193
2
3
4
• -20°C to +75°C
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing outward
as the conductors)
• Slate PVC jacket
Part No.
Pairs
M213222
M213223
M213224
2
3
4
178
Nominal Diameter
Inch
mm
0.198
5.03
0.211
5.36
0.232
5.89
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
20 AWG (0.56 mm2)
Part No.
Pairs
M213202
M213203
M213204
M213206
2
3
4
6
Nominal Diameter
Inch
mm
0.224
5.69
0.239
6.07
0.264
6.71
0.331
8.41
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
0.020
0.51
18 AWG (0.89 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
0.178
4.52
0.190
4.83
0.209
5.31
Part No.
Pairs
M213182
M213183
M213184
2
3
4
Nominal Diameter
Inch
mm
0.257
6.53
0.274
6.96
0.304
7.72
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
Cable > Manhattan > Plenum Cable > Multiconductor > Overall Foil Shield > 300 V
Manhattan™ Plenum Cable
300 V Overall Foil Shield, Multiconductor, PVC, PVC, Plenum Rated
24 AWG (0.22 mm2)
UL CMP
CSA CMP FT6
Part No.
Conductors
M244837
M244838
M244839
2
3
4
• -20°C to +75°C
Materials
• S
tranded bare copper
conductors
• Plenum-rated PVC insulation
25% overlap min.
Foil facing outward
• White plenum-rated PVC jacket
Availability
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
0.122
3.10
0.129
3.28
0.140
3.56
Part No.
Conductors
M244800
M244801
M244802
M244804
M244806
M244808
2
3
4
6
8
10
Nominal Diameter
Inch
mm
0.134
3.40
0.142
3.61
0.155
3.94
0.178
4.52
0.200
5.08
0.234
5.94
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
20 AWG (0.56 mm2)
Part No.
Conductors
M244816
M244817
M244818
2
3
4
Nominal Diameter
Inch
mm
0.150
3.81
0.159
4.04
0.174
4.42
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.015
0.38
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
179
18 AWG (0.89 mm2)
Stranding: 7/26 (16 x 0.40 mm)
UL CMP
CSA CMP FT6
Part No.
Conductors
M244825
M244826
M244827
2
3
4
18 AWG (0.89 mm2) drain wire
• -20°C to +75°C
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.015
0.38
16 AWG (1.32 mm2)
Nominal Diameter
Inch
mm
0.146
3.71
0.181
4.60
0.199
5.05
Part No.
Conductors
M244834
M244835
M244836
2
3
4
Nominal Diameter
Inch
mm
0.192
4.88
0.204
5.18
0.225
5.71
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing outward
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
180
300 V Overall Foil Shield, Multiconductor, FEP, PVDF, Plenum Rated
22 AWG (0.35 mm2)
Insulation thickness: 0.006 (0.15 mm)
Part No.
Conductors
M413226
2
UL CMR
CSA CMP FT6
Jacket Thickness
Inch
mm
0.015
0.38
18 AWG (0.96 mm2)
Insulation thickness: 0.007 (0.18 mm)
• -40°C to +125°C
Nominal Diameter
Inch
mm
0.118
3.00
Part No.
Conductors
M413242
2
Nominal Diameter
Inch
mm
0.162
4.11
Jacket Thickness
Inch
mm
0.015
0.38
Materials
• S
conductors
• FEP insulation
25% overlap min.
Foil facing outward
• Red PVDF jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
181
300 V Overall Foil Shield, Multiconductor, FEP, FEP, Plenum Rated
24 AWG (0.22 mm2)
UL CMP
CSA CMP FT6
• -20°C to +150°C
• C
hart F (page 532),
unless noted
Part No.
Conductors
M64837
M64838
M64839
M64840
M64841
M64842
M64843
M64844
M64845
M64846
M64847
2
3
4
5
6
7
8
9
10
12
15
Materials
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
22 AWG (0.35 mm2)
• S
conductors
• FEP insulation
25% overlap min.
Foil facing outward
• Slate FEP jacket
Availability
Nominal Diameter
Inch
mm
0.096
2.44
0.102
2.59
0.111
2.82
0.122
3.10
0.133
3.38
0.133
3.38
0.168
4.26
0.159
4.04
0.172
4.37
0.178
4.52
0.193
4.90
Part No.
Conductors
M64800
M64801
M64802
M64803
M64804
M64805
M64806
M64807
M64808
M64809
M64812
2
3
4
5
6
7
8
9
10
12
15
Nominal Diameter
Inch
mm
0.108
2.74
0.115
2.92
0.126
3.20
0.138
3.51
0.151
3.84
0.151
3.84
0.168
4.27
0.181
4.60
0.196
4.98
0.203
5.16
0.221
5.61
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
0.012
0.30
182
-80 to +150°C Temperature Rating, Color Code D
22 AWG (0.35 mm2)
Part No.
Conductors
M613226
1
UL CMP
CSA CMP FT6
• C
hart F (page 532),
unless noted
Materials
• S
conductors
• FEP insulation
25% overlap min.
Foil facing outward
• Slate FEP jacket
Part No.
Conductors
M64816
M64817
M64818
M64820
M64822
M64824
2
3
4
6
8
10
Nominal Diameter
Inch
mm
0.124
3.15
0.132
3.35
0.145
3.68
0.175
4.45
0.194
4.93
0.228
5.79
Jacket Thickness
Inch
Mm
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
0.012
0.30
0.012
0.30
18 AWG (0.96 mm2)
20 AWG (0.60 mm2) drain wire
Part No.
Conductors
M613242
2
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.015
0.38
20 AWG (0.56 mm2)
• -20°C to +150°C
Nominal Diameter
Inch
mm
0.118
2.99
Nominal Diameter
Inch
mm
0.162
4.11
Jacket Thickness
Inch
mm
0.015
0.38
18 AWG (0.89 mm2)
Insulation thickness: 0.009 (0.23 mm)
Part No.
Conductors
M64825
M64826
M64827
M64829
M64831
2
3
4
6
8
Nominal Diameter
Inch
mm
0.160
4.06
0.166
4.22
0.188
4.78
0.227
5.77
0.247
6.27
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
16 AWG (1.43 mm2)
Stranding: 7/24 (7 x 0.51 mm)
Part No.
Conductors
M64834
M64835
M64836
2
3
4
Nominal Diameter
Inch
mm
0.180
4.57
0.196
4.98
0.217
5.51
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
183
Cable > Manhattan > Plenum Cable > Multipair > Individually Foil Shielded Pairs > 300 V
300 V Individually Foil Shielded Pairs, Multipair, PVC, PVC
Plenum Rated
22 AWG (0.35 mm2)
Insulation thickness: 0.007 (0.18mm)
UL CMP
CSA CMP
Part No.
Pairs
M44473
M43103
M43106
2
3
6
• -20°C to +75°C
• C
hart A1 (page 528)
(Part number M243473: Black,
white, green/yellow)
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.024
0.60
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
0.192
4.88
0.211
5.36
0.301
7.65
Part No.
Pairs
M243473
M243103
M243106
2
3
6
Nominal Diameter
Inch
mm
0.219
5.56
0.227
5.77
0.316
8.03
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.020
0.51
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
20 AWG (0.56 mm2)
Part No.
Pairs
M243142
M243143
M243144
2
3
4
Nominal Diameter
Inch
mm
0.241
6.12
0.258
6.55
0.295
7.49
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.020
0.51
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
184
18 AWG (0.89 mm2)
Part No.
Pairs
M243172
M243173
2
3
Nominal Diameter
Inch
mm
0.276
7.01
0.295
7.49
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
Cable > Manhattan > Plenum Cable > Multipair > Overall Foil Shield > 300 V
300 V Overall Foil Shield, Multipair, FEP, PVC, Plenum Rated
24 AWG (0.22 mm2)
UL CMP
CSA CMP FT6
• -20°C to +75°C
Part No.
Pairs
M52893
M52894
M52895
M52896
M52897
M52898
M52900
M52902
1
2
3
4
5
6
9
12.5
Nominal Diameter
Inch
mm
0.155
3.94
0.155
3.94
0.164
4.17
0.180
4.57
0.197
5.00
0.215
5.46
0.252
6.40
0.282
7.16
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
Materials
• S
conductors
• FEP insulation
25% overlap min.
Foil facing inward
• Slate plenum-rated PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
185
300 V Overall Foil Shield, Multipair, FEP, FEP, Plenum Rated
24 AWG (0.22 mm2)
UL CMP
CSA CMP
Part No.
Pairs
M613190
M613191
M613192
M613193
M613194
1
2
3
4
5
Nominal Diameter
Inch
mm
0.155
3.94
0.155
3.94
0.164
4.17
0.180
4.57
0.197
5.00
Jacket Thickness
Inch
mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
• -80°C to +150°C
Materials
• Stranded bare copper pairs
• FEP insulation
25% overlap min.
Foil facing inward
drain wire sized the same as
conductors
• Red FEP jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
186
300 V Individually Foil Shielded Pairs, Multipair, FEP, PVDF
Plenum Rated
24 AWG (0.22 mm2)
UL CMP
CSA CMP
• -20°C to +150°C
• -20°C to +75°C (CMP)
Part No.
Pairs
M42891
M42892
M42893
M42894
M42895
M42896
M42897
M42898
M42899
2
3
4
5
6
7
9
12
18
Nominal Diameter
Inch
mm
0.192
4.88
0.205
5.21
0.244
6.20
0.250
6.35
0.274
6.96
0.274
6.96
0.325
8.26
0.367
9.32
0.446
11.33
Jacket Thickness
Inch
Mm
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.015
0.38
0.020
0.51
• Chart M (page 530)
Materials
• S
tranded bare copper
conductors
• FEP insulation
25% overlap min.
Foil facing inward
conductors
• Slate PVDF jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
187
Cable > Manhattan > Control Cable > Multiconductor > Braid Shield > 600 V
Manhattan™ Control Cable
600 V Braid Shield, Multiconductor, PVC, PVC
MIL-DTL-16878/1 Conductors
28 AWG (0.09 mm2)
Stranding: 7/36 (7 x 0.13 mm)
MIL-DTL-16878/1 and /17
Conductors (Types B and
B/N)
UL VW-1
• -55°C to +105°C
Part No.
Conductors
M1411*
M1412
M1604
M1605
M1606
M1608
M1610
M1612
1
2
4
5
6
8
10
12
• S
conductors
• PVC or PVC/nylon insulation
90% coverage
• White PVC jacket
188
Color
Code
P
P
F
F
F
F
F
F
MIL-DTL-16878/17 Conductors
26 AWG (0.14 mm2)
Stranding: 7/34 (7 x 0.16 mm)
Insulation thickness: 0.010 (0.25 mm) PVC/0.003 (0.08 mm) nylon
Part No.
Conductors
M1421
M1422
M1423
1
2
3
Nominal Diameter
Inch
mm
0.083
2.11
0.140
3.56
0.147
3.73
Jacket Thickness
Inch
mm
0.010
0.25
0.014
0.36
0.014
0.36
24 AWG (0.24 mm2)
Stranding: 19/36 (19 x 0.13 mm)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.013
0.33
0.014
0.36
0.015
0.38
0.017
0.43
0.018
0.46
0.020
0.51
*Black jacket. All others slate.
• C
hart P (page 535) unless
otherwise noted
Materials
Nominal Diameter
Inch
mm
0.073
1.85
0.116
2.95
0.132
3.35
0.144
3.66
0.157
3.99
0.175
4.45
0.201
5.11
0.210
5.33
Part No.
Conductors
M1431
M1432
M1433
1
2
3
Nominal Diameter
Inch
mm
0.093
2.36
0.156
3.96
0.164
4.17
Jacket Thickness
Inch
mm
0.010
0.25
0.016
0.41
0.016
0.41
22 AWG (0.38 mm2)
B/N)
UL VW-1
Part No.
Conductors
M1441
M1442
M1443
M1444
M1644
M1645
M1646
M1648
M1650*
1
2
3
4
4
5
6
8
10
• -55°C to +105°C
• S
conductors
90% coverage
• White PVC jacket
Color
Code
P
P
P
P
F
F
F
F
F
Stranding: 19/32 (19 x 0.20 mm)
Part No.
Conductors
M1451
M1452
M1453
M1454
1
2
3
4
Nominal Diameter
Inch
mm
0.108
2.74
0.194
4.93
0.214
5.44
0.232
5.89
Jacket Thickness
Inch
mm
0.010
0.25
0.020
0.51
0.025
0.64
0.025
0.64
18 AWG (0.96 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.010
0.25
0.020
0.51
0.020
0.51
0.020
0.51
0.019
0.48
0.020
0.51
0.020
0.51
0.025
0.64
0.026
0.66
20 AWG (0.62 mm2)
• C
otherwise noted
Materials
Nominal Diameter
Inch
mm
0.100
2.54
0.178
4.52
0.187
4.75
0.202
5.13
0.203
5.16
0.222
5.64
0.240
6.10
0.268
6.81
0.309
7.85
Part No.
Conductors
M1461
M1462
M1463
1
2
3
Nominal Diameter
Inch
mm
0.122
3.10
0.216
5.49
0.230
5.84
Jacket Thickness
Inch
mm
0.012
0.30
0.021
0.53
0.022
0.56
16 AWG (1.23 mm2)
Stranding: 19/29 (19 x 0.29 mm)
Insulation thickness: 0.011 (0.28 mm) PVC/0.004 (0.10 mm) nylon
Part No.
Conductors
M1471
M1472
M1473
M1474
1
2
3
4
Nominal Diameter
Inch
mm
0.144
3.66
0.240
6.10
0.257
6.53
0.280
7.11
Jacket Thickness
Inch
mm
0.018
0.46
0.023
0.58
0.025
0.64
0.025
0.64
189
Cable > Manhattan > Control Cable > Multiconductor > Braid Shield > 1000 V
1000 V Braid Shield, Multiconductor, PVC, PVC
MIL-DTL-16878/2 Conductors
18 AWG (0.96 mm2)
MIL-DTL-16878/2 and /18
Conductors (Types C and
C/N)
UL VW-1
• -55°C to +105°C
Part No.
Conductors
M1704
M1705
M1706
M1708
M1710
M1712
M1714
M1716
4
5
6
8
10
12
14
16
Jacket Thickness
Inch
mm
0.023
0.58
0.025
0.64
0.030
0.76
0.032
0.81
0.035
0.89
0.035
0.89
0.040
1.02
0.046
1.17
MIL-DTL-16878/18 Conductors
16 AWG (1.23 mm2)
Insulation thickness: 0.017 (0.43 mm) PVC/0.004 (0.10 mm) nylon
Materials
• S
conductors
90% coverage
• Slate PVC jacket
Availability
Nominal Diameter
Inch
mm
0.269
6.83
0.297
7.54
0.332
8.43
0.362
9.19
0.423
10.74
0.442
11.23
0.473
12.01
0.509
12.93
Part No.
Conductors
M1764
M1765
M1766
M1768
M1772
M1776
M1779
M1787
4
5
6
8
12
16
19
27
Nominal Diameter
Inch
mm
0.324
8.23
0.357
9.07
0.390
9.91
0.431
10.95
0.532
13.51
0.598
15.19
0.636
16.15
0.768
19.51
Jacket Thickness
Inch
mm
0.031
0.79
0.033
0.84
0.035
0.89
0.040
1.02
0.047
1.19
0.053
1.35
0.057
1.45
0.067
1.70
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
190
Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 600 V
600 V Unshielded, Multiconductor, PVC/Nylon, PVC
18 AWG (0.82 mm2)
Stranding: 7/0.0152 (7 x 0.39 mm)
Insulation thickness: 0.016 (0.41 mm) PVC/0.005 (0.13 mm) nylon
UL TC
• -25°C to +90°C
• Chart J (page 533)
Materials
• S
tranded bare copper
conductors
• PVC/nylon insulation
• Black PVC jacket
Part No.
Conductors
M3800
M3801
M3802
M3803
M3804
M3805
M3806
M3807
M3808
M3810
M3815
M3819
M3822
M3821
M3823
M3825
2
3
4
5
6
7
8
9
10
12
15
19
24
25
30
37
Features
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
16 AWG (1.31 mm2)
• UL Sunlight Resistant
• UL Direct Burial
Availability
Nominal Diameter
Inch
mm
0.185 x 0.273
4.70 x 6.93
0.287
7.29
0.310
7.87
0.336
8.53
0.362
9.19
0.362
9.19
0.390
9.91
0.417
10.59
0.449
11.40
0.463
11.76
0.533
13.54
0.569
14.45
0.646
16.41
0.657
16.69
0.694
17.63
0.745
18.92
Stranding: 7/0.0192 (7 x 0.49 mm)
Part No.
Conductors
M3826
M3828
M3829
M3830
M3831
M3832
M3833
M3834
M3835
M3837
M3838
M3839
M3840
M3843
M3841
M3842
2
3
4
5
6
7
8
9
10
12
15
19
24
25
30
37
Nominal Diameter
Inch
mm
0.197 x 0.297
5.00 x 7.54
0.310
7.87
0.339
8.61
0.368
9.35
0.398
10.11
0.398
10.11
0.429
10.90
0.461
11.71
0.497
12.62
0.545
13.84
0.588
14.94
0.630
16.00
0.717
18.21
0.729
18.52
0.770
19.56
0.869
22.07
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
191
14 AWG (2.08 mm2)
Stranding: 7/0.0242 (7 x 0.62 mm)
UL TC
• -25°C to +90°C
Materials
• S
tranded bare copper
conductors
• Black PVC jacket
Part No.
Conductors
M3845
M3847
M3848
M3849
M3850
M3851
M3852
M3853
M3854
M3856
M3857
M3858
M3859
M3862
M3860
M3861
2
3
4
5
6
7
8
9
10
12
15
19
24
25
30
37
Features
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
192
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
0.083
2.11
0.083
2.11
12 AWG (3.30 mm2)
• UL Direct Burial
Availability
Nominal Diameter
Inch
mm
0.212 x 0.32
5.38 x 8.31
0.345
8.76
0.375
9.53
0.409
10.39
0.444
11.28
0.444
11.28
0.479
12.17
0.547
13.89
0.589
14.96
0.607
15.42
0.657
16.69
0.705
17.91
0.805
20.45
0.859
21.82
0.907
23.04
0.974
24.74
Stranding: 7/0.0305 (7 x 0.78 mm)
Part No.
Conductors
M3865
M3867
M3868
M3869
M3870
M3871
M3872
M3873
M3874
M3876
M3877
M3878
M3879
M3880
M3883
M3881
M3882
2
3
4
5
6
7
8
9
10
12
15
16
19
24
25
30
37
Nominal Diameter
Inch
mm
0.231 x 0.365
5.87 x 9.27
0.386
9.80
0.421
10.69
0.460
11.68
0.501
12.73
0.501
12.73
0.575
14.61
0.617
15.67
0.665
16.89
0.686
17.42
0.744
18.90
0.759
19.28
0.800
20.32
0.957
24.31
0.973
24.71
1.029
26.14
1.107
28.12
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
0.083
2.11
0.083
2.11
0.083
2.11
10 AWG (5.26 mm2)
Stranding: 7/0.0385 (7 x 0.98 mm)
Insulation thickness: 0.022 (0.56 mm) PVC/0.005 (0.13 mm) nylon
UL TC
• -25°C to +90°C
Materials
Part No.
Conductors
M3902
M3903
M3904
M3905
M3906
M3907
M3908
M3910
M3911
M3913
M3915
M3916
2
3
4
5
6
7
8
9
10
12
14
15
Nominal Diameter
Inch
mm
0.267 x 0.365
6.78 x 9.27
0.464
11.79
0.540
13.72
0.590
14.99
0.641
16.28
0.641
16.28
0.694
17.63
0.748
19.00
0.809
20.55
0.875
22.23
0.920
23.37
0.950
24.13
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
0.083
2.11
0.083
2.11
• S
tranded bare copper
conductors
• Black PVC jacket
Features
• UL Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
193
18 AWG (0.96 mm2)
Part No.
Conductors
M39056
2
UL TC
Nominal Diameter
Inch
mm
0.283
7.19
Jacket Thickness
Inch
mm
0.048
1.22
16 AWG (1.32 mm2)
• -25°C to +90°C
Part No.
Conductors
M39057
2
Nominal Diameter
Inch
mm
0.301
7.65
Jacket Thickness
Inch
mm
0.048
1.22
Materials
14 AWG (2.08 mm2)
• S
conductors
• Black PVC jacket
Part No.
Conductors
M39058
2
Nominal Diameter
Inch
mm
0.355
9.02
Jacket Thickness
Inch
mm
0.048
1.22
Features
• UL Direct Burial
12 AWG (3.29 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Part No.
Conductors
M39059
2
Nominal Diameter
Inch
mm
0.393
9.98
Jacket Thickness
Inch
mm
0.048
1.22
194
Alpha Wire | www.alphawire.com | 1-800-52 ALPHA
Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
Cable > Manhattan > Control Cable > Multiconductor > Foil Shield > 600 V
600 V Foil Shield, Multiconductor, PVC/Nylon, PVC
18 AWG (0.82 mm2)
UL TC
• -25°C to +90°C
Part No.
Conductors
M33800
M33801
M33802
M33803
M33805
M33807
M33810
M33815
M33819
2
3
4
5
7
9
12
15
19
Nominal Diameter
Inch
mm
0.277
7.04
0.291
7.39
0.314
7.98
0.340
8.64
0.366
9.30
0.421
10.69
0.467
11.86
0.537
13.64
0.573
14.55
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
16 AWG (1.31 mm2)
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
Part No.
Conductors
M33826
M33828
M33829
M33830
M33832
M33834
M33837
M33838
M33839
2
3
4
5
7
9
12
15
19
• UL Direct Burial
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
14 AWG (2.08 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Nominal Diameter
Inch
mm
0.301
7.65
0.317
8.05
0.343
8.71
0.372
9.45
0.402
10.21
0.465
11.81
0.549
13.94
0.592
15.04
0.634
16.10
Part No.
Conductors
M33845
M33847
M33848
M33849
M33851
M33853
M33856
M33857
M33858
2
3
4
5
7
9
12
15
19
Nominal Diameter
Inch
mm
0.331
8.41
0.349
8.86
0.379
9.63
0.413
10.49
0.448
11.38
0.551
14.00
0.611
15.52
0.661
16.79
0.709
18.01
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
195
12 AWG (3.30 mm2)
UL TC
• -25°C to +90°C
Part No.
Conductors
M33865
M33867
M33868
M33869
M33870
M33871
M33873
M33876
M33877
M33879
2
3
4
5
6
7
9
12
15
19
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
Nominal Diameter
Inch
mm
0.369
9.37
0.390
9.91
0.425
10.80
0.464
11.79
0.505
12.83
0.505
12.83
0.621
15.77
0.690
17.53
0.748
19.00
0.804
20.42
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
10 AWG (5.26 mm2)
Part No.
Conductors
M33902
M33903
M33904
M33905
M33906
M33907
M33910
M33912
2
3
4
5
6
7
9
12
Nominal Diameter
Inch
mm
0.441
11.20
0.468
11.89
0.544
13.82
0.594
15.09
0.645
16.38
0.645
16.38
0.752
19.10
0.879
22.33
Jacket Thickness
Inch
mm
0.047
1.19
0.047
1.19
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.083
2.11
• UL Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
196
18 AWG (0.96 mm2)
Part No.
Conductors
M39109
2
UL TC
Jacket Thickness
Inch
mm
0.048
1.22
16 AWG (1.32 mm2)
• -25°C to +90°C
Nominal Diameter
Inch
mm
0.287
7.29
Part No.
Conductors
M39110
2
Nominal Diameter
Inch
mm
0.305
7.75
Jacket Thickness
Inch
mm
0.048
1.22
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
• UL Direct Burial
14 AWG (2.08 mm2)
Part No.
Conductors
M39111
2
Nominal Diameter
Inch
mm
0.359
9.11
Jacket Thickness
Inch
mm
0.048
1.22
12 AWG (3.29 mm2)
Part No.
Conductors
M39112
2
Nominal Diameter
Inch
mm
0.397
10.08
Jacket Thickness
Inch
mm
0.048
1.22
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
(Minimums may apply)
197
16 AWG (1.31 mm2)
Part No.
Conductors
7616/6
6
UL TC
Nominal Diameter
Inch
mm
0.401
10.19
Jacket Thickness
Inch
mm
0.048
1.22
14 AWG (2.08 mm2)
Stranding: 7/0.0242 (41 x 0.62 mm)
Operating Temperature
• -25°C to +90°C
Conductor Color Coding
Part No.
Conductors
7614/6
6
Nominal Diameter
Inch
mm
0.447
11.35
Jacket Thickness
Inch
mm
0.048
1.22
• Chart J1 (page 533)
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
wire equal in size to conductors
• Black PVC jacket
Features
• UL Direct Burial
Availability
Bulk, cut to length
198
Cable > Manhattan > Control Cable > Multiconductor > Unshielded > 300 V
22 AWG (0.35 mm2)
Stranding: 7/30 (7 x 0.25 mm)
Part No.
Conductors
M39071
M39072
2
3
UL PLTC, ITC
UL CMG
CSA CMG FT4
• -20°C to +105°C
Nominal Diameter
Inch
mm
0.203
5.16
0.213
5.41
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
20 AWG (0.61 mm2)
Part No.
Conductors
M39073
M39074
2
3
Nominal Diameter
Inch
mm
0.223
5.66
0.234
5.94
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
18 AWG (0.96 mm2)
Materials
• S
conductors
• PVC insulation
• Slate PVC jacket
Features
Part No.
Conductors
M39075
M39076
2
3
Nominal Diameter
Inch
mm
0.243
6.17
0.256
6.50
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
16 AWG (1.32 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Part No.
Conductors
M39077
M39078
2
3
Nominal Diameter
Inch
mm
0.261
6.63
0.275
6.99
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
14 AWG (2.08 mm2)
Part No.
Conductors
M39079*
M39080*
2
3
Nominal Diameter
Inch
mm
0.325
8.26
0.343
8.71
Jacket Thickness
Inch
mm
0.043
1.09
0.043
1.09
*Not CMG approved.
12 AWG (3.29 mm2)
Part No.
Conductors
M39081*
2
Nominal Diameter
Inch
mm
0.423
10.74
Jacket Thickness
Inch
mm
0.053
1.35
*Not CMG approved.
199
Cable > Manhattan > Control Cable > Multipair > Foil Shield, Individual Pairs > 300 V
300 V Foil Shield, Individual Pairs, Multipair, PVC, PVC
22 AWG (0.35 mm2)
UL PLTC, ITC
UL CMG
CSA CMG
• -20°C to +105°C
Part No.
Pairs
M39147
M39148
M39149
M39150
M39151
M39152
M39153
M39154
M39155
M39156
2
3
4
6
9
11
15
19
27
51
Nominal Diameter
Inch
mm
0.320
8.13
0.338
8.59
0.368
9.35
0.457
11.61
0.529
13.44
0.563
14.30
0.582
14.78
0.646
16.41
0.763
19.38
1.005
25.53
Jacket Thickness
Inch
mm
0.043
1.09
0.043
1.09
0.043
1.09
0.053
1.35
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.075
1.91
• Chart BR (page 529)
18 AWG (0.96 mm2)
Stranding: 19/30 (19 x 0.25 mm)
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing inward
smaller than conductor
• Slate PVC jacket
Part No.
Pairs
M39157
M39158
M39159
M39160
M39161
M39162
M39163
2
3
4
6
9
11
15
Nominal Diameter
Inch
mm
0.410
10.41
0.434
11.02
0.473
12.01
0.563
14.30
0.677
17.20
0.731
18.57
0.820
20.83
Jacket Thickness
Inch
mm
0.053
1.35
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.063
1.60
Features
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
200
Cable > Manhattan > Control Cable > Multipair > Overall Foil Shield > 300 V
22 AWG (0.35 mm2)
UL PLTC, ITC
UL CMG
CSA CMG
• -20°C to +105°C
Part No.
Pairs
M39130
M39131
M39132
M39133
M39134
M39135
M39136
M39137
M39138
M39139
2
3
4
6
9
11
15
19
27
51
Nominal Diameter
Inch
mm
0.296
7.52
0.312
7.92
0.339
8.61
0.420
10.67
0.483
12.27
0.520
13.21
0.580
14.73
0.642
16.31
0.759
19.28
0.995
25.27
Jacket Thickness
Inch
mm
0.043
1.09
0.043
1.09
0.043
1.09
0.053
1.35
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.075
1.91
18 AWG (0.96 mm2)
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Part No.
Pairs
M39140
M39141
M39142
M39143
M39144
M39145
M39146
2
3
4
6
9
11
15
Nominal Diameter
Inch
mm
0.362
9.19
0.403
10.24
0.438
11.13
0.518
13.16
0.622
15.80
0.671
17.04
0.751
19.08
Jacket Thickness
Inch
mm
0.043
1.09
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.063
1.60
Features
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
201
Cable > Manhattan > Control Cable > Multiconductor > Overall Foil Shield > 300 V
22 AWG (0.35 mm2)
Part No.
Conductors
M39113
M39114
2
3
UL PLTC, ITC
UL CMG
CSA CMG FT4
Nominal Diameter
Inch
mm
0.207
5.26
0.214
5.44
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
20 AWG (0.61 mm2)
• -20°C to +105°C
Part No.
Conductors
M39115
M39116
2
3
Nominal Diameter
Inch
mm
0.227
5.77
0.238
6.05
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
18 AWG (0.96 mm2)
Materials
• S
conductors
• PVC insulation
• Aluminum/polyester tape
shield, 25% overlap min.
Foil facing inward
• Slate PVC jacket
Part No.
Conductors
M39117
M39118
2
3
Part No.
Conductors
M39119
M39120
2
3
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
16 AWG (1.32 mm2)
Features
Availability
Nominal Diameter
Inch
mm
0.247
6.27
0.260
6.60
Nominal Diameter
Inch
mm
0.265
6.73
0.279
7.09
Jacket Thickness
Inch
mm
0.038
0.97
0.038
0.97
14 AWG (2.08 mm2)
Part No.
Conductors
M39121*
M39122*
2
3
Nominal Diameter
Inch
mm
0.329
8.36
0.347
8.81
Jacket Thickness
Inch
mm
0.043
1.09
0.043
1.09
*Not CMG approved.
12 AWG (3.29 mm2)
Insulation thickness: 0.032 (0.41 mm)
Part No.
Conductors
M39123*
2
Nominal Diameter
Inch
mm
0.427
10.85
Jacket Thickness
Inch
mm
0.053
1.35
*Not CMG approved.
202
Cable > Manhattan > Instrumentation Cable > Unshielded > 300 V
Manhattan™ Instrumentation Cable
300 V Unshielded Pairs, PVC, PVC
20 AWG (0.52 mm2)
Stranding: 7/0.0121 (7 x 0.31 mm)
Part No.
Pairs
M9500010
1
UL PLTC, ITC
UL CL3
CSA CMG FT4
• -20°C to +105°C
Nominal Diameter
Inch
mm
0.215
5.46
Jacket Thickness
Inch
mm
0.038
0.97
18 AWG (0.82 mm2)
Part No.
Pairs
M9508010
1
Nominal Diameter
Inch
mm
0.235
5.97
Jacket Thickness
Inch
mm
0.038
0.97
16 AWG (1.31 mm2)
• Black, white
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black PVC jacket
Part No.
Pairs
M9506010
1
Nominal Diameter
Inch
mm
0.259
6.58
Jacket Thickness
Inch
mm
0.038
0.97
Features
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
203
Cable > Manhattan > Instrumentation Cable > Overall Foil Shield > 300 V
300 V Overall Foil Shield, Pair, PVC, PVC
22 AWG (0.35 mm2)
Insulation thickness: 0.013 (0.33 mm)
Part No.
Pairs
5610B2201
1
UL PLTC, ITC
UL CL3
CSA CMG FT4
Nominal Diameter
Inch
mm
0.192
4.88
Jacket Thickness
Inch
mm
0.038
0.97
20 AWG (0.52 mm2)
• -20°C to +105°C
Part No.
Pairs
M9520010
1
Nominal Diameter
Inch
mm
0.219
5.56
Jacket Thickness
Inch
mm
0.038
0.97
• Black, white
18 AWG (0.82 mm2)
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing inward
wire one even AWG smaller
than conductor
• Black PVC jacket
Features
Part No.
Pairs
M9528010
1
Nominal Diameter
Inch
mm
0.239
6.07
Jacket Thickness
Inch
mm
0.038
0.97
16 AWG (1.31 mm2)
Part No.
Pairs
M9526010
1
Nominal Diameter
Inch
mm
0.263
6.68
Jacket Thickness
Inch
mm
0.038
0.97
14 AWG (2.08 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Part No.
Pairs
M9524010*
1
Nominal Diameter
Inch
mm
0.303
7.70
Jacket Thickness
Inch
mm
0.043
1.09
*Not CMG approved.
12AWG (3.29 mm2)
Stranding: 19/0.0185 (7 x 0.47 mm)
Part No.
Pairs
5610B1201*
1
Nominal Diameter
Inch
mm
0.368
9.35
Jacket Thickness
Inch
mm
0.045
1.14
*Not CMG approved.
204
Cable > Manhattan > Instrumentation Cable > Overall Foil Shield > 600 V
600 V Pairs, Overall Foil Shield, PVC/Nylon, PVC
20 AWG (0.52 mm2)
Stranding: 7/0.0121 (7 x 0.51 mm)
Insulation thickness: 0.013 (0.33 mm) PVC/0.003 (0.08 mm) nylon
Part No.
Pairs
5616B2001
1
UL TC
• Chart BW (page 529)
Materials
• S
tranded bare copper
conductors
• Aluminum/polyester foil shield,
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
• UL Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.040
1.02
18 AWG (0.82 mm2)
Stranding: 7/0.0152 (7 x 0.31 mm)
• -25°C to +90°C
Nominal Diameter
Inch
mm
0.220
5.59
Part No.
Pairs
M8528010
M8708020
M8708040
M8708060
M8708080
M8708120
M8708160
M8708240
M8708360
M8708500
1
2
4
6
8
12
16
24
36
50
Nominal Diameter
Inch
mm
0.279
7.09
0.396
10.06
0.456
11.58
0.572
14.53
0.617
15.67
0.737
18.72
0.856
21.74
1.025
26.04
1.188
30.18
1.356
34.44
Jacket Thickness
Inch
mm
0.048
1.22
0.050
1.27
0.050
1.27
0.065
1.65
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
16 AWG (1.31 mm2)
Part No.
Pairs
M8526010
M8706020
M8706040
M8706060
M8706080
M8706120
M8706160
M8706240
M8706360
M8706500
1
2
4
6
8
12
16
24
36
50
Nominal Diameter
Inch
mm
0.303
7.70
0.435
11.05
0.504
12.80
0.631
16.03
0.682
17.32
0.858
21.79
0.949
24.10
1.141
28.98
1.325
33.66
1.517
38.53
Jacket Thickness
Inch
mm
0.048
1.22
0.050
1.27
0.050
1.27
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
205
14 AWG (2.08 mm2)
Stranding: 7/0.0242 (7 x 0.61 mm)
UL TC
• -25°C to +90°C
Part No.
Pairs
M8524010
M8704020
M8704040
M8704060
M8704080
M8704120
M8704160
M8704240
M8704360
M8704500
1
2
4
6
8
12
16
24
36
50
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Nominal Diameter
Inch
mm
0.333
8.46
0.484
12.29
0.593
15.06
0.706
17.93
0.764
19.41
0.961
24.41
1.064
27.03
1.286
32.66
1.498
38.05
1.778
45.16
Jacket Thickness
Inch
mm
0.048
1.22
0.050
1.27
0.065
1.65
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.115
2.92
12AWG (3.29 mm2)
Stranding: 19/0.0185 (19 x 0.47 mm)
Part No.
Pairs
5616B1201
1
Nominal Diameter
Inch
mm
0.374
9.50
Jacket Thickness
Inch
mm
0.050
1.27
Features
• UL Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
206
Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Pairs > 600 V
600 V Pairs, Overall and Individually Foil Shielded Pairs, PVC/Nylon, PVC
18 AWG (0.82 mm2)
UL TC
• -25°C to +90°C
Part No.
Pairs
M8748020
M8748040
M8748060
M8748080
M8748120
M8748160
M8748200
M8748240
M8748360
M8748500
2
4
6
8
12
16
36
50
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
• UL Direct Burial
Jacket Thickness
Inch
mm
0.050
1.27
0.050
1.27
0.065
1.65
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
16 AWG (1.31 mm2)
Part No.
Pairs
M8746020
M8746040
M8746060
M8746080
M8746120
M8746160
M8746200
M8746240
M8746360
M8746500
2
4
6
8
12
16
36
50
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Nominal Diameter
Inch
mm
0.429
10.90
0.497
12.62
0.622
15.80
0.672
17.07
0.806
20.47
0.935
23.75
1.020
25.91
1.123
28.52
1.306
33.17
1.497
38.02
Nominal Diameter
Inch
mm
0.471
11.96
0.577
14.66
0.686
17.42
0.742
18.85
9.33
23.70
1.034
26.26
1.130
28.70
1.247
31.67
1.454
36.93
1.730
43.94
Jacket Thickness
Inch
mm
0.050
1.27
0.065
1.65
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.115
2.92
14 AWG (2.08 mm2)
Part No.
Pairs
M8744020
M8744040
M8744060
M8744080
M8744120
M8744160
M8744200
M8744240
M8744360
M8744500
2
4
6
8
12
16
36
50
Nominal Diameter
Inch
mm
0.523
13.28
0.641
16.28
0.765
19.43
0.869
22.07
1.043
26.49
1.158
29.41
1.267
32.18
1.401
35.59
1.638
41.61
1.945
49.40
Jacket Thickness
Inch
mm
0.050
1.27
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.085
2.16
0.115
2.92
207
Cable > Manhattan > Instrumentation Cable > Unshielded Pairs > 600 V
600 V Unshielded Pairs, PVC/Nylon, PVC
18 AWG (0.82 mm2)
Part No.
Pairs
5606B1801
1
UL TC
Nominal Diameter
Inch
mm
0.276
7.01
Jacket Thickness
Inch
mm
0.050
1.27
16 AWG (1.31 mm2)
• -25°C to +90°C
Part No.
Pairs
5606B1601
1
Nominal Diameter
Inch
mm
0.300
7.62
Jacket Thickness
Inch
mm
0.050
1.27
• Black, white
Materials
• S
tranded bare copper
conductors
• Black PVC jacket
Features
• UL Direct Burial
Availability
1000 ft (305 m)
Bulk, cut to length
208
Cable > Manhattan > Instrumentation Cable > Unshielded Triads > 300 V
300 V Unshielded Triads, PVC, PVC
20 AWG (0.52 mm2)
Part No.
Triads
M9600010
1
UL PLTC, ITC
UL CL3
CSA CMG FT4
• -20°C to +105°C
Nominal Diameter
Inch
mm
0.226
5.74
Jacket Thickness
Inch
mm
0.038
0.97
18 AWG (0.81 mm2)
Part No.
Triads
M9608010
1
Nominal Diameter
Inch
mm
0.247
6.27
Jacket Thickness
Inch
mm
0.038
0.97
16 AWG (1.31 mm2)
• Black, white, red
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black PVC jacket
Part No.
Triads
M9606010
1
Nominal Diameter
Inch
mm
0.293
7.44
Jacket Thickness
Inch
mm
0.038
0.97
Features
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
209
Cable > Manhattan > Instrumentation Cable > Foil Shield, Triads > 300 V
300 V Foil Shield, Triads, PVC, PVC
22 AWG (0.35 mm2)
Part No.
Triads
5640B2201
1
UL PLTC, ITC
UL CL3
CSA CMG FT4
Nominal Diameter
Inch
mm
0.201
5.11
Jacket Thickness
Inch
mm
0.038
0.96
20 AWG (0.52 mm2)
• -20°C to +105°C
• Black, white, red
Part No.
Triads
M9620010
5640B2004
5640B2012
1
4
12
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing inward
Stranded tinned copper drain
than conductor
• Black PVC jacket
Features
Nominal Diameter
Inch
mm
0.230
5.84
0.410
10.41
0.640
16.28
Jacket Thickness
Inch
mm
0.038
0.97
0.055
1.39
0.065
1.65
18 AWG (0.82 mm2)
Part No.
Triads
M9628010
1
Nominal Diameter
Inch
mm
0.251
6.38
Jacket Thickness
Inch
mm
0.038
0.97
16 AWG (1.31 mm2)
Part No.
Triads
M9626010
1
Nominal Diameter
Inch
mm
0.287
7.29
Jacket Thickness
Inch
mm
0.043
1.09
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
14 AWG (2.08 mm2)
Part No.
Triads
M9624010*
1
Nominal Diameter
Inch
mm
0.319
8.10
Jacket Thickness
Inch
mm
0.043
1.09
*Not CMG approved.
210
Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Triads > 300 V
300 V Overall and Individually Foil Shielded Triads, PVC, PVC
20 AWG (0.51 mm2)
Stranding: 7/0.0121 (7 x 0.54 mm)
UL PLTC
CSA CMG FT4
Part No.
Triads
5650B2004
5650B2008
5650B2012
4
8
12
Nominal Diameter
Inch
mm
0.458
11.63
0.586
14.88
0.723
18.36
Jacket Thickness
Inch
mm
0.055
1.39
0.055
1.39
0.065
1.65
• -20°C to +105°C
• -20°C to +60°C (CMG)
• Black, white, red
• White conductors are numbered
Materials
• S
tranded bare copper
conductors
• PVC insulation
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
Availability
1000 ft (305 m)
Bulk, cut to length
211
Cable > Manhattan > Instrumentation Cable > Overall Foil Shield, Triads > 600 V
600 V Overall Foil Shield, Triads, PVC/Nylon, PVC
18 AWG (0.82 mm2)
UL TC
Part No.
Triads
M8628010
M8808020
M8808040
M8808080
M8808120
M8808240
1
2
4
8
12
24
Nominal Diameter
Inch
mm
0.293
7.44
0.450
11.43
0.552
14.02
0.708
17.98
0.890
22.61
1.186
30.12
Jacket Thickness
Inch
mm
0.048
1.22
0.050
1.27
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
• -25°C to +90°C
16 AWG (1.31 mm2)
• Black, white, red
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Features
• UL Direct Burial
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Part No.
Triads
M8626010
M8806020
M8806040
M8806080
M8806120
M8806240
1
2
4
8
12
24
Nominal Diameter
Inch
mm
0.319
8.10
0.497
12.62
0.609
15.47
0.785
19.94
0.987
25.07
1.323
33.60
Jacket Thickness
Inch
mm
0.048
1.22
0.050
1.27
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
14 AWG (2.08 mm2)
Part No.
Triads
M8624010
M8804020
M8804040
M8804080
M8804120
M8804240
1
2
4
8
12
24
Nominal Diameter
Inch
mm
0.351
8.92
0.585
14.86
0.680
17.27
0.923
23.44
1.109
28.17
1.495
37.97
Jacket Thickness
Inch
mm
0.048
1.22
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
212
Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Multitriads > 600 V
600 V Overall and Individually Foil Shielded Multitriads, PVC/Nylon, PVC
18 AWG (0.81 mm2)
UL TC
Part No.
Triads
M8848020
M8848040
M8848080
M8848120
M8848240
2
4
8
12
24
• -25°C to +90°C
Materials
• S
tranded bare copper
conductors
25% overlap min., on both
individual triads and
overall cable
Foil facing inward
than conductor
• Black PVC jacket
Features
• UL Direct Burial
Jacket Thickness
Inch
mm
0.050
1.27
0.065
1.65
0.085
2.16
0.085
2.16
0.065
2.16
16 AWG (1.31 mm2)
• Black, white, red
Nominal Diameter
Inch
mm
0.501
12.73
0.614
15.60
0.832
21.13
0.996
25.30
1.336
33.93
Part No.
Triads
M8846020
M8846040
M8846080
M8846120
M8846240
2
4
8
12
24
Nominal Diameter
Inch
mm
0.583
14.81
0.677
17.20
0.918
23.32
1.104
28.04
1.488
37.80
Jacket Thickness
Inch
mm
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.085
2.16
14 AWG (2.08 mm2)
Part No.
Triads
M8844020
M8844040
M8844080
M8844120
M8844240
2
4
8
12
24
Nominal Diameter
Inch
mm
0.648
16.46
0.755
19.18
1.026
26.06
1.238
31.45
1.738
44.15
Jacket Thickness
Inch
mm
0.065
1.65
0.065
1.65
0.085
2.16
0.085
2.16
0.115
2.92
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
213
Cable > Manhattan > Instrumentation Cable > Overall Foil Shield, Composite > 300 V
300 V Overall Foil Shield, Composite, PVC/Nylon, PVC
20 AWG (0.52 mm2) Pairs
UL PLTC, ITC
UL CL3
CSA CMG FT4
• -20°C to +105°C
Part No.
Pairs
M9700020
M9700040
M9700060
M9700080
M9700120
M9700160
5610B2020*
M9700240
M9700360
M9700500
2
4
6
8
12
16
36
50
Nominal Diameter
Inch
mm
0.321
8.15
0.400
10.16
0.451
11.46
0.511
12.98
0.581
14.76
0.660
16.76
0.677
17.20
0.791
20.09
0.925
23.50
1.069
27.15
Jacket Thickness
Inch
mm
0.045
1.14
0.053
1.35
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.065
1.65
0.063
1.60
0.073
1.85
0.073
1.85
*No communication wire.
18 AWG (0.81 mm2) Pairs
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Communications wire is 22 AWG
(0.35 mm2), 7/30 (7 x 0.25 mm)
sttranding, bare copper with
0.016 (0.41 mm) thick insulation
25% overlap min.
Foil facing inward
than conductor
• Black PVC jacket
Part No.
Pairs
M9708020
M9708040
M9708060
M9708080
M9708120
M9708160
M9708240
M9708360
M9708500
2
4
6
8
12
16
24
36
50
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
214
Jacket Thickness
Inch
mm
0.045
1.14
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.073
1.85
0.073
1.85
0.073
1.85
16 AWG (1.31 mm2)
Features
Nominal Diameter
Inch
mm
0.353
8.97
0.431
10.95
0.499
12.67
0.558
14.17
0.664
16.87
0.735
18.67
0.905
22.99
1.049
26.64
1.199
30.45
Part No.
Pairs
M9706020
M9706040
M9706060
M9706080
M9706120
M9706160
M9706240
M9706360
M9706500
2
4
6
8
12
16
24
36
50
Nominal Diameter
Inch
mm
0.409
10.39
0.471
11.96
0.559
14.20
0.639
16.23
0.747
18.97
0.829
21.06
1.023
25.98
1.189
30.20
1.382
35.10
Jacket Thickness
Inch
mm
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.063
1.60
0.073
1.85
0.073
1.85
0.083
2.11
Cable > Manhattan > Instrumentation Cable > Overall and Individually Foil Shielded Pairs > 300 V
300 V Overall and Individually Foil Shielded Pairs, Composite
PVC/Nylon, PVC
20 AWG (0.52 mm2)*
UL PLTC, ITC
UL CL3
CSA CMG FT4
• -20°C to +105°C
Part No.
Pairs
M9740020
M9740040
M9740060
M9740080
M9740120
M9740160
5620B2020**
M9740240
M9740360
M9740500
2
4
6
8
12
16
36
50
Features
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.045
1.14
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.065
1.65
0.073
1.85
0.073
1.85
0.073
1.85
*Communications wire is 22 AWG (0.35 mm2), 7/30 (7 x 0.25 mm) stranding, bare copper with 0.016
(0.41 mm) thick insulation.
**0.013 (0.33 mm) insulation thickness.
Materials
• S
tranded bare copper
conductors
25% overlap min.
Foil facing inward
drain wire one even AWG size
smaller than conductors
• Black PVC jacket
Nominal Diameter
Inch
mm
0.349
8.86
0.427
10.85
0.493
12.52
0.539
13.69
0.643
16.33
0.724
18.39
0.752
19.10
0.882
22.40
1.011
25.68
1.169
29.69
18 AWG (0.82 mm2)
Part No.
Pairs
M9748020
M9748040
M9748060
M9748080
M9748120
M9748160
5620B1820
M9748240
M9748360
M9748500
2
4
6
8
12
16
36
50
Nominal Diameter
Inch
mm
0.401
10.19
0.463
11.76
0.547
13.89
0.616
15.65
0.712
18.08
0.805
20.45
0.921
23.36
0.983
24.97
1.130
28.70
1.349
34.26
Jacket Thickness
Inch
mm
0.053
1.35
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.063
1.60
0.075
1.91
0.073
1.85
0.073
1.85
0.083
2.11
16 AWG (1.31 mm2)
Part No.
Pairs
M9746020
M9746040
M9746060
M9746080
M9746120
M9746160
M9746240
M9746360
M9746500
2
4
6
8
12
16
24
36
50
Nominal Diameter
Inch
mm
0.441
11.20
0.512
13.00
0.630
16.00
0.690
17.53
0.819
20.80
0.929
23.60
1.123
28.52
1.328
33.73
1.521
38.63
Jacket Thickness
Inch
mm
0.053
1.35
0.053
1.35
0.063
1.60
0.063
1.60
0.063
1.60
0.073
1.85
0.073
1.85
0.083
2.11
0.083
2.11
215
Cable > Manhattan > Computer Cable > Multiconductor > Unshielded > 300 V
Manhattan™ Computer Cable
300 V Unshielded, Multiconductor, PVC, PVC
20 AWG (0.50 mm2)
UL AWM 2464
UL CL2
CSA AWM I/II A/B FT4
Applications
• Control and signal wiring
• Computers
• Instrumentation
Part No.
Conductors
882002
882003
882004
882005
882006
882007
882008
882010
882012
882015
882020
882025
2
3
4
5
6
7
8
10
12
15
Nominal Diameter
Inch
mm
0.202
5.13
0.213
5.41
0.231
5.87
0.251
6.38
0.272
6.91
0.272
6.91
0.293
7.44
0.318
8.08
0.338
8.59
0.389
9.88
0.430
10.92
0.471
11.96
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Color
Code
R
R
R
R
R
R
R
R
R
F
R
R
• -20°C to +105°C (CSA)
• -20°C to +90°C (CL2)
• -20°C to +80°C (AWM)
18 AWG (0.81 mm2)
Stranding: 16/30 (16 x 0.25 mm)
Part No.
Conductors
• See tables
881802
881803
881804
881805
881806
881807
881808
881809
881812
881815
881820
881825
2
3
4
5
6
7
8
9
12
15
Materials
• S
conductors
• PVC insulation
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Nominal Diameter
Inch
mm
0.222
5.64
0.234
5.94
0.255
6.48
0.278
7.06
0.289
7.34
0.302
7.67
0.341
8.66
0.379
9.63
0.408
10.36
0.465
11.81
0.511
12.98
0.600
15.24
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Color
Code
R
F
R
R
R
R
R
R
F
F
R
F
216
16 AWG (1.32 mm2)
Insulation thickness: 0.032 (0.81 mm)
UL AWM 2464
UL CL2
Part No.
Conductors
881602
881603
881604
881605
881606
881607
881610
2
3
4
5
6
7
10
Nominal Diameter
Inch
mm
0.312
7.92
0.329
8.36
0.375
9.53
0.405
10.29
0.410
10.41
0.455
11.56
0.578
14.68
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.045
1.14
0.045
1.14
0.045
1.14
0.045
1.14
0.045
1.14
Color
Code
F
F
F
F
R
F
R
Applications
• Computers
• Instrumentation
14 AWG (2.08 mm2)
Stranding: 41/30 (65 x 0.25 mm)
Insulation thickness: 0.031 (0.78 mm)
Part No.
Conductors
881403
881404
881405
3
4
5
Nominal Diameter
Inch
mm
0.378
9.60
0.434
11.02
0.485
12.32
Jacket Thickness
Inch
mm
0.035
0.89
0.045
1.14
0.060
1.52
Color
Code
F
F
F
• See tables
12 AWG (3.29 mm2)
Stranding: 65/30 (65 x 0.25 mm)
Materials
• S
conductors
• PVC insulation
• Slate PVC jacket
Part No.
Conductors
881202
881203
2
3
Nominal Diameter
Inch
mm
0.396
10.06
0.423
10.74
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
Color
Code
F
F
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
217
300 V Unshielded, Multiconductor, SR-PVC, PVC
24 AWG (0.22 mm2)
Stranding: 7/32 (7 x 0.20 mm)
UL AWM 2464
UL CL2
Part No.
Conductors
882402
882403
882404
882406
2
3
4
6
• See tables
Materials
• S
conductors
• Semirigid PVC insulation
• Slate PVC jacket
Availability
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Color
Code
E
E
E
E
22 AWG (0.35 mm2)
Applications
• Computers
• Instrumentation
Nominal Diameter
Inch
mm
0.152
3.86
0.159
4.04
0.170
4.32
0.197
5.00
Part No.
Conductors
882202
882203
882204
882205
882206
882207
882208
882209
882210
882212
882215
882220
882225
882230
882240
882250
882260
2
3
4
5
6
7
8
9
10
12
15
30
40
50
60
Nominal Diameter
Inch
mm
0.164
4.17
0.172
4.37
0.185
4.70
0.200
5.08
0.215
5.46
0.215
5.46
0.230
5.84
0.246
6.25
0.264
6.71
0.272
6.91
0.294
7.47
0.326
8.28
0.364
9.25
0.385
9.78
0.429
10.90
0.478
12.14
0.520
13.21
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.035
0.89
Color
Code
R
R
R
R
R
R
R
R
R
R
F
F
F
F
F
F
F
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
218
24 AWG (0.22 mm2)
Stranding: 7/32 (10 x 0.20 mm)
UL AWM 2343
UL CMG
CSA CMG FT4
Part No.
Conductors
M4501
M4502
M4503
M4504
M4506
7
12
15
19
37
Applications
• Computers
• Instrumentation
• -20°C to +75°C (CMG)
• Chart E (page 532)
Nominal Diameter
Inch
mm
0.262
6.65
0.312
7.92
0.332
8.43
0.349
8.86
0.437
11.10
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
22 AWG (0.35 mm2)
Part No.
Conductors
M4508
M4510
M4511
M4512
M4513
M4514
M4515
2
7
12
15
19
27
37
Nominal Diameter
Inch
mm
0.229
5.82
0.280
7.11
0.337
8.56
0.360
9.14
0.379
9.63
0.437
11.10
0.479
12.17
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Materials
• S
conductors
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
20 AWG (0.56 mm2)
Stranding: 7/28 (7 x 0.32 mm)
Part No.
Conductors
M4517
M4518
M4519
M4520
M4522
M4523
M4524
2
5
7
12
19
27
37
Nominal Diameter
Inch
mm
0.245
6.22
0.287
7.29
0.304
7.72
0.370
9.40
0.419
10.64
0.486
12.34
0.535
13.59
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
219
Cable > Manhattan > Computer Cable > Multiconductor > Foil Shield > 300 V
20 AWG (0.56 mm2)
Stranding: 7/28 (10 x 0.32 mm)
Color Code D
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• Computers
• Instrumentation
Part No.
Conductors
M4660
M4661
M4662
M4664
M4665
M4666
M4668
M4670
M4672
M4673
M4675
M4677
2
3
4
6
8
10
15
30
40
50
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
0.053
1.35
18 AWG (0.81 mm2)
Color Code D
• See tables
Nominal Diameter
Inch
mm
0.211
5.36
0.222
5.64
0.240
6.10
0.282
7.16
0.304
7.72
0.351
8.92
0.393
9.98
0.437
11.10
0.491
12.47
0.520
13.21
0.625
15.88
0.685
17.40
Part No.
Conductors
M4690
M4691
M4692*
M4693*
M4694
M4696
M4697
M4698
M4700
M4702
M4704
M4706
M4708
2
3
2
3
4
6
8
10
15
30
40
Nominal Diameter
Inch
mm
0.229
5.82
0.241
6.12
0.229
5.82
0.241
6.12
0.262
6.65
0.309
7.85
0.334
8.48
0.387
9.83
0.436
11.07
0.485
12.32
0.545
13.84
0.620
15.75
0.690
17.53
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
0.053
1.35
*Conductor color coding: 1 Brown, 2 Blue, 3 Green/Yellow.
220
16 AWG (1.32 mm2)
Stranding: 19/0.0117 (19 x 0.30 mm)
Color Code R
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• Computers
• Instrumentation
Part No.
Conductors
M4720
M4721
M4722*
M4723*
M4724
M4726
M4728
M4730
M4732
M4734
M4736
2
3
2
3
4
6
8
10
15
Nominal Diameter
Inch
mm
0.253
6.43
0.267
6.78
0.253
6.43
0.267
6.78
0.291
7.39
0.345
8.76
0.374
9.50
0.435
11.05
0.489
12.42
0.547
13.89
0.697
17.70
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
• See tables
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
221
24 AWG (0.22 mm2)
UL AWM 2464
UL CL2
Part No.
Conductors
1012405
1012407
1012409
5
7
9
Nominal Diameter
Inch
mm
0.190
4.83
0.205
5.21
0.236
5.99
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
Applications
• Sound broadcast
• Instrumentation
• -20°C to +80°C
• Chart R (page 535)
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing outward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
222
300 V Foil Shield, Multiconductor, SR-PVC, PVC
24 AWG (0.22 mm2)
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• C
omputer and control
applications
Part No.
Conductors
M4602
M4603
M4604
M4606
M4607
M4608
M4610
M4612
M4614
M4616
M4618
M4620
2
3
4
6
8
10
15
30
40
50
Materials
• S
conductors
25% overlap min.
Foil facing inward
• Slate PVC jacket
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
22 AWG (0.35 mm2)
Nominal Diameter
Inch
mm
0.159
4.04
0.166
4.22
0.178
4.52
0.204
5.18
0.217
5.51
0.247
6.27
0.273
6.93
0.301
7.65
0.335
8.51
0.353
8.97
0.393
9.98
0.430
10.92
Part No.
Conductors
M4633
M4634
M4635
M4636
M4638
M4640
M4642
M4644
M4646
M4648
M4650
M4652
2
3
4
6
8
10
15
30
40
50
Nominal Diameter
Inch
mm
0.171
4.34
0.179
4.55
0.192
4.88
0.222
5.64
0.237
6.02
0.271
6.88
0.301
7.65
0.333
8.46
0.371
9.42
0.392
9.96
0.436
11.07
0.479
12.17
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
223
Cable > Manhattan > Computer Cable > Multiconductor > Foil/Braid Shield > 300 V
300 V Foil/Braid Shield, Multiconductor, SR-PVC, PVC
65% Braid Coverage
28 AWG (0.08 mm2)
Stranding: 7/36 (7 x 0.12 mm)
Color Code D
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
S-232
R
Modems
Multiplexers
Serial data interfaces
Part No.
Conductors
M2403
M2404
M2405
M2406
M2407
M2408
M2409
M2410
M2412
M2414
M2416
M2420
3
4
5
6
7
8
9
10
15
25
37
50
70% Braid Coverage
24 AWG (0.22 mm2)
Color Code E
• See tables
Materials
• S
conductors
• Foil + braid shield
25% overlap min.
Foil facing outward
Tinned copper braid, 65% or
70% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Mutual capacitance: 25 pF/ft (82 pF/m)
Ground capacitance: 45 pF/ft (147.6 pF/m)
Nominal Diameter
Inch
mm
0.165
4.19
0.175
4.45
0.185
4.70
0.196
4.98
0.196
4.98
0.206
5.23
0.217
5.51
0.230
5.84
0.251
6.38
0.300
7.62
0.335
8.51
0.376
9.55
Part No.
Conductors
M5302
M5303
M5304
M5306
M5307
M5308
M5310
M5312
M5314
M5316
M5318
M5320
2
3
4
6
8
10
15
30
40
50
Nominal Diameter
Inch
mm
0.181
4.60
0.188
4.78
0.199
5.05
0.226
5.74
0.239
6.07
0.269
6.83
0.295
7.49
0.323
8.20
0.357
9.07
0.375
9.53
0.415
10.54
0.452
11.48
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Mutual capacitance: 32 pF/ft (105 pF/m)
Ground capacitance: 58 pF/ft (190.3 pF/m)
Part No. M5302:
Mutual capacitance: 35 pF/ft (114.8 pF/m)
Ground capacitance: 63 pF/ft (206.7 pF/m)
224
65% Braid Coverage
24 AWG (0.22 mm2)
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
S-232
R
Modems
Multiplexers
Part No.
Conductors
M2438
M2439
M2440
M2441
M2442
M2443
M2444
M2445
M2447
M2449
M2452
M2455
3
4
5
6
7
8
9
10
15
25
37
50
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Color
Code
O
O
O
O
O
O
O
O
F
F
F
F
Ground capacitance: 58 pF/ft (190 pF/m)
Nominal Diameter
Inch
mm
0.185
4.70
0.196
4.98
0.209
5.31
0.223
5.66
0.223
5.66
0.236
5.99
0.250
6.35
0.266
6.76
0.292
7.42
0.354
8.99
0.398
10.11
0.449
11.40
70% Braid Coverage
22 AWG (0.35 mm2)
Color Code E
• See tables
Materials
Part No.
Conductors
• S
conductors
25% overlap min.
Foil facing outward
70% coverage
• Slate PVC jacket
M5333
M5334
M5335
M5336
M5338
M5340
M5342
M5344
M5346
M5348
M5350
M5352
2
3
4
6
8
10
15
30
40
50
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Nominal Diameter
Inch
mm
0.193
4.90
0.201
5.11
0.214
5.44
0.244
6.20
0.259
6.58
0.293
7.44
0.323
8.20
0.355
9.02
0.393
9.98
0.414
10.52
0.458
11.63
0.501
12.73
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Mutual capacitance: 36 pF/ft (118.1 pF/m)
Ground capacitance: 65 pF/ft (213.3 pF/m)
Part No. M5333:
Mutual capacitance: 39 pF/ft (128 pF/m)
Ground capacitance: 70 pF/ft (229.7 pF/m)
225
65% Braid Coverage
22 AWG (0.35 mm2)
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
S-232
R
Modems
Multiplexers
Part No.
Conductors
M2473
M2474
M2475
M2476
M2477
M2478
M2479
M2480
M2481
M2482
M2483
M2485
3
4
5
6
7
8
9
10
15
25
37
50
Nominal Diameter
Inch
mm
0.198
5.03
0.211
5.36
0.226
5.74
0.241
6.12
0.241
6.12
0.256
6.50
0.272
6.91
0.290
7.37
0.320
8.13
0.390
9.91
0.440
11.18
0.504
12.80
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.86
Color
Code
O
O
O
O
O
O
O
O
F
F
F
F
• See table
Materials
• S
conductors
25% overlap min.
Foil facing outward
70% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
226
24 AWG (0.22 mm2)
UL AWM 2343
UL CMG
CSA CMG FT4
Applications
• C
omputer and control
applications
Part No.
Conductors
M5500
M5501
M5502
M5503
M5504
M5505
M5506
M5507
M5508
5
7
12
15
19
27
37
48
60
22 AWG (0.35 mm2)
Part No.
Conductors
M5509
M5510
M5511
M5512
M5513
M5514
M5515
M5516
M5517
5
7
12
15
19
27
37
48
60
• S
conductors
25% overlap min.
Foil facing outward
70% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Materials
Nominal Diameter
Inch
mm
0.274
6.96
0.288
7.32
0.338
8.59
0.357
9.07
0.375
9.53
0.426
10.82
0.463
11.76
0.514
13.06
0.551
14.00
Nominal Diameter
Inch
mm
0.291
7.39
0.306
7.77
0.363
9.22
0.385
9.78
0.405
10.29
0.463
11.76
0.505
12.83
0.563
14.30
0.605
15.37
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
20 AWG (0.56 mm2)
Part No.
Conductors
M5518
M5519
M5520
M5521
M5522
M5523
M5524
M5525
M5526
5
7
12
15
19
27
37
48
60
Nominal Diameter
Inch
mm
0.312
7.92
0.330
8.38
0.396
10.06
0.421
10.69
0.445
11.30
0.512
13.00
0.561
14.25
0.628
15.95
0.683
17.35
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Mutual capacitance: 40 pF/ft (131.2 pF/m)
Ground capacitance: 72 pF/ft (236.2 pF/m)
227
300 V Foil/Braid Shield, Low Capacitance, Multiconductor, FPE, PVC
24 AWG (0.22 mm2)
UL AWM 2919 (30 V)
UL CM VW-1
CSA CM FT4
Applications
S-232, RS-422
R
Modems
Multiplexers
Part No.
Conductors
M2456
M2457
M2458
M2459
M2460
M2461
M2462
M2463
M2465
M2467
M2470
3
4
5
6
7
8
9
10
15
25
37
Nominal Diameter
Inch
mm
0.217
5.51
0.231
5.87
0.248
6.30
0.265
6.73
0.265
6.73
0.282
7.16
0.300
7.62
0.320
8.13
0.353
8.97
0.432
10.97
0.488
12.40
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
Color
Code
O
O
O
O
O
O
O
O
F
F
F
Mutual capacitance: 11.9 pF/ft (39 pF/m)
Ground capacitance: 21.4 pF/ft (70.2 pF/m)
• -20°C to +75°C (CM)
• See table
Materials
• S
conductors
• Foam polyethylene insulation
25% overlap min.
Foil facing outward
65% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
228
300 V Foil/Braid Shield, Multiconductor, PVC, PVC
20 AWG (0.56 mm2)
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• Computer and control
Part No.
Conductors
M5360
M5361
M5362
M5364
M5365
M5366
M5368
M5370
M5372
M5375
M5377
2
3
4
6
8
10
15
40
50
Materials
• S
conductors
• PVC insulation
25% overlap min.
Foil facing outward
70% coverage
• Slate PVC jacket
Part No.
Conductors
M5390
M5391
M5392*
M5393*
M5394
M5396
M5397
M5398
M5400
M5402
M5404
M5406
2
3
2
3
4
6
8
10
15
30
Nominal Diameter
Inch
mm
0.251
6.38
0.263
6.68
0.251
6.38
0.263
6.68
0.284
7.21
0.328
8.33
0.356
9.04
0.409
10.39
0.456
11.58
0.507
12.88
0.609
15.47
0.648
16.46
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
0.053
1.35
16 AWG (1.32 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
0.053
1.35
18 AWG (0.81 mm2)
• Chart D (page 531)
Nominal Diameter
Inch
mm
0.233
5.92
0.241
6.12
0.262
6.65
0.304
7.72
0.326
8.28
0.373
9.47
0.415
10.54
0.459
11.66
0.513
13.03
0.653
16.59
0.713
18.11
Part No.
Conductors
M5420
M5421
M5422*
M5423*
M5424
M5426
M5428
M5430
M5432
M5434
M5436
2
3
2
3
4
6
8
10
15
Nominal Diameter
Inch
mm
0.275
6.99
0.289
7.34
0.275
6.99
0.289
7.34
0.313
7.95
0.367
9.32
0.396
10.06
0.457
11.61
0.511
12.98
0.611
15.52
0.687
17.45
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
0.053
1.35
229
Cable > Manhattan > Computer Cable > Multipair > Foil Shield > 300 V
300 V Foil Shield, Multipair, PVC, PVC
22 AWG (0.35 mm2)
Stranding: Solid
Part No.
Pairs
M3191
M3192
51
102
UL AWM 2464
UL CMG
CSA CMG FT4
Nominal Diameter
Inch
mm
0.710
18.03
1.120
28.45
Jacket Thickness
Inch
mm
0.050
1.27
0.085
2.16
20 AWG (0.56 mm2)
Applications
• Modems
• Multiplexers
• General data interfaces
Part No.
Pairs
M4785
M4786
M4789
M4791
2
3
12
19
Materials
• S
olid or stranded tinned
copper conductors
• PVC insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
18 AWG (0.81 mm2)
• Chart A (page 528)
Nominal Diameter
Inch
mm
0.301
7.65
0.319
8.10
0.548
13.92
0.688
17.48
Part No.
Pairs
M4799
M4793
M4794
2
3
6
Nominal Diameter
Inch
mm
0.330
8.38
0.350
8.89
0.462
11.73
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
230
300 V Foil Shield, Multipair, SR-PVC or PP, PVC
SR-PVC Insulation
24 AWG (0.22 mm2)
Color Code K
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
S-232
R
Modems
Multiplexers
Part No.
Pairs
M13190
M13191
M13192
M13193
M13194
M13195
M13196
M13197
M13198
M13199
M4758*
M13200
M3189
M13201
M4761*
M13202**
1
2
3
4
5
6
7
8
9
10
11
15
19
25
27
50
Nominal Diameter
Inch
mm
0.159
4.04
0.215
5.46
0.227
5.77
0.246
6.25
0.267
6.78
0.289
7.34
0.289
7.34
0.311
7.90
0.334
8.48
0.360
9.14
0.360
9.14
0.402
10.21
0.432
10.97
0.510
12.95
0.515
13.08
0.666
16.92
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.035
0.89
0.032
0.89
0.035
0.89
*Color code Chart B (page 528)
**Color code Chart A1 (page 528)
• See tables
Materials
• S
copper conductors
• Semirigid PVC or
polypropylene insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
SR-PVC Insulation
22 AWG (0.35 mm2)
Color Code B
Part No.
Pairs
M4770
M4771
M4772
M4773
M4774
M4775
M4776
M4777
M4778
M4779
2
3
4
5
6
9
11
15
19
27
Nominal Diameter
Inch
mm
0.235
5.97
0.248
6.30
0.269
6.83
0.293
7.44
0.318
8.08
0.369
9.37
0.399
10.13
0.448
11.38
0.481
12.22
0.618
15.70
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.053
1.35
Polypropylene Insulation
22 AWG (0.35 mm2)
Stranding: Solid
Insulation thickness: 0.008 (0.20 mm)
Color Code K
Part No.
Pairs
M3190
38
Nominal Diameter
Inch
mm
0.610
15.49
Jacket Thickness
Inch
mm
0.045
1.14
231
Cable > Manhattan > Computer Cable > Multipair > Foil/Braid Shield > 300 V
300 V Foil/Braid Shield, Multipair, SR-PVC, PVC
24 AWG (0.22 mm2)
UL AWM 1061
UL AWM 2343
UL CMG
CSA CMG FT4
Part No.
Pairs
M5650
M5651
M5652
M5653
M5654
M5655
M5656
5
7
12
15
19
27
37
Part No. M5650
• C
ontrol, signal, and data
transmission computers
• Industrial and electronic
equipment
22 AWG (0.35 mm2)
• Chart B (page 528)
Materials
• S
conductors
25% overlap min.
Foil facing outward
70% coverage
• Slate PVC jacket
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Mutual capacitance: 23.1 pF/ft (75.8 pF/m)
Ground capacitance: 42 pF/ft (137.8 pF/m)
Applications
Availability
Nominal Diameter
Inch
mm
0.351
8.92
0.373
9.47
0.455
11.56
0.486
12.34
0.516
13.11
0.599
15.21
0.666
16.92
Part No.
Pairs
M5660
M5661
M5662
M5665
M5666
5
7
12
27
37
Nominal Diameter
Inch
mm
0.377
9.58
0.402
10.21
0.496
12.60
0.666
16.92
0.735
18.67
Jacket Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Ground capacitance: 49 pF/ft (160.8 pF/m)
20 AWG (0.56 mm2)
Part No.
Pairs
M5670
M5671
M5673
M5674
M5675
5
7
15
19
27
Nominal Diameter
Inch
mm
0.413
10.49
0.442
11.23
0.592
15.04
0.631
16.03
0.746
18.95
Jacket Thickness
Inch
Mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Mutual capacitance: 27 pF/ft (88.6 pF/m)
Part No. M5670
Mutual capacitance: 29 pF/ft (95.1 pF/m)
Ground capacitance: 52 pF/ft (170.6pF/m)
232
300 V Foil Shield, Low Capacitance, 100 ohm, Multipair, FPP, PVC
24 AWG (0.22 mm2)
Insulation thickness: 0.0185 (0.47 mm)
UL AWM 2493
UL CM
CSA CM FT4
Applications
• R
S-232
• RS-422
Part No.
Pairs
M39249
M39250
M39251
M39252
M39254
M39256
M39257
M39259
M39260
M39262
M39268
2
3
4
6
9
11
12
15
17
19
27
• -20°C to +60°C (AWM)
Nominal Diameter
Inch
mm
0.323
8.20
0.340
8.64
0.369
9.37
0.436
11.07
0.506
12.85
0.580
14.73
0.597
15.16
0.646
16.41
0.682
17.32
0.693
17.60
0.821
20.85
Jacket Thickness
Inch
mm
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.065
1.65
0.065
1.65
0.065
1.65
0.065
1.65
0.065
1.65
0.065
1.65
Mutual capacitance: 12.5 pF/ft (41 pF/m)
Ground capacitance: 23 pF/ft (75.5 pF/m)
Part No. 39256
• Chart K (page 529)
Materials
• S
conductors
• Foam polypropylene insulation
25% overlap min.
Foil facing inward
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
233
300 V Foil/Braid Shield, Multipair, FPP, PVC
28 AWG (0.09 mm2)
Insulation thickness: 0.0145 (0.37 mm)
UL AWM 2919 (30 V)
UL CM
CSA CM
Applications
• R
S-422
• Modems
• Multiplexers
Part No.
Pairs
M2487
M2488
M2489
M2490
M2492
M2493
M2494
M2495*
M2496
M2497
M2498
2
3
4
5
7
8
10
12.5
15
18
25
*Discrete conductor is polyethylene insulated.
24 AWG (0.22 mm2)
Insulation thickness: 0.0125 (0.32 mm)
• S
conductors
25% overlap min.
Foil facing outward
65% coverage
• Slate PVC jacket
Availability
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.048
1.22
Mutual capacitance: 11 pF/ft (36.1 pF/m)
Ground capacitance: 20 pF/ft (65.6 pF/m)
Materials
Nominal Diameter
Inch
mm
0.240
6.10
0.252
6.40
0.271
6.88
0.292
7.42
0.314
7.98
0.336
8.53
0.385
9.78
0.395
10.03
0.427
10.85
0.457
11.61
0.555
14.10
Part No.
Pairs
M3420
M3421
M3422
M3423
M3424
M3425
M3426
M3427
M3428*
M3429
M3430
M3431
2
3
4
5
6
7
8
10
12.5
15
18
25
Nominal Diameter
Inch
mm
0.257
6.53
0.269
6.83
0.290
7.37
0.314
7.98
0.338
8.59
0.338
8.59
0.363
9.22
0.417
10.59
0.429
10.90
0.475
12.07
0.524
13.31
0.608
15.44
Jacket Thickness
Inch
mm
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.035
0.89
0.040
1.02
0.048
1.22
0.050
1.27
Ground capacitance: 22 pF/ft (72.2 pF/m)
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
234
300 V Foil/Braid Shield, Low Capacitance, Multipair, FPP, PVC
24 AWG (0.22 mm2)
UL AWM 2343
UL CM
CSA CM
Applications
• R
S-422
• Modems
• Multiplexers
Part No.
Pairs
M3475
M3476
M3477
M3478
M3479
M3480
M3481
M3482
M3483
M3484
M3485
2
3
4
5
6
7
8
10
15
18
25
• -20°C to +75°C (AWM)
Nominal Diameter
Inch
mm
0.346
8.79
0.363
9.22
0.392
9.96
0.425
10.80
0.459
11.66
0.459
11.66
0.494
12.55
0.603
15.32
0.669
16.99
0.716
18.19
0.832
21.13
Jacket Thickness
Inch
mm
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.048
1.22
0.065
1.65
0.065
1.65
0.065
1.65
0.065
1.65
Ground capacitance: 23 pF/ft (23 pF/m)
Part No. M3484 and 3485:
Ground capacitance: 21.4 pF/ft (21.4 pF/m)
Materials
• S
conductors
25% overlap min.
Foil facing outward
65% coverage
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
235
300 V Foil/Braid Shield, Low Capacitance, 100 Ohm, Multipair, PE, PVC
UL AWM 2960, CM
28 AWG (0.08 mm2)
Color Code K
UL AWM 2960 (30 V)
UL 2919 (30 V)
UL CM
CSA CM
Applications
• R
S-422
• Modems
• Multiplexers
Part No.
Pairs
M3970
M3971
M3972
M3973
M3974
M3975
M3977
M3931
M3978
M3979
M3932
2
3
4
5
7
9
12
13
18
25
31
UL AWM 2919, CM
24 AWG (0.22 mm2)
Insulation thickness: 0.016 (0.25 mm)
Color Code M
• See tables
Part No.
Pairs
Materials
M3993†
M3980*
M3990†
M3981*
M3991†
M3982*
M3992†
M3983*
M3940*
M3984*
M3985*
M3986*
M3987*
M3988*
M3989*
1
2
2
3
3
4
4
5
6
7
9
10
12
18
25
• S
conductors
• Polyethylene insulation
25% overlap min.
Foil facing outward
Tinned copper braid, 90%
coverage (65% where noted)
• Slate PVC jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Jacket Thickness
Inch
mm
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
Mutual capacitance: 15.5 pF/ft (50.9 pF/m)
Ground capacitance: 27.5 pF/ft (90.2 pF/m)
• -20°C to +80°C (AWM 2919)
• -20°C to +60°C (AWM 2960)
Nominal Diameter
Inch
mm
0.205
5.21
0.214
5.44
0.229
5.82
0.246
6.25
0.263
6.68
0.299
7.59
0.329
8.36
0.335
8.51
0.377
9.58
0.440
11.18
0.470
11.94
Nominal Diameter
Inch
mm
0.208
5.28
0.274
6.96
0.280
7.11
0.288
7.32
0.294
7.47
0.312
7.92
0.318
8.08
0.339
8.61
0.367
9.32
0.367
9.32
0.424
10.77
0.457
11.61
0.482
12.24
0.560
14.22
0.671
17.04
Jacket Thickness
Inch
mm
0.035
0.89
0.032
0.81
0.035
0.89
0.032
0.81
0.035
0.89
0.032
0.81
0.035
0.89
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.032
0.81
0.037
0.94
0.047
1.19
0.047
1.19
†120-ohm impedance
Mutual capacitance: 12.8 pF/ft (42 pF/m)
Ground capacitance: 23 pF/ft (75 pF/m)
*65% braid coverage.
236
24 AWG (0.22 mm2)
Color Code M
UL AWM 2464
UL CMG
CSA CMG FT4
Applications
• R
S-422
• Modems
• Multiplexers
Part
No.
Pairs
M3446
M3447
M3448
M3449
M3450
M3451
M3452
M3453
M3454
M3455
2
3
4
5
6
7
8
10
12
15
Nominal
Diameter
Jacket
Thickness
Inch
mm
Inch
mm
0.234
0.246
0.265
0.286
0.308
0.308
0.330
0.379
0.389
0.421
5.94
6.25
6.73
7.26
7.82
7.82
8.38
9.63
9.88
10.69
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
Capacitance
Mutual
pF/ft
pF/m
28
92
25
82
25
82
25
82
23.1
75.8
23.1
75.8
23.1
75.8
23.1
75.8
23.1
75.8
23.1
75.8
Ground
pF/ft
pF/m
50
164
45
147.6
45
147.6
45
147.6
42
137.8
42
137.8
42
137.8
42
137.8
42
137.8
42
137.8
22 AWG (0.35 mm2)
Color Code A
• See tables
Materials
• S
conductors
25% overlap min.
Foil facing outward
wire, 24 AWG (0.22 mm2),
7/32 (7 x 0.20 mm) stranding
65% coverage
• Slate PVC jacket
Part No.
Pairs
M3433
M3434
M3435
M3436
M3437
M3438
M3439
M3440
M3441
M3442
M3443
M3444
2
3
4
5
6
7
8
10
12
15
18
25
Nominal
Diameter
Jacket
Thickness
Inch
mm
Inch
mm
0.254
0.267
0.288
0.312
0.337
0.337
0.363
0.418
0.430
0.473
0.506
0.588
6.45
6.78
7.32
7.92
8.56
8.56
9.22
10.62
10.92
12.01
12.85
14.94
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.032
0.035
0.035
0.035
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
0.81
Capacitance
Mutual
pF/ft
pF/m
31
101.7
27
88.6
27
88.6
27
88.6
27
88.6
24.9
81.7
24.9
81.7
24.9
81.7
24.9
81.7
24.9
81.7
24.9
81.7
24.9
81.7
Ground
pF/ft
pF/m
56
183.7
49
160.8
49
160.8
49
160.8
49
160.8
45
147.6
45
147.6
45
147.6
45
147.6
45
147.6
45
147.6
45
147.6
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
237
Cable > Manhattan > Coaxial Cable
Manhattan™ Coaxial Cable
Coaxial and Twinax Cable
For a complete range of 50, 75,
93, and 100 ohm coaxial and
twinaxial, we offer a wide range of
insulations and jackets meeting
the requirements of military
specifications and regulatory
agencies such as UL and CSA.
For broadcast-quality video
transmission, our precision video
cables use FEP dielectrics to
achieve low capacitance, high
velocities of propagation, and
tight tolerances for maximum
signal integrity.
Availability
A. 100 ft (30.5 m)
B. 500 ft (152 m)
C. 500 ft (152 m) boxed
D. 1000 ft (305 m)
E. 1000 ft (305 m) boxed
F. 2000 ft (610 m)
G. Bulk, cut to length
Part No.
50-Ohm Transmission and Computer Cables
RG-55B/U, RG-58/U, RG-58A/U, and RG-58C/U Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
AWG (mm2) Stranding (mm) Material Material Dia., In. (mm)
Jacket
Material
Dia., In. (mm)
9058
20 (0.52)
Solid
BC
PE
0.116 (2.95)
TC Braid, 80%
Black Type I PVC
0.195 (4.95)
9058A
20 (0.48)
19/0.0071
(19 x 0.18)
TC
PE
0.116 (2.95)
TC Braid, 95%
Black Type I PVC
0.195 (4.95)
9058AC
20 (0.48)
19/0.0071
(19 x 0.18)
TC
PE
0.116 (2.95)
TC Braid, 95%
Black Type I PVC
0.195 (4.95)
9058C
20 (0.48)
19/0.0072
(19 x 0.18)
TC
PE
0.116 (2.95)
TC Braid, 95%
Black Type IIA PVC
0.195 (4.95)
9058X
20 (0.52)
Solid
BC
PE
0.116 (2.95)
TC Braid, 95%
Black Type I PVC
0.195 (4.95)
9158S
20 (0.52)
Solid
BC
FEP
0.107 (2.72)
TC Braid, 95%
Black FEP
0.159 (4.04)
M4210
20 (0.62)
19/32
(19 x 0.20)
TC
Foam
PE
0.116 (2.95)
TC Braid, 93%
Black or White
Type I PVC
0.193 (4.90)
M4213
20 (0.48)
19/0.0072
(19 x 0.18)
TC
PE
0.116 (2.95)
TC Braid, 94%
Black Type IIA PVC
0.195 (4.95)
M4219
20 (0.48)
19/0.0071
(19 x 0.18)
TC
PE
0.117 (2.97)
TC Braid, 91%
Black Type I PVC
0.203 (5.16)
M44209
20 (0.52)
Solid
BC
FEP
0.107 (2.72)
TC Braid, 95%
White Plenum PVC
0.159 (4.04)
9848
18 (0.82)
Solid
BC
Foam
PE
0.116 (2.95)
TC Braid, 95%
Black Type I PVC
0.195 (4.95)
238
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9058
53
66
28.5 (93.5)
UL AWM 1354
JAN-C-17A/RG-58/U
A, B, D
9058A
50
66
30.8 (101.1)
JAN-C-17A/RG-58A/U Type
A, B, C, D, E
9058AC
50
66
30.8 (101.1)
CL2
A, B, D, E
9058C
50
66
30.8 (101.1)
MIL-DTL-17/28B
RG 58C/U
A, B, D, E
9058X
53.5
66
28.5 (93.5)
9158S
50
70
30 (98.4)
M4210
52
76
26 (85.3)
M4213
50
66
30.8 (101.1)
M4219
50
66
30.8 (101.1)
M44209
53
69.5
26.4 (86.6)
9848
50
78
26 (85.3)
UL AWM 1354
UL CL2
JAN-C-17A/RG-58/U
UL CL2P
CSA CMP FT6
MIL-DTL-17/28 RG-58/U Type
UL AWM 1354
UL CM
CSA CM
JAN-C-17A/RG-58/U
MIL-DTL-17/28B RG-58C/U
UL CM
CSA CM
UL CMP
CSA CMP FT6
MIL-DTL-17/RG-58/U Type
UL AWM 1354
MIL-DTL-17/28B RG-58/U Type
A, B, C, D, E
B, D
A, B, D
A, B, D
A, B, D
A, B, D, G
A, B, D, E
239
Part No.
9055B
Part No.
RG-55B/U Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
20 (0.52)
Solid
SPC
PE
0.116 (2.95)
Dbl TC Braid, 95%
RG-8/U and RG-8A/U Type Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
Jacket
Material
Dia., In. (mm)
Black PE
0.201 (5.11)
Jacket
Material
Dia., In. (mm)
9008
13 (2.90)
7/21
(7 x 0.72)
M4201
13 (2.90)
7/21
(7 x 0.72)
BC
PE
0.285 (7.24)
BC Braid, 95%
Black Type IIA PVC
0.405 (10.29)
M4206
11 (4.60)
7/19
(7 x 0.91)
BC
Foam
PE
0.285 (7.24)
BC Braid, 96%
Black PVC
0.403 (10.24)
240
BC
PE
0.285 (7.24)
BC Braid, 94%
Black Type I PVC
0.405 (10.29)
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9055B
53.5
66
28.8 (94.5)
MIL-DTL-17D/26A RG-55B/U
A, B, D
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9008
52
66
29.5 (96.8)
JAN-C-17A/RG-8/U
A, B, D
M4201
52
66
28.5 (93.5)
M4206
50
78
26 (85.3)
UL AWM 1354
UL CMX
CSA CMX
MIL-DTL-17D/3A RG-8A/U
UL AWM 1354
UL CM
CSA CM
MIL-DTL-17/RG-8/U Type
A, B, D
A, B, D
241
RG-142B/U, RG-174 Type, RG-178B/U, RG-188A/U, RG-196A/U, RG-213 Type, RG-214 Type, RG-217/U, RG-223/U, RG-316/U Coaxial Cables
Center Conductor
Dielectric
Jacket
Shield Material,
Part No.
Coverage
Material
Dia., In. (mm)
9178B
30 (0.05)
7/38 (7 x 0.10)
SCW
PTFE
0.034 (0.86)
SPC Braid, 94%
Natural Tan FEP
0.071 (1.80)
9196A
30 (0.05)
7/38 (7 x 0.10)
SCW
PTFE
0.034 (0.86)
SPC Braid, 94%
Natural PTFE Tape
0.075 (1.91)
9174
26 (0.14)
7/34 (7 x 0.16)
BCW
PE
0.060 (1.52)
TC Braid, 85%
Black or Red
Type I PVC
0.102 (2.59)
9188A
25 (0.16)
7/0.0067
(7 x 0.17)
SCW
PTFE
0.060 (1.52)
SPC Braid, 94%
White PTFE Tape
0.105 (2.67)
9316
25 (0.16)
7/0.0067
(7 x 0.17)
SCW
PTFE
0.060 (1.52)
SPC Braid, 94%
Natural Tan FEP
0.098 (2.49)
9223
19 (0.62)
Solid
SPC
PE
0.116 (2.95)
Dbl SPC Braid,
95%
Black Type IIA PVC
0.212 (5.38)
M4251
19 (0.69)
Solid
SCW
PTFE
0.116 (2.95)
Dbl SPC Braid,
95%
Natural Tan FEP
0.195 (4.95)
9213
13 (3.11)
7/0.0296
(7 x 0.75)
BC
PE
0.285 (7.24)
BC Braid, 96%
Black Type IIA PVC
0.405 (10.29)
9214
13 (3.11)
7/0.0296
(7 x 0.75)
SPC
PE
0.285 (7.34)
Dbl SPC Braid,
95%
Black Type IIA PVC
0.425 (10.80)
9217
10 (5.70)
Solid
BC
PE
0.370 (9.40)
Dbl BC Braid, 95% Black Type IIA PVC
0.545 (13.84)
242
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9178B
50
70
29.3 (96.1)
MIL-DTL-17/RG-178B/U
A, B, D, G
9196A
50
70
29.3 (96.1)
MIL-DTL-17/RG-196A/U
A, B, D, G
9174
50
66
30.8 (101.1)
UL AWM 1354
MIL-DTL-17D/119F RG-174/U
A, B, D
9188A
50
70
29.3 (96.1)
MIL-DTL-17/69B RG-188A/U
A, B, D, G
9316
50
70
29.3 (96.1)
AWM 1971
CSA CMX FT4
MIL-DTL-17 M17/113 RG-316
A, B, D, G
9223
50
66
30.8 (101.1)
MIL-DTL-17D/84B RG-223/U
A, B, D
M4251
50
70
29 (95.1)
MIL-DTL-17/RG-142B/U
A, B, D, G
9213
50
66
30.8 (101.1)
MIL-DTL-17/74A RG-213 Type
A, B, D
9214
50
66
30.8 (101.1)
AWM 1354
MIL-DTL-17/75D RG-214/U
A, B, D, G
9217
50
66
30.8 (101.1)
MIL-DTL-17D/78A RG-217/U
A, B, D, G
243
Part No.
93-Ohm Coaxial Cables
RG-62A/U, RG-22B/U Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
Material
Dia., In. (mm)
Jacket
Material
Dia., In. (mm)
9062A
22 (0.32)
Solid
BCW
Semisolid PE
0.146 (3.71)
BC Braid, 95%
Black Type IIA PVC
0.242 (6.15)
9062AC
22 (0.32)
Solid
BCW
Semisolid PE
0.146 (3.71)
BC Braid, 95%
Black Type IIA PVC*
0.242 (6.15)
M4276
22 (0.32)
Solid
BCW
Semisolid PE
0.146 (3.71)
BC Braid, 95%
Black Type IIA PVC
0.239 (6.07)
M44276
22 (0.32)
Solid
BCW
Semisolid FEP
0.142 (3.61)
BC Braid, 94%
White Plenum PVC
0.202 (5.13)
M44276F
22 (0.32)
Solid
BCW
Foam FEP
0.146 (3.71)
BC Braid, 94%
White Plenum PVC
0.204 (5.18)
*Also available in white, green, blue, orange, yellow, and slate.
Part No.
95-Ohm Coaxial Cables
RG-180B/U Coaxial, RG-22B/U Twinax Cables
Center Conductor
Dielectric
Shield Material,
Coverage
Material
Dia., In. (mm)
9180B
30 (0.05)
7/38
(7 x 0.10)
M4203
18 (0.87)
7/0.0152
(7 x 0.39)
Jacket
Material
Dia., In. (mm)
SCW
PTFE
0.102 (2.59)
SPC Braid, 91%
Natural Tan FEP
0.141 (3.58)
BC*
PE
0.090 (2.85)
Dbl TC Braid,
95%
Black Type IIA PVC
0.420 (10.67)
*For identification, one conductor includes a single tinned copper strand.
244
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9062A
93
83
13.2 (43.3)
UL AWM 1478
MIL-DTL-17/30B RG-62A/U
A, B, D, E, F
9062AC
93
83
13.5 (44.3)
M4276
93
84
13.5 (44.3)
M44276
93
85
12.8 (42)
M44276F
93
85
12.5 (41)
UL AWM 1478
UL CL2
CSA CMH
UL AWM 1478
UL CL2
UL CM
CSA CM
MIL-DTL-17/RG-62A/U Type
UL CMP
CSA CMP
UL CMP
CSA CMP
MIL-DTL-17/RG-62U Type
A, B, D, E, F
A, B, D, G
A, B, D, G
A, B, D, G
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9180B
95
70
15.4 (50.5)
MIL-DTL-17/RG-180B/U
A, B, D, G
M4203
95
66
16 (52.5)
UL AWM 2498
MIL-DTL-17/RG-22B/U Type
A, B, D, G
245
Part No.
Twinax Cables
78-Ohm Twinax Cables
Dielectric
Center Conductor
Jacket
Material
Dia., In. (mm)
Shield Material,
Coverage
Material
Dia., In. (mm)
9888C
22 (0.35)
7/30
(7 x 0.25)
TC
White and Blue
HDPE
0.056 (1.42)
TC Braid, 85%
Apple Smoke Slate
PVC
0.184 (4.67)
9108
20 (0.56)
7/28
(7 x 0.32)
TC
Blue and Clear
FEP
0.074 (1.88)
TC Braid, 95%
Blue FEP
0.198 (5.03)
M4154
20 (0.56)
7/28
(7 x 0.32)
TC
Blue and Clear
PE
0.076 (1.93)
A/P Tape
TC Braid, 55%
Blue PVC
0.238 (6.05)
M4220
20 (0.56)
7/28
(7 x 0.32)
TC*
Natural PE
0.079 (2.01)
TC Braid, 85%
Black Type II PVC
0.235 (5.97)
*For identification, one conductor includes a bare copper strand Type IIA.
Part No.
Twinax Cables
100-Ohm Twinax Cables
Dielectric
Center Conductor
Jacket
Material
Dia., In. (mm)
Shield Material,
Coverage
BC
TC
FEP
0.072 (1.83)
TC Braid, 95%
Slate PVDF
0.252 (6.40)
AWG (mm ) Stranding (mm) Material
2
Material
Dia., In. (mm)
9109
20 (0.56)
7/28
(7 x 0.32)
9817
20 (0.56)
7/28
(7 x 0.32)
BC
TC
PE
0.083 (2.11)
TC Braid, 85%
Black PVC
0.330 (8.38)
M4271
20 (0.56)
7/28
(7 x 0.32)
BC
TC
PE
0.083 (2.11)
A/P/A Tape
TC Braid, 85%
Black PVC
0.330 (8.38)
Part No.
Twinax Cables
124- and 150-Ohm Twinax Cables
Dielectric
Center Conductor
Jacket
Material
Dia., In. (mm)
Shield Material,
Coverage
Material
Dia., In. (mm)
9823
22 (0.38)
19/34
(19 x 0.16)
TC
Black and Yellow
Foam PE
0.120 (3.05)
A/P/A Tape
Black PVC
0.329 (8.36)
M4158
16 (1.31)
Solid
BC
Blue and Clear
Foam PE
0.161 (4.09)
A/P/A Tape
TC Braid, 90%
Black PVC
0.440 (11.18)
246
Alpha Wire | www.alphawire.com | 1-800-52 ALPHA
Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
Twinax Cables
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9888C
78
66
19.7 (64.6)
UL AWM 2726
UL CM
CSA CMG FT4
D, E
9108
78
69.5
18.4 (60.4)
UL CMP
CSA CMP
B, D
M4154
78
66
19.7 (64.6)
UL AWM 2464
UL CM
CSA CM
A, B, D, G
M4220
78
66
19.7 (64.6)
MIL-DTL-17/RG-108 Type
A, B, D, G
Twinax Cables
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9109
100
69
13.3 (43.6)
UL CMP
UL CL2P
CSA CMP
D
9817
100
66
14.5 (47.6)
UL AWM 2498
A, B, D
M4271
100
66
14.5 (47.6)
UL CMG
UL CL2
CSA CMG
A, B, D, G
Twinax Cables
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9823
150
78
8.8 (28.9)
UL AWM 2668
A, B, D, G
M4158
124
78
10.9 (35.8)
UL AWM 2448
UL CMX
CSA CMX
A, B, D, G
247
Part No.
Center Conductor
Miniature Coaxial Cables
Dielectric
Shield Material,
Coverage
Jacket
Material
Dia., In. (mm)
M4243
30 (0.05)
7/38
(7 x 0.10)
M4242
28 (0.08)
Solid
TC
PP
0.023 (0.58)
TC Braid, 90%
Black PVC
0.054 (1.37)
M4244
27 (0.11)
7/35
(7 x 0.142)
BCW
PE
0.100 (2.54)
TC Braid, 93%
Black PVC
0.150 (3.81)
248
TC
Foam
HDPE
0.058 (1.47)
TC Braid, 89%
Black PVC
0.097 (2.46)
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
M4243
75
78
17.3 (56.8)
UL AWM 1375
A, B, D, G
M4242
32
66
55.2 (181.1)
UL CMH
CSA CMH
A, B, D, G
M4244
75
66
20.5 (67.3)
UL AWM 1354
A, B, D, G
249
Part No.
75-Ohm Video Cable
RG-59/U, RG-59B/U Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
Jacket
Material
Dia., In. (mm)
9059B
23 (0.26)
Solid
BCW
PE
0.146 (3.71)
BC Braid, 94%
Black Type IIA PVC
0.242 (6.15)
9159
23 (0.26)
Solid
BCW
FEP
0.132 (3.35)
BC Braid, 95%
Black PVDF
0.190 (4.83)
9810
23 (0.26)
Solid
BC
PE
0.146 (3.71)
A/P/A Tape
TC Braid, 95%
Black Type IIIA PE
0.220 (5.59)
M4223
23 (0.26)
Solid
BCW
PE
0.146 (3.71)
BC Braid, 94%
Black Type IIA PVC
0.241 (6.12)
9059
22 (0.32)
Solid
BCW
PE
0.146 (3.71)
BC Braid, 95%
Black, White, Slate
Type I PVC
0.242 (6.15)
9059C
22 (0.32)
Solid
BCW
PE
0.146 (3.71)
BC Braid, 95%
Black, Red,
Blue, Green, Slate
Type I PVC
0.242 (6.15)
9830
22 (0.32)
Solid
BCW
PE
0.146 (3.71)
BC Braid, 85%
Black Type I PVC
0.242 (6.15)
M4212
22 (0.32)
Solid
BCW
Foam
PE
0.146 (3.71)
BC Braid, 85%
Black Type I PVC
0.242 (6.15)
M4237
22 (0.35)
7/30
(7 x 0.25)
BC
Foam
PE
0.146 (3.71)
BC Braid, 95%
Black Type I PVC
0.240 (6.10)
M44212F
20 (0.52)
Solid
BCW
Foam
FEP
0.140 (3.56)
A/P/A Tape
TC Braid, 94%
White Plenum PVC
0.202 (5.13)
9102
20 (0.52)
Solid
BCW
Foam
FEP
0.140 (3.56)
A/P/A Tape
TC Braid, 94%
Black PVDF
0.212 (5.38)
250
75-Ohm Video Cable
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
9059B
75
66
20.5 (67.3)
9159
75
69.5
19.5 (64)
9810
75
66
21 (68.9)
MIL-DTL-17/RG-59/U Type
A, D
M4223
75
66
20.5 (67.3)
UL AWM 1354
UL CMX
CSA CMX
MIL-DTL-17D/29B RG-59B/U
A, B, D
9059
73
66
21 (68.9)
UL AWM 1354
JAN-C-17A/RG-59/U
A, B, D
9059C
73
66
21 (68.9)
9830
75
66
21.5 (70.5)
M4212
80
78
16.3 (53.5)
M4237
75
78
17.3 (56.8)
M44212F
75
82
16.5 (54.1)
9102
75
82
16.5 (54.1)
Specifications
UL CL2X
CSA CMH FT1
UL CL2P
UL CMP
CSA CMP FT6
MIL-DTL-17/RG-59B/U Type
UL AWM 1354
UL CL2
CSA CMG FT4
JAN-C-17A /RG-59/U
UL AWM 1354
UL CMX
CSA CMX
JAN-C-17A/RG-59/U
UL AWM 1354
UL CM
CSA CM
JAN-C-17A/RG-59/U
UL AWM 1354
UL CM
CSA CM
UL CMP
UL CATVP
CSA CMP FT6
UL CMP
UL CL2P
CSA CMP FT6
MIL-DTL-17/RG-59U Type
Availability
A, B, C, D, E
D
A, B, C, D, E
A, B, D
A, B, D
A, B, D
A, B, D, G
B, D
251
Part No.
Center Conductor
75-Ohm Video Cable
RG-6U Type, RG-6A/U Type
Dielectric
Shield Material,
Coverage
Jacket
Material
Dia., In. (mm)
M4204
21 (0.41)
Solid
BCW
PE
0.185 (4.70)
Dbl BC Braid, 95%
Black PE
0.332 (8.43)
9104
18 (0.82)
Solid
BCW
Foam
FEP
0.170 (4.32)
A/P Tape
TC Braid, 95%
Black PVDF
0.232 (5.89)
M4182
18 (0.82)
Solid
BC
Foam
PE
0.180 (4.57)
A/P/A Tape
TC Braid, 60%
Black Type I PVC
0.270 (6.86)
Part No.
75-Ohm Video Cable
RG-11/U, RG-11/U Type, RG-11A/U
Center Conductor
Dielectric
Shield Material,
Coverage
Jacket
Material
Dia., In. (mm)
9011A
18 (0.89)
7/26
(7 x 0.40)
TC
PE
0.285 (7.24)
BC Braid, 95%
Black Type IIA PVC
0.405 (10.29)
M4207
18 (0.89)
7/26
(7 x 0.40)
TC
PE
0.285 (7.24)
BC Braid, 95%
Black Type I PVC
0.405 (10.29)
9105
14 (2.08)
Solid
BC
Foam
FEP
0.274 (6.96)
A/P/A Tape
TC Braid, 60%
Black FEP
0.346 (8.79)
M4208
14 (2.08)
Solid
BC
Foam
PE
0.285 (7.24)
BC Braid, 95%
Black PE
0.405 (10.29)
252
75-Ohm Video Cable
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
M4204
75
66
20.5 (67.3)
MIL-DTL-17/RG-6A/U Type
9104
75
82
16.5 (54.1)
M4182
75
82
16.2 (53.1)
UL CMP
UL CATVP
CSA CMP FT6
MIL-DTL-17/RG-6U Type
UL AWM 1354
UL CM
CSA CM
MIL-DTL-17/ RG 6/U Type
Availability
B, D
A, B, D
75-Ohm Video Cable
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
9011A
75
66
20.5 (67.3)
M4207
75
66
20.5 (67.3)
9105
75
83
16.3 (53.5)
M4208
75
84
16.1 (52.8)
Specifications
UL CL2X
CSA CMH FT1
MIL-DTL-17D/6B RG 11A/U
UL CM
CSA CM
JAN-C-17A/ RG 11/U
UL CMP
UL CL2P
UL CATVP
CSA CMP FT6
MIL-DTL-17/RG-11/U Type
MIL-DTL-17/RG-11A/U Type
Availability
A, B, D
A, B, D
B, D
A, B, D
253
Part No.
75-Ohm Video Cables
RG-179B/U and RG-187A/U Coaxial Cables
Center Conductor
Dielectric
Shield Material,
Coverage
9179B
30 (0.05)
7/38
(7 x 0.10)
9187A
30 (0.05)
7/38
(7 x 0.10)
Jacket
Material
Dia., In. (mm)
SCW
PTFE
0.063 (1.60)
SPC Braid, 93%
Natural Tan FEP
0.100 (2.54)
SCW
PTFE
0.063 (1.60)
SPC Braid, 93%
Natural PTFE Tape
0.105 (2.67)
Ethernet Transceiver Cables
Pairs
Part No.
9852C
9853C
9854C
Type
AWG (mm2)
Stranding (mm)
Material
Material
Dia., In. (mm)
Data (3)
22 (0.35)
7/30 (7 x 0.25)
TC
Foam HDPE
0.064 (1.63)
Power (1)
20 (0.56)
7/28 (7 x 0.32)
TC
SR-PVC
0.058 (1.47)
Data (3)
20 (0.56)
7/28 (7 x 0.32)
TC
Foam HDPE
0.077 (1.96)
Power (1)
20 (0.56)
7/28 (7 x 0.32)
TC
SR-PVC
0.058 (1.47)
Data (3)
28 (0.08)
7/36 (7 x 0.12)
TC
PP
0.033 (0.84)
Power (1)
24 (0.23)
7/32 (7 x 0.20)
TC
SR-PVC
0.044 (1.12)
Key to Abbreviations
A/P
A/P/A
BC
BCW
FEP
HDPE
PE
PP
PTFE
PVC
PVDF
SCW
SPC
SR-PVC
TC
254
Dielectric
Shield Material,
Coverage
A/P (pairs)
A/P/A (overall)
TC Braid, 95%
A/P (pairs)
A/P (overall)
TC Braid, 95%
A/P (pairs)
A/P/A (overall)
TC Braid, 90%
Color Coding
Aluminum/polyester
Aluminum/polyester/aluminum
Bare copper
Bare copper-coated steel
Fluorinated ethylene propylene
High-density polyethylene
Polyethylene
Polypropylene
Polytetrafluoroethylene
Polyvinyl chloride
Polyvinylidene fluoride
Silver-coated, copper-coated steel
Silver-plated copper
Semirigid PVC
Tinned copper
Conductor
Data 1
Data 2
Data 3
Power
Color Code
9852C,
9854C
9853C
Green-Blue
White-Gray
YellowYellowOrange
Orange
WhiteGreen-Blue
Brown
Blue-Red
Black-Red
75-Ohm Video Cables
Part No.
Nom.
Impedance (Ω)
Vp (%)
Capacitance,
pF/ft (pF/m)
Specifications
Availability
9179B
75
70
19.5 (64)
MIL-DTL-17/RG-179B/U
A, B, D, G
9187A
75
70
19.5 (64)
MIL-DTL-17/RG-187A/U
A, B, D, G
Part No.
Jacket
Electrical Characteristics—Data Pairs
Nom. Impedance
Capacitance, pF/ft
Vp (%)
(Ω)
(pF/m)
Specifications
Availability
16.7 (54.8)
UL AWM 2919
UL CM
CSA CMG FT4
D
78
16.7 (54.8)
UL CM
CSA CMG FT4
D
66
19.7 (64.6)
UL AWM 2919
UL CM
CSA CMG FT4
D
Material
Dia., In. (mm)
9852C
Slate PVC
0.375 (9.53)
78
78
9853C
Slate PVC
0.401(10.19)
78
9854C
Slate PVC
0.250 (6.35)
78
255
Cable > Manhattan > High Temperature Wire > Multiconductor > Braid Shield > 600 V
Manhattan™ High-Temperature Wire and Cable
600 V, Multiconductor, PTFE, PTFE, Braid Shield
High Temperature
24 AWG (0.24 mm2)
Stranding: 19/36 (19 x 0.13 mm)
Insulation thickness: 0.009 (0.24 mm)
NEMA WC27500 Type RC
SAE AS22759/11
Part No.
Conductors
24RC2S06
24RC3S06
24RC4S06
2
3
4
Stranding: 19/34 (19 x 0.16 mm)
• -55°C to +200°C
• Per SAE AS22759/11
Materials
• S
tranded silver-plated
conductors
• PTFE insulation
• Silver-plated braid shield,
85% coverage
• Natural PTFE jacket
Availability
100 ft (30.5 m)
Bulk, cut to length
Spools may contain
multiple lengths
Part No.
Conductors
22RC2S06
22RC3S06
22RC4S06
2
3
4
Nominal Diameter
Inch
mm
0.136
3.45
0.143
3.63
0.156
3.96
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
20 AWG (0.61 mm2)
Stranding: 19/32 (19 x 0.20 mm)
Insulation thickness: 0.010 (0.25 mm)
Part No.
Conductors
20RC2S06
20RC3S06
20RC4S06
2
3
4
Nominal Diameter
Inch
mm
0.154
3.91
0.163
4.14
0.184
4.67
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
18 AWG (0.96 mm2)
(Minimums may apply)
256
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
22 AWG (0.38 mm2)
Operating Temperature
Conductor Color Coding
Nominal Diameter
Inch
mm
0.124
3.15
0.130
3.30
0.142
3.61
Stranding: 19/30 (19 x 0.25 mm)
Insulation thickness: 0.011 (0.28 mm)
Part No.
Conductors
18RC2S06
2
Nominal Diameter
Inch
mm
0.180
4.57
Jacket Thickness
Inch
mm
0.010
0.25
600 V, Multiconductor, ETFE, ETFE, Braid Shield
High Temperature
24 AWG (0.24 mm2)
Part No.
Conductors
275002402
2
NEMA WC27500 Type TE
SAE AS22759/16
• -55°C to +150°C
• Per SAE AS22759/16
Nominal Diameter
Inch
mm
0.132
3.35
Jacket Thickness
Inch
mm
0.010
0.25
22 AWG (0.38 mm2)
Part No.
Conductors
275002201
275002202
275002203
275002204
1
2
3
4
Nominal Diameter
Inch
mm
0.088
2.24
0.146
3.71
0.154
3.91
0.168
4.27
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
Materials
• S
conductors
• ETFE insulation
• Tinned copper braid shield,
85% coverage
• Natural ETFE jacket
Availability
100 ft (30.5 m)
Bulk, cut to length
Spools may contain
multiple lengths
20 AWG (0.61 mm2)
Part No.
Conductors
275002001
275002002
275002003
275002004
1
2
3
4
Nominal Diameter
Inch
mm
0.096
2.44
0.162
4.11
0.171
4.34
0.187
4.75
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
0.010
0.25
0.010
0.25
18 AWG (0.96 mm2)
Insulation thickness: 0.012 (0.30 mm)
Part No.
Conductors
275001801
275001802
1
2
Nominal Diameter
Inch
mm
0.107
2.72
0.182
4.62
Jacket Thickness
Inch
mm
0.010
0.25
0.010
0.25
257
NEMA HP3-EXBEE
26 AWG (0.14 mm2)
Stranding: 7/34 (7 x 0.16 mm)
MIL-W-16878/4 (Type E)
NEMA HP3
Part No.
Conductors
M1201
M1202
M1203
M1204
1
2
3
4
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
NEMA HP3-EXBEE
24 AWG (0.24 mm2)
• -55°C to +200°C
• Chart P (page 535)
Materials
• Silver-plated copper conductors
• PTFE insulation
braid shield, 85% coverage
• White PTFE jacket
Part No.
Conductors
M1211
M1212
M1213
M1214
1
2
3
4
Nominal Diameter
Inch
mm
0.087
2.21
0.136
3.45
0.143
3.63
0.155
3.94
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
NEMA HP3-EXBFE
22 AWG (0.38 mm2)
Insulation thickness: 0.009 (0.23 mm)
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Spools may contain
multiple lengths
Nominal Diameter
Inch
mm
0.081
2.06
0.124
3.15
0.130
3.30
0.140
3.56
Part No.
Conductors
M1221
M1222
M1223
M1224
1
2
3
4
Nominal Diameter
Inch
mm
0.092
2.34
0.146
3.71
0.154
3.91
0.167
4.24
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
NEMA HP3-EXBGE
20 AWG (0.61 mm2)
Part No.
Conductors
M1231
M1232
M1233*
M1234
1
2
3
4
Nominal Diameter
Inch
mm
0.100
2.54
0.158
4.01
0.171
4.34
0.186
4.72
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.010
0.25
0.012
0.30
*NEMA HP3-EXBJE.
258
NEMA HP3-EXBHE
18 AWG (0.96 mm2)
MIL-W-16878/14 (Type E)
NEMA HP3
• -55°C to +200°C
Part No.
Conductors
M1241*
M1242
M1243
M1244
1
2
3
4
Materials
• PTFE insulation
• White PTFE jacket
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
*NEMA HP3-EXBGE.
NEMA HP3-EXBJE
16 AWG (1.23 mm2)
Stranding: 19/29 (19 x 0.29 mm)
Nominal Diameter
Inch
mm
0.112
2.84
0.186
4.72
0.197
5.00
0.215
5.46
Part No.
Conductors
M1251
M1252
M1253
M1254
1
2
3
4
Nominal Diameter
Inch
mm
0.122
3.10
0.206
5.23
0.219
5.56
0.240
6.10
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
0.012
0.30
0.012
0.30
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
259
600 V, Multiconductor, PTFE, FEP, Braid Shield
24 AWG (0.24 mm2)
Insulation thickness: 0.0095 (0.24 mm)
Part No.
Conductors
72402
2
Components
• -55°C to +200°C
Nominal Diameter
Inch
mm
0.136
3.45
Jacket Thickness
Inch
mm
0.012
0.30
22 AWG (0.38 mm2)
Part No.
Conductors
72203
3
Nominal Diameter
Inch
mm
0.154
3.91
Jacket Thickness
Inch
mm
0.012
0.30
20 AWG (0.61 mm2)
Materials
• PTFE insulation
• Silver-plated copper braid
• White FEP jacket
Part No.
Conductors
72001
1
Jacket Thickness
Inch
mm
0.010
0.25
18 AWG (0.96 mm2)
Availability
100 ft (30.5 m)
500 ft (152 m)
Bulk, cut to length
Spools may contain
multiple lengths
Nominal Diameter
Inch
mm
0.100
2.54
Part No.
Conductors
71801
71802
1
2
Nominal Diameter
Inch
mm
0.112
2.84
0.186
4.72
Jacket Thickness
Inch
mm
0.010
0.25
0.012
0.30
16 AWG (1.23 mm2)
Insulation thickness: 0.012 (0.030 mm)
260
Part No.
Conductors
71602
2
Nominal Diameter
Inch
mm
0.206
5.23
Jacket Thickness
Inch
mm
0.012
0.30
Cable > Manhattan > Cordsets > 125/250 V
Manhattan™ Cordsets
125 and 250 V M.A.P. Multiple Application Power Cords
Twin-End Jumper and Power Cords
NEMA 5-15P
Connector
IEC C-13 Connector
SJT
UL Standard 817
CSA C22.2 No. 21
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black PVC jacket
• -20°C to +60°C
IEC C-14 Connector
IEC C-13 Connector
Availability
25-piece packages
• Black, white, green (NEC)
6-ft (1.8 m) Overall Length; Individual Leg Length Is 2 ft (0.6 m)
Part No.
Wire Size
Stranding
AWG
mm
Jumper
Power
AWG
mm2
468
472
18
0.82
41/34
41 x 0.16
470
474
16
1.32
65/34
65 x 0.16
Nominal Diameter
Inch
mm
0.300
7.62
0.325
8.26
Watts
1250
3250
Power Rating
Amps
10
13
Volts
125
250
261
Cable > Manhattan > Cordsets > 125 V
Manhattan™ Cordsets
125 V Power Cords
3-Conductor
NEMA 5-15P
Connector
SJ, SJT, SVT
UL 62 and 817
CSA C22.2 No. 21 and 49
Materials
• -20°C to +60°C
• B
lack, white, green or
green/yellow (NEC)
• Blue, brown, green/yellow (ICC)
• S
tranded bare copper conductors
• PVC or rubber insulation
• Aluminum/polyester foil shield
(where specified)
Foil facing inward
22 AWG (0.35 mm2) tinned
copper drain wire
• Black PVC, rubber, or neoprene
jacket (slate where marked)
Availability
25-piece packages
B suffix = 100-piece packages
PVC Jacket, PVC Insulation, Unshielded, SJT
Leads: Jacket Stripped 1.5” (38 mm). Leads Stripped 5/8” (16 mm)
Part No.
Cord Length
Wire Size
Stranding
AWG
mm
25 pc
100 pc
Ft
m
AWG
mm2
501
501B
6’ 7”
2
18
0.82
41/34
41 x 0.16
502
502B
9’ 10”
3
18
0.82
41/34
41 x 0.16
780*
780B*
6’ 0”
1.8
18
0.81
16/30
16 x 0.25
779*
779B*
8’ 0”
2.4
18
0.81
16/30
16 x 0.25
503
6’ 7”
2
16
1.32
65/34
65 x 0.16
505
505B
6’ 7”
2
14
2.08
41/30
41 x 0.25
506
9’ 10”
3
14
2.08
41/30
41 x 0.25
Nominal Diameter
Inch
mm
0.330
8.38
0.330
8.38
0.330 (0.300)** 8.38 (7.62)**
0.300 (0.330)†
7.62 (8.38)†
0.331
8.41
0.380
9.65
0.380
9.65
Power Rating
Watts Amps
1250
10
1250
10
1250
10
1250
10
1625
13
1875
15
1875
15
Color
Code
ICC
ICC
NEC
NEC
ICC
ICC
ICC
*Slate jacket
**Diameter for part no. 780B
†Diameter for part no. 779B
PVC Jacket, PVC Insulation, Shielded, SVT
Part No.
Cord Length
Wire Size
25 pc
100 pc
Ft
m
AWG
mm2
777*
777B*
6’ 0”
1.8
18
0.82
787*
787B*
8’ 0”
2.4
18
0.82
507F
6’ 7”
2
18
0.82
508F
9’ 10”
3
18
0.82
Stranding
AWG
mm
41/34
41 x 0.16
41/34
41 x 0.16
41/34
41 x 0.16
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.250
6.35
0.250
6.35
0.260
6.60
0.260
6.60
Power Rating
Watts
Amps
1250
10
1250
10
1250
10
1250
10
Color
Code
NEC
NEC
ICC
ICC
*Slate jacket
262
Manhattan™ Cordsets
125 V Power Cords
3-Conductor
NEMA 5-15P
Connector
SJ, SJT, SVT
UL 62 and 817
• -20°C to +60°C
• B
green/yellow (NEC)
Materials
• S
(where specified)
Foil facing inward
copper drain wire
Availability
25-piece packages
Rubber Jacket, Rubber Insulation, Unshielded, SJ
Cord Length
Wire Size
Stranding
Part No.
AWG
mm
Ft
m
AWG
mm2
615
6’ 0”
1.8
18
0.81
16/30
16 x 0.25
616
9’ 0”
2.7
18
0.81
16/30
16 x 0.25
778
8’ 0”
2.4
18
0.81
16/30
16 x 0.25
782
12’ 0”
3.7
18
0.81
16/30
16 x 0.25
783
9’ 0”
2.7
16
1.31
26/30
26 x 0.25
784
12’ 0”
3.7
16
1.31
26/30
26 x 0.25
788
9’ 0”
2.7
14
2.08
41/30
41 x 0.25
789
15’ 0”
4.5
14
2.08
41/30
41 x 0.25
Nominal Diameter
Inch
mm
0.320
7.13
0.320
8.13
0.320
8.13
0.320
8.13
0.340
8.64
0.340
8.64
0.380
9.65
0.380
9.65
Power Rating
Watts
Amps
1250
10
1250
10
1250
10
1250
10
1625
13
1625
13
1875
15
1875
15
Color
Code
Neoprene Jacket, Rubber Insulation, Unshielded, SJO
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
781
8’ 0”
2.4
18
0.81
16/30
16 x 0.25
Nominal Diameter
Inch
mm
0.330
8.38
Power Rating
Watts
Amps
1250
10
Color
Code
Rubber Jacket, Rubber Insulation, Unshielded, SV
Cord Length
Wire Size
Stranding
Part No.
AWG
mm
Ft
m
AWG
mm2
775
6’ 0”
1.8
18
0.82
41/34
41 x 0.16
776
8’ 0”
2.4
18
0.82
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.260
6.60
0.260
6.60
Power Rating
Watts
Amps
1250
10
1250
10
Color
Code
NEC
NEC
NEC
NEC
NEC
NEC
NEC
NEC
NEC
NEC
NEC
263
Manhattan™ Cordsets
125 V Electronic Line Cords
3-Conductor
SJT, SVT
UL 62 and 817
IEC C-13 Connector
• A
(where specified)
Foil facing inward
20 AWG (0.56 mm2) tinned copper drain wire
• PVC jacket, black
• -20°C to +60°C
IEC C-13 Right-Angle
Connector
Availability
25-piece packages
Materials
• S
tranded bare copper
conductors
• PVC insulation
PVC, Unshielded, Type SJT
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
511
6’ 7”
2
18
0.82
41/34
41 x 0.16
512
9’ 10”
3
18
0.82
41/34
41 x 0.16
513
6’ 7”
2
16
1.32
65/34
65 x 0.16
514
9’ 10”
3
16
1.32
65/34
65 x 0.16
Nominal Diameter
Inch
mm
0.300
7.62
0.300
7.72
0.331
8.41
0.331
8.41
Power Rating
Watts
Amps
1250
10
1250
10
1625
13
1625
13
PVC, Shielded, Right Angle, Type SJT
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
521F
6’ 7”
2
14
2.08
41/30
41 x 0.25
Nominal Diameter
Inch
mm
0.380
9.65
Power Rating
Watts
Amps
1825
15
PVC, Shielded, Type SVT
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
523
7’ 5”
2.3
18
0.82
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.250
6.35
Power Rating
Watts
Amps
1250
10
264
Manhattan™ Cordsets
125 V Jumper Cords
NEMA and IEC Connectors
IEC C-13 Connector
IEC C-14 Connector
SJ, SJT, SVT, SPT-1
UL 62 and 817
• -20°C to +60°C
Jumper Cords
• A
(where specified)
Foil facing inward
copper drain wire
• Black PVC or rubber jacket
(Part 601B available in white or
slate jacket)
Availability
Materials
25-piece packages
• S
tranded bare copper
conductors
Cord Length
Part No.
Ft
m
551
3’ 3”
1
Wire Size
AWG
mm2
18
0.82
Stranding
AWG
mm
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.300
7.62
Power Rating
Watts
Amps
1250
10
Color
Code
Cord Length
Part No.
Ft
m
560F
3’ 3”
1
Wire Size
AWG
mm2
18
0.82
Stranding
AWG
mm
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.260
6.60
Power Rating
Watts
Amps
1250
10
Color
Code
ICC
ICC
265
Manhattan™ Cordsets
125 V Jumper Cords
NEMA 5-15P
Connector
NEMA 5-15R
Connector
Extension Cords
Rubber, Unshielded, Type SJ
Cord Length
Part No.
Ft
m
633
10’ 0”
3.1
640
15’ 0”
4.6
Wire Size
AWG
mm2
16
1.32
16
1.32
Stranding
AWG
mm
26/30
26 x 0.25
26/30
26 x 0.25
Nominal Diameter
Inch
mm
0.340
8.64
0.340
8.64
Power Rating
Watts
Amps
1625
13
1625
13
Color
Code
NEC
NEC
NEMA 1-15P Connector
Parallel Lamp Cords
PVC, Unshielded, Type SPT-1
Leads: Conductors Split 1” (25.4 mm) and Stripped 5/8” (16 mm)
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
601B*
6’ 0”
1.8
18
0.82
41/34
41 x 0.16
Nominal Dimension
Inch
mm
0.110 x 0.220
2.79 x 5.69
Power Rating
Watts
Amps
1250
10
*100-piece packages.
266
Manhattan™ Cordsets
125 V Detachable Power Supply Cords
3-Conductor
NEMA 5-15P
Connector
IEC C-13 Connector
SJT, SVT
UL 62 and 817
Materials
• -20°C to +60°C
NEMA 5-15P
Connector
Connector
• Black, white, green or
green/yellow (NEC)
• S
tranded bare copper
conductors
• PVC insulation
Foil facing inward
Tinned copper drain wire
(see tables for size)
• Black PVC jacket
Availability
25-piece packages
Unshielded, Straight, Types SVT and SJT
Part No.
Cord Length
Wire Size
25 pc
100 pc
Ft
m
AWG
mm2
545
535
545B
535B
7’ 5”
7’ 5”
2.3
2.3
18
18
0.82
0.82
531
532
533
546
534
531B
532B
534B
6’ 7”
9’ 10”
6’ 7”
7’ 5”
9’ 10”
2
3
2
2.3
3
18
18
16
16
16
0.82
0.82
1.32
1.32
1.32
Shielded, Straight, Types SVT and SJT
Cord Length
Wire Size
Part No.
Ft
m
AWG
mm2
547F
548F
6’ 7”
9’ 10”
2
3
18
18
0.82
0.82
531F
532F
536F
6’ 7”
9’ 10”
9’ 10”
2
3
3
18
18
14
0.82
0.82
2.08
Stranding
AWG
mm
Type SVT
41/34
41 x 0.16
41/34
41 x 0.16
Type SJT
41/34
41 x 0.16
41/34
41 x 0.16
65/34
65 x 0.16
65/34
65 x 0.16
65/34
65 x 0.16
Stranding
AWG
mm
Type SVT
41/34
41 x 0.16
41/34
41 x 0.16
Type SJT
41/34
41 x 0.16
41/34
41 x 0.16
41/30
41 x 0.25
Nominal Diameter
Inch
mm
Drain
Wire*
Power Rating
Watts Amps
Color
Code
0.250
0.250
6.35
6.35
1250
1250
10
10
NEC
NEC
0.330
0.330
0.350
0.350
0.331
8.38
8.38
8.89
8.89
8.41
1250
1250
1625
1625
1625
10
10
13
13
13
NEC
NEC
ICC
ICC
NEC
Power Rating
Watts
Amps
Color
Code
Nominal Diameter
Inch
mm
A
A
0.260
0.260
6.60
6.60
1250
1250
10
10
ICC
ICC
B
B
C
0.317
0.317
0.400
8.05
8.05
10.16
1250
1250
1875
10
10
15
ICC
ICC
ICC
*Drain Wire:
A = 22 AWG (mm2), 7/30 (7 x 0.25 mm) stranding.
B = 18 AWG (0.82 mm2), 41/34 (41 x 0.16 mm) stranding.
C = 14 AWG (2.08 mm2), 41/30 (41 x 0.25 mm) stranding.
267
Manhattan™ Cordsets
3-Conductor
Unshielded, Right Angle, Type SJT
Part No.
Cord Length
25 pc
100 pc
Ft
m
537
537B
6’ 7”
2
538
9’ 10”
3
540
9’ 10”
3
Shielded, Right Angle, Type SVT
Cord Length
Part No.
Ft
m
550F
9’ 10”
3
Wire Size
AWG
mm2
18
0.82
18
0.82
16
1.32
Wire Size
AWG
mm2
18
0.82
Stranding
AWG
mm
41/34
41 x 0.16
41/34
41 x 0.16
65/34
65 x 0.16
Stranding
AWG
mm
41/34
41 x 0.16
Drain
Wire*
A
Nominal Diameter
Inch
mm
0.330
8.38
0.330
8.38
0.331
8.41
Power Rating
Watts
Amps
1250
10
1250
10
1625
13
Color
Code
Nominal Diameter
Inch
mm
0.260
6.60
Power Rating
Watts
Amps
1250
10
Color
Code
ICC
ICC
ICC
ICC
*Drain Wire:
NEMA 5-15P Connector
Unshielded, Straight, Type SVT
Cord Length
Part No.
Ft
m
543*
7’ 5”
2.3
Wire Size
AWG
mm2
18
0.82
Stranding
AWG
mm
41/34
41 x 0.16
Nominal Diameter
Inch
mm
0.240
6.09
Power Rating
Watts
Amps
1250
7
Color
Code
ICC
*Also available with slate jacket.
268
Manhattan™ Cordsets
125 V Medical-Grade Power Supply Cordsets
3-Conductor
SJT
UL 62 and 817
CSA FT2
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black or slate PVC jacket
• -20°C to +60°C
Availability
25-piece packages
Leads: Jacket Stripped 2” (50 mm). Leads Stripped 5/8” (16 mm)
Cord Length
Wire Size
Stranding
Part No.
Ft
m
AWG
mm2
AWG
mm
801
10’ 0”
3.0
18
1.20
43/34
43 x 0.16
802
10’ 0”
3.0
18
1.20
43/34
43 x 0.16
NEMA 5-15P
Connector
Part
No.
820
821
822
830
831
832
Cord Length
Ft
m
10’ 0”
3.0
10’ 0”
3.0
10’ 0”
3.0
10’ 0”
3.0
10’ 0”
3.0
10’ 0”
3.0
Nominal Diameter
Inch
mm
0.31
7.8
0.31
7.8
Power Ratings
Watts
Amps
1250
10
1250
10
Colors
Jacket
Plug
Black
Clear
Slate
Slate
IEC C-13 Connector
Wire Size
AWG
mm2
18
1.20
18
1.20
18
1.20
16
1.50
16
1.50
16
1.50
Stranding
AWG
mm
43/34
43 x 0.16
43/34
43 x 0.16
43/34
43 x 0.16
68/34
68 x 0.16
68/34
68 x 0.16
68/34
68 x 0.16
Nominal Diameter
Inch
mm
0.31
7.8
0.31
7.8
0.31
7.8
0.33
8.5
0.33
8.5
0.33
8.5
Power Ratings
Watts
Amps
1250
10
1250
10
1250
10
1625
13
1625
13
1625
13
Jacket
Black
Slate
Slate
Black
Slate
Slate
Colors
Plug
Clear
Slate
Clear
Clear
Slate
Clear
Recept.
Black
Slate
Clear
Black
Slate
Clear
269
Cable > Manhattan > Cordsets > 250 V
Manhattan™ Cordsets
250 V Internationally Approved Power Supply Cordsets
CE
ENEC-11
T-Mark
JET
UL
CSA
C-Tick
• Blue, brown, yellow/green
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black PVC jacket
Availability
• -15°C to +70°C
25-piece packages
XVI Plug Connector
IEC C-7 Connector
2-Conductor Unshielded. Cordage Type HO3VVH2F2XO.75
Cord Length
Wire Size
Part No.
Ft
m
AWG
mm2
952
5’ 6”
1.7
18
0.75
VIIG Plug Connector
Stranding
AWG
mm
23/32
23 x 0.20
Nominal Diameter
Inch
mm
0.133 x 0.22
4.00 x 5.60
Power Rating
Watts
Amps
625
2.5
IEC C-13 Connector
3-Conductor Unshielded. Cordage Type HO5VVF3G1.00
Ft
8’ 2”
IEC C-13 Connector
m
2.5
AWG
16
mm2
1.00
mm
31 x 0.20
Inch
0.268
mm
6.81
Watts
2500
Amps
2.5
IEC C-14 Connector
3-Conductor Unshielded. Cordage Type HARSJT3X18AWG
Cord Length
Wire Size
Part No.
Ft
m
AWG
mm2
953
8’ 2”
2.5
18
1.00
270
AWG
31/32
Stranding
AWG
mm
56/34
56 x 0.15
Nominal Diameter
Inch
mm
0.314
8.0
Power Rating
Watts
Amps
2500
10
Manhattan™ Cordsets
250 V Power Supply Cords, 3-Conductor
Australia
SAA
Materials
• S
tranded bare copper
conductors
• PVC insulation
• Black PVC jacket
• Cord Type: HO5VVF3G1.00
• -15°C to +70°C
Availability
25-piece packages
SAA 3 Connector
IEC C-13 Connector
Stranding
AWG
Mm
31/32
31 x 0.20
Nominal Diameter
Inch
mm
0.270
6.80
Power Rating
Watts
Amps
2500
10
Leads: Jacket Stripped 30 mm (1.2”). Leads Stripped 6 mm (0.24”)
Cord Length
Wire Size
Stranding
Part No.
AWG
Mm
Ft
m
AWG
mm2
911
8.2
2.5
16
1.00
31/32
31 x 0.20
Nominal Diameter
Inch
mm
0.270
6.80
Power Rating
Watts
Amps
2500
10
Part No.
910
Cord Length
Ft
m
8.2
2.5
Wire Size
AWG
mm2
16
1.00
SAA 3 Connector
271
Cable > Manhattan > Cordsets > 300, 600 V
Manhattan™ Cordsets
300 V and 600 V Conductor Cordage
CPE
SVO, SJOW, SOOW
UL 62
CSA C22.2 No. 49
CSA FT2
• -40°C to +90°C
• S
tranded bare copper
conductors
• Rubber insulation
• Black chlorinated polyethylene
(CPE) jacket
Availability
250 ft (76.2 m)
• Black, white (2 conductors)
(3 conductors)
• Black, white, green, red
(4 conductors)
CPE Jacket, 2-Conductor Cords, Types SVO, SJOW, and SOOW
Wire Size
Stranding
Insulation Thickness
Part No.
AWG
mm2
AWG
Mm
Inch
mm
Type SVO, 300 V
1931
18
0.82
41/34
41 x 0.16
0.017
0.43
Type SJOW, 300 V
1932
18
0.81
16/30
16 x 0.25
0.032
0.81
1933
16
1.32
26/30
26 x 0.25
0.032
0.81
Type SOOW, 600 V
1934
18
0.81
16/30
16 x 0.25
0.031
0.79
1935
16
1.32
26/30
26 x 0.25
0.031
0.79
1936
14
2.08
41/30
41 x 0.25
0.048
1.22
1937
12
3.29
65/30
65 x 0.25
0.050
1.27
CPE Jacket, 3-Conductor Cords, Types SJOW and SOOW
Wire Size
Stranding
Part No.
AWG
mm2
AWG
mm
1932/3
1933/3
18
16
0.81
1.32
16/30
26/30
1934/3
1935/3
1936/3
1937/3
1938/3
18
16
14
12
10
0.81
1.32
1.08
3.29
5.32
16/30
26/30
41/30
65/30
105/30
Inch
mm
Type SJOW, 300 V
16 x 0.25
0.032
0.81
26 x 0.25
0.032
0.81
Type SOOW, 600 V
16 x 0.25
0.031
0.79
26 x 0.25
0.031
0.79
41 x 0.25
0.048
1.22
65 x 0.25
0.050
1.27
105 x 0.25
0.050
1.27
CPE Jacket, 4-Conductor Cords, Type SOOW, 600 V
Wire Size
Stranding
Part No.
AWG
mm
AWG
mm2
1934/4
18
0.81
16/30
16 x 0.25
1935/4
16
1.32
26/30
26 x 0.25
1936/4
14
2.08
41/30
41 x 0.25
1937/4
12
3.29
65/30
65 x 0.25
1938/4
10
5.32
105/30
105 x 0.25
272
Materials
Inch
mm
0.031
0.79
0.031
0.79
0.048
1.22
0.050
1.27
0.050
1.27
Jacket Thickness
Inch
mm
Cable Dimension
Inch
mm
0.034
0.86
0.236
5.99
0.034
0.034
0.86
0.86
0.294
0.320
7.47
8.13
0.065
0.065
0.085
0.100
1.65
1.65
2.16
2.54
0.356
0.382
0.516
0.592
9.04
9.70
13.11
15.04
Jacket Thickness
Inch
mm
Cable Dimension
Inch
mm
0.034
0.034
0.86
0.86
0.330
0.358
7.85
8.64
0.065
0.065
0.085
0.100
0.100
1.65
1.65
2.16
2.54
2.54
0.373
0.401
0.543
0.623
0.642
9.47
10.19
13.79
15.82
16.31
Jacket Thickness
Inch
mm
0.065
1.65
0.065
1.65
0.085
2.16
0.100
2.54
0.100
2.54
Cable Dimension
Inch
mm
0.400
10.16
0.437
11.10
0.589
14.96
0.674
17.12
0.735
18.67
Cable > Manhattan > Cordsets > 300 V
Manhattan™ Cordsets
300 V 3-Conductor Cordage
PVC
SJT, SVT
UL 62
CSA C22.2 No. 49
Materials
• S
tranded bare copper
conductors
• PVC insulation
Foil facing inward
Tinned copper drain wire one
even AWG size smaller than
conductor
• -30°C to +105°C
• B
lack, white, green/yellow
(NEC)
(IEC 60446)
Availability
250 ft (76.2 m)
3-Conductor Cords (Unshielded)
Wire Size
Part No.
AWG
mm2
Stranding
AWG
mm
1952/3T
1953/3T
18
16
0.82
1.32
41/34
65/34
41 x 0.16
65 x 0.16
1951/3T
18
0.82
41/34
41 x 0.16
1941/3*
1942/3*
1943/3*
18
16
14
0.82
1.32
2.08
41/34
65/34
41/30
41 x 0.16
65 x 0.16
41 x 0.25
Inch
mm
Type SJT
0.032
0.81
0.032
0.81
Type SVT
0.016
0.41
Type SJT
0.032
0.81
0.032
0.81
0.032
0.81
Jacket Thickness
Inch
mm
Cable Dimension
Inch
mm
Color
Code
0.032
0.032
0.81
0.81
0.309
0.335
7.85
8.51
NEC
NEC
0.032
0.81
0.241
6.12
NEC
0.032
0.032
0.032
0.81
0.81
0.81
0.310
0.336
0.368
7.87
8.53
9.35
IEC
IEC
IEC
*Black jacket only.
3-Conductor Cords (Foil Shield)
Wire Size
Part No.
AWG
mm2
1941/3F*
1942/3F*
1943/3F*
18
16
14
0.82
1.32
2.08
Stranding
AWG
mm
41/34
65/34
41/30
41 x 0.16
65 x 0.16
41 x 0.25
Inch
mm
Type SJT
0.032
0.81
0.032
0.81
0.032
0.81
Jacket Thickness
Inch
mm
Cable Dimension
Inch
mm
0.032
0.032
0.032
0.314
0.340
0.372
0.81
0.81
0.81
7.98
8.64
9.45
Color
Code
IEC
IEC
IEC
*Black jacket only.
273
Manhattan™ Cordsets
Rubber
SJ, SV
UL 62
CSA C22.2 No. 49
Materials
• -30°C to +90°C
• S
tranded bare copper
conductors
• Rubber insulation
• Black chlorinated
polyethylene jacket
Availability
250 ft (76.2 m)
Wire Size
Part No.
AWG
mm2
Stranding
AWG
mm
1952/3
1953/3
18
16
0.81
1.32
16/30
26/30
16 x 0.25
26 x 0.25
1951/3
18
0.82
41/34
41 x 0.16
274
Inch
mm
Type SJ
0.032
0.81
0.032
0.81
Type SV
0.017
0.43
Jacket Thickness
Inch
mm
Cable Dimension
Inch
mm
0.034
0.034
0.86
0.86
0.309
0.340
7.85
8.64
0.036
0.91
0.256
6.50
Manhattan™ Cordsets
300 V Retractile Communications Cords
UL AWM 2464
Materials
• -20°C to +80°C
• See table
• S
tranded tinned copper
conductors
• Polypropylene insulation
• Black PVC Jacket
Availability
1-piece packages
Unshielded, 1 A
Cord Length: 1 ft (0.30 m) Retracted, 5 ft (1.5 m) Extended
23 AWG (0.27 mm2)
Stranding: 21/36 (21 x 0.13 mm)
Lead length, each end: 12” (304 mm)
Part No.
Conductors
702R
703R
704R
705R
706R
707R
2
3
4
5
6
7
Coil Diameter
Inch
0.688
0.688
0.750
0.875
0.875
0.875
Jacket Diameter
mm
17.48
17.48
19.05
22.23
22.23
22.23
Inch
0.190
0.200
0.220
0.230
0.230
0.250
mm
4.83
5.08
5.59
5.84
5.84
6.35
Unshielded, 1 A
Cord Length: 2 ft (0.61 m) Retracted, 10 ft (3.0 m) Extended
23 AWG (0.27 mm2)
Lead length, each end: 6” (152 mm)
Part No.
Conductors
702/2R
703/2R
704/2R
705/2R
706/2R
707/2R
2
3
4
5
6
7
Coil Diameter
Inch
0.625
0.688
0.688
0.750
0.875
0.875
Jacket Diameter
mm
15.88
17.48
17.48
19.05
22.23
22.23
Inch
0.180
0.190
0.200
0.215
0.230
0.230
mm
4.57
4.83
5.08
5.46
5.84
5.84
Unshielded, 1 A
Cord Length: 3 ft (0.91 m) Retracted, 15 ft (4.5 m) Extended
23 AWG (0.27 mm2)
Part No.
Conductors
704/3R
705/3R
706/3R
707/3R
4
5
6
7
Coil Diameter
Inch
0.688
0.750
0.875
0.875
Jacket Diameter
mm
17.48
19.05
22.23
22.23
Inch
0.200
0.210
0.230
0.230
mm
5.08
5.33
5.84
5.84
275
Manhattan™ Cordsets
UL AWM 2464
Materials
• S
conductors
• Black PVC Jacket
• -20°C to +80°C
Availability
• See table
1-piece packages
Unshielded, 1 A
Cord Length: 4 ft (1.2 m) Retracted, 20 ft (6.1 m) Extended
23 AWG (0.27 mm2)
Part No.
Conductors
703/4R
704/4R
705/4R
706/4R
707/4R
708/4R
710/4R
712/4R
715/4R
3
4
5
6
7
8
10
12
15
Coil Diameter
Inch
0.688
0.688
0.750
0.875
0.875
0.875
0.938
1.000
1.063
Jacket Diameter
mm
17.48
17.48
19.05
22.23
22.23
22.23
23.83
25.40
27.00
Inch
0.190
0.200
0.220
0.230
0.230
0.250
0.280
0.290
0.310
mm
4.83
5.08
5.59
5.84
5.84
6.35
7.11
7.37
7.87
Shielded: Spiral Wrapped Tinned Copper, 1A
23 AWG (0.27 mm2)
Part No.
Conductors
722/2R
723/2R
Coil Diameter
Cord Diameter
mm
5.33
2
Inch
0.750
mm
19.05
Inch
0.210
3
0.750
19.05
0.200
6 Blue
7 Yellow
8 Brown
9 Slate
10 Pink
11 Violet
12 Tan
13 White/Black
14 Red/Black
15 Green/Black
5.08
Shielding
Individual conductors
2 unshielded
1 shielded
1 Black
2 White
3 Red
4 Green
5 Orange
276
Manhattan™ Cordsets
UL AWM 4182, 4194, 4195,
4196, 4197, 4198
Materials
• -20°C to +60°C
• S
conductors
• Rubber insulation
• Black neoprene jacket
Availability
• See table
1-piece packages
Unshielded, 1 A
23 AWG (0.27 mm2)
Part No.
Conductors
680/2
681/2
682/2
683/2
684/2
685/2
2
3
4
5
6
7
Coil Diameter
Inch
0.750
0.813
0.938
1.063
1.125
1.250
mm
19.05
20.65
23.83
27.00
28.58
31.75
Cord Diameter
Inch
mm
0.220
5.59
0.220
5.59
0.250
6.35
0.290
7.37
0.310
7.87
0.320
8.13
AWM
4194
4195
4196
4197
4198
4182
Unshielded, 1 A
23 AWG (0.27 mm2)
Part No.
Conductors
680/4
681/4
682/4
683/4
684/4
685/4
2
3
4
5
6
7
Coil Diameter
Inch
0.743
0.753
0.875
1.008
1.110
1.140
mm
18.87
19.13
22.23
25.60
28.19
28.96
Cord Diameter
Inch
mm
0.215
5.46
0.220
5.59
0.250
6.35
0.285
7.24
0.305
7.75
0.320
8.13
AWM
4194
4195
4196
4197
4198
4182
1 Black
2 White
3 Red
4 Green
5 Blue
6 Yellow
7 Brown
277
Manhattan™ Cordsets
SO, SVO, SJO
UL 62
CSA C22.2 No. 49
Materials
• S
tranded bare copper
conductors
• Rubber insulation
• Black rubber jacket
• -20°C to +90°C
Availability
1-piece packages
• 1 Black, 2 White, 3 Red, 4 Green
Types SV and SJO
18 AWG (0.82 mm2)
Stranding: 41/34 (41 x 0.16 mm)
Insulation thickness: 0.015 (0.38 mm)
Part No.
Conductors
Coil Diameter
Cord Diameter
Inch
mm
Inch
mm
22.73
0.220
5.59
32.08
0.33
9.4
Type SVO
725
2
0.895
Type SJO
727
3
1.263
Type SVO
18 AWG (0.82 mm2)
Part No.
Conductors
760/2
3
Coil Diameter
Inch
1.000
Cord Diameter
mm
25.40
Inch
0.27
mm
7.0
Type SVO
18 AWG (0.82 mm2)
Part No.
Conductors
760/4
3
278
Coil Diameter
Inch
1.000
Cord Diameter
mm
25.40
Inch
0.27
mm
7.0
Cable > Manhattan > Cordsets > 300 V/600 V
Manhattan™ Cordsets
300 V/600 V Retractile Communications Cords
SO, SVO, SJO
UL 62
CSA C22.2 No. 49
Materials
• S
tranded bare copper
conductors
• Rubber insulation
• -20°C to +90°C
Availability
1-piece packages
Type SJO, 300 V
16 AWG (1.31 mm2)
Stranding: 65/34 (65 x 0.16 mm)
Insulation thickness: 0.030 (0.76 mm)
Part No.
Conductors
665/4
3
Coil Diameter
Inch
1.335
Cord Diameter
mm
33.91
Inch
0.385
mm
9.78
Type SO, 600 V
14 AWG (2.08 mm2)
Stranding: 41/30 (41 x 0.25 mm)
Part No.
Conductors
674/2
4
Coil Diameter
Inch
2.055
Cord Diameter
mm
52.20
Inch
0.610
mm
15.49
Type SO, 600 V
14 AWG (2.08 mm2)
Part No.
Conductors
674/4
4
Coil Diameter
Inch
2.055
Cord Diameter
mm
52.20
Inch
0.610
mm
15.49
279
Manhattan™ Cordsets
300 V Retractile Power Cords
NEMA 5-15 Connector
SVO, SJO
UL 62 and 817
Materials
• S
tranded bare copper
conductors
• Rubber insulation
• Molded NEMA 5-15P male plug,
one end
• 1 Black, 2 White, 3 Green or
Green/Yellow
Availability
• -20°C to +60°C
1-piece packages
Types SVO and SJO
18 AWG (0.82 mm2)
Jacket stripped 1.5” (38.1 mm); insulation stripped 0.5” (12.7 mm)
Part No.
Conductors
654
2
Coil Diameter
Inch
mm
Cord Diameter
Inch
mm
Power Rating
Watts
Amps
Type SVO
0.875
22.23
0.240
6.10
1250
10
0.330
8.38
1250
10
Type SJO
656
3
1.375
34.93
Type SJO
16 AWG (1.31 mm2)
Part No.
Conductors
659
3
280
Coil Diameter
Inch
mm
1.333
33.86
Cord Diameter
Inch
mm
0.350
8.89
Power Rating
Watts
Amps
1625
13
Cable > Manhattan > Cordsets > 30 V
Manhattan™ Cordsets
30 V Miniature Retractile Communications Cords
UL AWM 20013
• -20°C to +60°C
Materials
• S
conductors
• PVC insulation
• Black PVC Jacket
Availability
1-piece packages
Cord length: 2 ft (0.61 m) retracted, 10 ft (3.0 m) extended
28 AWG (0.09 mm2)
Part No.
Conductors
651
652
2
4
Stranding: 19/40 (19 x 0.08 mm)
Lead length, each end: 6 (152 mm)
Coil Diameter
Inch
mm
0.471
11.96
0.592
15.04
Cord Diameter
Inch
0.135
0.150
mm
3.43
3.81
281
Cable > Manhattan > Cordsets > 5000 V
Manhattan™ Cordsets
5000 V Retractile Test Lead Wire
Materials
• -30°C to +60°C
• S
conductors
• Rubber insulation
• Black jacket
• Black or red
Availability
1-piece packages
20 AWG (0.53 mm2)
Stranding: 41/36 (41 x 0.13 mm)
Insulation thickness: 0.050 (1.52 mm)
Jacket stripped 1.5” (38.1 mm); insulation stripped 0.50” (12.7 mm)
Part No.
Conductors
650*
1
Coil Diameter
Inch
mm
0.580
14.73
Cord Diameter
Inch
mm
0.165
4.19
Power Rating
Watts
Amps
1250
10
*Not UL Listed
282
Cable > Manhattan > Cordsets > 2000 V
Manhattan™ Cordsets
2000 V Portable Power Cable
Type W
ICEA Accepted
NEMA Accepted
Materials
• -30°C to +90°C
• S
tranded bare copper
conductors
• Thermoset insulation
(CPE) jacket
Availability
• See tables
Cut to specific length
1-Conductor Cable
Part No.
7431
7432
7434
7436
7437
7439
Wire Size
AWG
6
4
2
1/0
2/0
4/0
mm2
13.57
21.55
34.45
53.1
67.08
107
Stranding
AWG
133/27
133/25
133/23
259/24
259/23
259/21
mm
133 x 0.36
133 x 0.45
133 x 0.57
259 x 0.51
259 x 0.57
259 x 0.72
Insulation
Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.078
1.98
0.078
1.98
0.078
1.98
Jacket
Thickness
Inch
mm
0.080
2.03
0.080
2.03
0.080
2.03
0.080
2.03
0.080
2.03
0.080
2.03
Nominal
Diameter
Inch
mm
0.510
12.95
0.570
14.48
0.660
16.76
0.770
19.56
0.820
20.83
0.930
23.62
Current-Carrying
Capacity*
Amps
85
110
150
200
235
315
Insulation
Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
Jacket
Thickness
Inch
mm
0.095
2.41
0.095
2.41
0.110
2.79
0.140
3.56
Nominal
Diameter
Inch
mm
0.810
20.57
0.930
23.62
1.080
27.43
1.270
32.26
Current-Carrying
Capacity*
Amps
50
65
90
125
Insulation
Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
Jacket
Thickness
Inch
mm
0.140
3.56
0.140
3.56
0.140
3.56
Nominal
Diameter
Inch
mm
0.910
23.11
1.010
25.65
1.170
29.72
Current-Carrying
Capacity*
Amps
50
65
85
Conductor color coding: black.
*Single conductor at 40°C ambient.
2-Conductor Cable
Part No.
7680
7681
7682
7684
Wire Size
AWG
8
6
4
2
mm2
8.61
13.57
21.55
34.45
Stranding
AWG
133/29
133/27
133/25
133/23
mm
133 x 0.28
133 x 0.36
133 x 0.45
133 x 0.57
Conductor color coding: black, white.
3-Conductor Cable
Part No.
7700
7701
7702
Wire Size
AWG
8
6
4
mm2
8.61
13.57
21.6
Stranding
AWG
133/29
133/27
133/25
mm
133 x 0.28
133 x 0.36
133 x 0.45
Conductor color coding: black, white, green.
283
Manhattan™ Cordsets
Type W
ICEA Accepted
NEMA Accepted
Materials
• -30°C to +90°C
• S
tranded bare copper
conductors
(CPE) jacket
Availability
• See tables
4-Conductor Cable
Part No.
7800
7801
Wire Size
AWG
8
6
Stranding
mm2
8.61
13.57
AWG
133/29
133/27
mm
133 x 0.28
133 x 0.36
Insulation
Thickness
Inch
mm
0.063
1.60
0.063
1.60
Jacket
Thickness
Inch
mm
0.110
2.79
0.110
2.79
Nominal
Diameter
Inch
mm
0.990
25.15
1.010
25.65
Current-Carrying
Capacity*
Amps
40
50
Conductor color coding: black, white, green, red.
4-Conductor Cable with Ground
Part No.
7760
7761
7762
7764
7765
7766
Wire Size
AWG
8
6
4
2
1
1/0
mm2
8.61
13.6
21.6
34.4
42.4
53.0
Stranding
AWG
133/29
133/0.0140
133/0.0177
133/0.0223
133/0.0251
259/24
mm
133 x 0.28
133 x 0.36
133 x 0.45
133 x 0.57
133 x 0.64
259 x 0.51
Insulation
Thickness
Inch
mm
0.063
1.60
0.063
1.60
0.063
1.60
0.063
1.60
0.078
1.98
0.078
1.98
Nominal
Diameter
Inch
mm
0.990
25.15
1.100
27.94
1.270
32.26
1.480
37.59
1.680
42.67
1.790
45.47
Current-Carrying
Capacity*
Amps
55
55
75
100
110
130
Ground Wire**
AWG
12
12
10
9
8
7
mm2
3.08
3.08
5.32
7.00
8.63
10.5
Conductor color coding: black, white, red, orange.
**Ground wire is stranded bare copper with insulation.
284
Manhattan™ Thermocouple Cable
Temperature Measurement
and Control
The measurement of temperature
is one of the most vital functions
in the control of manufacturing
and processing operations. As
demands for greater quality,
reliability, and economy increase,
the demands for more precise
measurement and control increase.
Newer and more sophisticated
electronic circuitry is employed
creating stringent demands
on the wire and cable used to
sense and transmit temperature
measurements. To meet these
ever-increasing demands, Alpha
has a full line of thermocouplegrade wire and thermocouple
extension wire and cable.
The Thermocouple
At the heart of all temperature
measurements is the thermocouple.
Although involving very complex
design parameters, the fundamental
concept of all thermocouples is the
same. Two wires of dissimilar metal
are joined together at one end. An
increase in temperature creates an
electromotive force (EMF) or signal,
which is transmitted through these
wires to a monitoring device which
“reads” this signal and displays it
on a previously calibrated meter or
digital device.
The monitoring device is usually
at a location some distance away
from the actual thermocouple.
To connect the thermocouple
to the monitor requires wire or
cable (for multiple thermocouple
installations) that will maintain the
integrity of the temperature-EMF
Limits of Error for Thermocouple Grade
ANSI Type
Material
J
Iron/Constantan
K
Chromel/Alumel
T
Copper/Constantan
E
Chromel/Constantan
R
Platinum 13% Rhodium/
Platinum
S
Platinum 10% Rhodium/
Platinum
Temperature Range (°C)
0 to 277
277 to 760
0 to 277
277 to 1260
-184 to -101
-101 to -59
-59 to 93
93 to 371
0 to 316
316 to 871
0 to 538
538 to 1482
0 to 538
538 to 1482
signal generated by the primary
wires in the thermocouple.
Conductor Materials
The range and accuracy of
temperature measurement are
dependent on the conductor
materials employed. Pairs of
various metal alloys will react
differently with changes in
temperature.
The following tables give
the temperature range and
tolerances for the most popular
alloy combinations. All Alpha
thermocouple wire and cable
is tested and calibrated to
the standard limits of error as
indicated. Where situations require
closer tolerances, wire and cable
calibrated to the special error limits
is available under special order.
Standard Limits (±)
2.22°C
0.75%
2.22°C
0.75%
2%
0.83°C
0.75%
1.67°C
0.5%
1.39°C
0.25%
1.39°C
0.25%
Special Limits (±)
1.11°C
0.375%
1.11°C
0.375%
1%
1%
0.42°C
0.375%
1.25°C
0.375%
285
Limits of Error for Thermocouple Extension Wire
ANSI Type
Material
JX
Iron/Constantan
KX
Chromel/Alumel
TX
Copper/Constantan
EX
Chromel/Constantan
RSX
Copper/Copper Alloy 11
Insulation and Jacket Material Properties
Temperature (°C)
Material
Continuous Intermittent
PVC
105
FEP
200
TFE Tape
260
Glass Braid
510
650
High-Temp Glass Braid
700
870
-18 to 204
-18 to 204
-59 to 93
-18 to 204
24 to 204
Flame
G
E
E
E
E
Standard Limits (±)
2.22°C
2.22°C
0.83°C
2.22°C
6.67°C
Mechanical
Abrasion
Flexibility
G
G
E
G
E
E
F/G
G
F/G
G
Solvents
F
E
E
E
E
Special Limits (±)
1.11°C
1.11°C
0.42°C
1.11°C
Chemical Resistance
Acids
Bases
G
G
E
E
E
E
E
E
E
E
Moisture
G
E
E
F/G
F/G
E = Excellent, G = Good, F = Fair
ISA/ANSI Thermocouple Color Coding
Positive Wire
ANSI Type
Material
Insul. Color
J, JX
Iron
White
K, KX
Chromel
Yellow
T, TX
Copper
Blue
E, EX
Chromel
Violet
RX, SX
Copper
Black
286
Negative Wire
Material
Constantan
Alumel
Constantan
Constantan
Alloy 11
Insul. Color
Red
Red
Red
Red
Red
Grade
Brown
Brown
Brown
Brown
Jacket Color
Tracer
Black
Yellow
Blue
Violet
Extension
Black
Yellow
Blue
Violet
Green
Cable > Manhattan > Thermocouple Grade Wire
Manhattan™ Thermocouple Grade Wire
ISA MC 96.1
• -20°C to +510°C
• ISA color-coded insulation
and jacket
Materials
• Solid or stranded alloy wire
• Braided fiberglass or
FEP insulation
FEP jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Duplex Parallel: Glass Braid Insulation, Glass Braid Jacket
Conductor Size
Outer Dimension
Part No.
Inch
mm
AWG
mm2
Type J: Iron/Constantan
5769/1
30
0.05
0.030 x 0.048
0.76 x 1.22
5766
24
0.20
0.040 x 0.068
1.02 x 1.73
5767H*
24
0.20
0.064 x 0.102
1.63 x 2.59
5763H*
0.084 x 0.142
2.13 x 3.61
5762S**
0.090 x 0.154
2.29 x 3.91
M9180012
0.060 x 0.106
1.53 x 2.69
Type K: Chromel/Alumel
5776
24
0.20
0.040 x 0.068
1.02 x 1.73
5772S**
0.060 x 0.108
1.53 x 2.74
5773H *
0.084 x 0.142
2.13 x 3.61
M9180013
0.060 x 0.106
1.53 x 2.69
Type T: Copper/Constantan
M9180014
0.060 x 0.106
1.53 x 2.69
*High temperature
**7/28 (7 x 0.32 mm) stranding
Duplex Parallel: FEP Insulation, FEP Jacket
Conductor Size
Outer Dimension
Part No.
Inch
mm
AWG
mm2
M9160012
0.072 x 0.124
1.83 x 3.15
M9160013
0.072 x 0.124
1.83 x 3.15
M9160014
0.072 x 0.124
1.83 x 3.15
287
Cable > Manhattan > Thermocouple Extension Wire > Unshielded
Manhattan™ Thermocouple Extension Wire
Duplex Parallel, Unshielded
Part No.
5716
5710
5724
5724S*
5721
ISA MC 96.1
• -20°C to +105°C
and jacket
Materials
• PVC, glass braid, or
FEP insulation
FEP jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
288
5731
5731S*
5730
5740
Conductor Size
Outer Dimension
Inch
mm
AWG
mm2
Type JX: Iron/Constantan
0.092 x 0.154
2.34 x 3.91
14
2.08
0.124 x 0.218
3.15 x 5.54
Type KX: Chromel/Alumel
0.092 x 0.154
2.34 x 3.91
0.098 x 0.166
2.49 x 4.22
16
1.31
0.111 x 0.192
2.82 x 4.88
Type TX: Copper/Constantan
0.092 x 0.154
2.34 x 3.91
0.098 x 0.166
2.49 x 4.22
16
1.31
0.111 x 0.192
2.82 x 4.88
Type RSX: Copper/Copper Alloy 11
16
1.31
0.111 x 0.192
2.82 x 4.88
Conductor Size
Outer Dimension
Part No.
AWG
mm2
Inch
mm
5714
16
1.31
0.085 x 0.150
2.16 x 3.81
Type SX: Copper/Copper Alloy 11
5741H*
16
1.31
0.085 x 0.150
2.16 x 3.81
*High temperature
Part No.
5715
Conductor Size
Outer Dimension
Inch
mm
AWG
mm2
16
1.31
0.087 x 0.154
2.21 x 3.91
Cable > Manhattan > Thermocouple Extension Wire > Single and Multipair > Unshielded and Foil Shield > 300 V
300 V, Single and Multipair, Unshielded and Foil Shield
ISA MC 96.1
UL PLTC, ITC
• -20°C to +105°C
• -80°C to +200°C (Hightemperature versions)
and jacket
Materials
• Solid alloy wire
• PVC or FEP insulation
• Aluminum/polyester shield,
25% overlap min.
Foil facing inward
• PVC or FEP jacket
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
Unshielded Single Pair, PVC Insulation, PVC Jacket
UL PLTC/ITC, 300 V, 105°C
Conductor Size
Outer Dimension
Part No.
Inch
mm
AWG
mm2
Type EX: Chromel/Constantan
M9000011
0.205
5.21
M9006011
16
1.31
0.235
5.97
M9000012
0.205
5.21
M9006012
16
1.31
0.235
5.97
M9000013
0.205
5.21
M9006013
16
1.31
0.235
5.97
M9000014
0.205
5.21
M9006014
16
1.31
0.235
5.97
Foil Shielded Individual and Overall, Twisted Pairs, PVC Insulation, PVC Jacket
Conductor Size
Outer Dimension
Part No.
Pairs
AWG
mm2
Inch
mm
M9020011
1
0.205
5.21
M9240041
4
0.440
11.18
M9240081
8
0.550
13.97
M9240121
12
0.665
16.89
M9240241
24
0.875
22.23
M9026011
16
1.31
1
0.235
5.97
M9020012
1
0.205
5.21
M9240042
4
0.440
11.18
M9240082
8
0.550
13.97
M9240122
12
0.665
16.89
M9240162
16
0.740
18.80
M9240242
24
0.875
22.23
M9240362
36
1.010
25.65
M9026012
16
1.31
1
0.235
5.97
M9020013
1
0.205
5.21
M9240043
4
0.440
11.18
M9240083
8
0.550
13.97
M9240123
12
0.665
16.89
M9240243
24
0.875
22.23
M9026013
16
1.31
1
0.235
5.97
M9020014
1
0.205
5.21
M9240044
4
0.440
11.18
M9240084
8
0.550
13.97
M9240124
12
0.665
16.89
M9240244
24
0.875
22.23
M9026014
16
1.31
1
0.235
5.97
289
ISA MC 96.1
UL PLTC, ITC
• -20°C to +105°C
and jacket
Materials
• Solid alloy wire
25% overlap min.
Foil facing inward
• PVC or FEP jacket
Foil Shielded Overall, Twisted Pairs, Solid Conductors, PVC Insulation, PVC Jacket
UL PLTC, 300 V, 105°C
Conductor Size
Outer Dimension
Part No.
Pairs
Inch
mm
AWG
mm2
5711/2004
4
0.369
9.37
5711/2008
8
0.480
12.19
5711/2012
12
0.557
14.15
5712/2002
2
0.325
8.26
5712/2004
4
0.369
9.37
5712/2008
8
0.480
12.19
5712/2024
24
0.828
21.03
5712/2036
36
0.956
24.28
5713/2004
4
0.369
9.37
5713/2012
12
0.557
14.15
5713/2024
24
0.828
21.03
5714/1601
16
1.31
2
0.256
6.50
Foil Shielded Twisted Pairs, FEP Insulation, FEP Jacket
High Temperature: -80°C to 200°C
Conductor Size
Part No.
Pairs
AWG
mm2
5717/2001
1
5717/1601
16
1.31
1
5718/2001
1
5718/1601
16
1.31
1
Outer Dimension
Inch
mm
0.150
0.188
3.81
4.78
0.150
0.188
3.81
4.78
Availability
100 ft (30.5 m)
500 ft (152 m)
1000 ft (305 m)
Bulk, cut to length
290
