KSW30B-1000
KSW30B-1000
    JONARDTOOLS
    KSW30B-1000
KSW30B-1000 数据手册
Premier Tool Manufacturer Since 1958 Kynar® Wire | Data Sheet KYNAR® WIRE KYNAR ® Insulated, Silver Plated Copper Conductor Ideally suited for wire wrapping and many other applications. The Kynar insulation provides a flexible yet abrasion resistant wire and the conductor is made from silver plated OFHC (Oxygen Free High Conductivity) copper. WIRE SIZE INSULATION DIA. ROLL SIZE BLUE YELLOW WHITE BLACK RED 30.4 R24B-0100 R24Y-0100 R24W-0100 R24BLK-0100 R24R-0100 100 30.4 R26B-0100 R26Y-0100 R26W-0100 R26BLK-0100 R26R-0100 0.60 100 30.4 R28B-0100 R28Y-0100 R28W-0100 R28BLK-0100 R28R-0100 0.50 100 1000 30.4 304.4 R30B-0100 R30B-1000 R30Y-0100 R30Y-1000 R30W-0100 R30W-1000 R30BLK-0100 R30BLK-1000 R30R-0100 R30R-1000 AWG mm In. mm Feet Meters 24 0.50 .030 0.76 100 26 0.40 .027 0.69 28 0.32 .024 30 0.25 .020 GREEN R30G-0100 R30G-1000 Pre-Cut & Pre-Stripped Wire Wrapping Wire 30 AWG (0.25mm) Pre-Cut/Pre-Stripped Wire 50 Pieces/Pkg. • • • • • • 50 pieces per package Kynar ® insulated Silver plated copper conductor INSULATION LENGTH UL listed 1” of stripped wire on either end Add 2” to the insulation length (see chart below) for total length of wire BLUE YELLOW WHITE RED 25 30-B-50-010 30-Y-50-010 30-W-50-010 30-R-50-010 2 51 30-B-50-020 30-Y-50-020 30-W-50-020 30-R-50-020 3 76 30-B-50-030 30-Y-50-030 30-W-50-030 30-R-50-030 5 127 30-B-50-050 30-Y-50-050 30-W-50-050 30-R-50-050 In. mm 1 Tel 914.793.0700 | Fax 914.793.4527 | jonard.com Premier Tool Manufacturer Since 1958 Kynar® Wire | Data Sheet KSW Wire Wrapping Wire Rolls for Cut/Strip/Wrap Applications Low strip force Kynar ® insulated silver plated copper conductor wire is further processed to provide a low strip force for use with CSW bits and sleeves. Ideally suited for wire wrapping and many other applications. The Kynar insulation provides a flexible yet abrasion resistant wire and the conductor is made from silver plated OFHC (Oxygen Free High Conductivity) copper. WIRE SIZE INSULATION DIA. ROLL SIZE BLUE YELLOW WHITE BLACK RED 30.4 KSW24B-0100 KSW24Y-0100 KSW24W-0100 KSW24BLK-0100 KSW24R-0100 100 30.4 KSW26B-0100 KSW26Y-0100 KSW26W-0100 KSW26BLK-0100 KSW26R-0100 0.60 100 30.4 KSW28B-0100 KSW28Y-0100 KSW28W-0100 KSW28BLK-0100 KSW28R-0100 0.50 100 1000 30.4 304.4 KSW30B-0100 KSW30B-1000 KSW30Y-0100 KSW30Y-1000 KSW30W-0100 KSW30W-1000 KSW30BLK-0100 KSW30BLK-1000 KSW30R-0100 KSW30R-1000 AWG mm In. mm Feet Meters 24 0.50 .030 0.76 100 26 0.40 .027 0.69 28 0.32 .024 30 0.25 .020 Wire Dispenser - WD-30 Series • • • • 50 ft. (15.2m) roll of 30 AWG (0.25mm) Kynar ® wire-wrapping wire Built-in plunger cuts wire to desired length Built-in stripper strips 1” (25.4mm) of insulation Refillable JONARD P/N DESCRIPTION REPLACEMENT ROLL OF WIRE WD-30-B Dispenser with 50’ of Blue wire R-30B-0050 WD-30-Y Dispenser with 50’ of Yellow wire R-30Y-0050 WD-30-W Dispenser with 50’ of White wire R-30W-0050 WD-30-R Dispenser with 50’ of Red wire R-30R-0050 WD-30-TRI Dispenser with 50’ of Blue, White and Red wire R-30-TRI Tel 914.793.0700 | Fax 914.793.4527 | jonard.com GREEN KSW30G-0100 KSW30G-1000 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Jonard Industries: R26R-0100 R28R-0100 R28Y-0100 R26B-0100 R24W-0100 R28B-0100 R28W-0100 R24B-0100 R24Y-0100 R26Y-0100 R24R-0100 R26W-0100 KSW24R-0100 KSW24W-0100 KSW24B-0100 KSW30B-1000 KSW30W-1000 R28BLK-0100 KSW30W-0100 KSW30R-0100 KSW30B-0100 KSW30Y-0100 R30BLK-0100 KSW30BLK-0100 KSW26Y-0100 KSW28Y-0100 KSW28B-0100 KSW26B-0100 KSW28R-0100 KSW26R-0100 KSW24Y-0100 KSW26W-0100 KSW28W-0100 KSW26BLK-0100 R26BLK-0100 R30B-0100 R30R-0100 R30W-0100 R30Y-0100 KSW24BLK-0100 R24BLK-0100 30-W-50-020 30-Y-50-050 30-B-50-020 30-Y-50-010 KSW28BLK-0100 30-B-50010 30-R-50-050 30-R-50-020 30-Y-50-020 30-B-50-050 30-W-50-050 30-B-50-030 30-W-50-010 30-R-50-030 30-R-50-010 30-Y-50-030 30-W-50-030 R30BLK-1000 R-30W-0050 R-30R-0050 WD-30-TRI R30R-1000 R30W1000 R-30Y-0050 R30Y-1000 KSW30R-1000 R-30-TRI R-30B-0050 WD-30-W WD-30-Y WD-30-B WD-30-R KSW30BLK-1000 KSW30Y-1000 R30B-1000 R30G-0100 R30G-1000 KSW30G-0100 KSW30G-1000
KSW30B-1000 价格&库存
很抱歉,暂时无法提供与“KSW30B-1000”相匹配的价格&库存,您可以联系我们找货
