NMN0.50BK100
NMN0.50BK100
    TECHFLEX
NMN0.50BK100 数据手册
ADVANCED ENGINEERING SPECIALTY Technical Data Sheet Technical Data Sheet Put-Ups D  ense, Full Coverage Construction Nominal Size R  esists Gasoline And Engine Chemicals Part # 3/32” NMN0.09BK 1/8” NMN0.13BK 3/16” NMN0.19BK 1/4” NMN0.25BK 5/16” NMN0.31BK 3/8” NMN0.38BK 1/2” NMN0.50BK 5/8” NMN0.63BK 3/4” NMN0.75BK 7/8” NMN0.88BK 1” NMN1.00BK 1 1/4” NMN1.25BK 1 1/2” NMN1.50BK 1 3/4” NMN1.75BK 2” NMN2.00BK 2 1/2” NMN2.50BK 3” NMN3.00BK TIGHT WEAVE 3/8” NMT0.38BK E  conomical And Easy To Install S  oft, Pliable And Quiet C  ut And Abrasion Resistant M  eets Military Specifications A-A-59301 Wall Thickness ±0.015” Bulk Spool Shop Spool 0.020” 0.020” 0.030” 0.030” 0.030” 0.030” 0.030” 0.040” 0.040” 0.040” 0.050” 0.050” 0.060” 0.060” 0.060” 0.060” 0.060” 1,000’ 1,000’ 1,000’ 500’ 500’ 500’ 250’ 250’ 250’ 200’ 200’ 125’ 100’ 100’ 100’ 100’ 100’ 225’ 225’ 200’ 200’ 125’ 125’ 100’ 75’ 75’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 50’ 0.030” 250’ 75’ Full Coverage, Soft, Supple, Strong And Attractive Cut Cleanly Hot Knife Material Polyamide Multifilament Grade NMN Multifilament Thickness N/A Available Colors Black Black Black Black Black Black Black Black Black Black Black Black Black Black Black Black Black Black (BK The wide operating temperature range allows NM to protect delicate wiring in engine compartments and near exhaust systems. NM creates a unique and attractive retro look when installed on a/v cables. www.techflex.com 1.47 Black (BK) NM’s fabric-like softness and flexibility meet surprisingly tough specifications. The high coverage sleeving meets or exceeds military specifications A-A-59301. NM is highly resistant to abrasion, cuts, common automotive and marine chemicals, UV damage and vibration. It will not rot or retain moisture. 1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409 104 Demarest Road • Sparta, NJ 07871 0.29 0.33 0.56 0.79 0.99 1.09 1.74 2.85 3.15 4.35 5.15 5.50 6.46 7.73 9.01 10.32 11.00 Colors Available: Under the hood or across the floor, NM is the perfect sleeving product for protecting and improving the appearance of wires and cables. NM has been used in military wire harness applications for many years. Drawing Number TF001NM-WD (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) (BK) Lbs/ 100’ Nylon Multi’s qualities make it a viable choice for defense and military applications that call for flexibility, strength and full coverage protection. HALOGEN FREE SPECIALTY ADVANCED ENGINEERING Technical Data Sheet Technical Data Sheet Melt Point ABRASION ASTM D-2117 428°F (220°C) Maximum Continuous Abrasion Resistance 248°F (120°C) Abrasion Test Machine Taber 5150 Abrasion Test Wheel Calibrase H-18 Abrasion Test Load 500g Room Temperature 70°F CHEMICAL RESISTANCE 1=No Effect 4=More Affected 2=Little Effect 5=Severely Affected 3=Affected Humidity 58% Much Pulling Of Fibers Very Visible Wear 20 Test Cycles Wear Pattern Continues 400 Test Cycles Wear Pattern Continues 900 Test Cycles Wear Pattern Continues 1,400 Test Cycles Hole Completely Through Material Destroyed 3,200 Test Cycles Pre-Test Weight 11,759.5 mg Post-Test Weight 10,990.2 mg Test End Loss Of Mass Point Of Destruction Aromatic Solvents_________________ 1 Aliphatic Solvents__________________ 1 Chlorinated Solvents_______________ 1 Weak Bases_______________________ 1 Salts_____________________________ 1 Strong Bases______________________ 2 Salt Water 0-S-1926_________________ 1 Hydraulic Fluid MIL-H-5606__________ 1 Lube Oil MIL-L-7808________________ 1 De-Icing Fluid MIL-A-8243___________ 1 Strong Acids______________________ 5 Strong Oxidants___________________ 5 Esters/Ketones____________________ 2 UV Light_________________________ 2 Petroleum________________________ 2 Fungus ASTM G-21_________________ 3 Halogen Free____________________ Yes RoHS___________________________ Yes SVHC_________________________ None Minimum Continuous -49°F (-45°C) PHYSICAL PROPERTIES Monofilament Diameter__________NA ASTM D-204 Recommended Cutting______Hot Knife Colors__________________________ 1 Wall Thickness______________ .02"-.06" Specific Gravity_________________ 1.14 ASTM D-792 Moisture Absorption_____________ 2.5 % ASTM D-570 Hard Vacuum Data_________________ ASTM E-595 at 10-5 torr TML__________________________ 1.10 CVCM_________________________ .01 WVR___________________________ .69 Outgassing___________________ High Oxygen Index___________________ 22 ASTM D-2863 769.3 mg © 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden. Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable. Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions. 07-30 Users should make their own evaluation to determine the suitability of these products for their unique and specific applications. www.techflex.com Mil-I-23053 Very High
NMN0.50BK100 价格&库存
很抱歉,暂时无法提供与“NMN0.50BK100”相匹配的价格&库存,您可以联系我们找货
