ADVANCED ENGINEERING
SPECIALTY
Technical Data Sheet
Put-Ups
D
ense, Full Coverage
Construction
Nominal
Size
R
esists Gasoline And
Engine Chemicals
Part
3/32”
NMN0.09BK
1/8”
NMN0.13BK
3/16”
NMN0.19BK
1/4”
NMN0.25BK
5/16”
NMN0.31BK
3/8”
NMN0.38BK
1/2”
NMN0.50BK
5/8”
NMN0.63BK
3/4”
NMN0.75BK
7/8”
NMN0.88BK
1”
NMN1.00BK
1 1/4”
NMN1.25BK
1 1/2”
NMN1.50BK
1 3/4”
NMN1.75BK
2”
NMN2.00BK
2 1/2”
NMN2.50BK
3”
NMN3.00BK
TIGHT WEAVE
3/8”
NMT0.38BK
E
conomical And Easy To
Install
S
oft, Pliable And Quiet
C
ut And Abrasion Resistant
M
eets Military
Specifications A-A-59301
Wall Thickness
±0.015”
Bulk
Spool
Shop
Spool
0.020”
0.020”
0.030”
0.030”
0.030”
0.030”
0.030”
0.040”
0.040”
0.040”
0.050”
0.050”
0.060”
0.060”
0.060”
0.060”
0.060”
1,000’
1,000’
1,000’
500’
500’
500’
250’
250’
250’
200’
200’
125’
100’
100’
100’
100’
100’
225’
225’
200’
200’
125’
125’
100’
75’
75’
50’
50’
50’
50’
50’
50’
50’
50’
0.030”
250’
75’
Full Coverage, Soft, Supple, Strong
And Attractive
Cut Cleanly
Hot Knife
Material
Polyamide Multifilament
Grade
NMN
Multifilament Thickness
N/A
Available
Colors
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black
Black (BK
The wide operating temperature range allows NM
to protect delicate wiring in engine compartments
and near exhaust systems. NM creates a unique and
attractive retro look when installed on a/v cables.
www.techflex.com
1.47
Black (BK)
NM’s fabric-like softness and flexibility meet surprisingly
tough specifications. The high coverage sleeving
meets or exceeds military specifications A-A-59301.
NM is highly resistant to abrasion, cuts, common
automotive and marine chemicals, UV damage and
vibration. It will not rot or retain moisture.
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
0.29
0.33
0.56
0.79
0.99
1.09
1.74
2.85
3.15
4.35
5.15
5.50
6.46
7.73
9.01
10.32
11.00
Colors Available:
Under the hood or across the floor, NM is the
perfect sleeving product for protecting and
improving the appearance of wires and cables.
NM has been used in military wire harness
applications for many years.
Drawing Number
TF001NM-WD
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
(BK)
Lbs/
100’
Nylon Multi’s qualities make it a viable
choice for defense and military applications
that call for flexibility, strength and full
coverage protection.
HALOGEN
FREE
SPECIALTY
ADVANCED
ENGINEERING
Melt Point
ABRASION
ASTM D-2117
428°F (220°C)
Maximum Continuous
Abrasion Resistance
248°F (120°C)
Abrasion Test Machine
Taber 5150
Abrasion Test Wheel
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
70°F
CHEMICAL
RESISTANCE
1=No Effect
4=More Affected
2=Little Effect 5=Severely Affected
3=Affected
Humidity
58%
Much Pulling Of Fibers Very Visible Wear
20 Test Cycles
Wear Pattern Continues
400 Test Cycles
900 Test Cycles
1,400 Test Cycles
Hole Completely Through
Material Destroyed
3,200 Test Cycles
Pre-Test Weight
11,759.5 mg
Post-Test Weight
10,990.2 mg
Test End Loss Of Mass
Point Of Destruction
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases______________________ 2
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 5
Strong Oxidants___________________ 5
Esters/Ketones____________________ 2
UV Light_________________________ 2
Petroleum________________________ 2
Fungus ASTM G-21_________________ 3
Halogen Free____________________ Yes
RoHS___________________________ Yes
SVHC_________________________ None
Minimum Continuous
-49°F (-45°C)
PHYSICAL
PROPERTIES
Monofilament Diameter__________NA
ASTM D-204
Recommended Cutting______Hot Knife
Colors__________________________ 1
Wall Thickness______________ .02"-.06"
Specific Gravity_________________ 1.14
ASTM D-792
Moisture Absorption_____________ 2.5
% ASTM D-570
Hard Vacuum Data_________________
ASTM E-595 at 10-5 torr
TML__________________________ 1.10
CVCM_________________________ .01
WVR___________________________ .69
Outgassing___________________ High
Oxygen Index___________________ 22
ASTM D-2863
769.3 mg
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
07-30
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Mil-I-23053
Very High
很抱歉,暂时无法提供与“NMN0.25BK200”相匹配的价格&库存,您可以联系我们找货
