EXTREME
TEMPERATURE
Technical Data Sheet
ADVANCED ENGINEERING
TUBE
Put-Ups
E
conomical And Easy To
Install
C
uts Easily With Scissors
R
eflects Radiant Heat
I nsulates Delicate Wires
And Components
R
esists Gasoline And
Engine Chemicals
Nominal
Size
Part
Wall
Thickness
±0.006”
Bulk
Spool
Shop
Spool
Available
Colors
Lbs/
100’
1/4”
3/8”
1/2”
5/8”
3/4”
7/8”
1”
1 1/4”
1 1/2”
1 3/4”
2”
2 1/2”
3”
TTN0.25SV
TTN0.38SV
TTN0.50SV
TTN0.63SV
TTN0.75SV
TTN0.88SV
TTN1.00SV
TTN1.25SV
TTN1.50SV
TTN1.75SV
TTN2.00SV
TTN2.50SV
TTN3.00SV
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
0.025”
350’
300’
250’
250’
250’
250’
250’
250’
250’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
100’
50’
50’
50’
50’
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
Silver
2.55
1.86
2.55
3.00
3.45
4.10
4.50
5.40
6.20
7.40
8.70
10.10
19.00
Reflective Aluminized Surface Bonded
to Insulating Fiberglass
THERMASHIELD® creates a buffer between your wires, hoses and cables and the
high temperature environments they are required to perform in. ThermaShield® is
engineered by laminating an aluminum heat shield to a layer of strong fiberglass
insulation. This system provides superior protection from radiant heat by reflecting it away from sensitive electronics, wiring and hoses.
Cut Cleanly
Scissor
THERMASHIELD® TUBE (TTN) is designed to easily slip over wires or hoses. The
seamless construction provides full coverage and protection, and the flexible
sleeving cuts easily with scissors.
Colors Available:
Silver (SV)
Material
Aluminum Laminated Fiberglass
Grade
TTN
Wall Thickness
.025”
When applied, the aluminum laminate
reflects heat away and the insulating
fiberglass backing protects the fragile
contents from thermal damage and failure.
Drawing Number
TF001TT-WD
www.techflex.com
1 (833) SLEEVING • (973) 300-9242 • fax: (973) 300-9409
104 Demarest Road • Sparta, NJ 07871
HALOGEN
FREE
FAR-25
EXTREME
TEMPERATURE
TUBE
Melt Point
ASTM D-2117
ABRASION
Very High
Rating______________Non Combustible
Will not burn
Abrasion Test Machine
Calibrase H-18
Abrasion Test Load
500g
Room Temperature
73°F
Humidity
55%
Foil Layer Worn Through
1,000 Test Cycle
Fiberglass Layer Worn
Through - Material
Destroyed
1,200 Test Cycles
Pre-Test Weight
10,925.0 mg
Post-Test Weight
9,607.6 mg
Test End Loss Of Mass
Point Of Destruction
1,317.4 mg
Mil-I-23053
491°F (255°C)
Minimum Continuous
-76°F (-60°C)
Taber 5150
Abrasion Test Wheel
Maximum Continuous
CHEMICAL
RESISTANCE
1=No Effect
2=Little Effect
3=Affected
4=More Affected
5=Severely Affected
Aromatic Solvents_________________ 1
Aliphatic Solvents__________________ 1
Chlorinated Solvents_______________ 1
Weak Bases_______________________ 1
Salts_____________________________ 1
Strong Bases_______________________ 1
Salt Water 0-S-1926_________________ 1
Hydraulic Fluid MIL-H-5606__________ 1
Lube Oil MIL-L-7808________________ 1
De-Icing Fluid MIL-A-8243___________ 1
Strong Acids______________________ 2
Strong Oxidants___________________ 2
Esters/Ketones____________________ 1
UV Light_________________________ 1
Petroleum________________________ 1
Fungus ASTM G-21_________________ 1
Halogen Free____________________ Yes
PHYSICAL
PROPERTIES
Flammability Rating__ Non Combustible
Recommended Cutting_______ Scissor
Colors___________________________ 1
Wall Thickness__________________ .025”
RoHS___________________________ Yes
© 2021 Techflex® - Any unauthorized reproduction, in whole or part, in any medium whatsoever, without the express written permission of Techflex® is strictly forbidden.
Techflex® product names and logos are registered trademarks of Techflex®, unless otherwise attributed. The contents and illustrations contained herein are believed to be reliable.
Techflex® makes no warranties as to their accuracy or completeness and disclaims any liability in connection with their use. Techflex’s® only obligations are those in standard terms
of sale for these products and Techflex® will not be liable for any consequential or other damages arising due to misuse of these products or typographical errors or omissions.
08-26
Users should make their own evaluation to determine the suitability of these products for their unique and specific applications.
www.techflex.com
Abrasion Resistance
FLAMMABILITY
2,048°F (1,120°C)
很抱歉,暂时无法提供与“TTN1.50SV100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2270.455861+295.05153
