D130-12
D130-12
    DABURNELECTRONICS
D130-12 数据手册
#D130 DAFLEX Vinyl Coated Fiberglass Tubing 130°C Page 1 of 2 TEL: 973-328-3200 FAX: 973-328-313 #D130 DAFLEX Vinyl Coated Fiberglass Tubing 130°C Description: Made from an inorganic fiberglass base sleeving with a heat resistant extremely flexible, tough plastic insulation coating. DAFLEX 130 Class B (4000V), Grade B-1 is recommended for continuous temperatures of -20°C up to 130°C. It is constructed to provide a tough, flexible, heat resistant sleeving. Daflex 130 cuts cleanly. It will not fray or support combustion. Meets MIL-I-3190C, NEMA VSI ASTM D372. MIL-I-21557. Passes UL VW-1 flame test. UL standard 1441. DAFLEX MIL-I-3190 Inside Diameter (IN.) Size Std. Spool or Coil Part No. Size MIN. NOM. MAX. D130-24 24 01 0.02 .022 0.027 100', 1000' D130-22 22 02 0.025 .027 0.032 100', 1000' D130-20 20 03 0.032 .034 0.039 25'*, 100', 1000' D130-18 18 04 0.036 .042 0.049 25'*, 100', 1000' D130-17 17 05 0.040 .047 0.054 100', 1000' D130-16 16 06 0.051 .053 0.061 25'*, 100', 1000' D130-15 15 07 0.057 .059 0.067 100', 1000' D130-14 14 08 0.064 .066 0.074 25'*, 100', 1000' D130-13 13 09 0.072 .076 0.082 100', 500',1000' D130-12 12 10 0.081 .085 0.091 25'*, 100', 500',1000' D130-11 11 11 0.091 .095 0.101 100' D130-10 10 12 0.102 .106 0.112 25'*, 100', 500',1000' D130-9 9 13 0.114 .118 0.124 100' D130-8 8 14 0.129 .133 0.141 25'*, 100', 500' D130-7 7 15 0.144 .148 0.158 100' D130-6 6 16 0.162 .166 0.178 100', 250' D130-5 5 17 0.182 .186 0.198 100' D130-4 4 18 0.204 .208 0.224 100', 250' D130-3 3 19 0.229 .234 0.249 100' D130-2 2 20 0.258 .263 0.278 100', 250' D130-1 1 21 0.289 .294 0.311 100' D130-0 0 22 0.325 .330 0.347 100' D130-3/8 3/8" 23 0.375 .387 0.399 100' D130-7/167/16" 24 0.438 .450 0.462 100' D130-1/2 1/2" 25 0.500 .512 0.524 100' D130-5/8 5/8" 26 0.625 .640 0.655 100' D130-3/4 3/4" 27 0.750 .768 0.786 100' D130-7/8 7/8" 28 0.875 .893 0.911 100' D130-1" 1" 29 1.000 1.006 1.036 100' Stock Colors: Black, Yellow. Other colors available. All the above tubing can be ordered cut to your specifications. *Please call for quantities less than 100'. Specifications: NEMA VS-1, ASTM D372 Grade B-B-1 (4000V), UL standard 1441. Grade A & Mil-1-21557 constructions available to order. DAFLEX Vinyl Coated Fiberglass Tubing Assortments These handy assortments are ideal for labs and experimentation. Vinyl Coated Fiberglass Kits DAFLEX Cat. No.No. of 6" Lengths/PackTubing Size D130PA-1 30 #24 Thru 12 D130PA-2 15 #11 Thru 0 D130PA-3 10 #3/8 Thru 1" http://www.daburn.com/d130daflexvinylcoatedfiberglasstubing130c.aspx 5/16/2016
D130-12 价格&库存
很抱歉,暂时无法提供与“D130-12”相匹配的价格&库存,您可以联系我们找货
