CONTROLS
CONTROLS
JR
SERIES
ALTERNATING RELAY
UL listed
CSA recognized
Duplex Alternating Control
SPDT or DPDT Control Relay
10 Amp Rated
Externally Controlled
The electronic alternating relay is designed to replace mechanical
style devices used in control applications requiring a duplexing
or alternating action of the control circuits to operate pumps,
compressors, etc. This is achieved by activating a control switch
which is common to one side of the input control voltage. The output
contact of the relay(s) change state when this switch is opened
(on de-energization of the control circuit). When the control initiate
switch is actuated and released or opened, the relay will change
state. The next time the initiate switch is actuated and released it
will change back to its original state. Two red LED’s located on the
top of the dust resistant enclosure provide the status of the relay.
SPECIFICATIONS:
WIRING DIAGRAM:
Input . . . . . . . . . . . . . . . . . . . . . . . . 24 VAC/DC, 110, 220 VAC
± 15%, 50/60 Hz
Maximum power consumption . . . 24 VAC: 1.5 VA
110 VAC: 5 VA
220 VAC: 11 VA
Output . . . . . . . . . . . . . . . . . . . . . . SPDT 10 A resistive
DPDT 10 A resistive
DPDT 10 A crosswired
Minimum pulse . . . . . . . . . . . . . . . 30 ms
Contact material . . . . . . . . . . . . . . AgCdO
Maximum loading . . . . . . . . . . . . . 10 A AC resistive 8 A DC inductive
Maximum switching voltage . . . . . 250 VAC
250 VDC
Relay maximum power rating . . . . 2200 VA
80 W
Mechanical life of relay . . . . . . . . . 3 x 106 operations
Electrical life of relay . . . . . . . . . . . 2 x 105 at 2200 VA resistive load
Operating temperature . . . . . . . . . 14°F to 140°F
-10°C to +60°C
Weight . . . . . . . . . . . . . . . . . . . . . . 2.8 oz. (100g)
PJR
PJRX
INITIATE
SWITCH
4
LJR2
INITIATE
SWITCH
5
4
5
3
6
3
6
2
7
2
7
1
1
8
6
5
4
8
3
9
10
2
8
7
1
11
INITIATE SWITCH*
* INITIATE SWITCH must be isolated from other circuits
ORDERING INFORMATION:
MOUNTING
L = 11 pin plug-in
P = 8 pin plug-in
L
JR2
110A
MOUNTING
SERIES
INPUT POWER
SERIES
INPUT POWER
JR2 = DPDT (LJRZ only)
JR = SPDT
JRX = DPDT crosswired
24A = 24 VAC/DC
110A = 110 VAC
220A = 220 VAC
Products and specifications subject to change without notice.
Order/Technical Support – Tel: (800) 677-5311 / FAX: (800) 677-3865 / www.crouzet-usa.com
2/78
CONTROLS
CONTROLS
JRS
SERIES
ALTERNATING RELAY WITH
SELECTOR SWITCH
UL listed
10 Amp Rated
Selection of Lead or Lag Load
2
output contact of the relay(s) change state when this switch is
opened (on de-energization of the control circuit). When the control
initiate switch is actuated and released or opened, the relay will
change state. The next time the initiate switch is actuated, it will
change back to its original state. Two red LED’s located on the top
of the dust resistant enclosure provide the status of the relay. A 3
Position Selector switch is installed for selection of normal operation (alternating) or selection of lead or lag load.
SPECIFICATIONS:
WIRING DIAGRAM:
±15%, 50/60 Hz
110 VAC: 5 VA
220 VAC: 11VA
DPDT 10 A resistive
250 VDC
80 W
-10°C to +60°C
PJRS
PJRXS
LJRS2
INITIATE
SWITCH
INITIATE
SWITCH
4
5
4
5
6
3
6
2
7
2
7
1
1
8
6
5
3
8
7
4
8
3
9
10
2
1
11
INITIATE SWITCH
L
JRS 2
110A
MOUNTING
SERIES
INPUT POWER
SERIES
MOUNTING
LJRS 2 = DPDT
PJRS = SPDT
PJRXS = DPDT (crosswired)
L = 11 pin plug-in
P = 8 pin plug-in
NOTE: DPDT relay available only with 11 pin plug-in (L).
INPUT POWER
24A = 24
VAC/DC
110A = 110 VAC
220A = 220 VAC
2/79
很抱歉,暂时无法提供与“LJR224AD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+755.76019
- 7+724.28731
- 13+695.30518
