TM5RF-66(50)
TM5RF-66(50)
    HRS(广濑)
TM5RF-66(50) 数据手册
FLYER Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM-DS Series FCC Standard, THT Type Modular Jack Connector Features 1 Complies with US FCC Standard requirements 2 Space-saving 8 pin x 4-port type available 3 Compact with a mounted height of 11.7mm from the board surface, 14mm width and 17mm depth 4 Shielded type uses the same connector housing, making board pattern changes unnecessary (When switching to the shielded type is required make sure to use the pattern for the shielded type) Application Examples ●Industrial PC, LAN, HUB, Interphone, Computer, etc. Mating Port Size and Contact Count (6pos. Size) The relationship between the jack connector mating port size and the number of contacts is shown below. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. Please check the drawing for details. Specifications Rated Current 0.5A Rated Voltage 125V AC Operating Temperature -55 to +85°C* Contact Resistance 230mΩ Max. (100 mA DC) Withstanding Voltage 500V AC for 1 min. Insulation Resistance 100MΩ Min. (100V DC) Mating Durability 200 times *Includes the temperature rise due to current flow. - RoHS compliant MKT-E-21071F Issued: May 10, 2022 © 2022 HIROSE ELECTRIC CO., LTD. All rights reserved. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities.
TM5RF-66(50) 价格&库存
很抱歉,暂时无法提供与“TM5RF-66(50)”相匹配的价格&库存,您可以联系我们找货
