TM5RSA-2424(50)
TM5RSA-2424(50)
    HRS(广濑)
TM5RSA-2424(50) 数据手册
FLYER Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM-DS Series FCC Standard, THT Type Modular Jack Connector Features 1 Complies with US FCC Standard requirements 2 Space-saving 8 pin x 4-port type available 3 Compact with a mounted height of 11.7mm from the board surface, 14mm width and 17mm depth 4 Shielded type uses the same connector housing, making board pattern changes unnecessary (When switching to the shielded type is required make sure to use the pattern for the shielded type) Application Examples ●Industrial PC, LAN, HUB, Interphone, Computer, etc. Mating Port Size and Contact Count (6pos. Size) The relationship between the jack connector mating port size and the number of contacts is shown below. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. Please check the drawing for details. Specifications Rated Current 0.5A Rated Voltage 125V AC Operating Temperature -55 to +85°C* Contact Resistance 230mΩ Max. (100 mA DC) Withstanding Voltage 500V AC for 1 min. Insulation Resistance 100MΩ Min. (100V DC) Mating Durability 200 times *Includes the temperature rise due to current flow. - RoHS compliant MKT-E-21071F Issued: May 10, 2022 © 2022 HIROSE ELECTRIC CO., LTD. All rights reserved. Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings, or availabilities.
TM5RSA-2424(50)
物料型号:未在文档中明确列出具体型号。
器件简介:FLYER TM-DS系列适用于工业PC、局域网、集线器、对讲机、计算机等应用。
引脚分配:文档提供了6位尺寸的插口与接触点数量的关系,例如Model 66、Model 64和Model 62,其中64和62型号分别通过从66型号的两侧移除1个和2个引脚获得。
参数特性: - 额定电流:0.5A - 额定电压:125V AC - 工作温度:-55至+85°C(包括由电流流动引起的温度升高) - 接触电阻:最大230mΩ(100mA DC) - 耐电压:500V AC,持续1分钟 - 绝缘电阻:最小100MΩ(100V DC) - 插拔耐久性:200次
功能详解:文档提到了符合美国FCC标准要求、节省空间的8针x4端口类型、紧凑的尺寸(从板面到安装高度为11.7mm,宽度14mm,深度17mm),以及屏蔽类型使用相同的连接器外壳,无需更改板图(如果需要切换到屏蔽类型,请确保使用屏蔽类型的板图)。
应用信息:适用于需要EMI防护的DIP模组插口连接器。
封装信息:文档中未提供详细的封装信息,但提到了产品的紧凑尺寸。
TM5RSA-2424(50) 价格&库存
很抱歉,暂时无法提供与“TM5RSA-2424(50)”相匹配的价格&库存,您可以联系我们找货
