TM11R-5M2-88
TM11R-5M2-88
    HRS(广濑)
TM11R-5M2-88 数据手册
Subminiature, LAN Modular Jack Connectors ■Features 24 1. Fast Ethernet Support Other series TM21R--5C--88--LP 2. Subminiature Design Contributes to Saving Space in the Equipment 17.5 15 Having built-in optical indicators, with height of only 11.5mm, width of 15mm and depth of 17.5mm the connectors can be used in extremely limited spaces. 3. Built-in Optical Indicators Optical indicators are integral part of the connectors help saving space on customer’s board. Compared with LED type indicators, they do not emit any electrical noise. 21 13.4 Conforms to the TIA/EIA-568-A data wiring standard and meets requirements of CAT5 transmission performance for 1,2-3,6 conductor pairs. As such, these products fully support Fast Ethernet (100BASE-TX) transmission. 16 14.5 11.5 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM11R-5M2 Series TM11R--5M2--88--LP Space saving housing LED optical indicators are taking place 4. EMI protection Metal shield covers the outer surfaces of the connectors assuring complete protection against electromagnetic interference. Built-in multiple shield and ground contacts assure reliable connection with the mounting panel as well as with the mating connectors. 5. Environmental considerations EMI protection Plating is lead-free in order to protect environment. 6. FCC Standards Meets requirements of FCC Title 47, Part 68, Subpart F. ■Applications Telecom Hubs, Routers, Bridges and ATM Transmission Equipment, Ethernet Switches and Networking Equipment, Test and Measurement Equipment, Medical Diagnostic Equipment. Built-in LED type Built-in Optical pipe type (Possibility of electromagnetic noise emission and interference.) (No electromagnetic noise emission.) 2018.8② 1 TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors ■Product Specifications Current rating 1A Voltage rating 125V AC Operating temperature range : -25ç to +80ç (Note) Rating Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Conditions 1. Insulation resistance 100Mø min. 100V DC 2. Dielectric Withstanding Voltage No flashover or insulation breakdown (between adjacent contacts) 500V AC applied for 1minute 3. Withstanding voltage No flashover or insulation breakdown (between contact and shield 1500V AC / 1minute 4. Contact resistance 230mø max. 100mA 5. Vibration No electrical discontinuity of 5μ sec. or more. Contact resistance : 250mø max. Frequency : 10 to 55Hz, single amplitude of 0.75mm, 2 hours / 3 axis 6. Shock No electrical discontinuity of 5μ sec. or more. Contact resistance : 250mø max. Acceleration of 490 m/s2, 11ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 7. Durability (mating/un-mating) Contact resistance : 250mø max. 200 cycles Temperature : -55ç/+15ç to +35ç/+85ç/+15ç to +35ç Duration : 30/2 to 3/30/2 to 3 (Minutes) 5 cycles Contact resistance : 250mø max. 8. Temperature cycle Insulation resistance : 100Mø min. 9. Humidity Contact resistance : 250mø max. Insulation resistance : 1Mø min. (High humidity) Insulation resistance : 10Mø min. (Dry state) 10. Salt Spray Contact resistance : 250mø max. 500 hours at temperature of 40ç and humidity of 90% to 95% Exposed to density 5% salt water for 48 hours Note : Includes temperature rise caused by current flow. ■Materials / Finish Material Finish Remarks Insulator Part PBT Color : Black UL94V-0 Contact Copper alloy Contact area : Gold plating Termination area : Tin alloy plating ------- Polycarbonate Color : Transparent UL94V-0 Copper alloy Tin plating ------- Optical pipe Shield ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Jacks TM11 R - 5M2 - 8 8 - LP 1 2 3 4 5 6 1 Series name TM11 Series 2 Connector type R : Jack 3 Jack type 5M2 : PCB Right-angle through hole type 4 Jack opening code 8 : 8 contacts 5 Number of inserted contacts 6 Optical pipe 8 : 8 contact LP : With optical pipe inserted Blank : Without optical pipe 2 TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors ■Modular Jack Connectors Supporting CAT5 (for 1,2-3,6 pair) ●Single Port With Built-in Optical Pipe 14.5 ( 4.25 ) 0.8 15 0.45 0.25 3.6 0.6 3 1.7 11.5 Contact No. 1 11.5 Contact No. 8 0.3 (2) 11.4 1 14.75 5.55 3.1 11.25 YES (4.25) 222-2905-0 TM11R--5M2 1 PC Contact No. 8 3.1 TM11R-5M2-88-LP 2.54 RoHS (4.25) HRS No. Contact No. 1 11.1 Contact No. 7 Contact No. 2 ●Single Port Without Optical Pipe 14.5 (4.25) 0.8 15 Contact No. 1 3.6 0.6 3 11.5 11.5 Contact No. 8 0.45 (2) 0.25 0.3 1 11.4 5.55 14.75 0.8 YES (4.25) RoHS 3.1 HRS No. 222-2906-2 2.54 Part No. TM11R-5M2-88 3.1 0.8 (4.25) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. 17.5 0.8 0.8 Contact No. 8 Contact No. 1 Contact No. 7 Contact No. 2 3 TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors BRecommended PCB mounting patterns ●With Built-in Optical Pipe ●Without Optical Pipe 11.1 8.89 6.35 8.89 3.81 6.35 LED location area 3.81 LED light emission area Printed board edge 14.75 1 2MIN 2 2 2-Ø2.4 11.4 MIN 18.1MIN 4 3 4 No conductive & ground traces 11.4 Printed board edge Connector front edge 11.4 MIN 14.75 18.1 MIN Suggested LEDs 3.2MAX LED light emitting center 2.7 MAX 1.5 MAX *Recommendations for PCB Design 1 2 3 4 Areas indicated should be free of conductive traces. Area indicated should be free of conductive & ground traces. Recommended board thickness : 1.6mm. To assure that the indicator light pipes operates correctly the LED’s must be installed directly on the PCB, within recommended dimensions and with light emitting center in upward direction. Contact applicable manufacturer for LED specification. BPanel Cutout ●For Both Types, With and Without Built-in Optical Pipe (33) Lock lever 1MIN 1 1 3±1 1 TM21P--88P 15.4 4.5MIN 12 PCB mounting surface 0.3 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Connector front edge 11.4 5 6 2- Ø1.6 2 No conductive & ground traces 8 5MIN 3.1 2-Ø1.6 2- Ø2.4 11.4 MAX Contact No. 8- Ø1 7 2 MIN 8 6 4 2 11.4 MAX 5 MIN 3.1 7 5 3 1 1 No conductive traces 1.27 2.54 8-Ø1 3.1MAX 11.25 2.54 Contact No. 1 No conductive traces 3.1MAX 1.27 Panel side 1 Connector front surface 1 0 2 -0.7 3.1MAX *Recommendations for Panel Design 5.55 1 The shield contacts should connect with the panel cut-out on all sides. Note : IPA cleaning at room temperature is recommended for the cleaning of this product. When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may change color; therefore, please make a selection based on a table showing the effects on the resin. These tables are issued by the various manufacturers of cleaning agents. 4 TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors BCAT5 Transmission Characteristics Data For fully mated receptacle (TM11R-5M2-88-LP) and plug (TM21P-88P). ●Signal Attenuation 0.5 0.3 0.2 0.1 0 0 20 40 60 80 100 80 100 80 100 Frequency(MHz) 1,2 3,6 CAT5 Spec NEXT(dB) ●Near-End Crosstalk (NEXT) 90 80 70 60 50 40 30 20 10 0 0 20 40 60 Frequency(MHz) 1,2-3,6 CAT5 Spec ●Return Loss Return Loss(dB) Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Attenuation(dB) 0.4 80 70 60 50 40 30 20 10 0 0 20 1,2 40 60 Frequency(MHz) 3,6 CAT5 Spec 5 TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors GUIDANCE FOR MODULAR CONNECTORS ■Modular Connector Terminal Numbers Unless otherwise specified, see the figures below for the terminal numbers of the product. Plug Jack (mating face) Contact No.1 Contact No.8 Contact No.8 Contact No.1 ■Attention to Plug Mating FCC PLUG DIMENSIONS 5.89 - 6.15 Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Use only plugs conforming to FCC standards. Please pay particular attention to dimensions shown right. ■Opening Size and Number of Conductors(6-Conductor) See the figures below for the relationship between the opening size and the number of conductors of the jack connectors. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. For details, please contact us for drawings because only standard models are shown in the catalogs. ■Recommended Soldering for Modular Dip Connectors ●Flow solder (automatic soldering machine) Pre-heat : 90 - 130ç Pre-heat time : 120 seconds maximum Solder temperature : 240 - 260ç Soldering time : 10 seconds maximum ●Hand soldering Soldering iron tip temperature : 350ç Soldering temperature : 5 seconds maximum Soldering iron output : 30 - 40W Note : When soldering, use care not to apply excessive force to the connector terminals. ●Recommended Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2018. Contents are subject to change without notice for the purpose of improvements.
TM11R-5M2-88 价格&库存
很抱歉,暂时无法提供与“TM11R-5M2-88”相匹配的价格&库存,您可以联系我们找货
