GT13
GT5
For Network, High speed communication
Features
All surface shielded construction.
Ideal for use as automotive USB connectors.
Applications
In-car data communications, etc.
(For USB2.0, LVDS)
GT9
GT8E
GT25
GT18W
GT10
GT7
GT3
GT32
GT17
GT11
GT36
GT26
GT21
GT19
— Automotive Shielded Connector —
(2mm Pitch)
GT15
For 2018
Network,HIROSE
Dec.1.2018 Copyright
ELECTRIC CO., LTD. All Rights Reserved.
PO5G
GT16
GT17 Series
120
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
GT17 Series ● For Network, High speed communication
GT5
F Connectors
GT13
Center Terminals
(Used with 6, 8, and 10 pos. cable)
GT16
GT19
GT21
1.45
2.1
GT26
Material
Plating
Copper alloy
Tin plating
Conductor Size (AWG)
20 to 22 AWG
24 to 28 AWG
30 AWG
24 to 28 AWG
Outer Diameter
φ1.1 to 1.3
φ0.7 to 1.0
φ1.1 to 1.3
φ0.5 to 0.7
Packaging
RoHS
10,000 pcs/reel
YES
Packaging
RoHS
10,000 pcs/reel
YES
GT17
M Connectors
GT32
Center Terminals
(Used with 6, and 10 pos. cable)
GT3
GT7
18
GT10
GT18W
1.7
GT25
0.64
0.9
GT8E
Material
Plating
Brass
Tin plating
20 to 22 AWG
24 to 28 AWG
Outer Diameter
φ1.1 to 1.3
φ0.7 to 1.0
φ1.1 to 1.3
GT15
HRS No.
767-0082-0
767-0076-8
767-0121-0
GT9
Part No.
GT17-2022PCF
GT17-2428PCF
GT17A-2428PCF
121
HRS No.
767- 0009 -0
767- 0010 -0
767- 0064 -9
767- 0122-3
GT11
Part No.
GT17-2022SCF
GT17-2428SCF
GT17-30SCF
GT17B-2428SCF
GT36
Dec.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
14.35
21.1
PO5G
1.7
6 Pos. Straight Connectors
Contact
No.4
38.5
GT32
GT17
GT11
GT36
GT26
GT21
GT19
13.3
Contact
No.6
6.6
16.6
PO5G
Contact
No.1
BThe product comprises 6 parts.
(Housing, insulator, outer terminal, shield plate, retainer, and center terminal)
● Housing
Part No.
GT17VS- 6DS -HU
GT17VSA-6DS-HU
GT3
GT7
HRS No.
767- 0051-7
767- 0052-0
Material / Plating or Color
PBT/Light Gray
PBT/Black
Packaging
RoHS
1
YES
HRS No.
767-0026-0
PBT/Dark Gray
Packaging
1
RoHS
YES
HRS No.
767- 0050-4
Copper alloy / Tin plating
HRS No.
767- 0049-5
Packaging
1
RoHS
YES
HRS No.
767- 0053-2
PBT/Dark Gray
Packaging
1
RoHS
YES
● Insulator
Part No.
GT17V-6DS-2C
● Outer terminal
Part No.
GT17VS- 6DS -5CF
Outer Diameter
φ4.8 to 5.2
Packaging
1
● Shield plate
Part No.
GT17VS- 6DS -SC
GT10
GT18W
● Center terminal
BMating Table
GT9
GT8E
Part No.
GT17VS- 6DS -R
GT25
● Retainer
GT15
For 2018
Network,HIROSE
Contact
No.3
14.7
BBy using two key codings for different purposes, incorrect insertion can be prevented.
GT16
GT13
GT5
122
Used with 6,8, and 10 pos. cable
Color
Cable side connector
Gray
GT17VS- 6DS-HU
Black
GT17VSA- 6DS-HU
Board connector
GT17V- 6DP- DS(70)
GT17VB - 6DP- DS(70)
GT17VA - 6DP- DS(70)
GT17VC - 6DP- DS(70)
RoHS
YES
GT5
6 Pos. Right-angle Connectors
GT13
Contact
No.6
Contact
No.4
GT19
Contact
No.1
PO5G
GT21
GT26
GT36
Part No.
GT17V-6DS-HU
GT17VA-6DS-HU
RoHS
1
YES
HRS No.
767-0026-0
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0027-2
767-0075-5
HRS No.
767-0028-5
Packaging
1
RoHS
YES
HRS No.
767- 0031-0
PBT / Dark Gray
Packaging
1
RoHS
YES
● Insulator
Part No.
GT17V-6DS-2C
● Outer terminal
Part No.
GT17V-6DS-5CF
GT17V-6DS-3.8CF
Outer Diameter
φ4.8 to 5.2
φ3.6 to 4.0
Packaging
RoHS
1
YES
GT3
Packaging
GT32
PBT / Light Gray
PBT / Black
GT17
HRS No.
767-0029-8
767-0030-7
● Shield plate
GT7
Part No.
GT17V-6DS-SC
● Retainer
GT18W
● Center terminal
GT17V-6DS-HU
Black
GT17VA-6DS-HU
Board connector
GT17V- 6DP-DS(70)(Cable exit direction, up side from mounting side)
GT17VB- 6DP-DS(70)(Cable exit direction, down side from mounting side)
GT17VA- 6DP-DS(70)(Cable exit direction, up side from mounting side)
GT17VC- 6DP-DS(70)(Cable exit direction, down side from mounting side)
GT8E
Gray
GT25
BMating Table
Color
GT10
Part No.
GT17V-6DS-R
GT9
GT15
123
● Housing
GT11
GT16
Contact
No.3
6 Pos. Printed Circuit Board Connectors
● Cable extraction facing up
In Combination with a Right-angle Connector
(Facing Up)
16.5
15
13.1
2
GT17V-6DP-DS
(70)
15.7
12.2
T=1.6
GT17V-6DS-HU
PC BOARD
PANEL
GT26
In Combination with a Straight Connector
16.5
26.5
13.1
2
HRS No.
14.5
GT17VS-6DS-HU
PC BOARD
PANEL
Housing: PBT/Light Gray
Center terminal: Brass /Tin plating
Outer terminal: Copper alloy /Tin plating
Packaging
RoHS
1
YES
● Cable extraction facing down
(Facing Down)
16.5
PANEL
GT10
13.1
T=1.6
GT17VB- 6DP-DS(70)
GT17VB-6DP-DS(70)
12.2
GT18W
GT17V-6DS-HU
22
GT7
GT3
GT17V-6DP-DS(70) 767-0024-4 70
GT25
12.2
T=1.6
Part No.
23.2
GT32
GT17
GT11
15.7
GT36
GT17VS-6DS-R
GT17V-6DS-R
GT9
GT8E
3
Part No.
HRS No.
GT17VB-6DP-DS(70) 767-0032-2 70
124
2
15
Packaging
RoHS
1
YES
PC BOARD
15.7
GT19
GT21
GT17V-6DP-DS(70)
GT17V-6DP-DS
(70)
GT15
For 2018
Network,HIROSE
22
PO5G
GT17V-6DS-R
3
23.2
GT16
GT13
GT5
GT5
GT13
13.1
GT17VA-6DP-DS(70)
3
GT16
16.5
15
(Facing Up)
GT17V-6DS-R
2
22
12.2
15.7
T=1.6
GT17VA-6DS-HU
PC BOARD
PANEL
16.5
GT26
26.5
13.1
GT17VA-6DP-DS
2
14.5
15.7
T=1.6
12.2
1
YES
GT3
(Facing Down)
16.5
PANEL
13.1
HRS No.
GT17VC-6DP-DS(70) 767- 0033-5 70
Packaging
RoHS
1
YES
GT15
Housing: PBT/Black
PC BOARD
GT9
Part No.
15.7
12.2
T=1.6
22
2
GT8E
3
15
GT25
GT17-6DS-R
GT18W
GT17VC- 6DP-DS(70)
23.2
GT17VC-6DP-DS(70)
GT10
GT17VA-6DS-HU
GT7
125
RoHS
GT32
Packaging
GT17VSA-6DS-HU
PANEL
GT17
GT17VA-6DP-DS(70) 767-0025-7 70
Housing: PBT/Black
PC BOARD
GT11
HRS No.
GT36
GT17VS-6DS-R
Part No.
GT21
GT19
23.2
PO5G
GT17VA- 6DP-DS(70)
6 Pos. In-line Connectors
GT16
GT13
GT5
PO5G
GT19
Contact
No.4
GT17
GT11
GT36
GT26
GT21
Contact
No.1
● Housing
Part No.
GT17VSN-6DP-HU
GT17VSV-6DP-HU
GT17VSNA-6DP-HU
Packaging
RoHS
1
YES
Packaging
1
RoHS
YES
HRS No.
767-0077-0
767-0128-0
767-0326-3
HRS No.
767-0078-3
PBT / Dark Gray
HRS No.
767-0080-5
HRS No.
767-0079-6
Packaging
1
RoHS
YES
HRS No.
767-0081-8
PBT / Dark Gray
Packaging
1
RoHS
YES
PBT / Light Gray
PBT / Black
GT32
● Insulator
Part No.
GT17V-6DP-2C
GT3
● Outer terminal
Part No.
GT17VS-6DP-5CF
Outer Diameter
φ4.8 to 5.0
Packaging
1
RoHS
YES
GT25
GT18W
GT10
GT7
● Shield plate
Part No.
GT17VS-6DP-SC
● Retainer
Part No.
GT17VS-6DP-R
● Center terminal
Used with 6, and 10 Pos. cable
BMating Table
GT9
GT8E
Color
GT15
For 2018
Network,HIROSE
Contact
No.6
Contact
No.3
126
Gray
Black
In-line Connector
GT17VSN-6DP-HU
GT17VSV-6DP-HU
GT17VSNA-6DP-HU
BMated Condition
Cable side Connector
GT17V-6DS-HU
GT17VS-6DS-HU
GT17VA-6DS-HU
GT17VSA-6DS-HU
62.6
GT5
8 Pos. Right-angle Connectors
GT13
18
7.3
15.6
Contact
No.1
22
13.3
GT21
Contact
No.8
GT19
Contact
No.5
GT26
PBT / Light Gray
PBT / Black
Packaging
RoHS
1
YES
HRS No.
767-0005-0
PBT / Dark Gray
Packaging
1
RoHS
YES
GT17
HRS No.
767-0003-4
767-0004-7
● Insulator
Part No.
GT17-8DS-2C
GT32
● Outer terminal
HRS No.
767-0006-2 70
Packaging
1
RoHS
YES
HRS No.
767-0008-8
PBT / Dark Gray
Packaging
1
RoHS
YES
RoHS
YES
GT7
● Shield plate
Part No.
GT17-8DS-SC(70)
Packaging
1
GT3
Part No.
HRS No.
Outer Diameter
GT17-8DS-7CF(70) 767-0007-5 70 Phosphor bronze / Tin plating
φ6.8 to 7.2
● Retainer
GT10
Part No.
GT17-8DS-R
● Center terminal
GT18W
BMating Table
GT17- 8DS-HU
Black
GT17A- 8DS-HU
GT8E
Gray
Board connector
GT17V- 8DP-DS(Cable exit direction, up side from mounting side)
GT17VB- 8DP-DS(Cable exit direction, down side from mounting side)
GT17VB - 8DP- DS-SB(Cable exit direction, down side from mounting side)
GT17VA- 8DP-DS(Cable exit direction, up side from mounting side)
GT17VC- 8DP-DS(Cable exit direction, down side from mounting side)
GT17VC - 8DP- DS-SB(Cable exit direction, down side from mounting side)
GT25
Color
GT9
GT15
127
Part No.
GT17-8DS-HU
GT17A-8DS-HU
GT11
● Housing
GT36
Contact
No.4
PO5G
14.6
12
GT16
16.1
27
8 Pos. Straight Connectors
7.3
13.3
GT19
13.3
Contact
No.1
Contact
No.8
38.5
GT7
GT3
GT32
GT17
GT11
GT36
GT26
GT21
Contact
No.5
● Housing
Part No.
GT17S-8DS-HU
GT17SA-8DS-HU
HRS No.
767-0108-2
767-0109-5
PBT / Light Gray
PBT / Black
Packaging
RoHS
1
YES
HRS No.
767-0005-0
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0106-7
HRS No.
767-0107-0
Packaging
1
RoHS
YES
HRS No.
767-0110-4
PBT / Dark Gray
Packaging
1
RoHS
YES
● Insulator
Part No.
GT17-8DS-2C
● Outer terminal
Part No.
GT17S-8DS-7CF
Outer Diameter
φ6.8 to 7.2
Packaging
1
● Shield plate
Part No.
GT17S-8DS-SC
GT10
● Retainer
Part No.
GT17S-8DS-R
GT25
GT18W
● Center terminal
BMating Table
GT9
GT8E
Color
GT15
For 2018
Network,HIROSE
PO5G
Contact
No.4
16.1
18
GT16
GT13
GT5
128
Gray
GT17S- 8DS-HU
Black
GT17SA- 8DS-HU
Board connector
GT17V- 8DP- DS
GT17VB - 8DP- DS
GT17VB - 8DP- DS-SB
GT17VA - 8DP- DS
GT17VC - 8DP- DS
GT17VC - 8DP- DS-SB
RoHS
YES
GT5
8 Pos. Printed Circuit Board Connectors
16.5
GT13
15
13.1
3
2
GT16
GT17-8DS-R
23.2
12.2
15.7
PO5G
22
GT17V-8DP-DS
T=1.6
GT17-8DS-HU
PC BOARD
PANEL
16.5
GT21
26.5
13.1
2
14.5
12.2
T=1.6
PANEL
Packaging
RoHS
767-0139-6
1
YES
GT32
HRS No.
GT3
PANEL
GT7
GT17-8DS-HU
16.5
13.1
GT17VB-8DP-DS
2
GT25
3
15.7
12.2
PC BOARD
GT17-8DS-R
T=1.6
22
GT17VB-8DP-DS-SB
(with enhanced shielding type)
GT18W
23.2
GT10
GT17VB-8DP-DS
15
HRS No.
GT17VB- 8DP-DS-SB
767- 0123-6
Shield case: Brass /Tin plating
RoHS
1
YES
GT15
767-0185-3
Packaging
GT9
GT17VB- 8DP-DS
GT8E
Part No.
129
GT17S-8DS-HU
PC BOARD
GT17
GT17V-8DP-DS
GT11
Part No.
GT17S-8DS-R
GT36
15.7
GT17V-8DP-DS
GT26
GT19
GT17V-8DP-DS
●Cable extraction facing up
16.5
GT16
GT17V-6DS-R
T=1.6
GT17VA-8DP-DS
12.2
15.7
22
2
GT17VA-6DS-HU
PC BOARD
PANEL
GT21
GT19
PO5G
GT17VA-6DP-DS(70)
3
16.5
26.5
GT26
13.1
GT17VA-6DP-DS
2
GT17
GT17VA-8DP-DS
14.5
GT17VSA-6DS-HU
PC BOARD
PANEL
HRS No.
Packaging
RoHS
767-0200-5
Housing: PBT/Black
1
YES
GT3
GT32
12.2
T=1.6
GT11
15.7
GT36
GT17VS-6DS-R
Part No.
GT7
●Cable extraction facing down
GT17A-8DS-HU
PANEL
16.5
13.1
GT17-8DS-R
3
15
Part No.
GT17VC- 8DP-DS
GT17VC- 8DP-DS-SB
HRS No.
767-0199-8
Housing: PBT/Black
767-0124-9
Housing: PBT/Black
Shield Case: Brass /Tin plating
15.7
12.2
GT17VC-8DP-DS-SB
GT25
GT8E
GT9
130
T=1.6
GT17VC-8DP-DS
22
23.2
GT18W
GT10
GT17VC-8DP-DS
GT15
For 2018
Network,HIROSE
15
13.1
23.2
GT13
GT5
Packaging
RoHS
1
YES
2
PC BOARD
GT5
10 Pos. Right-angle Connectors
GT13
27
20.6
18.7
8.6
GT16
17.2
Contact
No.5
GT19
13.3
22
Contact
No.1
Contact
No.10
GT21
Contact
No.6
GT26
PBT / Light Gray
PBT / Black
Packaging
RoHS
1
YES
HRS No.
767-0036-3
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0037-6
HRS No.
767-0038-9
Packaging
1
RoHS
YES
HRS No.
767-0041-3
PBT / Dark Gray
Packaging
1
RoHS
YES
GT17
HRS No.
767-0039-1
767-0040-0
● Insulator
Part No.
GT17V-10DS-2C
GT32
● Outer terminal
Outer Diameter
φ7.5 to 8
Packaging
1
RoHS
YES
● Shield plate
GT7
Part No.
GT17V-10DS-SC
GT3
Part No.
GT17V-10DS-8CF
● Retainer
GT10
Part No.
GT17V-10DS-R
● Center terminal
GT18W
GT25
BMating Table
Gray
GT17V- 10DS-HU
Black
GT17VA- 10DS-HU
Board connector
GT17V- 10DP-DS(70)(Cable exit direction, up side from mounting side)
GT17V- 10DP-DSA(70)(Straight type)
GT17V- 10DP-DS-SB(70)(Cable exit direction, up side from mounting side)
GT17V-10DP- DSA-SB(Straight type)
GT17VA- 10DP-DS(70)(Cable exit direction, up side from mounting side)
GT17VA- 10DP-DSA(70)(Straight type)
GT17VA- 10DP-DS-SB(70)(Cable exit direction, up side from mounting side)
GT17VA -10DP- DSA-SB(Straight type)
GT9
GT8E
Color
GT15
131
Part No.
GT17V-10DS-HU
GT17VA-10DS-HU
GT11
● Housing
GT36
12
PO5G
18.2
10 Pos. Straight Connectors
GT19
13.3
Contact
No.1
Contact
No.10
Contact
No.6
GT17
GT11
GT36
GT26
GT21
38.5
● Housing
Part No.
GT17VS-10DS-HU
GT17VSA-10DS-HU
GT32
GT3
GT7
HRS No.
767-0061-0
767-0062-3
PBT / Light Gray
PBT / Black
Packaging
RoHS
1
YES
HRS No.
767-0036-3
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0059-9
HRS No.
767-0060-8
Packaging
1
RoHS
YES
HRS No.
767-0063-6
PBT / Dark Gray
Packaging
1
RoHS
YES
● Insulator
Part No.
GT17V-10DS-2C
● Outer terminal
Part No.
GT17VS-10DS-8CF
Outer Diameter
φ7.5 to 8
Packaging
1
● Shield plate
Part No.
GT17VS-10DS-SC
GT10
● Retainer
Part No.
GT17VS-10DS-R
GT18W
GT25
BMating Table
Color
GT8E
Gray
GT17VS- 10DS-HU
GT9
● Center terminal
Black
GT17VSA- 10DS-HU
GT15
For 2018
Network,HIROSE
PO5G
Contact
No.5
18.7
20.6
GT16
8.6
GT13
GT5
132
Board connector
GT17V-10DP- DS(70)
GT17V-10DP- DSA(70)
GT17V-10DP- DS-SB(70)
GT17V-10DP- DSA-SB
GT17VA-10DP- DS(70)
GT17VA-10DP- DSA(70)
GT17VA-10DP- DS-SB(70)
GT17VA-10DP- DSA-SB
RoHS
YES
GT5
10 Pos. Printed Circuit Board Connectors
● Right-angle type
16.5
15
(Cable Side)
22
23.2
12.2
15.7
PO5G
GT17V-10DP-DS-SB(70)
T=1.6
GT17V-10DS-HU
Board
Panel
GT19
GT21
(Cable Side)
16.5
26.5
13.1
2
14.5
12.2
T=1.6
RoHS
1
YES
GT32
GT17V-10DP-DS-SB(70) 767-0069-2 70
GT17V-10DP-DS(70)
Packaging
GT17
767-0034-8 70
Panel
GT3
●Straight-type
T=1.6
26.5
15.7
12.2
GT17V-10DP-DSA-SB
HRS No.
RoHS
1
YES
GT15
GT17V-10DP-DSA-SB 767- 0154-0
Packaging
GT9
GT17V-10DP-DSA(70) 767- 0067-7 70
GT8E
Part No.
GT25
GT17VS-10DS-HU
Board
Panel
GT17V-10DP-DSA(70)
GT18W
GT17V-10DP-DSA(70)
14.5
GT17VS-10DS-R
GT10
16.5
13.1
2
GT7
In Combination with a Straight Connector (Cable Side)
133
HRS No.
GT17VS-10DS-HU
Board
GT11
Part No.
GT17VS-10DS-R
GT36
15.7
GT17V-10DP-DS
(70)
GT26
GT17V-10DS-R
GT16
GT17V-10DP-DS(70)
3
13.1
2
GT17V-10DP-DS(70)
GT13
16.5
15
(Cable Side)
●Right-angle type
GT16
13.1
2
22
23.2
T=1.6
GT17VA-10DS-HU
Board
Panel
GT21
(Cable Side)
GT26
16.5
26.5
13.1
2
GT17VA-10DP-DS(70)
14.5
T=1.6
GT36
15.7
GT17VS-10DS-R
GT11
GT17
12.2
15.7
PO5G
GT19
GT17VA-10DP-DS-SB(70)
Part No.
HRS No.
767-0035-0 70
Housing: PBT/Black
GT17VA-10DP-DS-SB(70) 767-0070-1 70
Housing: PBT/Black
Center terminale: Brass /Tin plating
GT17VA-10DP-DS(70)
GT17VSA-10DS-HU
Board
Panel
Packaging
RoHS
1
YES
GT3
GT32
GT17V-10DS-R
GT17VA-10DP-DS(70)
GT17VA-10DP-DS(70)
●Straight-type
GT7
(Cable Side)
16.5
13.1
2
14.5
15.7
GT17VA-10DP-DSA(70) GT17VA-10DP-DSA-SB
GT25
GT8E
GT9
134
26.5
GT17VS-10DS-R
12.2
GT18W
GT10
T=1.6
GT17VSA-10DS-HU
Board
GT15
For 2018
Network,HIROSE
3
12.2
GT13
GT5
GT17VA-10DP-DSA(70)
Part No.
HRS No.
GT17VA-10DP-DSA(70) 767- 0068-0 70
Housing: PBT/Black
GT17VA-10DP-DSA-SB 767- 0174-7
Housing: PBT/Black
Panel
Packaging
RoHS
1
YES
GT5
10 Pos. In-line Connectors
GT13
40
GT16
24
9.8
21.6
Contact
No.1
GT19
Contact
No.10
Contact
No.5
GT21
GT26
(Housing, insulator case, outer terminal, shield plate, retainer, and center terminal)
GT36
Part No.
GT17VSN-10DP-HU
PBT / Light Gray
Packaging
1
RoHS
YES
HRS No.
767-0112-0
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767- 0114-5
767- 0130-1
HRS No.
767-0113-2
Packaging
1,224 pcs/pack
RoHS
YES
HRS No.
767-0111-7
767-0131-4
Packaging
RoHS
1
YES
Part No.
GT17V-10DP-2C
GT17
● Insulator
● Outer terminal
Part No.
GT17VS- 10DP-5.2CF
GT17VS- 10DP-8CF
Outer Diameter
Ø5.0 to 5.4
Ø7.5 to 8.0
Packaging
RoHS
1,224 pcs/pack
YES
GT32
HRS No.
767-0115-8
GT3
● Shield plate
Part No.
GT17VS-10DP-SC
GT7
● Retainer
PBT / Dark Gray
GT10
Part No.
GT17VS-10DP-5.2R
GT17VS-10DP-8R
● Center terminal
GT18W
BMated condition
GT17VS-10DP-5.2R or
GT17VS-10DP-8R
GT17VS-10DS-HU
GT17VSN-10DP-HU
GT25
GT17VS-10DS-R or
GT17VS-10DS-4.6R
GT8E
GT9
66.5
GT15
135
● Housing
GT11
15.7
PO5G
Contact
No.6
GT13
GT5
BWiring Method
GT17V-10DS-HU Harness Finish
1 Strip the Jacket.
Jacket
8 Insert the insulator into the Outer terminal.
GT16
Outside shield
PO5G
Outer terminal
2 Cut the shield and intermediate material to
expose the wire and braid.
GT19
9 Insert the Shield Cover.
Shield Cover
GT21
Signal wires
GT26
3 Bend back the drain wire over the Jacket.
GT36
10 Fold back the Outer terminal.
Drain wire
GT11
4 Wrap with conductive tape.
11 Crimp the Outer terminal.
GT32
GT17
Conductive tape
5 Strip the wire leads.
12 Insert the Outer terminal into the housing.
Wire
GT7
GT3
Housing
6 Crimp the center terminals.
13 Insert the retainer.
GT10
Center terminal
GT25
GT18W
Retainer
7 Insert the center terminals into the insulator.
14 Completion
Insulator
GT8E
GT9
GT15
For 2018
Network,HIROSE
Drain wire
136
*Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative.
Different cables will require different crimp height settings.
GT5
11 Insert the Outer terminal into the housing.
GT16
Housing
GT13
GT17VS-10DS-HU Harness Finish
Outer terminal
PO5G
9 Crimp the Outer terminal.
Retainer
GT21
10 Insert the Shield Cover.
GT19
Shield Cover
13 Completion
GT26
GT36
GT17
GT32
GT3
GT7
GT10
GT18W
GT25
GT8E
GT9
GT15
137
GT11
12 Insert the retainer.
6 pos. In-line Type (Waterproof Type)
F Connectors
GT16
GT13
GT5
24.05
PO5G
GT19
GT36
GT11
● Insulator
GT3
GT32
● Housing
GT17
GT26
GT21
GT17W
(Housing, insulator, outer terminal, shield plate, and center terminal)
Part No.
GT17W-6S-HU
Part No.
GT17V-6DS-2C
Part No.
GT17VS-6DS-5CF
GT7
PBT / Light Gray
Packaging
1
RoHS
YES
HRS No.
767-0026-0
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0050-4
HRS No.
767-0049-5
Packaging
1
RoHS
YES
HRS No.
PBT / Dark Gray
Silicon/White
Packaging
RoHS
1
YES
GT18W
GT25
GT8E
GT9
Packaging
1
● Retainer
GT17W-1P/S-R
767-0216-5
● Center terminal
138
Outer Diameter
Ø4.8 to 5.2
● Shield plate
Part No.
GT10
HRS No.
767-0214-0
● Outer terminal
Part No.
GT17VS-6DS-SC
GT15
For 2018
Network,HIROSE
(49.3)
20.3
Used with 6,8 and 10 Pos. cable
RoHS
YES
GT5
M Connectors
GT13
GT16
23.8
PO5G
(50.4)
26.6
A
GT17−6DP−2C
A
GT19
GT21
GT26
GT36
Part No.
GT17W-6PP-HU
HRS No.
Packaging
RoHS
1
YES
HRS No.
767-0078-3
PBT / Dark Gray
Packaging
1
RoHS
YES
HRS No.
767-0080-5
Material / Plating or Color Outer Diameter
Ø4.8 to 5.2
HRS No.
767-0079-6
Packaging
1
RoHS
YES
HRS No.
PBT / Dark Gray
Silicon / White
Packaging
RoHS
1
YES
767-0215-2
GT17
PBT / Light Gray
Silicon / White
● Insulator
Part No.
GT17V-6DP-2C
GT32
● Outer terminal
Packaging
1
● Shield plate
GT7
Part No.
GT17VS-6DP-SC
RoHS
YES
GT3
Part No.
GT17VS-6DP-5CF
● Retainer
767-0216-5
GT18W
● Center terminal
GT10
Part No.
GT17W-1P/S-R
GT25
GT8E
GT9
GT15
139
● Housing
GT11
GT17W
4 pos. Right-angle Connector (1 Row type)
GT16
9.5
12.85
GT19
4
17.05
3
25
2
PO5G
20.95
1
GT21
8.1
GT26
Key Variation
0.5
1.5
0.5
0.5
1.5
0.5
1.5
GT11
GT36
1.5
1
BThe product comprises 5 parts.
(Housing, insulator, outer terminal, retainer, center
terminal)
Part No.
GT17H- 4S-HU
GT17H2- 4S-HU
GT7
GT10
● Outer terminal
GT18W
● Retainer
● Center terminal
Part No.
GT17H-4S-5CF
Part No.
GT17H-4S-R
Part No.
GT8-2428SCF(70)
S ta n d a r d
Key A
Key B
Key C
Light Gray
Brown
Green
Blue
HRS No.
767- 0085-9
767- 0245-3
HRS No.
767-0084-6
767-0167-1
767-0168-4
767-0169-7
PBT / Light Gray
PBT / Brown
PBT / Green
PBT / Blue
HRS No.
767-0087-4
HRS No.
767-0086-1
PBT / Dark Gray
PBT / Dark Gray
Packaging
Remarks
With lock guard
1
RoHS
YES
HRS No.
758-0001-8 70 Phosphor Bronze / Tin plating
Packaging
RoHS
1
YES
Outer Diameter
Ø4.8 to 5.2
Packaging
1
Packaging
1
RoHS
YES
RoHS
YES
Conductor Size(AWG)
24 to 28 AWG
Outer Diameter
Ø0.8 to 1.5
Packaging
10,000 pcs/reel
RoHS
YES
BMating Table
Board connector
GT9
GT8E
1
● Insulator
Part No.
GT17H-4S-2C
GT17H-4S-2C(A)
GT17H-4S-2C(B)
GT17H-4S-2C(C)
Color
Light Gray
Brown
Green
Blue
140
1
● Housing
GT25
GT3
GT32
GT17
1
GT15
For 2018
Network,HIROSE
5.2
PUSH
GT13
GT5
GT17H-4S-ASSY
GT17H-4S-ASSY(Key typeA)
GT17H-4S-ASSY(Key typeB)
GT17H-4S-ASSY(Key typeC)
SMT Type
GT17H-4P-2H/GT17HR-4P-2H
GT17H-4P-2H(A)
GT17H-4P-2H(B)
GT17H-4P-2H(C)
DIP Type
Angle Type
Straight Type
GT17H-4P-2DS
GT17H-4P-2DSA
GT17H-4P-2DS(A)
GT17H-4P-2DSA(A)
GT17H-4P-2DS(B)
GT17H-4P-2DSA(B)
GT17H-4P-2DS(C)
GT17H-4P-2DSA(C)
GT5
B Wiring Method (4 Pos. Right-angle 1 Row Type)
GT13
GT16
GT19
GT21
GT26
GT36
GT17
GT32
GT3
GT7
GT10
GT18W
GT25
GT8E
GT9
* Concerning the crimp height of terminals, crimp height settings have been prepared for each type of cable. Please contact a Hirose Electric account representative
Please note that new crimp height settings will be made for new cables and that this might take several days.
terminal insertion jig(GT17-4S/PR-MD)
GT15
141
GT11
PO5G
Insert center terminal to the insulator.
4 Pos. Straight Connectors (1 Row type)
5.2
7.9
12.85
2
3
φ8.3
1
GT19
30.95
GT21
4
GT26
Key Variation
0.5
1.5
0.5
0.5
1.5
0.5
1.5
GT17
GT32
GT3
GT7
GT10
GT18W
GT25
4
GT8E
3
GT9
2
GT15
1
4
4
3
3
4
142
BThe product comprises 4 parts.
(Housing, insulator, outer terminal, center terminal)
1
2
2
3
1
1
1
2
GT11
GT36
1.5
1
For 2018
Network,HIROSE
PO5G
8.7
PUSH
GT16
GT13
GT5
1
1
S ta n d a r d
Key A
Key B
Key C
Light Gray
Brown
Green
Blue
● Housing
Part No.
GT17HS- 4S-HU
GT17HSK- 4S-HU
HRS No.
767- 0133-0
767-0244-0
HRS No.
767-0084-6
767-0167-1
767-0168-4
767-0169-7
PBT / Light Gray
PBT / Brown
PBT / Green
PBT / Blue
HRS No.
767- 0135-5
PBT / Dark Gray
Packaging
Remarks
With lock guard
1
RoHS
YES
● Insulator
Part No.
GT17H-4S-2C
GT17H-4S-2C(A)
GT17H-4S-2C(B)
GT17H-4S-2C(C)
Packaging
RoHS
1
YES
● Outer terminal
Part No.
GT17HS- 4S-5CF
Outer Diameter
Ø4.8 to 5.2
Packaging
1
RoHS
YES
● Center terminal
Part No.
GT8-2428SCF(70)
HRS No.
Conductor Size(AWG) Outer Diameter
24 to 28 AWG
Ø0.8 to 1.5
Packaging
10,000 pcs/reel
RoHS
YES
BMating Table
Board connector
Color
Light Gray
Brown
Green
Blue
GT17H-4S-ASSY
SMT Type
GT17H-4P-2H(A)
GT17H-4P-2H(B)
GT17H-4P-2H(C)
DIP Type
Angle Type
Straight Type
GT17H-4P-2DS
GT17H-4P-2DSA
GT17H-4P-2DS(A)
GT17H-4P-2DSA(A)
GT17H-4P-2DS(B)
GT17H-4P-2DSA(B)
GT17H-4P-2DS(C)
GT17H-4P-2DSA(C)
GT5
B Wiring Method (4 Pos. Straight 1 RowType)
GT13
GT16
PO5G
GT21
GT19
GT26
GT36
GT17
GT32
GT3
GT7
GT10
GT18W
GT25
GT8E
GT9
GT15
143
GT11
Center Terminal
4 Pos. Board Connectors
(1 Row type, Right-angle SMT Type, Right side key)
0.5
1
1.5
1
Key B
Green
1
1
1.5
GT17H-4P-2H
GT19
7.2
Standard
Light Gray
0.5
PO5G
1 2 3 4
GT17H-4P-2H(B)
0.5
15.45
GT17H-4P-2H
12.2
>PPS
GF40<
GT17H-4P-2H(C)
0.5
Key A
Brown
GT17H-4P-2H
Key C
Blue
Part No.
GT17H- 4P-2H
GT17H- 4P-2H(A)
GT17H- 4P-2H(B)
GT17H- 4P-2H(C)
HRS No.
767-0083-3
767-0170-6
767-0171-9
767-0172-1
Color
Light Gray
Brown
Green
Blue
Material / Plating
Housing:PPS
Center terminal:Brass/Tin plating
Outer terminal:Copper alloy/Tin plating
Packaging
RoHS
400 pcs/reel
YES
4 Pos. SMT Connector(1 Row type, Left side key)
GT3
GT32
GT17
GT11
GT36
GT26
GT21
1.5
GT17H-4P-2H(A)
GT7
GT17H-4P-2H(S)
Standard
Light Gray
