FX15-31S-0.5SV(30)
FX15-31S-0.5SV(30)
    HRS(广濑)
FX15-31S-0.5SV(30) 数据手册
1mm Pitch Wire-to-Board Connectors supporting LVDS signal FX15 Series Space saving, Equal length transmission lines Termination side: 0.5mm pitch, 1-row construction Mating side: 1 mm pitch, staggered 2-row construction Fig.1 ■Features 1. Space-saving Self-alignment of ±1.5mm Large guide post 1.5mm Reduction in space is achieved by designing the contacts in 2-row staggered 1mm pitch on the mating side and on a single row 0.5mm pitch on the termination side (Fig.1). 1.5mm 2. Equal length transmission lines Contact configuration provides equal length transmission lines, which prevents LVDS signal loss within the connector. 3. Variations Fig.2 Side latch -locks Availability of shielded and non-shielded types allows for design flexibility and cost reduction. 4. Self alignment and self-guiding Built-in guide posts allow secure self-alignment within ±1.5mm (Fig.2). 5. Secure and complete mating / unmating Side latch locking provides complete and secure mating, as well as easy unmating (Fig.3). 6. Enhanced shielding performance with FX15S Enlarged metal shields prevent intrusion and emission of electromagnetic interference, which enhances the integrity of the LVDS signal (Fig.4). 7. RoHS compliant All materials and substances used to produce this product comply with RoHS standards. With metal shields (FX15 and FX15S Series) Without metal shields (FX15M Series) Fig.3 High Shielding Performance 0 Without metal Emitting Noise Level (dBm) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contacts consolidated into 1 row for equal length transmission lines -10 With metal -20 -30 -40 -50 0.1 0.2 0.3 0.5 1 1.5 2 Frequency (GHz) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.10e 3 Fig.4 1 FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal ■Product Specifications Current rating Voltage rating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Ratings 0.5A 100V AC Operating temperature range Storage temperature range -55ç to +80ç (Note 1) -10ç to +60ç (Note 2) Item 1. Contact resistance 2. Insulation resistance 3. Withstanding voltage 4. Insertion-Extraction force Specification 60mø max. (Note 3) 500Mø min. No flashover or insulation breakdown. 2N min., 30N max. Conditions 1mA 100V DC 300V AC/one minute With corresponding connector 5. Mating cycles Contact resistance : 80mø max.(Note 3) 50 cycles 6. Vibration resistance 7. Shock resistance No electrical discontinuity of 1µs or more. No electrical discontinuity of 1µs or more. Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 2 hours, 3 axis Acceleration of 490m/s2, 11ms durations, sine half-wave waveform, 3 cycles, 3axis. 8. Humidity resistance Contact resistance : 80mø max. 96 hours at 40ç, RH 90% to 95% No damage, cracks, or parts dislocation.(Note 3) 9. Temperature cycle Contact resistance : 80mø max. (Note 3) Insulation resistance : 500Mø min. Temperature : -55ç → +15ç to +35ç → +85ç → +15ç to +35ç Time : 30 → 5 → 30 → 5 (Minutes) 5 cycles 10. Salt spray Contact resistance : 80mø max. (Note 3) No corrosions 5% water solution for 48 hours. Note 1 : Includes temperature rise caused by current flow. Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating temperature and humidity range includes non-conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Includes wire conductor resistance (12mm long). ■Materials / Finish ●Receptacle Insulator Component Material Polyamide Finish Color : Black Remarks UL94V-0 Contact Phosphor bronze Contact area : Gold plated Termination area : Tin plated --------------- FX15S : Nickel silver FX15SC : Stainless steel FX15S : --------------FX15SC : Tin plated --------------- Phosphor bronze Selective gold flash plated --------------- Insulator Material Polyamide Finish Color : Black Remarks UL94V-0 Contact Phosphor bronze Contact area : Gold plated Termination area : Tin plated --------------- Metal shell (shielded version only) Metal latch locks (shielded version only) Nickel silver Stainless steel ----------------------------- ----------------------------- Metal shell, metal latch locks (on micro coax version only) Stainless steel Nickel plated --------------- Metal shell (shielded version only) Metal fittings (shielded version only) ●Plug Component ■Product Number Structure qSeries Name wConfiguration ●Receptacle FX15 S - 31 S - 0.5 SH (**) q w e r t y ●Plug w e r u ●Crimp contact FX15 - 3032 PCF B q i o !0 P S : Male contact : Female contact tContact pitch : 0.5 mm SH yHousing configuration SV : Right angle : Straight uTermination C : Crimp 0.5SD : Micro-coaxial cable GND : Separate ground plate iApplicable conductor 2830 3032 : 28 to 30 AWG : 30 to 32 AWG oPackaging !0Plating (contact area) PCF B Blank (30) : Male contact / reel : Gold plated : Embossed Packaging (1,000 pcs/reel) : Embossed Packaging (100 pcs/reel) !1Packaging 2 15M : With shields (or crimp contact) : With shields – enhanced shielding : With shields – enhanced shielding (PCB mounting pattern : VESA standard) : Without shields eNumber of contacts rConnector type FX15 S - 31 P - C q !1 : FX15 Blank 15S 15SC FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal ■FX15 Series – Functional Diagram Crimp contact Plugs Receptacles With shields-standard Vertical, with shields (FX15-31P-C) (FX15-31S-0.5SV) B Crimp contact (FX15-3032-PCFB) (FX15M-P-C) Right angle, with shields –enhanced shielding (FX15S-S-0.5SH) B With shields – enhanced shielding (FX15S-P-C) Right angle, without shields (FX15M-S-0.5SH) B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Without shields Crimp contact (FX15-2830-PCFB) With shields – enhanced shielding 28 to 30 AWG (FX15SW-31P-C) With shields – enhanced shielding PCB mouting pattern : VESA standard (FX15SC-S-0.5SH) 28 Ground plate (FX15S-P-GND) Micro-coaxial cable (FX15S-P-0.5SD) With shields – enhanced shielding PCB mouting pattern : VESA standard (FX15SC-S-0.5SV) A 3 FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal ■Plugs ●With shields (FX15-31P-C) (27) 24.6±0.3 22.57±0.15 2.7±0.1 18.3±0.3 3.7±0.3 (13.45) 9.4±0.3 Polarizing mark indicator Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.2 Part No. HRS No. No. of contacts RoHS FX15-31P-C 575-2101-2 31 Yes Note 1 : Packaged in trays. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. No.1 14±0.15 P=1±0.1 No.30 P=1±0.1 15±0.15 No.31 ●With shields, enhanced shielding (FX15S-**P-C) (A) B±0.3 C±0.15 4±0.3 2.7±0.1 (13.45) 9.4±0.3 Polarizing mark indicator 3.7±0.3 D±0.3 No.2 No.1 No.n-1 P=1±0.1 F±0.15 No.n Part No. HRS No. No. of contacts A B C D E F FX15S-31P-C 575-2106-6 31 27 24.6 22.6 18.3 14 15 FX15S-41P-C 575-2107-9 41 32 29.6 27.6 23.3 19 20 FX15S-51P-C 575-2103-8 51 37 34.6 32.6 28.3 24 25 Note 1 : Packaged in trays. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. 4 E±0.15 P=1±0.1 RoHS Yes FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal ●With shields – enhanced shielding 28 to 30 AWG (FX15SW-31P-C) (27) 24.6±0.3 22.57±0.15 Polarizing mark indicator 4±0.3 2.7±0.1 (13.45) 9.4±0.3 B 28 Part No. HRS No. No. of contacts RoHS FX15SW-31P-C 575-2113-1 31 Yes No.2 14±0.15 P=1±0.1 3.7±0.3 No.30 A Note 1 : Packaged in trays. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. No.1 P=1±0.1 15±0.15 No.31 ●Without shields (FX15M-**P-C) (A) B±0.3 Polarizing mark indicator (13.6) (13) 9.55±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 18.3±0.3 4.2±0.3 C±0.3 (D) No.2 No.1 E±0.15 P=1±0.1 No.n-1 P=1±0.1 F±0.15 No.n Part No. HRS No. No. of contacts A B C D E F FX15M-21P-C 575-2109-4 21 24.8 20.5 13.7 25.8 9 10 FX15M-31P-C 575-2108-1 31 29.8 25.5 18.7 30.8 14 15 RoHS Yes Note 1 : Sold in 100 piece packages. Please order in full package quantities. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. 5 FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal BPlug crimp contacts Part No. HRS No. FX15-2830PCFB 575-2002-0 FX15-3032PCFB 575-2003-3 Packaging Quantity Finish RoHS Reel 20,000 pcs/reel Gold plated Yes ●Applicable cable (Tin plated, annealed copper wire) 30 AWG (7/0.1mm) 32 AWG (7/0.08mm) Ø0.5 to 0.6mm 1571 UL No. 1516, 1571 (Note) 1571 ●Wire strip length: 1.1 to 1.8mm Note : When using wires other than those noted above, please contact Hirose for asistance. ●Tools Item Applicator Press unit 6 Part No. AP105-FX15-2830 AP105-FX15-3032 CM-105C HRS No. 901-4036-0 901-4033-1 901-0001-0 0.35±0.1 Applicable crimp contact FX15-2830PCFB FX15-3032PCFB ––––––––– (7) Jacket diameter 1517 0.72±0.1 0.9±0.15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX15-3032PCFB Applicable wire size (Stranded wire conductor) Ø0.56 to 0.72mm UL No. 2±0.15 28 AWG (7/0.127mm) 30 AWG (7/0.1mm) Jacket diameter 0.5±0.15 FX15-2830PCFB Applicable wire size (Stranded wire conductor) t=0.15±0.05 FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal Cd#& Cd#c ●Plug – Micro-coaxial cable (FX15S-**P-0.5SD) Cd#' Cd#c"& 6 7¤%#( 8¤%#&* EdaVg^o^c\bVg` ^cY^XVidg '#,¤%#&* &( -#,*¤%#( 6 Part No. HRS No. No. of contacts A B C D FX15S-41P-0.5SD 575-2110-3 41 31.9 29.6 27.57 20 FX15S-51P-0.5SD 575-2118-5 51 36.9 34.6 32.57 25 (#*¤%#( RoHS Yes Note 1 : Packaged in trays. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. ●Ground plate for micro-coaxial cable type 6¤%#' &#**¤%#' 7¤%#' '#'¤%#' &&#)*¤%#( Part No. HRS No. No. of contacts A B FX15S-41P-GND 575-2111-6 41 29.2 30.06 FX15S-51P-GND 575-2117-2 51 34.2 35.06 RoHS Yes Note 1 : Packaged in trays. Note 2 : Dimensions in parenthesis ( ) are reference dimensions. ●Applicable cable (Micro-coaxial cable) 6¤%#' 7¤%#&* 40 AWG (7/0.03mm) No. of contacts 41 A 23.1 B 20 51 28.1 25 E2%#*¤%#%, >ccZgXdcYjXidg >chjaVidg
FX15-31S-0.5SV(30) 价格&库存
很抱歉,暂时无法提供与“FX15-31S-0.5SV(30)”相匹配的价格&库存,您可以联系我们找货
