FX16M2-41S-0.5SV(30)
    HRS(广濑)
FX16M2-41S-0.5SV(30) 数据手册
0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors FX16 Series Supports next generation high-speed transmission Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Fig.1 V-by-One® HS compatible connector (mv) +200 Eye Diagram (3.75Gbps) +100 ® "V-by-One HS" is a trade mark of Thine Electronics, Inc. 0 -100 Features -200 【Shielded FFC 300mm hamess】 1.Supports next-generation high speed transmissions FX16 Series supports next-generation high-speed signals including signal transmission of up to 6Gbps. The FX16 series delivers exceptional impedance-matching, even at sharp signal rise times of Tr=50ps (10 - 90%). (Fig.1) 2. V-by-One® HS compatible connector The FX16 Series connector is recommended by Thine Electronics, Inc. for their V-By-One® HS nextgeneration panel interface, due to the connector’s outstanding signal integrity performance at 3.75Gb/ s - the top data rate of the interface. As shown in Fig.2 on the right, the eye pattern remains wide open at 3.75Gbps. (Please refer to the transmission property data shown on Page 4.) Fig.2 Simplified FFC harness assembly with a flip-lock system ①Insert the FFC into the plug [Patented] Direct plug-in style plug FFC 3. A patented flip-lock harness simplifies FFC applications. We have incorporated our proprietary patented fliplock design that greatly simplifies FFC assembly by eliminating the need for costly cable soldering (Fig.3). wClose the flip-lock eCompleted mating sequence Fig.3 4. Vertical cable plug The vertical plug mating style simplifies the assembly process. In addition, it offers a lower profile by limiting the mated height to only 8mm (Fig.4). Vertical mating, horizontal wiring 5. Multiple variations of plug style, cable type and number of positions available The series features a common plug for shielded FFC and micro coaxial cable. Available plug variations include right-angle, vertical style for batch harness assembly and direct plugin styles. Multiple position sizes are available (please see page 5 for variations). 6. RoHS compliant All materials and substances used to produce these parts fully comply with RoHS standards. Easy operation with the use of a side lock Vertical style plug Vertical mating 8mm Vertical style receptacle Designed for low mated height Fig.4 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2018.2③ 1 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Product Specifications Current Rating 0.5A Ratings Storage Temperature Range : -10 to 60℃ (Note 3) Items 1.Contact resistance 2.Insulation resistance 3.Withstand voltage 4.Overall push-pull force 5.Durability Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Vibration Voltage Rating AC60V Operating Temperature Range : -55 to 85℃ (Note 1) (Note 2) Operating Humidity Range : relative humidity of no more than 85% (Note 2) (Note 4) Operating Humidity Range : relative humidity of no more than 70% (Note 3) (Note 4) Specifications Conditions 80mø max (Note 5) Measured at 1mA 500Mø minimum Measured at DC 100V No flashover or breakdown Inserting force (0.5 × number of pos.) : no more than 1N Extracting force (0.05 × number of pos.) : no less than 1N Contact resistance : variation from the initial state : no more than 20mø AC 200V is applied for 1 minute Measured by using applicable connectors 50 mating cycles Frequency 10 - 55Hz, half amplitude 0.75mm, 2 hours for 3 axial directions Accelerated velocity : 490m/s2, for 11ms, half-sine in 3 directions, 3 times for each of No electrical discontinuity of 1µ or greater the three directions (axes) Contact resistance : variation from the initial state : 20mø max 96 hours at 40ç temperature and the Insulation resistance : minimum of 500Mø humidity range from 90 to 95% Temperature : -55 → 5 to 35 → 85 → 5 to 35ç Contact resistance : variation from the initial state : 20mø max 5 cycles of the testing time period of Insulation resistance : 500Mø min 30 → 5 → 30 → 5 minutes No electrical discontinuity of 1µ or greater 7.Shock 8. Humidity resistance 9. Temperature cycles Note 1 : Includes temperature rise caused by current flow. Note 2 : The operating temperature range when the operating humidity is above 80% shall be -55 to 40ç. Note 3 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. Note 4 : No condensation allowed. Note 5 : The conductor resistance of connected cables is not included. Materials / Finish Receptacle Part Insulator Contact Shell Materials FX16 : LCP resin FX16M2 : Polyamide resin Copper alloy Copper alloy Finish Remarks Black color UL94V-0 Gold plating Pure tin-plating ------------------------------------------- Plug Part Insulator Contact (FX16-SD/SDL only) Shell Materials FX16-SD/SDL : Polyamide resin : PC resin FX16F-HC FX16M2-HC : PBT resin Finish FX16-SD/SDL : Beige color : Black color FX16F-HC FX16M2-HC : Black color Contact interface area : gold plating Copper alloy Termination area : pure tin-plating FX16-SD/SDL : Stainless steel FX16-SD/SDL : Nickel plating : Stainless steel FX16F-HC : Nickel plating FX16F-HC FX16M2-HC : Copper alloy FX16M2-HC : Pure tin-plating Remarks UL94V-0 ------------------------------------------- Accessories Part Cover shell 2 Materials Stainless steel Finish ---------------------- Remarks ---------------------- FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. Receptacle FX 16 M2 - 51 S - 0.5 SH (**) Plug FX 16 M2 - 51 P - HC Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Accessories (Cover shell) FX 16 - 31 P - GND Series Name Series No. Shape designation Number of positions Contact type Contact pitch Product type (Receptacle) Product type(Plug) Product type (Accessories) Packaging : FX : 16 None/F/M2 : Hirose control identification code S P 0.5 None SH SV SD : female contact : male contact : 0.5mm pitch : No contact : right-angle type : vertical type : Right-angle batch cable assembly type (Micro coaxial cable) SDL : Vertical batch cable assembly type (Micro coaxial cable) HC : FFC holder type GND : Right-angle type cover for micro coaxial cables GNDL : Vertical type cover for micro coaxial cables None : embossed tape package (1,000pcs/reel) (30) : embossed tape package (100pcs/reel) 3 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Transmission properties Differential impedance [Rise time: Tr=100ps] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A differential impedance of 100ø ±10% is maintained at signal rise time of 100ps. (※Notes), This specification is met by way of an impedance-matching design based on SI simulation. (ø) 120 PCB+SMA FX16 Cable (ø) 120 110 110 100 100 PCB+SMA FX16 Cable 90 90 93.6ø 80 [Micro coax cable harness product] 95.2ø 80 [Shielded FFC type harness product] Eye diagram The FX16 Series connector shows outstanding performance at 3.75Gbps, the maximum speed of V-By-One® HS developed by Thine Electronics, Inc. Testing with actual V-by-One® HS signals shows that the eye pattern is wide open at these signal speeds. (※Notes) * V-by-One® HS is a trade mark of Thine Electronics, Inc. Eye Mask Eye Mask [Micro coax cable harness 500mm product] [Shielded FFC type harness 500mm product] *Note) Results may vary depending on the length and properties of the cables used. 4 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Diagram of FX16 Series variations and mating table Receptacle Plug Additional Components Cable Assemblies Right-angle batch cable assembly type (FX16**-P-0.5SD) Ground Plate for micro coax cables (FX16**-P-GND) Micro coax cable assembly Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right-angle type (FX16-**S-0.5SH) FFC cable Assembly Vertical type (FX16-**S-0.5SV) FFC holder type (FX16**-P-HC) Vertical batch cable assembly type (FX16**-P-0.5SDL) Right-angle type (FX16M2-**S-0.5SH) FFC holder type assembly Ground plate for micro coax cables (FX16**-P-GNDL) Micro coax cable assembly FFC batch assembly type FFC holder type (FX16M2**P-HC) FFC holder type assembly Vertical type (FX16M2-**S-0.5SV) 5 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors FX16 Series mating dimensions (Reference dimensions) Plug Right-angle, PCB mount type (FX16-**S-0.5SH) Right-angle type micro coaxial cable harness (FX16**P-SD) Mated condition (14.85) (9.95) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (14.6) Receptacle Vertical, PCB mount type (FX16-**S-0.5SV) Holder FFC type assembly (FX16**-P-HC) (10.2) (8) Vertical type micro coaxial cable harness (FX16**-P-SDL) Right-angle, PCB mount type (FX16M2-**S-0.5SH) Vertical, PCB mount type (FX16M2-**S-0.5SV) Holder FFC type assembly (FX16M2-**-P-HC) (16.5) (16.75) (Unit : mm) 6 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Receptacle 0. 25±0. 15 5. 55±0. 2 4. 8±0. 2 2.1±0.2 1. 5±0. 1 Right-angle type (FX16-**S-0.5SH) A±0. 3 B±0. 2 C±0. 15 P=0.5±0.1 n-0.18±0.05 No.1 Polarity mark No.n 1. 5±0. 1 Product lot No. 4. 4±0. 3 P=E±0.1 D±0. 2 4-0.5±0.1 F±0. 2 G±0. 3 H±0. 15 P=0. 5±0.1 (1. 05) (0. 6) A±0.3 B±0.2 C±0.15 No.1 P=0.5±0.1 Signal contact: (0. 5) Shell: (0. 7) (5. 8) No.n n-0.18±0.05 1.5±0.1 0.25±0.15 5.55±0.2 4.8±0.2 2.1±0.2 1.5±0.1 Right-angle type (FX16M2-**S-0.5SH) Polarity mark P=E±0.1 Product lot No. 6-0.5±0.1 F±0.2 G±0.3 H±0.15 4.4±0.3 P=0.5±0.1 (1.05) Signal contact:(0.5) (1.05) (0.6) Shell:(0.7) (5.8) Recommended PCB layout (Metal mask dimension) No. 1 No. n B±0. 05 C±0. 05 3. 5±0. 05 1. 55±0. 05 Notes: 1 The co-planarity of the contact and shell of this product is 0.1mm max. 2 Insulation measures such as the pattern prohibited area or resist processing are required in the area identified by      inside the land pattern. 3 ( ) is a reference dimension. 4 During the manufacturing process, products may incur some minor cosmetic damage (dents/ scratches), but this will not affect their performance. 5 This product is delivered in an embossed reel packaging; the packaged quantity for one reel is 2. 05±0. 05 1,000 pieces for standard articles (00) and 100 2 Pattern prohibited area pieces for the specification of (30). 2. 5±0. 05 5. 1±0. 05 P=0. 5±0. 03 n−0. 25±0. 03(Land pattern) n−0. 22±0. 03(Metal mask) K−1. 3±0. 05 D±0. 05 P=E±0. 05 F±0. 05 J±0. 05 2. 5±0. 05 1. 55±0. 05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (1. 05) Unit : mm Part No. HRS No. No. of Contacts A B C (n) 21 22.85 16 10 D E 4 ----- 10 20.46 10 19.75 FX16-21S-0.5SH(**) FX16-31S-0.5SH(**) 575-3411-5 ** 575-3412-8 ** 31 27.85 21 15 ----- FX16M2-41S-0.5SH(**) FX16M2-51S-0.5SH(**) 575-3003-9 ** 575-3004-1 ** 41 51 32.85 26 20 ----37.85 31 25 ----- 4 5 F G H J 12 25.46 15 24.75 20 30.46 20 29.75 25 35.46 25 34.75 K RoHS 4 ○ 6 (00) : Embossed package (1,000pcs/reel), (30) : Embossed package (100pcs/reel) 7 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Vertical type (FX16-**S-0.5SV) Polarity mark A±0. 3 B±0. 2 P=0. 5±0. 1 n-0. 18±0. 05 No.1 No.n 1. 5±0. 1 A 4-0.5±0.1 C±0. 2 E±0. 2 F±0. 2 Lot No. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5. 3±0. 3 4. 2±0. 2 Signal contact:(0.7) Shell: (0.5) 5. 5±0. 3 Vertical type (FX16M2-**S-0.5SV) A±0.3 No.1 B±0.2 P=0.5±0.1 n-0.18±0.05 Polarity mark (side face) Lot No. (side face) No.n 1.5±0.1 A P=D±0.1 E±0.2 F±0.2 6-0.5±0.1 5.3±0.3 4.7±0.2 Signal contact: (0.7) Shell: (0.5) 5.5±0.3 1. 55±0. 05 3. 5±0. 05 1. 55±0. 05 Recommended PCB layout (Metal mask dimension) No. n F±0. 05 No. 1 2. 5±0. 05 B±0. 05 n-0.25±0.03(Land pattern) n-0.22±0.03(Metal mask) P=0. 5±0. 03 2 05 P=D±0. 05 C±0. Pattern prohibition area 2. 5±0. 05 G−1. 3±0. 05 E±0. 05 F±0. 05 Notes : 1 The co-planarity of the contact and shell should measure no more than 0.1 (mm). 2 Insulation measures such as the pattern prohibited area or resist processing are required in the area identified by      inside the land pattern. 3 ( ) is a reference dimension. 4 During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect their performance. 5 This product is delivered in an embossed package; the packaged quantity in one reel is 1,000 pieces for standard articles (00) and 100 pieces for the specification of (30). Unit : mm Part No. HRS No. No. of Contacts A (n) 21 20.46 B C D - FX16-21S-0.5SV(**) 575-3401-1 ** 10 4 FX16-31S-0.5SV(**) 575-3402-4 ** 31 25.46 15 - FX16M2-41S-0.5SV(**) 575-3002-6 ** 41 30.46 20 - (00) : Embossed package (1,000pcs/reel), (30) : Embossed package (100pcs/reel) 8 4 E F 10 16 12 21 20 26 G 4 6 RoHS ○ FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Emboss carrier dimensions (receptacles only) Horizontal type (FX16-**S-0.5SH / FX16M2-**S-0.5SH) FX16-21S-0.5SH(**) FX16-31S-0.5SH(**) 575-3411-5 ** No. of Contacts (n) 21 575-3412-8 ** 31 FX16M2-41S-0.5SH(**) 575-3003-9 ** 41 FX16M2-51S-0.5SH(**) 575-3004-1 ** 51 Part No. HRS No. Unit : mm A B C D 44 40.4 20.2 56 52.4 26.2 W 23.76 28.76 33.76 38.76 44.5 56.5 (00) : Embossed package (1,000pcs/reel), (30) : Embossed package (100pcs/reel) P=4±0. 1 (6. 7) (0. 5) Reel Dimensions +0. 15 1. 7 0 0. 1 1. 5+  0 (1. 6)(W) φ380±2 φ80±2 (D) C±0. 1 B±0. 1 A±0. 3 2±0. 15 φ1 3 φ2 ±0. 5 1 ± 0 . 8 φ1 . 5 +0 P=12±0. 1 (3. 65) (8. 4) Note 1 : ( ) shows a reference dimension. Vertical type (FX16-**S-0.5SV / FX16M2-**S-0.5SV) FX16-21S-0.5SV(**) FX16-31S-0.5SV(**) 575-3401-1 ** No. of Contacts (n) 21 575-3402-4 ** 31 FX16M2-41S-0.5SV(**) 575-3002-6 ** 41 Part No. HRS No. Unit : mm A B C D 44 40.4 20.2 E 20.57 6.9 25.57 30.57 W 44.5 7 (00) : Embossed package (1,000pcs/reel), (30) : Embossed package (100pcs/reel) P=4±0.1 Reel Dimensions φ1 3± 0.5 (0.5) 8 0. (1. 6)(W) ± 21 φ380±2 φ80±2 A±0.3 B±0.1 φ 0 +0.15 (10) 2±0.15 (E) C±0.1 P=12±0.1 (D) φ1 5 . +0  0 . 1 Unreeling direction 1.7 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.  0 . 1 Unreeling direction +0.1 1.5  0 (7) (5) Note 1 : ( ) shows a reference dimension. 9 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Recommended Temperature Profile This temperature profile is a reference based on the following conditions. Since your actual conditions may vary, please check your process before mounting the connectors. (Peak temperature : MAX250ç) 250 230 230℃ 180℃ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Connector surface temperature(ç) 180 150 (Applicable Conditions) Test PCB Dimensions : 40×30×1(mm) Reflow method Material : glass epoxy Solder Composition : Sn-3 Ag-0.5 Cn (flux component : 10.5wt%) Metal mask thickness : 0.12mm 150℃ Note 1 : This temperature profile is a recommended value. Note 2 : The reflow process should not be conducted more than two times. Note 3 : The values may show a slight variance due to solder paste type and thickness. 100 25 0 30 ±10 seconds 90 ±30 seconds Pre-heating time(150~180ç) Time (sec) Soldering time (minimum of 230°C) Cleaning Conditions Cleaning with organic solvents Solvent IPA (Isopropyl alcohol) Clean at normal temperature ○ Heated cleaning ○ Water cleaning If wet cleaning is necessary, please select the proper cleaning agent (terpene, alkali saponification agent etc.) based on the reaction it will have on the metals and resins of the connector. This information is issued by the manufacturer of the cleaning agent. Additionally, please make sure not to apply an excessive amount of the cleaning agent. Points to note during cleaning When using organic solvents or wet cleaning agents, please ensure proper rinsing is done to eliminate the possibility of deterioration in electrical performance caused by flux or cleaning agents remaining in the connector. 10 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Plug Right-angle batch cable assembly type Part No. FX16-21P-0.5SD FX16-31P-0.5SD HRS No. 575-3301-7 575-3302-0 Unit : mm No. of Contacts (n) 21 31 A B C D RoHS 21.9 26.9 19.6 24.6 17.57 22.57 10 15 ○ No. n No. 1 (1. 6) (5. 15) (7. 6) (10. 9) (13. 3) 9. 25±0. 3 2. 8±0. 1 P=0. 5±0. 08 D±0. 1 (E) (F) 3. 5±0. 3 Notes : 1. ( ) shows a reference dimension. 2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches) or black spots in the resin, but these small imperfections will not affect their performance. 3. This product is delivered in a tray package. Right-angle-type cover shell for micro axial cables FX16-21P-GND 575-3311-0 No. of Contacts (n) 21 FX16-31P-GND 575-3312-3 31 Part No. HRS No. Unit : mm A B C 19.2 13.2 20.06 24.2 18.2 25.06 RoHS ○ 1 +0. 1 A− 0. 15 1. 55±0. 15 8. 45±0. 15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (A) B±0. 3 C±0. 15 +0.2 B-0.1 2. 2±0. 15 C±0. 15 Notes : 1. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect their performance. 2. This product is delivered packaged on a 2500pcs/reel. 3. This product is an accessory to the separately sold item "Right angle batch cable connection type plug (FX16-**P-0.5SD)". Please be sure to use them together. 11 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Vertical batch cable connection type Part No. FX16-21P-0.5SDL FX16-31P-0.5SDL Unit : mm HRS No. No. of Contacts (n) A B C D E F RoHS 575-3321-4 575-3322-7 21 31 18.07 23.07 13.7 18.7 11.5 16.5 10 15 23.6 28.6 17.57 22.57 ○ A±0.3 (B) (C) D±0.1 (8.65) (4.9) (1.6) P=0.5±0.08 No.1 No.n (E) 2.4±0.3 (9.6) F±0.15 (6.55) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A±0.3 2.8±0.1 Notes : 1. ( ) shows a reference dimension. 2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches) or black spots in the resin, but these small imperfections will not affect their performance. 3. This product is delivered in a tray package. Vertical type cover shell for micro coaxial cables Part No. FX16-21P-GNDL FX16-31P-GNDL No. of Contacts (n) 21 31 HRS No. 575-3331-8 575-3332-0 Unit : mm A B C RoHS 20.37 25.37 11.47 16.47 18.17 23.17 ○ 1.3±0.15 9±0.15 A±0.2 B±0.2 2.05±0.15 C±0.15 Notes : 1. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect their performance. 2. This product is delivered packaged on a 2000pcs/reel. 3. This product is a compliment to the separately sold item "vertical batch cable assembly type plug (FX16-**P-0.5SDL)". Please be sure to use them together. 12 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Applicable wires Micro coaxial cables Applicable conductor size (core structure) 36 AWG# (7pcs/0.05mm) 38 AWG# (7pcs/0.04mm) 40 AWG# (7pcs/0.03mm) Insulation diameter No. of Contacts (n) Applicable connectors FX16-21P-0.5SD FX16-21P-0.5SDL FX16-31P-0.5SD FX16-31P-0.5SDL 21 Ø0.3~Ø0.5mm 31 A B 13.1 10 18.1 15 C 4.55 4.3 4.55 4.3 B±0. 15 7 P=0. 5±0. 07 0. 9 MAX Solder coat 1 MIN  0 2. 1−0. 1 Marginal cable length cutting position 3 4 A±0. 2 8 (C) Selected cable material 3 Internal conductor Dielectric 0. 6±0. 1 Metal bar 0. 05 5 1+ −0. 2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended micro coaxial cable dimensions External conductor 6 Jacket AWG #36, 38, 40 micro axial cables Notes : 1 ( ) shows a reference dimension. 2 Pulse heat batch soldering is recommended to affix the harness to the connector 3 To prevent any conductor deformation prior to harnessing, please use the cable material immediately after cutting 4 After confirming that the soldered state has no problems, departure from recommended values is permissible 5 Use of out-of-spec dimension cables may hinder the correct attachment to the connector. Additionally, use of excessive force during cable connection may cause faults such as unsoldered areas and disconnects. 6 The protrusion of the external conductor from the metal bar should be minimized. 7 Apply a solder coat (pre-tinning) on the internal conductor. 8 Shows the position at which the connector should be connected and the cable inserted into the connector when the cable has been stripped at the recommended length. If cable is stripped at a different length, the amount of cable insertion will need to be changed as well. 13 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors FFC holder type (FX16F-**P-HC) Part No. FX16F-21P-HC FX16F-31P-HC HRS No. 575-3265-5 575-3266-8 Unit : mm No. of Contacts (n) 21 31 A B C RoHS 22.4 27.4 17.57 22.57 20.4 25.4 ○ (3.2)(4) A±0.3 3.7±0.3 2.8±0.1 8.7±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.15 C±0.3 Notes : 1. ( ) shows a reference dimension. 2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches). But this will not affect their performance. Additionally there may be mold sinks present. 3. This product is delivered in a tray package. FFC holder type (FX16M2-**P-HC) Part No. FX16M2-41P-HC FX16M2-51P-HC HRS No. 575-3262-7 575-3263-0 Unit : mm No. of Contacts (n) 41 51 A B RoHS 35.4 40.4 27.57 32.57 ○ (A) B±0.15 (6.45) 3.5±0.3 15±0.3 11.2±0.3 1.65±0.2 Notes : 1. ( ) shows a reference dimension. 2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect their performance. Additionally there may be mold sinks present. 3. This product is delivered in a tray package. 14 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Applicable wires Completely shielded FFC for holder type No. of Contacts (n) 21 31 Unit : mm Applicable connectors A B C D E F FX16F-21P-HC FX16F-31P-HC 13.2 18.2 12.8 17.8 11.2 16.2 10 15 12.8 17.8 10.7 15.7 Recommended FFC dimensions +3 (L+14.4) 0 9.2 +20 6.2 +0.1 0 ax m 2 . R0 max 2 R0. 0 −0.06 2 0.85 max max R0.2 max 2 R0. (0.7) E±0.05 5 0.3±0.03 1.4±0.05 1.4±0.05 D±0.05 P=0.5±0.03 C±0.05 A±0.1 ◆B±0.05 Enlarged view (7.2) 1.05 6.05 + −0.7 Connector cut-off position(Mi n7. 1mm) 1 6 2 F±0.4 4 3.5±0.5 10.7±1 Enlarged view Conductor (gold-plated annealed copper foil) Insulator (polyester) Insulator (polyester) ◆0. 45±0. 03 0. 33±0. 03 ◆0. 3±0. 03 (0. 12) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ◆3.8 2.3±0.05 Reinforcing film Ground plate (conductive tape) 10 The length of the harness when the harness is used for both sides. (7. 2) FX16F-**P-HC 9 L+3 0 (7. 2) FX16F-**P-HC Notes : 1 The plating on the ground plate (tape) must be at least 1.5µm of Sn plating, with the first 1 to 5µm of Ni plating + at least 0.2µ of Au plating on the pad surface as well as C-2000-equivalent sealing. 2      denotes the shielded area. (both sides are shielded). 3      denotes the area for the ground plate (conductive tape). 4      denotes the area for the reinforcing film. 5 The width of the conductor must be 0.3 ±0.03mm. 6 The ground plate (tape) and shield must overlap each other. This will allow a conductive path to be established through both ground plates and on both sides. 7 FFC must be made to satisfy the differential impedance value of 100ø ±7%. 8 ( ) denotes the reference dimension and ◆ mark denotes important dimensions. 9 The L dimension is the length of the harness from one end face to the other end face of the connector cable port. 15 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Completely shielded FFC for holder type No. of Contacts (n) 41 51 Unit : mm Applicable connectors A B C D E F FX16M2-41P-HC FX16M2-51P-HC 24.4 29.4 23 28 21.2 26.2 20 25 23.5 28.5 20.7 25.7 Recommended FFC dimensions +3 (L+26.3) 0 10.5+20 R0.2 MAX L +3 0 (13.15) R0 (0.7) 0.85 MAX X 11 +0.5 0 Connector cut-off position(NIN 13.12mm) 6 2 3 +0.4 1 FX16M2-**P-HC FX16M2-**P-HC MA .2 M AX E±0.1 A MAX +3 (L+26.3) 0 (13.15) (13.15) 4 .5 .2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C0 2 R0 Enlarged view Harness lengths and tolerance for double-ended assemblies 9.1+0.1 0 ◆B±0.05 C±0.05 D±0.05 P=0.5±0.03 5 0.3±0.03 1.5±0.05 1.5±0.05 ◆6.5 −00.06 2.5±0.5 F−1 9 Warpage provision OK NG Reinforcing film 4±0.5 (12) ◆0.45±0.03 0.33±0.03 ◆0.3±0.03 5 0.035±0.01 1 Conductor (gold-plated annealed copper foil) Insulator (polyester) Enlarged view Insulator (polyester) Reinforcing film Ground plate (conductive tape) Notes : 1 The plating on the grounding plate (tape) must be at least 1.5µm of Sn plating, with the first 1 to 5µm of Ni plating + at least 0.2µ of Au plating on the pad surface as well as C-2000-equivalent sealing. 2      denotes the shielded area. (both sides are shielded). 3      denotes the area for the ground plate (conductive tape). 4      denotes the area for the reinforcing film. 5 The width of the conductor must be 0.3 ±0.03mm. 6 The ground plate (tape) and shield must overlap each other. This will allow a conductive path to be established through both ground plates and on both sides. 7 The manufacturing work should be directed to ensure that the FFC is made to satisfy a differential impedance value of 100ø ±7%. 8 ( ) denotes the reference dimension and ◆ mark denotes important dimensions. 9 Warpage of the reinforcing film is permitted only in the direction of OK in reference to ▲ ▲ on both sides. However, please make sure that the film can still be inserted into the connector without any problems. 16 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use Plug (Vertical/horizontal batch cable connection type) [Precautions for soldering] [1] Recommended soldering iron Wire solder with flux (lead-free type: Sn-3Au-0.5Cu) When using micro coax cables……Ø0.15 Length : number of pos. ×0.5mm Be careful not use an excessive amount of flux, especially when using a wire solder that contains flux. Doing so may cause the flux to run up to the contact portion which can lead to contact failure. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [2] Prior to fixing the cables to the connector, make sure that the conductor is placed correctly in the center of the contact. Fix the cable at the metal bar guide on the connector. [3] Before you solder down the cables onto the connector, please check for the following issues : ・Deformation of the conductor Deformation of the conductor Pitch deviation ・Pitch deviations to the conductor relative to the contact ・Extreme uplift of the conductor tip end This feature can lead to unsoldered spaces or solder bridges. Uplift [4] Recommended pulse heat conditions Conditions will vary depending on the length/type of cable used, type of solder, etc… Please reference the recommended profile conditions when setting up your working conditions. Pressure on the iron tip 13-17N Main heating Y℃ Main heating Temperature (Y) Hold time (X) 220℃ 275±5℃ 2 ±0.5 seconds Preheating 220℃ Idling 50℃ 2s 2s 2s Xs Time to apply pressure on the iron tip [5] Please check the soldered part after soldering to ensure no deformities were made. The illustrations below depict some examples of correct parts and some examples of incorrectly soldered parts. Example of a correctly soldered part The conductor is located at the center of the contact, and the whole area is uniformly soldered. Examples of incorrectly soldered parts Solder bridge Insufficient amount of solder used Scattered solder balls Floating Uplift of the conductor The conductor is located too close to the extended contact. 17 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use [Precautions for resin sealing] [1] To prevent insulation failure due to foreign materials, cable disconnection during the routing of the cable and other failures, we recommend that the soldered area be protected with an ultraviolet curable resin or another equivalent material. Recommended resin sealing material : Ultraviolet curable resin 3033 manufactured by ThreeBond Co., Ltd. [2] Please refer to the resin manufacturer’s directions for recommended usage conditions. [3] Ensure that the complete soldering area of the conductor is covered with resin. Be careful not to let the applied resin flow into or stick to the connector contacts. (0.65) (1) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (2.7) (16.5) [4] Please pay close attention to the load (e.g. tension, stress.) placed on the soldered part after soldering. Poor handling could cause cable disconnection. [How to mount the cover shell] [1] After connecting the cables, mount the separately sold cover shell (for micro coax cables : FX16-31P-GND). [2] Place the cover shell over the connector from above, set it on the connector while holding it with your fingers. Pinch together Pinch together Cover shell qPrepare the cover shell. wPlace it horizontally on the connector from above. eSet it on the connector and pinch it down [3] After applying it to the connector, check to see if all six "joining point" locations are correctly in place. Illustration showing proper joining Joining point Joining point Joining point (cross-section of the joining point). Joining point Joining point The cover shell is locked into place and is seated correctly. Joining point OK 18 The cover shell is not locked and is still incomplete. NG FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use [Ground soldering of the connector to the cable] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [1] Soldering the metal bar of the cable and the connector shell will enhance the shielding properties and provide additional cable strain relief.      Soldered part Soldered part [2] Do not apply too much solder as this can lead to deformation/melting of the cable/connector due to the heat generated while soldering. Plug (FFC holder type) [Precautions during harness work] [1] Inserting FFC Insert the FFC straight along the guide rib of the mold, as shown in the following figure. It cannot be inserted in different directions. Please be careful not to deform FFC or damage the case or spring contact. Connector (FX16M2-**P-HC) Molded guide rib Spring contact Conductor portion FFC has been completely inserted. FFC [2] Confirming the insertion of the FFC Check if the FFC has been inserted correctly by observing the tip end of the FFC from above the connector. * If the FFC was inserted correctly, the tip of the FFC will meet up with the wall of the connector. Check the tip end of the FFC by observing it from above the connector as shown in the figure on the left. Check to see if the FFC edge meets the wall of the connector. Wall of the connector If the end of the FFC does not meet the wall of the connector *Re-insert it until they meet evenly with each other. Wall of the connector 19 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use [3] Fixing the FFC As shown in the figure below, hold the connector in both hands and push the lock straight with both thumbs. At this time, verify the hooks are tightly attached to each other on both sides. Additionally, after closing the lock, verify that the FFC cannot be easily pulled out, and that the hooks on both sides are tightly attached to each other by holding both ends of the assembly and pulling the FFC in the drawing direction with a force of 3 to 5 N Hinges (at 4 places) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Right side Left side Check to see that the FFC cannot be pulled out with a force of 3 to 5 N. Left side Right side Check to see that the hooks on both sides are tightly attached to each other. [4] Other cautions qFrom the time of opening the package until the assembly process, please do not handle the product in the manner which will cause the lock of the connector to be pushed down. If the lock gets deflected it in the direction shown in the figure below, discard the connector. wOnce FFC has been removed from the connector, do not reuse the connector. eAt the time of packing the harness, be careful not to let the connector be damaged or deformed. 20 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use General cautions [Cautions for handling] [1] Insertion into the connector on the side of PCB The mating direction of this connector has been specified. Mating should be done with the mark facing the direction shown in the figure below. Additionally, insertion should be done until the locks on both sides are set. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB side: FX16M2-**S-0.5SH Triangle mark When inserting it, do not touch the button of the plug, and hold this face to insert it. Mating Although this connector is designed to prevent reverse insertion, the connector could be damaged if it were mated forcibly with a force exceeding 25 N. Avoid forced mating, and please verify the triangle mark position before mating. Do not pull it out at an angle as shown in the figure below. This could damage the connector. [2] Unmating the connector mounted on a PCB This connector is structured to lock on both ends when mated. When unmating the connector, pull it out straight while pushing on both sides with your fingers to unlock it. Please do not pull out FFC with a strong force.    Pull-out ① Push it. ① Push it. Pull-out wPull it out straight. ePull it out straight while pushing in the buttons. Do not pull it out at an angle as shown in the figure below. This could damage the connector. 〈Incorrect insertion method〉 21 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Precautions of use 〈Incorrect pull-out method〉 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [3] In the case when the connector has been unmated forcibly. If the connector has been unmated forcibly, push it back once to the completely mated condition, from this state, pull the plug by the "correct pullout method". Be sure to push it once to the completely mated condition. [4] In the case when you have pulled it out with one side locked If the plug has been pulled out with one side locked, the locked part could be damaged if you pull it out forcibly. In such a situation, do not try to unlock it forcibly, but mate the plug again as it is, and pull out the plug by the "correct pull-out method" again with both sides locked. If the plug has been pulled out with one side locked, be sure to mate them again. [5] Handling after mating After mating, be careful not to apply load to the connector during cable routing. The connector could be damaged if you pull the cable with a force of 20 N or more. Additionally, it could cause cable disconnection. Please make sure that you do not pull the cable forcibly. Repeated strain could also cause cable disconnection. Avoid any use which involves repeated strain. Repeated tension When you use a cable that is folded back from the connector base, please maintain a large bend radius or keep the folding position away from the connector base in order minimize the load on the connector. Allow for a large bend radius. Keep the folding position away from the connector base. Using the cable in a folded state. 22 FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO: 23 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 24 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 02/2018. Contents are subject to change without notice for the purpose of improvements.
FX16M2-41S-0.5SV(30) 价格&库存
很抱歉,暂时无法提供与“FX16M2-41S-0.5SV(30)”相匹配的价格&库存,您可以联系我们找货
