3560-16S(50)
3560-16S(50)
    HRS(广濑)
3560-16S(50) 数据手册
3500 Series Long-Life I/O Connectors Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■OVERVIEW These miniature, shielded interface connectors were designed for use with portable terminal equipment. They are suited to a wide range of applications including hand-held terminals and PDA equipment because of excellent insertion/removal durability (20,000 times). ■FEATURES (1) Long-life connectors have an insertion/removal life of 20,000 cycles. (2) The structure of the contacts is the highly reliable, two-contact bellows type. (3) The lock uses a snap-lock system which relieves the stress that accompanies forceful removal, making these connectors resistant to external forces such as sudden pulls of the cable. (4) Release of the lock is achieved with a simple operation of the push buttons at the left and right sides of the plug. A positive lock sensation is provided by a click locking sound when the connector engages. (5) The miniature, lightweight design (i.e., about 2g for a 16-conductor receptacle) makes these connectors effective in reducing the overall size and weight of terminal equipment. (6) Use of a new box-bending structure for the metal shell supports EMI protection and makes this a tough connector. (7) ESD protection is provided by the metal shell-not the cover (unless it is metal plated). (8) The board mounting system uses 0.8-mm spaced single row SMT for easy mounting. (9) Suitable boards can be from 0.8 to 1.6mm thick, affording a wide selection of board thicknesses. (10) There are two types of plug-side wiring systems, the pressure welding type designed to save labor in wiring, and the solder type which enables an arbitrary selection of the type of cable. ■APPLICATIONS Hand-held terminals, PDA equipment, notebook computers, mobile communications equipment, office automation equipment, measuring instruments, etc. 257 04/2009 Major Specifications Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Materials and Processing Rated Value Operating temperature range -40℃ to +85℃ Rated voltage 125VAC Rated current 1A Insulation resistance 1,000MΩ or greater/ 250VDC Withstand voltage 350VAC for 1 minute Contact resistance Insertion/removal life Item Material Processing Insulation Synthetic resin Black color UL94V-0 Contacts Copper alloy Selective gold plating Shell Stainless steel Tin plating Insulation Synthetic resin Black color UL94V-0 Contacts Copper alloy Selective gold plating Shell Stainless steel ─ 40mΩ or less Lock spring Stainless steel ─ 20,000 times Cover Synthetic resin Receptacles Plugs Black color Structure of the Product Number ● Receptacle Connectors 35 60 − 16 S R (50) (1) (2) ● (4) (5) (7) (8) Plug Connectors 35 30 A − 16 P − CV (50) (1) (2) (3) (4) (5) (6) (8) (1) Series No.: 35 (2) Termination style 60: Right-angle SMT type 30: Discrete wire pressure welding type 40: Solder type (3) Suitable wire A: AWG 28 (4) Number of contacts (5) Type of opening portion P: Plug connector S: Receptacle connector (6) Cover form CV: Standard type (7) Engagement direction of the connector No symbol: Forward engagement R: Reverse engagement (8) Specification contents (50): Specifications support RoHS Diagram of Connector When Engaged (Please see information about the connector mounting method.) Plug connector side Set body side 258 04/2009 ■ RECEPTACLE CONNECTORS ■ FORWARD ENGAGEMENT TYPE Plug logo mark position when engaged Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Logo mark side (Note)CONTACT No. for 16pos Engagement key (Both sides) Forward engagement type 3560-16S(50) Unit: mm HRS No. Number of contact CL235-0007-0-50 CL235-0001-3-50 10 16 Product No. A B C D E F RoHS 3560-10S(50) 3560-16S(50) 16.2 21.0 07.2 12.0 19.0 23.8 23.2 28.0 20.8 25.6 20.5 25.3 YES ■ REVERSE ENGAGEMENT TYPE Plug logo mark position when engaged Logo mark side ※……Reverse contact number arrangement Engagement key (Both sides) Reverse engagement type 3560-16SR(50) Unit: mm HRS No. Number of contact CL235-0008-2-50 CL235-0002-6-50 10 16 Product No. A B C D E F RoHS 3560-10SR(50) 3560-16SR(50) 16.2 21.0 07.2 12.0 19.0 23.8 23.2 28.0 20.8 25.6 20.5 25.3 YES 259 04/2009 Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■ PLUG CONNECTORS Logo mark side 3530A-16P-CV(50) Unit: mm Item HRS No. Number of contact Pressure welding wiring type CL235-0009-5-50 10 CL235-0003-9-50 CL235-0010-4-50 CL235-0004-1-50 16 10 16 Solder wiring type Product No. A B C 3530A-10P-CV(50) 21.8 20.8 24.0 3530A-16P-CV(50) 26.6 3540-10P-CV(50) 21.8 3540-16P-CV(50) 26.6 25.6 20.8 25.6 28.8 24.0 28.8 RoHS YES B Internal Structure Diagram (Pressure welding wiring type) Cable clamp Frame Shell Cover A Cover B Pressure plate(A) Pressure plate(B) Logo mark side ※ This look spring forms a single body structure with the frame and cable clamp. Insulation ※Lock spring Suitable cable Contacts Specification Number of contact Cable outside diameter AWG28(7/0.127) UL20276 Conductor outside diameter :φ0.58 10 φ5.0 16 φ5.9 B Harness tool Item Wire forming palette Number of contact common Tools required for the harness Product No. HRS No. 3530/CA-MD CL902-0345-9 10 3530-10/SP-MP CL902-2060-0 16 3530-16/SP-MP CL902-2009-2 Set palette Solder wiring ○ ─ ○ ─ Remaining length cutting jig common 3530/CU-MP CL902-0346-1 ○ ─ Pressure welding jig common 3530/ID-MP CL902-0347-4 ○ ─ 10 3530-10/CA-MP(01) CL902-2061-2(01) ○ ○ 16 3530-16/CA-MP(01) CL902-0348-7(01) Cable caulking jig 260 Pressure welding wiring 04/2009 B Board Mounting Dimensions Diagram (Note)CONTACT No. for 16pos. No.16(Note)…(16S) No.1 …(16SR) 2.2 1d ia( . t hr ou gh ho le) No.1 …(16S) No.16(Note)…(16SR) or . f a( di g) in nt ou m Edge of board 1.8 h ug ro th . a( di Front of connector ) le ho Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. w re sc Pattern pad Pattern prohibited area Board mounting dimensions diagram(2 : 1) Suitable board thickness t = 0.8∼1.6 (mm) Product No. A B C D E F 3560-10S(50) 3560-10SR(50) 17.6 16.2 07.2 09.3 11.6 20.5 3560-16S(50) 3560-16SR(50) 22.4 21.0 12.0 11.4 16.4 25.3 B Technical DocumentⅠ Ⅰ (Reference) Number of Insertion / Removal Cycles and Contact Resistance (mΩ) 60 40 20 0 Start 1000 10000 20000 (Times) 261 04/2009 B Technical DocumentⅡ Ⅱ Connector Mounting Method 1. Soldering Method This connector and board mounting method uses soldering at the four dip locations marked A at the left and right sides as well as the two surface mounting locations marked B at the left and right sides for a total of six locations. Nov.1.2016 Copyright 2016 Sep.1.2018 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Location A represents board through holes of 1.8mm diameter and 1mm diameter, whereas location B represents pads of 2.8 × 1.85mm width. (See the board mounting diagram.) Powered by TCPDF (www.tcpdf.org) As illustrated in the diagram below, the opening portion of the connector is either inserted into the body of the set or inserted into a rectangular hole of the set. Connector opening portion Board Connector 2. Soldering and Screw Fastening Method When there is not sufficient strength with the connector opening portion at the set, the mounting holes C (as in Figure 1) at the left and right sides of the connector are used after the solder mounting to further fix the connector with M2 screws. The connector can be fixed to just the board with this method (as in Figure 2); however, in consideration of connector twisting, the most effective mounting method is to fix the connector to both the body and the board with screws as illustrated in Figures 3 and 4. (Figure 1) Board Body of the set Nut anchoring (Figure 2) 262 (Figure 3) Tapping screw anchoring (Figure 4) 04/2009
3560-16S(50) 价格&库存
很抱歉,暂时无法提供与“3560-16S(50)”相匹配的价格&库存,您可以联系我们找货
