ESR10-NC2A4HB-00-D2-10A 数据手册
Electronic Standard Relay – ESR10 ISO Micro
Description
The smart power relay ESR10 Micro (Electronic Standard Relay) is a
solid state relay which can replace electro-mechanical relays.
The ESR10 is a plus switching (high side switch) closing relay (NO) in
an ISO Micro automotive relay enclosure.
It allows bipolar control by a positive voltage. This space-saving relay
is available in three power classes:
l 10 A for max. 85° C / (12 and 24) Vdc
l 17 A for max. 105° C / (12 and 24) Vdc
l 30 A for max. 85° C / 12 Vdc
Applications
ESR10 Micro
The ESR10 helps to switch loads whose current demand is too high
to be connected directly to the controlgear. The switching function
of the ESR10 is completely noiseless. This allows installation in the
vehicle's interior.
The ESR10 Micro is suitable for all applications in DC 12 V or 24 V
electrical systems where valves, motors, lamps etc. have to switched:
l
Road vehicles (passenger cars, bicycles, trucks, buses, working
vehicles and emergency cars, special vehicles)
l
Construction vehicles and agricultural vehicles
l
Watercraft (ships, sailing boats, motor yachts etc.)
Benefits
l
The
low current consumption, particularly in the ON condition,
helps to reduce gas consumption as well as CO2 emissions.
l
The solid state relay switches silently and features wear-free
operation of all loads with an extremely long life span.
Order numbering code
Type No.
ESR10
electronic standard relay
Protection (characteristic curve)
N not protected, only short circuit protection
Type of enclosure
C2 Micro enclosure with hexagonal latching lugs
C3 Micro design without retaining clip
Terminals (pins)
A4 standard automotive, 4-pole (ISO)
Load and control
HB high-side-switch (HSS), bipolar control
Sub type
00 standard
System voltage
D1 DC 12 V
D2 DC 24 V
Current rating (at 25°C)
10 A
17 A
30 A * (12 V only)
ESR10 - N C2 A4 HB - 00 - D1 - 10A ordering example
Technical data (25 °C) – ESR10 Micro 10 A
Voltage supply LINE+
System voltage
Operating voltage
DC 12 V / DC 24 V
6...16 V / 10...32 V
Closed current1)
OFF
8 µA
Load circuit LOAD
Load output
MOSFET, high side switching (HSS)
Load types resistive, inductive and capacitive
Protective function short circuit proof,
temperature disconnection (pulsing)
Current rating
IN
10 A
Typical life
> 1,000,000 cycles
Voltage drop1)
UON
75 mV
Max. short circuit current
60 A (L/R = 3 ms)
Control input IN+
Control voltage
ON
12 V: ±6...16 V; 24 V: ±10...32 V
OFF
12 V: ±0...2 V; 24 V: ±0...4 V
Control current 1) 2) 10 mA (at 13.5 V respectively 27 V)
(derating see chart)
Switching frequency max.
see chart
Rising edge
< 5 ms
General data
Reverse polarity
load
yes (reverse polarity conductive) 3)
protection circuit,
load circuit
Cycle times 1) tON
0.5 ms
tOFF
0.5 ms
Temperature range
-40 °C…85 °C
Dimensions ISO Standard Micro
(with retaining lugs)
plugged in
26 x 15.5 x 26 mm
including contacts
26 x 15.5 x 37 mm
Mass1)
15 g
1)
2)
Please be informed that we have minimum ordering quantities to be observed.
3)
2047
UB
typically
The upstream controlgear may misconstrue the situation as “wire
break” due to the extremely low control current. In this case the
trigger threshold should be adjusted.
In the event of reverse polarity connection, the MOSFET will switch
through automatically for self-protection.
www.e-t-a.de
1
5
Technical data (25 °C) – ESR10 Micro 17 A
Technical data (25 °C) – ESR10 Micro 30 A
System voltage
UB
Operating voltage
DC 12 V / DC 24 V
System voltage
Operating voltage
Closed current1)
OFF
8 µA
Load circuit LOAD
Load output
Current rating
IN
17 A
Voltage drop1)
UON
75 mV
100 A (L/R = 3 ms)
Control input IN+
Control voltage
ON
OFF
see chart
Rising edge
< 5 ms
General data
Reverse polarity
load
protection circuit,
load circuit
Cycle times 1) tON
0.5 ms
tOFF
0.5 ms
Temperature range
-40 °C…105 °C
plugged in
26 x 15.5 x 26 mm
including contacts
26 x 15.5 x 37 mm
Mass1)
15 g
Approvals
5
DC 12 V
6...16 V
Closed current1)
OFF
5 µA
Load circuit LOAD
Load output
Current rating
IN
30 A
Voltage drop1)
UON
50 mV
100 A (L/R = 3 ms)
Control input IN+
Control voltage
ON
12 V: ±6...16 V
OFF
12 V: ±0...2 V
see chart
Rising edge
< 5 ms
General data
Reverse polarity
load
protection circuit,
load circuit
Cycle times 1) tON
0.5 ms
tOFF
3.5 ms
Temperature range
-40 °C…85 °C
plugged in
26 x 15.5 x 26 mm
including contacts
26 x 15.5 x 37 mm
Mass1)
15 g
Important: The 30A version of the ESR10 Micro will only be available upon request and for high volume projects (> 5000 pcs). Small
quantities cannot be ordered.
Tests
Authority
Approval mark
Regulation
KBA
E1
ECE R 10
Qualifications
ESR10 Micro 10 A/12 V variant, VW
VW80000:2013-06 (LV124)
TL81000:2013-02
ESR10 Micro 10 A/12 V variant, GM
GMW 15267
GMW 3097
ESR10 Micro 10 A, 17 A, 30 A / 24 V
Environmental tests to LV124
(Specification and severity to VW80000: 2013-06)
UB
Chemical resistance
Tested with battery acid, interior
cleaner, glass cleaner, acetone,
spirit, cream, caffeine and sugar
containing drink.
Vibration
ISO 60068-2-64:2008 test FH 30g
Shock
ISO 60068-2-27:2009 test EA 50g
Free fall
Drop height 1m onto concrete
Salt spray
DIN EN 60068-2-11:2000 Test KA
Degree of protection
ISO 20653 2nd Edition:2013/IEC
60068-2-68:1997 IP5K3
Pin assignment
ESR10 Micro
Electrical tests to ISO 16750-2
LINE + 3
(30)
INa
1
(86/31) control input
INb
2
(31/86) ground
LOAD
5 (88a)
3
UB
load output
5
2
1
^ Automotive terminal designation
2
www.e-t-a.de
2047
Dimensions
Schematic diagram
Alternative control
of bipolar control inputs
4.5±0.15
14±0.15
8±0.15
4.5±0.15
Pin assignment is in accordance with ISO 7588
3 and 5 – blade terminals 6.3 x 0.8 [mm]
1 and 2 – blade terminals 4.8 x 0.8 [mm]
15.4±0.3
Control inputs
alternative 1
IN a
UB
alternative 2
GND
IN b
GND
UB
alternative 1
UB
UB
26±0.5
LINE+
INa
ESR10
Control
11.1±0.2
ISO-Micro
ESR10-N...
11±0.5
LOAD
INb
Control
on
off
LOAD
ESR
on
off
22.8±0.2
5.5±0.1
3
3
alternative 2
UB
UB
LINE+
26±0.2
INa
ESR10
ISO-Micro
ESR10-N...
Dimensions: Design without retaining clip
14±0.15
8±0.15
4.5±0.15
LOAD
LOAD
INb
Control
on
off
Control
ESR
on
off
4.5±0.15
5
11±0.5
26±0.5
15.4±0.3
22.8±0.2
3
3
All dimensions without tolerances are for reference only. E-T-A reserves the right change
specifications at any time in the interest of improved design, performance and cost effectiveness, the right to make changes in these specifications without notice is reserved. Product
markings may not be exactly as the ordering codes. Errors and omissions excepted.
2047
www.e-t-a.de
3
Derating
Load current for – 10 A variant
IN [A]
Load current for – 30 A variant
12
IN [A]
35
30
11
25
10
15
8
-40
25
50
10
85
-40
TU [°C]
25
50
85
TU [°C]
2,5 mm2 cross-section
4 mm2 cross-section
1 mm2 cross-section
Load current for 17 A variant
IN [A]
18
17
16
15
14
13
12
11
10
9
8
-40
25
50
85
105
TU [°C]
1,5 mm cross-section
2
Control current for 12 V – 10 A / 17 A / 30 A variant
5
IN [mA]
Control current for 24 V – 10 A / 17 A / 30 A variant
IN [mA]
13
12
11
11
10
10
9
9
8
8
7
7
6
6
5
5
4
4
3
6
7
8
9
10
11
12
13
14
15
16
UB[V]
4
13
12
www.e-t-a.de
3
10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
UB[V]
2047
Frequency control 10 A
10 A / 12 V variant
Frequency measurement with 100 Hz
10 A / 24 V variant
Frequency measurement with 50 Hz
I [A] 13
I [A] 11
70 °C
85 °C
12
11
70 °C
85 °C
10
9
10
8
9
7
8
6
7
5
6
4
5
3
4
2
10%
20%
30%
40%
60%
90%
95%
99%
10%
20%
30%
40%
60%
90%
Duty Cycle
(TON/T)
95%
99%
Duty Cycle
(TON/T)
Frequency measurement with 150 Hz
I [A] 10
I [A] 10
70 °C
85 °C
9
8
70 °C
85 °C
9
8
7
7
6
6
5
5
4
4
3
3
2
2
1
1
10%
20%
30%
40%
60%
90%
95%
99%
10%
Duty Cycle
(TON/T)
40%
60%
90%
95%
99%
The max. load current depends on the load type.
Please contact the manufacturer of the load if the
limit values shown above are reached. E-T-A is
able to test whether the relay works in the limit
range.
70 °C
85 °C
9
30%
Duty Cycle
(TON/T)
Frequency measurement with 200 Hz
I [A] 10
20%
8
7
6
5
4
5
3
2
1
10%
20%
30%
40%
60%
90%
95%
99%
Duty Cycle
(TON/T)
2047
www.e-t-a.de
5
Frequency control 17 A / 30 A
17 A / 12 V variant
17 A / 24 V variant
I [A] 16
I [A] 15
70 °C
85 °C
15
14
70 °C
85 °C
14
13
13
12
12
11
11
10
10
9
9
8
8
7
7
6
10%
20%
30%
40%
60%
90%
95%
99%
10%
20%
30%
40%
60%
90%
Duty Cycle
(TON/T)
99%
I [A] 13
I [A] 12
12
11
70 °C
85 °C
11
10
9
8
8
7
7
6
6
5
5
4
4
3
10%
20%
30%
40%
60%
90%
70 °C
85 °C
10
9
3
95%
Duty Cycle
(TON/T)
95%
99%
Duty Cycle
(TON/T)
2
10%
20%
30%
40%
60%
90%
95%
99%
Duty Cycle
(TON/T)
30 A / 12 V variant
I [A]
5
28
27
26
25
24
23
22
21
18
17
16
15
range.
70 °C
85 °C
10%
20%
30%
40%
60%
90%
95%
99%
Duty Cycle
(TON/T)
I [A]
26
25
24
23
22
21
18
17
16
15
14
13
12
11
10
9
70 °C
85 °C
10%
20%
30%
40%
60%
90%
95%
99%
Duty Cycle
(TON/T)
6
www.e-t-a.de
2047
ESR10-NC2A4HB-00-D2-10A 价格&库存
很抱歉,暂时无法提供与“ESR10-NC2A4HB-00-D2-10A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+216.29600
- 10+207.52720
- 100+196.88480
- 500+187.28070
- 1000+180.67080
- 国内价格
- 1+259.39440
- 200+103.50720
- 500+100.05120
- 1000+98.33400
- 国内价格 香港价格
- 1+252.635381+32.83062
- 10+225.0212810+29.24209
- 30+212.9067130+27.66777
- 50+207.4931850+26.96427
- 100+200.36238100+26.03761
- 250+191.30448250+24.86051
- 500+184.72159500+24.00505
