E-1048-8I3-C3D1V0-4U3-15A
    E-T-A
    插件,50x11.5mm
E-1048-8I3-C3D1V0-4U3-15A 数据手册
Smart Power Relay E-1048-8I... Description The Smart Power Relay E-1048-8I.- is a remotely controllable electronic load disconnecting relay with three functions in a single unit: l electronic relay l electronic overcurrent protection l status indication The 7 pin INLINE version is designed for use with various E-T-A terminal blocks, e. g. 17-P10-Si. A choice of current ratings is available from 1 A through 20 A. An operating voltage range of DC 9...32 V allows the connection of DC 12 V and DC 24 V loads. In order to switch and protect loads remotely, it has until now been necessary to connect several discreet components together: - an electro-mechanic relay, control cable and integral contact to close the load circuit - an additional protective element (circuit breaker or fuse) for cable or equipment protection - a device for current measurement (shunt) Now type E-1048-8I. combines all these functions in a single unit, thus minimising the number of connections in the circuit and thereby reducing the risk of failures. Applications Type E-1048-8I. is suited to all applications with DC 12 V or DC 24 V circuits, where magnetic valves, motors or lamp loads have to be switched, protected or monitored: - road vehicles (utility vehicles, buses, special vehicles) - rail vehicles - marine industry (ships, boats, yachts etc.) The Power Relay is also suitable for industrial use (process control, machine-building, engineering) as an electronic coupling relay between PLC and DC 12 V or DC 24 V load Features l l l l l l l l Integral power electronics provide a wear-resistant switching function, insensitive to shock and vibration. Only a fraction of the control power needed by electro-mechanical relays is required for switching loads. This is important for battery buffered load circuits which have to remain controlled even with the generator off line. The extremely low induced current consumption of less than 1 mA is absolutely necessary for battery buffered applications. The load circuit is disconnected in the event of an overload or short circuit, the trip curve is also suitable for smaller motor loads. The load circuit is permanently monitored for wire breakage. The device additionally provides the user with a load currentproportional analog voltage from 0 to 5 V to allow further processing of the actual value of the current flow in a power management system. This voltage signal can also be used for building up a control circuit or for disconnecting the unit at a low load current value by means of the external control. For switching and monitoring loads of 20 A plus it is possible to connect several units in parallel. Uniform power distribution between units must be ensured by symmetrical design of the supply cables (length and cross section). Coloured label, e. g. red = 10 A, see ordering information. 1812 E-1048-8I... INLINE version Technical Data (TU = 25 °C, US = DC 24 V) (TU = ambient temperature at UN) Power supply LINE + Type Voltage ratings UN Operating voltage US: DC power supply with small R i battery and generator etc. DC 12 V/DC 24 V DC 9...32 V Load circuit LOAD Load output Max. current rating IN Types of loads Current rating range IN Induced current consumption I0 of the unit (OFF condition) Typical voltage drop UON at rated current IN (at 25 °C) IN 1 2 3 5 A A A A Switching point 50 55 60 80 UON mV mV mV mV Power MOSFET, high side switching 20 A resistive, inductive, capacitive, lamp loads, motors (depending on duration of inrush current) 1 A...15 A (fixed ratings) up to 85 °C ambient without load reduction, 20 A up to 70 °C. Two basic versions with factory pre- set ratings: version 1: 1 A/2 A/3 A/5 A/7.5 A/10 A version 2: 15 A/20 A < 1 mA IN 7.5 A 10 A 15 A 20 A UON 90 mV 110 mV 60 mV 60 mV 5 typically 1.3 x IN (-40 °C...+85 °C: 1.1...1.5 x IN) Trip time (standard curve) typically 200 ms with switch-on onto overload and/or load increase on duty Current limitation version 1: typically 75 A version 2: typically 350 A Temperature disconnection power transistor > 150 °C After trip - resettable via external control signal (low-high) at control input IN+ - reset of supply voltage Parallel connection of channels for loads of 20 A plus, several units of identical current ratings may be connected in parallel. To ensure equal distribution of current between units, symmetrical design of the supply feed is necessary (length and cross section). Leakage current in OFF condition version 1: max. 100 µA version 2: max. 500 µA Free-wheeling diode for connected load integral version 1: max. 40 A version 2: max. 100 A www.e-t-a.de 1 Smart Power Relay E-1048-8I... Technical Data (TU = 25 °C, US = DC 24 V) (TU = ambient temperature at UN) Delay time ton/toff (resistive load) Temperature range ambient temperature typically 5 ms / typically 1.5 ms (EMC filter in control input) Wire breakage monitoring in wire breakage thresholds: ON and OFF in OFF-condition (version 1): condition of load Rload > typically 100 kΩ in OFF-condition (version 2): Rload > typically 10 kΩ in ON-condition: Iload < typically 0.2 x IN indication via group fault signalisation SF (switching output) Fault indication will not be stored, i.e. after remedy of wire breakage fault indication will disappear possible options: - wire breakage indication only in ON condition - wire breakage indication only in OFF condition - no wire breakage indication) Short circuit, overload - disconnection of load, indication via in load circuit group signal SF - no automatic re-start - after remedy of the fault unit has to be reset via control input IN+ Control input IN+ Control voltage IN+ 0...5 V = “OFF”, 8.5...32 V = “ON” Control current IE 1...10 mA (8.5...DC 32 V) Reset in the event of a failure - reset via external control signal (low - high) at control input IN+ - via reset of supply voltage Switching frequency at resistive or inductive load max. 100 Hz Status and diagnostic function 5 Control signal AS Group signal SF Analogue output U(I) transistor output minus switching (LSS), open collector, short circuit and overload proof, max. load: DC 32 V/2 A 0 V-level: when unit is set (at IN+ = 8.4...32 V) transistor output minus switching (LSS), open collector, short circuit and overload proof, load max. DC 32 V/2 A 0 V-level with overload and short circuit disconnection, wire breakage indication voltage output 0-5 V proportional to load current: 1 V = 0.2 x IN 5 V = 1.0 x IN 5 V... typically 6.5 V = overload range tolerance: (for Iload > 0.2 x IN) ± 8 % of IN max. output current 5 mA load resistance > 1 kΩ against GND Trip times response time when switching on a load: definition of t90 t90 = typically 20 ms reached 90% of final value response time of load change on duty: t90 = typically 1 ms Visual status indication Control signal AS Group fault signal SF Technical Data (TU = 25 °C, US = DC 24 V) (TU = ambient temperatureat UN) - standard: -40...+85 °C load reduction (70 °C at 20 A) - for other temperature ranges please see ordering key without Tests Humid heat Temperature change Vibration (random) Shock Corrosion Protection class EMC requirements combined test, 9 cycles with functional test test to DIN EN 60068-2-30, Z/AD min. temperature -40 °C, max. temperature +90 °C test to DIN IEC 60068-2-14, Nb in operation, with temperature change 6 g eff. (10 Hz...2,000 Hz) test to DIN EN 60068-2-64 25 g/11 ms, 10 shocks test to DIN EN 60068-2-27 test to DIN EN 60068-2-52, severity 3 housing IP30 to DIN 40050 higher protection class upon request EMC directive: emitted interference EN 61000-6-3 noise immunity EN 61000-6-2 Automotive directive: emitted interference, noise immunity: 72/245/EW6 und 95/54/E6 Terminals of INLINE version (7 pin, standard) 7 blade terminals 6.3 mm x 0.8 mm to DIN 46244-A6.3-0.8 contact material CuZn37F37 copper-plated and tin-plated Mounting: - E-T-A socket type 17-P10-Si (max. load 16 A) - on a pc board with 6.3 mm receptacles Housing INLINE version max. dimensions Materials Mass INLINE: 11.5 x 50 x 56 mm when plugged in 11.5 x 50 x 66 mm including terminals INLINE: PA66 approx. 23 g...33 g, depending on version Approvals CE, e1 logo according to EU, EMC and automotive directives LED yellow LED red General data Reverse polarity protection Control circuit Load circuit Status outputs 2 yes no (due to integral free-wheeling diode) interference voltage resistance max. DC 32 V www.e-t-a.de 1812 Smart Power Relay E-1048-8I... Dimensions INLINE version (all options = “DELUXE”) 1 4 6 3 LED red 7 5 LED yellow 50 1.97 This is a metric design and millimeter dimensions take precedence ( mm ) inch Connection diagram INLINE version (all options = “DELUXE”) LINE (+) DC 12 V/24 V AS yellow SF red control input Available configurations: IN+ part number (without options = “BASIC”) E-1048-8I 3 - C 0 A 0 V0 - 4 U3 - ... A group fault signal part number (various options) E-1048-8I 4 - C 0 A 0 V0 - 4 U3 - ... A E-1048-8I 4 - C 3 A 1 V0 - 4 U3 - ... A E-1048-8I 4 - C 3 D 1 V0 - 4 U3 - ... A E-1048-8I 4 - C 3 D 1 V1 - 4 U3 - ... A E-1048-8I 4 - C 3 D 3 V0 - 4 U3 - ... A E-1048-8I 4 - C 3 D 4 V0 - 4 U3 - ... A control signal 4 1…10 mA SF * AS * analogue output 0 … 5 V max. 6,5 V = U(I) * max. 2 A max. 2 A max. 5 mA 5 part number (all options = “DELUXE”) E-1048-8I 2 11.5 .453 Type E-1048-8I Smart Power Relay DC 12 V/24 V - 1 A...20 A in INLINE version Housing / temperature range 3 with housing / 70 °C (without moisture condensation) 4 with housing / -40 °C...+85 °C (70 °C at IN = 20 A) C with control input (+ control 8.5...32 V) LEDs 0 without LEDs 3 2 LEDs: AS yellow, SF red Status output minus-switching A without D with AS and SF Contents of group fault signal SF/ LED indication SF 0 without 1 short circuit / overload 3 short circuit / overload + wire breakage on 4 short circuit / overload + wire breakage off + wire breakage on Analogue output V0 without V1 0...5 V (only current rating to 10 A) Characteristic curve 4 200 ms (switch-off delay with overload) Voltage rating U3 DC 12/24 V Current ratings / colour of label 1 A / black 2 A / grey 3 A / purple 5 A / light-brown 7.5 A / brown 10 A / red 15 A / blue 20 A / yellow 66 2.60 56 2.21 Ordering Information LOAD (+) - C 3 D 4 V1 - 4 U3 - ... A GND * Optionally available: - signal outputs AS / SF - analogue output U(I) Preferred types Preferred types E-1048-8I4-C3D1V1-4U3E-1048-8I3-C3D1V0-4U3E-1048-8I4-C3A1V0-4U3- 1812 Standard current ratings (A) 1 2 3 5 x x x x 7.5 10 x x 15 20 x x x x x x x x x x x x x x x x Pin selection INLINE version www.e-t-a.de E-1048-8I. 17-P10-Si LINE + GND SF U(I) AS IN+ LOAD (2) (5) (7) (3) (6) (4) (1) (2) (5) (7) (3) (6) (4) (1) [2(k)] [12] [24] [2(i)] [23] [11] [1] 3 Smart Power Relay E-1048-8I... Typical time/current characteristics (TA = 25 °C) Version 1: 1 A, 2 A, 3 A, 5 A, 7.5 A and 10 A (standard 200 ms) 1000 Trip time in ms 100 10 1 current limitation n 0.1 0 2 1 typ. 1.3 x IN (typ. 75 A) I (A) ... times rated current IN Version 2: 15 A and 20 A (standard 200 ms) 1000 Trip time in ms 100 10 1 5 current limitation 0.1 0 1 2 typ. 1.3 x IN (typ. 350 A) I (A) ... times rated current IN 4 www.e-t-a.de 1812 E-1048-8I... - Accessories E-1048-8I... Accessories for E-1048-8I. 2-way mounting socket 6-way mounting socket 23-P10-Si 63-P10-Si (retaining clip Y 300 581 03 available on request) blade terminal DIN 46244 part 2 C profile (2xA2.8-0.8) (QC 2x.110) -P10 2(k) 11 12 24 23 2(i) symmetrical rail EN 50022-35x7.5 adapter X20040901 G-profile EN 50035-G32 64 2.52 ~70 ~2.76 8 .315 Installation drawing with mounting clips Y 300 504 02 2 .079 7.5 .295 1.9 .075 10 .394 0.5 .020 12.5 .492 17 .669 125 4.92 1 .039 2 .079 2 .079 female connector pressure-relief joint (1.1 mm (.043 in.) thick constriction) 154.8 6.09 5.4 .213 22.2 .874 cylinder head screw washer M4x4 ISO1207 A 4.3 DIN 125 nickel plated nickel plated Insulating sleeving for busbar (10-way) Y 303 824 01 9 .354 21 .827 100 quick-connect tabs 6.3 (.250) DIN 46247 tinned brass, insulated M4 Cu rail, tin-plated 12.8 .504 10 .394 7.4 retaining .291 clip Connector bus links -P10 X 210 588 01/ 1.5 mm2, (AWG 16), brown (up to 13 A max. load) X 210 588 02/ 2.5 mm2, (AWG 14), black (up to 20 A max. load) X 210 588 03/ 2.5 mm2, (AWG 14), red (up to 20 A max. load) X 210 588 04/ 2.5 mm2, (AWG 14), blue (up to 20 A max. load) 2 mounting clips Y 300 504 02 (2 pcs needed per unit) 7 .276 12.5 .492 polarized blade terminals DIN 46244-A6.3-0.8 (QC .250) Busbar (10-way) (supplied as a complete package) for type 17 socket (for max. 100 A continuous load), more positions available on request X 211 157 01 with terminal X 211 157 02 without terminal Phoenix terminal AKG 35 max. cross section 35 mm2 (AWG 2) 6.25 .246 45.8 1.80 5 .197 41.3 1.63 1 12.5 .492 80 3.15 polarization recess 7.4 .291 10 .394 1.4 .055 33.3 1.31 8.5 .335 24 2(i) 23 6.5 .256 25.8 1.02 2(k) 12 11 2 .079 6.8 .268 6 x 6.8 = 40.8 retaining clip 4.4 .173 1 12.5 .492 50 1.97 57.4 2.26 50 1.97 64 2.52 57.4 2.26 50 1.97 10 .394 2.8 .110 6.3 .248 depth 10 mm (.394 in.) 4.4 .173 12.5 .492 -P70 10 .394 slot for fitting labels from Phoenix, Weidmüller 25 .984 polarized recess max. 1.18 6 .236 3.5 .138 polarized blade terminal DIN 46244-A6.3-0.8 (QC .250) max. 30 75 2.95 6 x .268 = 1.61 Single mounting sockets (with adapter) (up to 16 A max. load) 17-P10-Si 17-P10-Si-20025 17-P70-Si 17-P70-Si-20025 (retaining clip Y 300 581 11 available on request) 60.4 2.38 50 1.97 7.3 .287 5 8.5 .335 M4 16.5 .650 20 .787 This is a metric design and millimeter dimensions take precedence ( mm ) inch All dimensions without tolerances are for reference only. In the interest of improved design, performance and cost effectiveness the right to make changes in these specifications without notice is reserved. Product markings may not be exactly as the ordering codes. Errors and omissions excepted. 1812 www.e-t-a.de 5 5 6 www.e-t-a.de 1812
E-1048-8I3-C3D1V0-4U3-15A 价格&库存
很抱歉,暂时无法提供与“E-1048-8I3-C3D1V0-4U3-15A”相匹配的价格&库存,您可以联系我们找货
