Device Networking Access
1-Port Serial Server
SE5001
RoHS-compliant
Cigarette pack compact size
Make Serial Devices Ready to the Network
Rugged metal case with wall or DIN-Rail mount
The Industrial Serial Server SE5001 is a cost effective gateway for
10/100Mbps Fast Ethernet full duplex auto negotiation
Ethernet (TCP/IP) and serial signal communications. It allows
Support TCP server/client, UDP, Virtual COM and
Tunneling modes
almost any serial device to be connected to a new or existing Ethernet
network.
Monitor, manage, and control industrial field devices
By encapsulating serial data and transporting it over Ethernet,
remotely
SE5001 offers full-duplex and bi-directional data that is transmission
Configuration: Web Server page / Serial Console / Telnet
transparent between the serial port and the Ethernet network.
Upgrade firmware from a remote-PC via Ethernet
Redundant dual DC power inputs for non-stop operation
Console / Windows Utility
Easy to Use
Flexible configuration options enable this unit to be setup over
Ethernet by Telnet, Web browser, Serial Console, or other Windows
utilities. Packed in a rugged metal housing for wall or DIN-Rail
mount with 5~30VDC wide power input range, SE5001 is ideal for
almost any industrial and manufacturing automation.
ATOP Virtual COM software provides existing Windows based
application to access serial device by mapping the Virtual COM
port to a remote serial server via Ethenet.
Specially Designed for Automation Fields
In industrial and manufacturing automation fields, SE5001 is used
as a field device to connect the Ethernet through TCP/IP protocol
directly. It is also specially designed for conjunction with PLCs,
HMIs, Barcode Scanners, Data Terminals, Electronic Kanbans,
Shop Floor Control Systems, and Pick-to-Light Systems.
Technologies
Ethernet Serial Server
SE5001
Specifications
Ethernet
TCP Server Mode
Compliance
IEEE802.3
Port
1-port
Transmission Rate
10/100Mbps Auto-detection
Connector
RJ-45
Auto MDI/MDI-X
Yes
Host Computer
Ethe
Link Mode
TCP Server
Single connection or Virtual Com mode
TCP Client
Single destination or Virtual COM mode
UDP
Up to 4 Ranges of IPs
rnet
SE5001
Serial Bus
PLC
Serial
RS-232(SE5001-S2)
Interface
RS-422/485 software selectable(SE5001-S5)
RS-232/422/485 Software selectable(SE5001)
Ports
1-port
Baud Rate
1200bps~230Kbps
Parity
None, Odd, Even, Mark, Space
Data Bits
7, 8
Stop Bits
1, 2
Flow Control
None, Software: Xon/Xoff, Hardware: RTS/CTS
Connector
9-pin D-Sub
Protection
15KV ESD
DC 5V and 9-30V
Consumption
Max. 1.5W
rnet
SE5001
SE5001
Card Reader
Serial Bus
Card Reader
Environment
Operating
0°C ~ 60°C ( 32º ~ 140ºF )
Storage
-40º ~ 85ºC ( -40º~ 185ºF ), 5 ~ 95%RH
Dimension
Host Computer
UDP mode
65mm x 78mm x 28mm
WxHxD
Host Computer
Ethe
Power
Input
TCP Client mode
Software
Configuration
Web Page / Telnet / Serial console / Windows utility
Virtual Com
Windows port redirection software
Support Protocol
ICMP, TCP(UDP) / IP, DHCP client, SNMP, HTTP, Telnet
Ethe
Ordering Information
1P1SE5001S2001G
SE5001-S2
SE5001
1-port RS-232(DB9) serial server without adapter
1P1SE5001S5001G SE5001-S5
1-port RS-422/485(D-Sub) serial server without adapter
1P1SE500100003G SE5001
1-port RS-232/422/485(D-Sub) serial server without adapter
Serial Bus
Display
Optional Accessories
Power Adapter
US315-12(US-TB3)
rnet
P/N:70100000000027G
3-pin Terminal block (5.08 mm) power adaptor,
100-240VAC input, 1.25A @ 12VDC output, US plug
USE315-12(EU-TB3)
P/N:70100000000028G
Tunneling mode
Ethe
100-240VAC input, 1.25A @ 12VDC output, EU plug
UN305-0510(US-DC)
P/N:50500051500001G
SE5001
DC jack (3.5/1.35/7.5 mm) power adaptor,
100-240VAC input, 1.0 A @ 5 VDC output, US plug
SE5001
UNE305-0510(EU-DC) P/N:50500051500011G
rnet
Serial Bus
PLC
100-240VAC input, 1.0 A @ 5 VDC output, EU plug
ADP-DB9(F)-TB5
P/N:59906231G
Touch Screen
Female DB9 to Female 3.81mm TB5 Converter
DK-25
P/N:30200000000022G
DIN Rail Kit
Atop Technologies, Inc.
TEL:+886-3-5508137
FAX:+886-3-5508131
sales@atop.com.tw
http://www.atop.com.tw
Design and specification are subjected to change without notice.
All product names referenced herein are registered trademarks of their respective companies.
CA_SE5001_E:v3-110707
很抱歉,暂时无法提供与“SE5001(DB)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1045.785751+135.94877
