B055-001-SER
B055-001-SER
    TRIPPLITE
    SERIAL SERVER INTERFACE MODULE
B055-001-SER 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector Serial Server Interface Unit (B064Series) Highlights ● Needed to connect to a DB9 male serial port on a server to a B064-Series NetDirector KVM switch via Cat5e/6 cable ● Easy to install; no software needed ● Allows a maximum distance of 492 ft. (150 m.) from KVM to serial port via Cat5e/6 cable ● Compact and lightweight design ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B055-001-SER System Requirements ● Server or CPU with a DB9 male serial connector ● A B064-Series NetDirector Cat5 KVM Switch ● Cat5e/6 cable Package Includes Description Tripp Lite's Serial Server Interface Unit connects the DB9 male serial port on a server to a B064-Series NetDirector KVM switch using Cat5e/6 cabling. Use of Cat5e/6 cables frees up space in server cabinets that would otherwise be filled by traditional, bulkier KVM cable kits. Includes a USB cable for powering the unit. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Note: SIU's that were purchased prior to that of your KVM switch may require a firmware upgrade in order for them to work properly (see Maintenance under OSD Operation section of your B064-Series KVM Owner's Manual for details) Features ● Eliminates the need for thicker, heavier KVM cable kits ● Compact, lightweight design ● Plug and Play; no software required ● Includes a USB cable to power the unit ● Supports VT100 serial emulation ● 492 ft. (150 m.) distance from KVM switch ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332151483 Accessory Type Server Interface Unit Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories 1/2 ● B055-001-SER SIU ● USB Cable to power the unit 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 1.70 x 5.10 x 4.90 Shipping Dimensions (hwd / cm) 4.32 x 12.95 x 12.45 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B055-001-SER 价格&库存
很抱歉,暂时无法提供与“B055-001-SER”相匹配的价格&库存,您可以联系我们找货
