B055-001-USB
B055-001-USB
    TRIPPLITE
    USB SERVER INTERFACE MODULE
B055-001-USB 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector USB Server Interface Unit (B064Series) Highlights ● Needed to connect a USB server to a B064-Series NetDirector KVM switch via Cat5e/6 cable ● Easy to install; no software needed ● Allows a maximum distance of 164 ft. (50 m.) from KVM to server via Cat5e/6 cable ● Compact and lightweight design ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: B055-001-USB System Requirements Description Tripp Lite's USB Server Interface Unit connects a USB server to a B064-Series NetDirector KVM switch using Cat5e/6 cabling. Use of Cat5e/6 cables frees up space in server cabinets that would otherwise be filled by traditional, bulkier KVM cable kits. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Note: SIU's that were purchased prior to that of your KVM switch may require a firmware upgrade in order for them to work properly (see Maintenance under OSD Operation section of your B064-Series KVM Owner's Manual for details) Features ● Eliminates the need for thicker, heavier KVM cable kits ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● 164 ft. (50 m.) distance from KVM switch ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Note: Support documentation for the B055-001-USB is under the B064 series, as this is an accessory for those models. Specifications OVERVIEW UPC Code 037332151476 Accessory Type Server Interface Unit Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories 1/2 ● Server or CPU with a HD15 connector and USB type A connector ● A B064-Series NetDirector Cat5 KVM Switch ● Cat5e/6 cable Package Includes ● 1 USB Server Interface Unit 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 1.80 x 4.90 x 4.90 Shipping Dimensions (hwd / cm) 4.57 x 12.45 x 12.45 Shipping Weight (lbs.) 0.30 Shipping Weight (kg) 0.14 STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B055-001-USB 价格&库存
很抱歉,暂时无法提供与“B055-001-USB”相匹配的价格&库存,您可以联系我们找货
