B055-001-USB-V2
B055-001-USB-V2
    TRIPPLITE
    USB SERVER INTERFACE MODULE
B055-001-USB-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector USB Server Interface Unit with Virtual Media Support (B064-Series) MODEL NUMBER: B055-001-USB-V2 Highlights ● Connect a USB server to a B064- IPG Series NetDirector KVM switch via Cat5e/6 cable ● Provides the connected server with access to Virtual Media ● Allows a maximum distance of 164 ft. (50 m.) from KVM to Server via Cat5e/6 cable ● Compact and lightweight design ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases System Requirements ● Server or CPU with a HD15 connector and USB type A connector ● A B064- IPG Series NetDirector Cat5 KVM Switch ● Cat5e/6 cable Package Includes Description Tripp Lite's USB Server Interface Unit with Virtual Media support connects a USB server to a B064- IPG Series NetDirector KVM switch using Cat5e/6 cabling. The server connected using this interface unit will be able to access the Virtual Media functionality of the B064- IPG series KVM switch. Use of Cat5e/6 cables frees up space in server cabinets that would otherwise be filled by traditional, bulkier KVM cable kits. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Note: SIU's that were purchased prior to that of your KVM switch may require a firmware upgrade in order for them to work properly (see Maintenance under OSD Operation section of your B064-Series KVM Owner's Manual for details) Features ● Provides the connected server with access to Virtual Media ● Eliminates the need for thicker, heavier KVM cable kits ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● 164 ft. (50 m.) distance from KVM switch ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Specifications OVERVIEW UPC Code 037332151742 Accessory Type Server Interface Unit Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories 1/2 ● USB Server Interface Unit with Virtual Media support 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 1.70 x 5.10 x 4.90 Shipping Dimensions (hwd / cm) 4.32 x 12.95 x 12.45 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 STANDARDS & COMPLIANCE Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B055-001-USB-V2 价格&库存
很抱歉,暂时无法提供与“B055-001-USB-V2”相匹配的价格&库存,您可以联系我们找货
