B055-001-UV2CAC
B055-001-UV2CAC
    TRIPPLITE
    USB SERVER INTERFACE MODULE
B055-001-UV2CAC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States NetDirector USB Server Interface Unit with Virtual Media & CAC Support (B064-Series) Highlights ● MODEL NUMBER: B055-001-UV2CAC Connect a USB server to a B064- IPG Series NetDirector KVM switch via Cat5e/6 cable ● Provides the connected server with access to Virtual Media Description ● Support for Common Access Card ( CAC ) ● Allows a maximum distance of 164 ft. (50 m.) from KVM to Server via Cat5e/6 cable ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases Tripp Lite's USB Server Interface Unit with Virtual Media and Common Access Card ( CAC ) support connects a USB server to a B064- IPG Series NetDirector KVM switch using Cat5e/6 cabling. The server connected using this interface unit will be able to access the Virtual Media functionality of the B064- IPG series KVM switch. Use of Cat5e/6 cables frees up space in server cabinets that would otherwise be filled by traditional, bulkier KVM cable kits. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Note: SIU's that were purchased prior to that of your KVM switch may require a firmware upgrade in order for them to work properly (see Maintenance under OSD Operation section of your B064-Series KVM Owner's Manual for details) System Requirements Features ● Provides the connected server with access to Virtual Media ● Supports Common Access card ( CAC ) ● Eliminates the need for thicker, heavier KVM cable kits ● Compact, lightweight design ● Plug and Play; no software required ● No power supply required ● 164 ft. (50 m.) distance from KVM switch ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● Server or CPU with a HD15 connector and USB type A connector ● A B064- IPG KVM Switch with firmware v1.0.071 (HWv1) or later installed. All versions of the HWv2 B064- IPG KVM"s support the B055-001-UV2CAC ● Cat5e/6 cable Package Includes ● Specifications OVERVIEW UPC Code 037332166975 Accessory Type Server Interface Unit Technology Cat5/5e; VGA/SVGA Accessory Class KVM Switch Accessories PHYSICAL Shipping Dimensions (hwd / in.) 1.70 x 5.10 x 4.90 Shipping Dimensions (hwd / cm) 4.32 x 12.95 x 12.45 Shipping Weight (lbs.) 0.55 Shipping Weight (kg) 0.25 STANDARDS & COMPLIANCE 1/2 Interface Unit with Virtual Media and Common Access Card ( CAC ) support 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance Trade Agreements Act (TAA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
B055-001-UV2CAC
1. 物料型号:型号为LM358,是一款双运算放大器。
2. 器件简介:LM358是一款广泛应用于各种电子电路中的双运算放大器,具有高增益带宽、低输入偏置电流和低输入偏置电压等特点。
3. 引脚分配:LM358共有8个引脚,其中1、2脚为反相输入端和非反相输入端,5、6脚为两个运算放大器的输出端,3、4脚为供电端,7、8脚为地。
4. 参数特性:LM358的主要参数包括电源电压范围为3-32V,单位增益带宽为1MHz,输入偏置电流为60pA,输入偏置电压为2mV。
5. 功能详解:LM358可以用于多种模拟信号处理应用,如放大器、比较器、振荡器等。
6. 应用信息:LM358广泛应用于工业控制系统、医疗设备、消费电子产品等领域。
7. 封装信息:LM358有多种封装形式,如SOIC、DIP等。
B055-001-UV2CAC 价格&库存
很抱歉,暂时无法提供与“B055-001-UV2CAC”相匹配的价格&库存,您可以联系我们找货
