SE5001-S2(DB)
SE5001-S2(DB)
    ATOPTECHNOLOGIES(上尚)
    SERIALDEVICESERVER1-PORT
SE5001-S2(DB) 数据手册
Device Networking Access 1-Port Serial Server ■ ■ SE5001 RoHS-compliant ■ Cigarette pack compact size Make Serial Devices Ready to the Network ■ Rugged metal case with wall or DIN-Rail mount The Industrial Serial Server SE5001 is a cost effective gateway for ■ 10/100Mbps Fast Ethernet full duplex auto negotiation Ethernet (TCP/IP) and serial signal communications. It allows ■ Support TCP server/client, UDP, Virtual COM and Tunneling modes almost any serial device to be connected to a new or existing Ethernet network. Monitor, manage, and control industrial field devices By encapsulating serial data and transporting it over Ethernet, remotely SE5001 offers full-duplex and bi-directional data that is transmission ■ Configuration: Web Server page / Serial Console / Telnet transparent between the serial port and the Ethernet network. ■ Upgrade firmware from a remote-PC via Ethernet ■ Redundant dual DC power inputs for non-stop operation ■ Console / Windows Utility Easy to Use Flexible configuration options enable this unit to be setup over Ethernet by Telnet, Web browser, Serial Console, or other Windows utilities. Packed in a rugged metal housing for wall or DIN-Rail mount with 5~30VDC wide power input range, SE5001 is ideal for almost any industrial and manufacturing automation. ATOP Virtual COM software provides existing Windows based application to access serial device by mapping the Virtual COM port to a remote serial server via Ethenet. Specially Designed for Automation Fields In industrial and manufacturing automation fields, SE5001 is used as a field device to connect the Ethernet through TCP/IP protocol directly. It is also specially designed for conjunction with PLCs, HMIs, Barcode Scanners, Data Terminals, Electronic Kanbans, Shop Floor Control Systems, and Pick-to-Light Systems. Technologies Ethernet Serial Server SE5001 Specifications Ethernet TCP Server Mode Compliance IEEE802.3 Port 1-port Transmission Rate 10/100Mbps Auto-detection Connector RJ-45 Auto MDI/MDI-X Yes Host Computer Ethe Link Mode TCP Server Single connection or Virtual Com mode TCP Client Single destination or Virtual COM mode UDP Up to 4 Ranges of IPs rnet SE5001 Serial Bus PLC Serial RS-232(SE5001-S2) Interface RS-422/485 software selectable(SE5001-S5) RS-232/422/485 Software selectable(SE5001) Ports 1-port Baud Rate 1200bps~230Kbps Parity None, Odd, Even, Mark, Space Data Bits 7, 8 Stop Bits 1, 2 Flow Control None, Software: Xon/Xoff, Hardware: RTS/CTS Connector 9-pin D-Sub Protection 15KV ESD DC 5V and 9-30V Consumption Max. 1.5W rnet SE5001 SE5001 Card Reader Serial Bus Card Reader Environment Operating 0°C ~ 60°C ( 32º ~ 140ºF ) Storage -40º ~ 85ºC ( -40º~ 185ºF ), 5 ~ 95%RH Dimension Host Computer UDP mode 65mm x 78mm x 28mm WxHxD Host Computer Ethe Power Input TCP Client mode Software Configuration Web Page / Telnet / Serial console / Windows utility Virtual Com Windows port redirection software Support Protocol ICMP, TCP(UDP) / IP, DHCP client, SNMP, HTTP, Telnet Ethe Ordering Information 1P1SE5001S2001G SE5001-S2 SE5001 1-port RS-232(DB9) serial server without adapter 1P1SE5001S5001G SE5001-S5 1-port RS-422/485(D-Sub) serial server without adapter 1P1SE500100003G SE5001 1-port RS-232/422/485(D-Sub) serial server without adapter Serial Bus Display Optional Accessories Power Adapter US315-12(US-TB3) rnet P/N:70100000000027G 3-pin Terminal block (5.08 mm) power adaptor, 100-240VAC input, 1.25A @ 12VDC output, US plug USE315-12(EU-TB3) P/N:70100000000028G Tunneling mode Ethe 3-pin Terminal block (5.08 mm) power adaptor, 100-240VAC input, 1.25A @ 12VDC output, EU plug UN305-0510(US-DC) P/N:50500051500001G SE5001 DC jack (3.5/1.35/7.5 mm) power adaptor, 100-240VAC input, 1.0 A @ 5 VDC output, US plug SE5001 UNE305-0510(EU-DC) P/N:50500051500011G DC jack (3.5/1.35/7.5 mm) power adaptor, rnet Serial Bus PLC 100-240VAC input, 1.0 A @ 5 VDC output, EU plug ADP-DB9(F)-TB5 P/N:59906231G Touch Screen Female DB9 to Female 3.81mm TB5 Converter DK-25 P/N:30200000000022G DIN Rail Kit Atop Technologies, Inc. TEL:+886-3-5508137 FAX:+886-3-5508131 sales@atop.com.tw http://www.atop.com.tw Design and specification are subjected to change without notice. All product names referenced herein are registered trademarks of their respective companies. CA_SE5001_E:v3-110707
SE5001-S2(DB) 价格&库存
很抱歉,暂时无法提供与“SE5001-S2(DB)”相匹配的价格&库存,您可以联系我们找货
