GW51C-MAXI-WDT
GW51C-MAXI-WDT
    ATOPTECHNOLOGIES(上尚)
    SERIALDEVICESERVER1-PORT
GW51C-MAXI-WDT 数据手册
Device Networking Access Ethernet Serial Server ■ ■ GW51C-MAXI RoHS compliant ■ 1-port DIN-Rail model (IP50 Standard) ■ Selectable RS-232/422/485 serial interface (15 KV ESD protection) ■ 10/100Mbps Fast Ethernet full duplex auto negotiation ■ Support with TCP Server/Client, UDP and Virtual COM mode ■ Configurable via serial console, Telnet, Web server, or Windows based utilities ■ Upgradeable firmware via network The Industrial Serial Server GW51C- MAXI is a gateway between Ethernet (TCP/IP) and RS-232/422/485 communications. It allows almost any serial device to be connected to a new or existing Ethernet network. By encapsulating serial data and transporting it over Ethernet, GW51C- MAXI offers full-duplex, bi-directional data transmission transparent between serial port and Ethernet network. In industrial and manufacturing automation fields, GW51C- MAXI is used as a field device to connect Ethernet through TCP/IP protocol directly. It is also specially designed for conjunction with PLCs, HMIs, Barcode Scanners, Data Terminals, Electronic Kanbans, Shop Floor Control Systems, and Pick-to-Light Systems. Terminal Server (main control program executed in this unit) makes most use of Ethernet connectivity to drive serial devices. It transforms whatever serial data received to TCP/UDP format then enables a host computer to drive the serial devices through the Ethernet. Atop Virtual COM software provides existing Windows based applications to access serial-Ethernet devices by mapping to remote serial server over Ethernet. Flexible configuration options enable this unit to be setup over Ethernet by Telnet, web browser, serial console, or other Windows utilities. Packed in a rugged metal housing with DIN Railmountable case and 9~30VDC wide power input range, GW51C-MAXI is ideal for almost any industrial and manufacturing automation. Technologies Industrial Serial Server GW51C-MAXI Specifications TCP Server Mode System CPU 16-bit x86 Embedded CPU Flash 512 KBytes RAM 512 KBytes SDRAM EEPROM 512 Bytes Watchdog Hardware built-in Computer Ethe Ethernet rnet GW51C-MAXI Compliance IEEE802.3 Port 1-port Transmission Rate 10/100Mbps Auto-detection Connector RJ-45 Auto MDI/MDI-X No RS-232/RS-485 PLC Link Mode TCP Server Up to 4 connections or Virtual Com mode TCP Client Single destination UDP Single destination TCP Client mode Serial Interface RS-232/422/485 switch selectable Ports 1-port Baud Rate 1200bps~230Kbps Parity None, Odd, Even, Mark, Space Data Bits 7, 8 Stop Bits 1, 2 Ethe None, Software: Xon/Xoff, Hardware: RTS/CTS Connector 5-pin 5.08mm terminal block / 8-pin Mini DIN Protection 15KV ESD GW51C-MAXI Card Reader Power DC 9 ~ 30V Consumption Max. 2.8W rnet GW51C-MAXI Flow Control Input Remote Control Host RS-232/RS-485 Card Reader Environment Operating 0ºC~60ºC Storage -40º ~ 85ºC ( -40º~ 185ºF ), 5 ~ 95%RH UDP mode Dimension WxHxD 45mm x 91mm x 80mm Software Ethe Configuration Web Page / Telnet / Serial console / Windows utility Virtual Com Windows port redirection software Support Protocol ICMP, TCP(UDP) / IP, DHCP client, SNMP, SMTP, HTTP, Telnet rnet GW51C-MAXI Ordering Information GW51C-MAXI-WDT RS-232/RS-485 1-port switch selectable RS-232/422/485 (Terminal Block) serial serverlity Display GW51C-MAXI Front Panel RUN DSR OFF RS-232 ON CONSOLE OFF RS-485 ON RS-422 SW2 SW1 RS-232/422/485 Mini-Din Pin Assignment Mode Switch Table TxD/R+ RTS/R- DCD DTR RxD/R+ CTS/T- OFF ON OFF LED Indicator Mode Switch Tunneling mode RS-232/422/485 Mini-Din Connector Ethe S.G OFF RS-232 ON CONSOLE OFF RS-485 ON RS-422 TxD/T+ S.G. RTS/RTxD/T+ LAN CTS/T- LAN DSR SW1 SW2 MODE S.G. RTS/R- LAN ON SW1 S.G SW1 SW2 MODE RUN SW2 RxD/R+ CTS/T- 91.00mm OFF DCD DTR ON LAN ON TxD/R+ RTS/R- OFF COM RxD/R+ 10/100Mbps Ethernet CTS/T- GW51C-MAXI RS-232/422/485 Terminal Block Connector GW51C-MAXI RxD/R+ F.G. F.G. VIN- VIN- VIN+ VIN+ rnet Power Supply Input Connector RS-232/RS-485 PLC Touch Screen 45.00mm Atop Technologies, Inc. TEL:+886-3-5508137 FAX:+886-3-5508131 sales@atop.com.tw http://www.atop.com.tw Design and specification are subject to change without notice. All product names referenced herein are registered trademarks of their respective companies. CA_GW51C-MAXI_E:v2-040730
GW51C-MAXI-WDT 价格&库存
很抱歉,暂时无法提供与“GW51C-MAXI-WDT”相匹配的价格&库存,您可以联系我们找货
