NG5
NG5
    TRIPPLITE
    ETHERNETSWITCHUN-MGD5-PORT
NG5 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 5-Port 10/100/1000 Mbps Desktop Gigabit Ethernet Unmanaged Switch, Metal Housing MODEL NUMBER: NG5 Highlights ● 5 auto-negotiable 10/100/1000 Mbps RJ45 ports ● Supports auto MDI/MDIX crossover function ● Consumes very little input power—just 1W ● 2 Gbps switching capacity per port with full duplex ● Plug and play with no configuration required Package Includes Energy-efficient unmanaged switch sets up in seconds with no configuration required. Provides a Gigabit network connection for multiple devices. Ideal for home or small offices, workgroups and creative production environments. Description The NG5 5-Port 10/100/1000 Mbps Desktop Gigabit Ethernet Unmanaged Switch adds 10/100/1000 Mbps Ethernet capacity to your home office, small office, workgroup or creative production environment. Share large bandwidth-intensive files, such as CAD drawings and videos, at Gigabit speeds, improving efficiency and cutting costly downtime. This desktop switch features five twisted-pair RJ45 Gigabit Ethernet ports that support auto-negotiable 10/100/1000 Mbps and auto MDI/MDIX cross-over detection functions for convenient plug-and-play capability. No configuration is required, so you can have your Gigabit network up and running immediately. Easy-to-read LEDs indicate connection and activity status for each port. IEEE 802.3x flow control allows smooth transmission of large files. The NG5 supports IEEE 802.3az Energy Efficient Ethernet standards by putting unused ports into a lowpower state without interrupting network connections. It consumes very little input power—just a single watt. The detachable five-foot input cord with NEMA 1-15P plug connects to a protected UPS, generator or mains input AC source. The heavy-duty metal housing includes keyhole tabs for optional wall-mounting. Features Unmanaged Network Switch for Home/Small Offices or Workgroups5 twisted-pair RJ45 Gigabit Ethernet portsAuto-negotiable 10/100/1000 MbpsAutomatic MDI/MDIX cross-over detection10 Gbps switching capacity (2 Gbps per port with full duplex)Easy-to-read LEDs indicate connection and activity status for each portSupports 9k jumbo framesSupports MAC address auto-learning and autoagingSupports 802.3x flow control (full duplex) and back pressure (half duplex) Compliant with IEEE 802.3az Energy Efficient Ethernet StandardsAutomatically shifts unused ports to low-power state without interrupting network connectionConsumes very little input power—just 1WAlso meets IEEE 802.3ab, 802.3i, 802.3u and 802.3 standards Heavy-Duty Metal HousingFanless design for silent operationDetachable 5 ft. AC power cord with NEMA 1-15P plugPlug-and-play—no configuration necessaryKeyhole tabs for optional wall-mounting Works with the Most Popular Web Browsers The NG5 is browser-based and works independently from the connected computer's operating system. Because switch compatibility is based on common hardware standards, rather than system software dependencies, the NG5 accommodates most platforms. Preferred web browsers include Google Chrome 1/4 ● NG5 5-Port 10/100/1000 Mbps Desktop Gigabit Ethernet Unmanaged Switch ● External power supply w/NEMA 1-15P plug and 5 ft. cord ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States (on both Windows and macOS) and Microsoft Edge (Windows only). Specifications OVERVIEW UPC Code 037332194770 Product Type Unmanaged Switch INPUT Electrical Consumption (Max) 1W Nominal Input Voltage Description Included 5V DC output power adapter accepts 100-240V AC nominal input Plug Type Power adapter includes NEMA 1-15P non-polarized input plug Voltage Compatibility (VAC) 100-240 Input Plug Type NEMA 1-15P Input Cord Length (ft.) 5 Input Cord Length (m) 1.52 POWER Power Consumption (Watts) 1 USER INTERFACE, ALERTS & CONTROLS LED Indicators Power LED (Green for Power On); One LED per RJ45 port (Green indicates 10/100Mbps link; Amber indicates 1000Mbps link; LEDs flash to indicate port activity) PHYSICAL Primary Form Factor Desktop Color Black Form Factors Supported Desktop, Wall mount Shipping Dimensions (hwd / in.) 4.80 x 3.80 x 6.40 Shipping Dimensions (hwd / cm) 12.19 x 9.65 x 16.26 Shipping Weight (lbs.) 0.90 Shipping Weight (kg) 0.41 Unit Dimensions (hwd / in.) 1.100 x 3.070 x 5.510 Unit Dimensions (hwd / cm) 2.8 x 14.0 x 7.8 Unit Weight (lbs.) 0.56 Unit Weight (kg) 0.25 Rack Units 0 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States ENVIRONMENTAL Storage Temperature Range 14 to 158F (-10 to 70C) Relative Humidity 10 to 90% (non-condensing) Operating Temperature 32 to 104F (0 to 40C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Network Compatibility Details Auto-negotiable Switching Capacity 10 Gbps Switching Capacity Details 2 Gbps per port with full duplex CONNECTIONS Number of Ports 5 RJ45 Ports 5 RJ45 Ports Detail 5x 10/100/1000BASE-T SFP Uplink Ports 0 PoE Supported Ports 0 Network Switch Ports (5) 10/100/1000 (RJ45) FEATURES & SPECIFICATIONS Fans (Type/Quantity) Fanless Jumbo Frames 9000 Console Port No MAC Auto Learning Yes RMON No SNMP No Storm Control No DHCP Snooping No Auto MDI/MDIX Crossover Detection Yes STANDARDS & COMPLIANCE Product Certifications EN 55022; EN 55024; EN 60950-1; IEC 60950-1; NOM (Mexico) Product Compliance RoHS; IEEE 802.3 Auto-Negotiation; IEEE 802.3ab 1000Base-T; IEEE 802.3az (Energy Efficient Ethernet); IEEE 802.3i 10Base-T; IEEE 802.3u 100Base-TX/FX; IEEE 802.3x Flow Control; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 5-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
很抱歉,暂时无法提供与“NG5”相匹配的价格&库存,您可以联系我们找货
